K 1/16 CLEAR 4FT
K 1/16 CLEAR 4FT
    SUMITOMO(住友)
    热收缩 套管,半刚性 0.063"(1.60mm) 2 至 1 透明 4.00'(1.22m)
K 1/16 CLEAR 4FT 数据手册
SUMITUBE® K AMS-DTL-23053/8 UL & CSA SEMI-RIGID POLYVINYLIDENE FLUORIDE 2 : 1 Shrink Ratio MILITARY SPECIFICATION & UL / CSA RoHS/RoHS2 Compliant TYPICAL Lead-Free FEATURES 1) SUMITUBE K is a translucent semi-rigid, inherently flame retarded, heat-shrinkable PVDF tubing, that is recognized by Underwriters' Laboratories (UL) Subject 224 with a VW-1 rating and meets or exceeds the requirements of AMS-DTL-23053/8. 2) SUMITUBE K is tough and abrasion resistant in mechanical environments. It has excellent properties for cut-through and solvent resistance. 4) Operating temperature range is -55o C to +175o C. 5) SUMITUBE K is recommended for applications for strain relieving components such as soldered connections and splices which are in high continuous operating temperature environments. The material is good for applications where abrasion resistance is important. 3) Shrink temperature is 170o C. STANDARD SIZE 3/64 1/16 3/32 1/8 3/16 1/4 3/8 1/2 3/4 1 1 1/2 *2 Standard Colors: Standard Package: How to Order: Example: INSIDE DIAMETER AS SUPPLIED (MIN) INCH (MM) SIZES INSIDE DIAMETER AFTER RECOVERY (MAX) INCH (MM) WALL THICKNESS AFTER RECOVERY (NOM) INCH (MM) .046 1.2 .023 0.6 .010 .063 1.6 .031 0.8 .010 .093 2.4 .046 1.2 .010 .125 3.2 .062 1.6 .010 .187 4.8 .093 2.4 .010 .250 6.4 .125 3.2 .012 .375 9.5 .187 4.8 .012 .500 12.7 .250 6.4 .012 .750 19.1 .375 9.5 .017 1.000 25.4 .500 12.7 .019 1.500 38.1 .750 19.1 .020 2.000 50.8 1.000 25.4 .020 Clear (Translucent). Colors available subject to factory acceptance and quote. 4 feet (4') (Type of material) (Size) (Color) (Packaging) K 1/4 Clear 4' * = non-MIL spec size 0.25 0.25 0.25 0.25 0.25 0.30 0.30 0.30 0.43 0.48 0.51 0.51 K SPECIFICATION VALUES PROPERTY (UNITS) Physical: Tensile strength (psi) Elongation (%) Specific gravity Low temperature flex (-55o C) Heat shock (300o C 4 hrs.) Heat resistance (250o C 168 hrs.) Elongation (%) Secant modulus (psi) Deformation (150o C 1 hr.) (%) Longitudinal change (%) Electrical: Dielectric strength (volts/mil) Volume resistivity (ohm-cm) Chemical: Copper stability (180o C 168 hrs.) Elongation (%) Water absorption (%) Fluid resistance (23o C 24 hrs.) Tensile strength (psi) Flammability Shrink temperature, nominal TEST METHOD REQUIREMENT ASTM D638 ASTM D638 ASTM D792 AMS-DTL-23053 AMS-DTL-23053 5000 min. 150 min. 1.8 max. no cracking no cracking ASTM D638 ASTM D882 UL 224 AMS-DTL-23053 100 min. 120000 min. 50 max. +10 ASTM D876 ASTM D876 800 min. 1.0 X 1013 min. UL 224 ASTM D570 70% of unaged value min. 0.5 max. AMS-DTL-23053 UL 224 VW-1 5000 min. Pass 170o C UL 224, 150o C, 600V, VW-1 File E75077 YDTU2, Cat. No. SUMITUBE K or 852 AMS-DTL-23053/8 Specification reference: SUMITOMO ELECTRIC INTERCONNECT PRODUCTS INC. www.seipusa.com 915 Armorlite Drive San Marcos, CA 92069 Telephone: FAX: (800) 758-3515 (800) 758-3517 Rev. 6/27/16
K 1/16 CLEAR 4FT 价格&库存
很抱歉,暂时无法提供与“K 1/16 CLEAR 4FT”相匹配的价格&库存,您可以联系我们找货
