WRL-15007
WRL-15007
    SPARKFUNELECTRONICS
    PIXHAWK RADIO TELEMETRY KIT
WRL-15007 数据手册
  Pixhawk Radio Telemetry Kit WRL-15007 The Radio Telemetry Kit for Pixhawk is a small, lightweight, and inexpensive open source radio platform that can allow for ranges of better than 300m out of the box with the ability to be extended to several kilometers with the use of a patch antenna on the ground. The radio uses open source firmware which has been specially designed to work well with MAVLink packets and to be integrated with the Mission Planner, Copter, Rover, and Plane. This telemetry kit includes two radio modules, USB cable, Android adapter cable, two JST-GH cables, two right-angled RP-SMA connectors, and two 915MHz antennas. Each radio module in the kit features a transmit power of 100mW, a RX sensitivity of -117dB, a full duplex transparent serial link of 57600baud and are equipped with a micro USB and UART port for easy connectivity.     In order to use the Radio Telemetry Kit, you’ll need to plug one module into the Telem1 port on your Pixhawk4 using one of the provided JST-GH cables, and plug the other module into the USB port on your base station. If you follow the prompts you will be able to have both radio modules connected in less than five minutes. In the Documents tab above you will find a full getting started guide to help you set up your Pixhawk with this kit in no time! INCLUDES       2x Radio Modules with Antennas 1x Micro USB Cable 1x Android OTG Adapter Cable 1x GH 6P-GH 4P Cable 1x MLX 6P-GH 4P Cable 2x Right-Angled RP-SMA Connectors FEATURES               100 mW maximum output power (adjustable) -117 dBm receive sensitivity Open-source SIK firmware RP-SMA connector 2-way full-duplex communication through adaptive TDM UART interface Transparent serial link MAVLink protocol framing FT230X is a USB to BASIC UART IC Interchangeable air and ground modules 915 or 433 mHz Micro-USB port 4-position JST-GH connector Supply voltage: 5V DC (from USB or JST-GH) Transmit current: 100 mA at 20dBm Receive current: 25 mA Serial interface: 3.3 V UART https://www.sparkfun.com/products/15007 11-12-18
WRL-15007 价格&库存
很抱歉,暂时无法提供与“WRL-15007”相匹配的价格&库存,您可以联系我们找货
