HVCB1206BDE500M
Stackpole Electronics, Inc.
High Voltage Thick Film Chip Resistor
Resistive Product Solutions
Features:
Utilizes fine film resistor deposition technology
Superior pulse handling capabilities
Very low noise
Ultra-high stability
RoHS compliant and halogen free
REACH compliant
Electrical Specifications
Type/Code
Power Rating (W)
@ 70ºC
Maximum Working
Voltage (V)
TCR
(ppm/ºC)
HVCB1206
0.33
1500
±25
Ohmic Range (Ω) and Tolerance
0.1%
500M
Proper terminal isolation is required to achieve the voltage ratings for each given size.
Mechanical Specifications
L
Body Length
0.126 ± 0.01
3.20 ± 0.25
Type/Code
HVCB1206
W
Body Width
0.063 ± 0.005
1.60 ± 0.13
H
Body Height (Max.)
0.030
0.76
a
Top Termination
0.010 ± 0.005
0.25 ± 0.13
b
Bottom Termination
0.020 ± 0.010
0.51 ± 0.25
Unit
inches
mm
Performance Characteristics
Test
Typical Performance
Short Time Overload
Load Life
Temperature Cycle
Moisture Resistance
Shock
Vibration
Dielectric Withstanding Voltage
Resistance to Soldering Heat
Parameter
0.1%
0.1%
0.1%
0.1%
0.05%
0.05%
0.05%
0.05%
Typical
TCR
measured from 25°C to 75°C
10X rated wattage
Consult Stackpole for custom pulse applications
Measured at 100V
Consult Stackpole for custom test voltages
Pulse Capability
Resistance Value
Operating temperature range is -55ºC to +150ºC
Rev Date: 5/15/2023
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
HVCB1206BDE500M
Power Derating Curve:
Recommended Pad Layouts
Type/Code
HVCB1206
A
0.087
2.20
B
0.165
4.20
C
0.063
1.60
Unit
inches
mm
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Rev Date: 5/15/2023
2
www.seielect.com
HVCB1206BDE500M
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
HVCB
Surface Mount Chip Resistor
SMD
Standard Series RoHS
Compliant
Lead-Free
Termination
Composition
YES
RoHS compliant by
100% Matte Sn ("T")
means of exemption 7c-I
Lead-Free
Lead-Free
Effective Date
Mfg. Effective Date
Code
(Std Product Series)
(YY/WW)
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Rev Date: 5/15/2023
3
www.seielect.com
HVCB1206BDE500M
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
H
V
C
Product Series
Description
Solderable wraparound
HVCB
(100% matte tin)
Code
B
1
Size
Code
W
1206 0.33
2
Tolerance
Code Tol
B
0.1%
Rev Date: 5/15/2023
B
D
E
5
Packaging
TCR
Code
Description
Size Quantity Code ppm
D 7" Reel - Paper Tape 1206 500
E
25
4
M
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
500 Mohm = 500M
www.seielect.com
很抱歉,暂时无法提供与“HVCB1206BDE500M”相匹配的价格&库存,您可以联系我们找货
