GENERAL DESCRIPTION
GF 260 High Strength is a high performance, general-purpose adhesive with a long open time. Once set it forms a tough, but flexible
bond. This very versatile adhesive works particularly well when bonding glass to light gauge metals and metals to ABS plastics. Also
suitable for bonding many plastics, ceramics, aluminum, fiberglass, some hardwoods, paper and board.
GF 213 Laminate is an economical general-purpose adhesive suitable for use on wood, ceramics, and some plastics, such as rigid PVC
and polystyrene. It is medium in viscosity and can be used for porous surfaces, such as foams and fabrics.
GF 23 Wood is an assembly grade product with excellent bonding properties and a high level of adhesive strength, suitable for many
assembly applications where both high and low temperature conditions prevail. It is good on most materials, such as wood, paper, fabric,
many plastics, and light gauge metals.
GF 14 Carton is a high output packaging adhesive, suitable for use on most paper and board substrates. The low viscosity of this product
helps prevent stringing, improves glue gun output, and ensures bonds are made with the minimum gap between surfaces. It is a versatile
packaging adhesive; the low viscosity enables it to be used for small delicate assemblies as well as very high output applications that
require fast adhesive dispensing.
GF 232 General is an economical clear general-purpose adhesive with good adhesion to many surfaces. It has a high viscosity, which
makes it suitable for porous substrates, such as fabrics and foams. It has excellent gap filling and low sag properties.
TECHNICAL CHARACTERISTICS
Model
Part# in 1 lb. pk (15 sticks)
Part# in 11 lb. pk (165 sticks)
Adhesive type:
Color:
½” sticks
Molten tack:
260 Hi Strength
110049646
110049647
Very pale amber
213 Laminate
23 Wood
14 Carton
110049640
110049637
110049643
110049641
110049638
110049644
Synthetic polymer based hotmelt
Very pale amber
Very pale amber
Light brown
232 General
110049634
110049635
Clear/
transparent
Medium
Medium
High
High
Medium
½”
12”
½”
12”
½”
12”
½”
12”
½”
12”
11 lbs
11 lbs
11 lbs
11 lbs
11 lbs
Sticks per lb. (approx.)
16
16
16
16
16
Suggested Application
Temperature:
380ºF
380ºF
380ºF
380ºF
380ºF
7000 cps
6000 cps
5000 cps
2000 cps
9500 cps
194ºF
158ºF
Medium
10ºF
194ºF
167ºF
Long
10ºF
190ºF
167ºF
Long
-4ºF
235ºF
185ºF
Short
-14ºF
189ºF
167ºF
Medium
-22ºF
Diameter (Nominal)
Length (Nominal)
Carton Quantity
Brookfield viscosity (ASTM
D3236)
@ 350ºF spindle 27
Ring & Ball Softening Point (ASTM E28)
Heat Resistance (BS5350 Part H3)
Open Time
Low temperature flexibility (tg)
STEINEL
S9051 Lyndale Avenue South
Bloomington, MN 55420
www.steinel.net
(800) 852-4343
sales@steinel.net
很抱歉,暂时无法提供与“110049644”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1465.544951+189.60736
- 5+1358.436685+175.75005
- 10+1314.7819910+170.10215
- 25+1259.2539425+162.91811
