SFM210-LPSE-S45-SD-BK
    SULLINS
    CONN HDR 45POS 0.039 GOLD SMD
SFM210-LPSE-S45-SD-BK 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 1910 INITIAL RELEASE 2/5/2009 JH F F E E PIN 1 (C MOUNTING) A 2.00 .079 B 2.00 .079 PIN 1 0.30 .012 1.00 .039 1.40 .055 3.60 .142 1.50 .059 0.60 .024 D (NOT REQ'D FOR USE AS TOP ENTRY) SFM210-LP_E-S_ _-SC-BK (STANDARD) (NOT REQ'D FOR USE AS TOP ENTRY) 2.00 .079 D A 0.60 .024 B 0.30 .012 0.60 .024 RECOMMENDED PCB LAYOUT SFM210-LP_E-S_ _-SC-BK 1.00 .039 2.00 .079 3.60 .142 1.50 .059 C C 1.40 .055 PIN 1 SFM210-LP_E-S_ _-SD-BK (OPPOSITE BEND, APPLICABLE ON EVEN PIN COUNTS) PIN 1 (D MOUNTING) 0.60 .024 RECOMMENDED PCB LAYOUT SFM210-LP_E-S_ _-SD-BK 0.70 .028 2.10 .083 B A 2.20 .087 0.10 [.004] B 1.00 .039 NOTES: A 1. INSULATOR MATERIAL: L.C.P, UL 94V-0, BLACK COLOR. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 1 AMP. 02-20, 0.20mm MAX. 5. INSULATOR RESISTANCE: 1000 MEGA OHMS MIN. 21-50, 0.30mm MAX. 6. CONTACT RESISTANCE: 20 MILLI OHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 300V. 8. OPERATING TEMPERATURE: -40° C TO +125° C. 9. PROCESSING TEMP.: 260° C FOR 10 SECS MAX. (INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.) 10. FOR TOP/BOTTOM ENTRY. 11. CONSULT FACTORY FOR THE MATE IF BEING USED AS BOTTOM ENTRY. 8 7 6 5 0.10 .004 2.90 .114 UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: 5 .X= .30 [.012] .XX= .20 [.008] .XXX= .10 [.004] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 4 DRAWN NAME 2/05/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. HEADER, FEMALE 1mm CC, 1 ROW, SMT SFM210-LP_E-S_ _-S_-BK SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 11198 SCALE: 16:1 2 A SHEET 1 OF 1 1 FILE NAME: C:\Documents and Settings\jhsieh\Desktop\JH PDM WIP\11198, SFM210-LP_E-S_ _-S_-BK PRINT: 3/6/2009 A
SFM210-LPSE-S45-SD-BK 价格&库存
很抱歉,暂时无法提供与“SFM210-LPSE-S45-SD-BK”相匹配的价格&库存,您可以联系我们找货
