35T0231-30P
35T0231-30P
    LAIRD(莱尔德)
    聚对二甲苯 铁氧体磁芯磁环 型 长度 宽 0.231"(5.87mm) 直径 0.101"(2.56mm) 高
35T0231-30P 数据手册
CORE DIMENSIONS OD ID A UNCOATED CORE MM INCHES OD 5.84 (.230) ID 3.05 (.120) TH 2.54 (.100) A ± ± ± PARYLENE TH 35T0231-300 INCHES (.006) (.005) (.005) MM .15 .13 .13 35T0231-30P OD 5.87 (.231) ± .15 (.006) ID 3.02 (.119) ± .13 (.005) TH 2.57 (.101) ± .13 (.005) FREQ. (kHz) VOLT. (V) TURNS 5000 INITIAL PERMEABILITY WEIGHT / K 0.53 LBS ELECTRICAL SPECIFICATION MIN NOM MAX MIN TOL. L Q 1.322 10 (-20%) 1.652 - MAX TOL. 1.983 (+20%) - 100 100 1 1 COATING SPECIFICATIONS TYPE coating thickness (mils.) Min. DLB VAC TEST FORCE (LB) 35T0231-300 UNCOATED - - - 35T0231-30P PARYLENE 0.5 1000 0.30 NOTES: Rev Description Date INT A Original Draft 4/18/1995 JBE B TRANSFER TO LOTUS NOTES 11/19/1997 IS C REMOVE Q SPECS REACTIVATE PRINT 10/6/1995 JRK 4/25/2006 WMM CHANGE PART NUMBER D REVISED TEMPLATE Date: 4/25/06 DWG # 35T0231-30P-D Drawn By: WMM Title # 35T0231-30P Steward This document contains information which is proprietary to Steward. No production or publication of this document in whole or in part shall be made without written authorization from Steward. UNCONTROLLED DOCUMENT Rev: D
35T0231-30P 价格&库存
很抱歉,暂时无法提供与“35T0231-30P”相匹配的价格&库存,您可以联系我们找货
