110049634
110049634
    STEINEL
    GF 232 GENERAL PURPOSE GLUE STIC
110049634 数据手册
GENERAL DESCRIPTION GF 260 High Strength is a high performance, general-purpose adhesive with a long open time. Once set it forms a tough, but flexible bond. This very versatile adhesive works particularly well when bonding glass to light gauge metals and metals to ABS plastics. Also suitable for bonding many plastics, ceramics, aluminum, fiberglass, some hardwoods, paper and board. GF 213 Laminate is an economical general-purpose adhesive suitable for use on wood, ceramics, and some plastics, such as rigid PVC and polystyrene. It is medium in viscosity and can be used for porous surfaces, such as foams and fabrics. GF 23 Wood is an assembly grade product with excellent bonding properties and a high level of adhesive strength, suitable for many assembly applications where both high and low temperature conditions prevail. It is good on most materials, such as wood, paper, fabric, many plastics, and light gauge metals. GF 14 Carton is a high output packaging adhesive, suitable for use on most paper and board substrates. The low viscosity of this product helps prevent stringing, improves glue gun output, and ensures bonds are made with the minimum gap between surfaces. It is a versatile packaging adhesive; the low viscosity enables it to be used for small delicate assemblies as well as very high output applications that require fast adhesive dispensing. GF 232 General is an economical clear general-purpose adhesive with good adhesion to many surfaces. It has a high viscosity, which makes it suitable for porous substrates, such as fabrics and foams. It has excellent gap filling and low sag properties. TECHNICAL CHARACTERISTICS Model Part# in 1 lb. pk (15 sticks) Part# in 11 lb. pk (165 sticks) Adhesive type: Color: ½” sticks Molten tack: 260 Hi Strength 110049646 110049647 Very pale amber 213 Laminate 23 Wood 14 Carton 110049640 110049637 110049643 110049641 110049638 110049644 Synthetic polymer based hotmelt Very pale amber Very pale amber Light brown 232 General 110049634 110049635 Clear/ transparent Medium Medium High High Medium ½” 12” ½” 12” ½” 12” ½” 12” ½” 12” 11 lbs 11 lbs 11 lbs 11 lbs 11 lbs Sticks per lb. (approx.) 16 16 16 16 16 Suggested Application Temperature: 380ºF 380ºF 380ºF 380ºF 380ºF 7000 cps 6000 cps 5000 cps 2000 cps 9500 cps 194ºF 158ºF Medium 10ºF 194ºF 167ºF Long 10ºF 190ºF 167ºF Long -4ºF 235ºF 185ºF Short -14ºF 189ºF 167ºF Medium -22ºF Diameter (Nominal) Length (Nominal) Carton Quantity Brookfield viscosity (ASTM D3236) @ 350ºF spindle 27 Ring & Ball Softening Point (ASTM E28) Heat Resistance (BS5350 Part H3) Open Time Low temperature flexibility (tg) STEINEL S9051 Lyndale Avenue South Bloomington, MN 55420 www.steinel.net (800) 852-4343 sales@steinel.net
110049634 价格&库存
很抱歉,暂时无法提供与“110049634”相匹配的价格&库存,您可以联系我们找货
  • 1+163.393461+21.17891
  • 5+151.395575+19.62375
  • 10+146.5200910+18.99180
  • 30+139.1184130+18.03240
库存:19
