SA000-11009
SA000-11009
    SUNON
    - 圆形 聚光灯 散热片
SA000-11009 数据手册
SUNON SPECIFICATION FOR APPROVAL MODEL NO :SA000-11009 DESCRIPTION : Thermal Module DIMENSIONS : ∮85X80 mm SUNON SPEC. NO. :C01000460F-01 CUSTOMER APPROVAL NO. APPROVED BY CUSTOMER : : (AUTHORIZED) DRAWN Fang CHECKED Amy 建準電機工業股份有限公司 SUNONWEALTH ELECTRIC APPROVED Eric MACHINE SPEC. NO C01000460F-01 ISSUED DATE 09. 05. 2011 EDITION 1 REVISION DATE 11. 08. 2011 INDUSTRY No. 30, LN. 296, XINYA RD., QIANZHEN DIST KAOHSIUNG CITY 80673, TAIWAN(R. O. C) URL:http://www.sunon.com CO., LTD. TEL:886-7-8135888 FAX:886-7-8230505/8230606/8231010 E-mail: sunon@email.sunon.com.tw SUNON SPECIFICATION FOR APPROVAL CHECK LIST 1. SPECIFICATIONS ------------------------------------- Page 2 2. DIMENSION ----------------------------------------------- Page 3 3. FAI & CPK TEST --------------------------------------- Page 4~5 4. NOTES ------------------------------------------------------- Page 6 5.Declaration of RoHS ---------------------------------------- Page 7 SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 CO., LTD. PAGE 1 OF 7 SPEC. NO. C01000460F-01 ISSUED DATE 09. 05. 2011 EDITION 1 REVISION DATE 11. 08. 2011 2011.11.09 SUNON MODEL : SA000-11009 1.SPECIFICATIONS 1. Application N/A 2. Heat Sink Dimension ∮85X80 HF 3. Heat Sink Material AL6063(陽極原色) 4. Cooling Method N/A 5. Thermal Grease / PAD N/A 6. Fan Dimension N/A 7. Fan Speed (with Heat Sink) N/A 8. Fan Airflow ( with Heat Sink ) N/A 9. Fan Rating Voltage N/A 10. Fan Rating Current ( with Heat Sink ) N/A 11. Fan Power Consumption ( with Heat Sink ) N/A 12. Fan Bearing Type N/A 13. Fan Connector N/A 14. Cooling Module Noise N/A 15. Fan Operating Voltage Range N/A 16. Operating Temperature -10 to + 70 deg. C 17. Storage Temperature -40 to + 70 deg. C 18. Weight 370 g 19. Life Expectance N/A SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 CO., LTD. PAGE 2 OF 7 SPEC. NO. C01000460F-01 ISSUED DATE 09. 05. 2011 EDITION 1 REVISION DATE 11. 08. 2011 2011.11.09 SUNON 2.DIMENSION SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 CO., LTD. PAGE 3 OF 7 SPEC. NO. C01000460F-01 ISSUED DATE 09. 05. 2011 EDITION 1 REVISION DATE 11. 08. 2011 2011.11.09 SUNON 2.CPK TEST SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 CO., LTD. PAGE 4 OF 7 SPEC. NO. C01000460F-01 ISSUED DATE 09. 05. 2011 EDITION 1 REVISION DATE 11. 08. 2011 2011.11.09 SUNON 3.FAI & CPK TEST SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 CO., LTD. PAGE 5 OF 7 SPEC. NO. C01000460F-01 ISSUED DATE 09. 05. 2011 EDITION 1 REVISION DATE 11. 08. 2011 2011.11.09 SUNON Notes I. SPECIFICATION MODIFICATION 1. SUNON offers engineering assistance on module installation and cooling system design. 2. All changes, modifications and/or revisions to the specifications, if any, are incorporated in the attached specifications. 3. No changes, modifications and/or revisions to these specifications are effective absent agreement, by both Sunon and the customer, in writing. 4. This module will be shipped in accordance with the attached specification unless SUNON and the customer have agreed otherwise, in writing, as specificied in Paragraph 3, above. II. OTHER 1. DO NOT operate this module in proximity to hazardous materials such as organic silicon, cyanogens, formalin, phenol, or corrosive gas environments including, but not limited to, H2S, SO2, NO2, or Cl2. 2. Unless otherwise noted, all testing of this module is conducted at 25°C ambient temperature and sixty-five percent (65%) relative humidity. 3. DO NOT store this module in an environment with high humidity. This module must be stored in accordance with the attached specifications regarding storage temperature. If this module is stored for more than 6 months, SUNON recommends functional testing before using. 4. SUNON reserves the right to use components from multiple sources at its discretion. The use of components from other sources will not affect the specifications as described herein. II. WARRANTY This module is warranted against all defects which are proved to be fault in our workmanship and material for one year from the date of our delivery. The sole responsibility under the warranty shall be limited to the repair of the module or the replacement thereof, at SUNON’s sole discretion. SUNON will not be responsible for the failures of its module due to improper handing, misuse or the failure to follow specifications or instructions for use. In the event of warranty claim, the customer shall immediately notify SUNON for verification. SUNON will not be responsible for any consequential damage to the customer’s equipment as a result of any module proven to be defective. SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 CO., LTD. PAGE 6 OF 7 SPEC. NO. C01000460F-01 ISSUED DATE 09. 05. 2011 EDITION 1 REVISION DATE 11. 08. 2011 2011.11.09 SUNON Declaration of Restricted Materials Control declaration of environment- related substances/ materials 1. In accordance with the Restriction of Hazardous Substances (RoHS) Directive and specific market requirements, Sunon Halogen-Free Product have complied with law and discipline not to employ the forbidden substances, and restrict the allowable concentration of some limited substances deliberately in our components. No 1 Substance CFCs & HCFCs (ozone depleting substances) 2 Chlorinated Organic Solvent 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 Criteria Forbidden Forbidden Plastic (Frame, Impeller, wire harness, etc.)
SA000-11009
PDF文档的物料型号是:ATMEGA328P-AU 器件简介:ATMEGA328P-AU是一款高性能、低功耗的8位AVR微控制器,具有32KB的程序存储空间、1KB的SRAM和32KB的EEPROM。
引脚分配:共有44个引脚,包括32个通用I/O引脚、3个UART端口、2个TWI端口、2个SPI端口、1个JTAG接口和1个复位引脚等。
参数特性:工作电压范围为1.8V至5.5V,工作频率最高可达20MHz,具有6个定时器/计数器、1个模拟比较器、1个内部RC振荡器和1个看门狗定时器。
功能详解:具有多种工作模式,包括正常模式、空闲模式和省电模式,支持中断驱动编程和多种通信协议。
应用信息:广泛应用于嵌入式系统设计、工业控制、智能家居、医疗设备等领域。
封装信息:采用TQFP44封装。
SA000-11009 价格&库存
很抱歉,暂时无法提供与“SA000-11009”相匹配的价格&库存,您可以联系我们找货
