35T0301-00P
35T0301-00P
    LAIRD(莱尔德)
    铁氧体磁芯 内径 外径 长度
35T0301-00P 数据手册
Steward CORE DIMENSIONS UNCOATED CORE OD ID A A 35T0301-000 MM OD 7.62 ID 3.18 TH 4.78 SINGLE PARYLENE COATING INCHES (.300) (.125) (.188) OD ID TH (.301) (.124) (.189) TH ± ± ± MM .15 .13 .13 INCHES (.006) (.005) (.005) 35T0301-00P 7.65 3.15 4.80 WEIGHT / K INITIAL PERMEABILITY ± ± ± .15 .13 .13 (.006) (.005) (.005) 1.93 LBS 5000 ELECTRICAL SPECIFICATION MIN NOM MAX MIN TOL. L Q 3.344 10 (-20%) TYPE PARYLENE MAX TOL. 4.181 5.017 (+20%) - FREQ. (kHz) VOLT. (V) TURNS 100 100 COATING SPECIFICATIONS Max. Coating Min. DLB (mm / mils.) VAC 0.5 1000 1 1 TEST FORCE (LB) 0.58 NOTES: Rev Description A Original Draft 6/14/1995 JBE 6/14/1995 JBE B REVISED PRINT C UPDATED TO NEW FORMAT D TRANSFER TO LOTUS NOTES E REM Q SPECS CHANGE P/N REACTIVATE PRINT F Revised Template Date: 6/1/2006 DWG # 35T0301-00P-F Drawn By: WMM Title # 35T0301-00P Steward This document contains information which is proprietary to Steward. No production or publication of this document in whole or in part shall be made without written authorization from Steward. UNCONTROLLED DOCUMENT Date INT 6/14/1995 JBE 11/19/1997 IS 10/6/2005 JRK 6/1/2006 WMM Rev: F
35T0301-00P 价格&库存
很抱歉,暂时无法提供与“35T0301-00P”相匹配的价格&库存,您可以联系我们找货
