STL-N-660
STL-N-660
    REALTEK(瑞昱)
    4-PORT PCIE 2.5GB REALTEK ETHERN
STL-N-660 数据手册
PRODUCT DATA SHEET STL N-660 PCIe 4-Port 2.5G Realtek RTL8125 Ethernet Network Adapter • • • • • Add Four RJ-45 Ethernet ports to any PC Features 4 x Realtek RTL8125B Network Controller chipset (Latest, 2nd Generation 2.5G Ethernet Chipset from Realtek) Multi-Gigabit Ethernet connectivity supporting network speeds of 2.5G, 1G, 100Mbps and 10 Mbps Compatible with 2.5BASE-T, Supports 2.5Gbps network speeds on CAT5e and CAT6a cabling 4 Ethernet ports for redundancy, separation and connecting to NAS, RAID or additional servers Break the 1 Gigabit logjam that's bogging down your network. Today it's fast, easy, and inexpensive to upgrade your network with New 2.5Gb network adapters for your desktop, server, and laptop. The N-660 utilizes the new Ethernet standard (IEEE 802.3bz) based on the same technology as 10Gb Ethernet with a transfer rate to 2.5Gbits/sec. This data rate is 2.5 times faster than 1Gb networks allowing you to move files faster yet runs on the same Cat5e cable. Increase your network speed and efficiency while avoiding the high cost of upgrading to a 10Gb network. Four independent Multi-Gigabit RJ45 ports allow connectivity to multiple networks for high-bandwidth workstations and servers. Having more than one Ethernet Port / Multiple NICS can enable teaming, increasing Network Bandwidth through a supported switch. Enable your PC to act like a Router or a Firewall, having more than one Ethernet port allows you to have peer connections to other devices. Don't be IO-Bound, each port can be on a separate network. You can even run a home media server to multiple devices across the house. Features • • • • • • • PCIe x2 form factor compatible with x4, x8 and x16 PCI Express slots 4- RJ45 Ethernet ports Supports 10/100/1000/2500 Mbps Ethernet Supports Preboot eXecution Environment (PXE) LED indicators indicate status of link/ activity and speed Supports Jumbo Frames up to 9K Supports WOL Systems Requirements Windows 10 RS5 or later (64 bits Only) Linux kernel 5.8 or later Available 1-lane PCIe 2.0 slot Package Contents 1 x PCIe 2.5G 4-Speed Multi-Gigabit Network Adapter 1 x User Manual STL - 16220 Manning Way, Suite 101, Cerritos, CA. 90703 - support@stlio.com - www.stlio.com
STL-N-660 价格&库存
很抱歉,暂时无法提供与“STL-N-660”相匹配的价格&库存,您可以联系我们找货
