8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO.
NO
DESCRIPTION
DATE
BY
A
474
ORIGINAL RELEASE
10-20-05
MNH
B
841
REVERSE BENDS
11/28/2005
HT
C
1694
ADDING TOLERANCE
5/16/2008
IA
D
1902
UPDATE PCB LAYOUT, REMOVE
BOM
1/22/2009
JH
F
F
E
E
.450 11.43
D
D
.100 2.54
A .010 [.25]
.025 0.64
.318 8.08
.100 2.54
C
C
.160 4.06
.300±.025 7.62±0.64
.100 2.54
.100 2.54
B
A
B
NOTES:
1. INSULATOR MATERIAL: PA9T.
2. CONTACT MATERIAL: PHOSPHOR BRONZE
3. PLATING: SEE TABLE
4. OPERATING TEMPERATURE: -65°C TO +125°C
5. PROCESSING TEMPERATURE: 260°C MAX FOR 120 SECS MAX.
6. UL FLAMMABILITY: 94V-0
7. VOLTAGE RATING: 600 VDC MINIMUM AT SEA LEVEL.
8. CURRENT RATING: 3 AMP
9. INSULATION RESISTANCE: 5000 MEGA OHMS.
10. MODIFICATION: SURFACE MOUNT.
CUSTOMER COPY
UNLESS OTHERWISE SPECIFIED:
Pb
7
6
DIMENSIONS ARE IN INCHES[MM]
TOLERANCES:
ANGULAR: 30'
.XX= .02 [.508]
.XXX= .005 [.1270]
.XXXX= .0005 [.0127]
SURFACE FINISH: 63 Ra
5
4
Aria
A
HEADER, .100 CC
G_C_ _SFBN-M30
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
NAME
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
8
DATE
DRAWN
REV
C10584
SCALE: 4:1
2
D
SHEET 1 OF 1
1
FILE NAME: Z:\ECO PENDING\1902\C10584, G_C_ _SFBN-M30 HEADERS PRINT: 2/9/2009
很抱歉,暂时无法提供与“GTC06SFBN-M30”相匹配的价格&库存,您可以联系我们找货
