SA000-12004
SA000-12004
    SUNON
    - 圆形 聚光灯 散热片
SA000-12004 数据手册
SUNON SPECIFICATION FOR APPROVAL MODEL NO :SA000-12004 DESCRIPTION : Thermal Module DIMENSIONS :∮85X75 mm SUNON SPEC. NO. :C01000730F-01 CUSTOMER APPROVAL NO. APPROVED BY CUSTOMER : : (AUTHORIZED) DRAWN Qian 2/18 CHECKED Amy APPROVED Eric SPEC. NO C01000730F-01 ISSUED DATE 02. 18. 2012 EDITION 0 REVISION DATE 建準電機工業股份有限公司 SUNONWEALTH ELECTRIC MACHINE INDUSTRY CO., LTD. NO. 30, LN. 296, XINYA RD., QIANZHEN DIST., TEL:886-7-8135888 KAOHSIUNG CITY 80673, TAIWAN (R.O.C) FAX:886-7-8230505/8230606/8231010 URL:http://www.sunon.com E-mail: sunon@email.sunon.com.tw SUNON SPECIFICATION FOR APPROVAL CHECK LIST 1. SPECIFICATIONS ------------------------------------- Page 2 2. DIMENSION --------------------------------------------- Page 3 3. CPK TEST ------------------------------------------------ Page 4~5 4. NOTES ------------------------------------------------------- Page 6 5. Declaration of RoHS ---------------------------------------Page 7 SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 CO., LTD. PAGE 1 OF 7 SPEC. NO. C01000730F-01 ISSUED DATE 02. 18. 2012 EDITION 0 REVISION DATE 2012.02.20 SUNON MODEL : SA000-12004 1.SPECIFICATIONS 1. Application Cpu Chipeset 10W 2. Heat Sink Dimension ∮85X75 HF 3. Heat Sink Material AL6063(陽極黑色) 4. Cooling Method N/A 5. Thermal Grease / PAD N/A 6. Fan Dimension N/A 7. Fan Speed (with Heat Sink) N/A 8. Fan Airflow ( with Heat Sink ) N/A 9. Fan Rating Voltage N/A 10. Fan Rating Current ( with Heat Sink ) N/A 11. Fan Power Consumption ( with Heat Sink ) N/A 12. Fan Bearing Type N/A 13. Fan Connector N/A 14. Cooling Module Noise N/A 15. Fan Operating Voltage Range N/A 16. Operating Temperature -10 to + 70 deg. C 17. Storage Temperature -40 to + 70 deg. C 18. Weight 342 g 19. Life Expectance N/A SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 2012.02.20 CO., LTD. PAGE 2 OF 7 SPEC. NO. C01000730F-01 ISSUED DATE 02. 18. 2012 EDITION 0 REVISION DATE SUNON 2.DIMENSION SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 2012.02.20 CO., LTD. PAGE 3 OF 7 SPEC. NO. C01000730F-01 ISSUED DATE 02. 18. 2012 EDITION 0 REVISION DATE SUNON 3. CPK TEST 1. CPK TEST SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 2012.02.20 CO., LTD. PAGE 4 OF 7 SPEC. NO. C01000730F-01 ISSUED DATE 02. 18. 2012 EDITION 0 REVISION DATE SUNON 3. CPK TEST SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 2012.02.20 CO., LTD. PAGE 5 OF 7 SPEC. NO. C01000730F-01 ISSUED DATE 02. 18. 2012 EDITION 0 REVISION DATE SUNON Notes I. SPECIFICATION MODIFICATION 1. SUNON offers engineering assistance on module installation and cooling system design. 2. All changes, modifications and/or revisions to the specifications, if any, are incorporated in the attached specifications. 3. No changes, modifications and/or revisions to these specifications are effective absent agreement, by both Sunon and the customer, in writing. 4. This module will be shipped in accordance with the attached specification unless SUNON and the customer have agreed otherwise, in writing, as specificied in Paragraph 3, above. II. OTHER 1. DO NOT operate this module in proximity to hazardous materials such as organic silicon, cyanogens, formalin, phenol, or corrosive gas environments including, but not limited to, H2S, SO2, NO2, or Cl2. 2. Unless otherwise noted, all testing of this module is conducted at 25°C ambient temperature and sixty-five percent (65%) relative humidity. 3. DO NOT store this module in an environment with high humidity. This module must be stored in accordance with the attached specifications regarding storage temperature. If this module is stored for more than 6 months, SUNON recommends functional testing before using. 4. SUNON reserves the right to use components from multiple sources at its discretion. The use of components from other sources will not affect the specifications as described herein. III. WARRANTY This module is warranted against all defects which are proved to be fault in our workmanship and material for one year from the date of our delivery. The sole responsibility under the warranty shall be limited to the repair of the module or the replacement thereof, at SUNON’s sole discretion. SUNON will not be responsible for the failures of its module due to improper handing, misuse or the failure to follow specifications or instructions for use. In the event of warranty claim, the customer shall immediately notify SUNON for verification. SUNON will not be responsible for any consequential damage to the customer’s equipment as a result of any module proven to be defective. SUNONWEALTH MACHINE ELECTRIC INDUSTRY 建準電機工業股份有限公司 CO., LTD. PAGE 6 SPEC. NO. C01000730F-01 ISSUED DATE 02. 18. 2012 EDITION 0 REVISION DATE 2012.02.20 OF 7 SUNON Declaration of Restricted Materials Control declaration of environment- related substances/ materials 1. In accordance with the Restriction of Hazardous Substances (RoHS) Directive and specific market requirements, Sunon Halogen-Free Product have complied with law and discipline not to employ the forbidden substances, and restrict the allowable concentration of some limited substances deliberately in our components. No 1 Substance CFCs & HCFCs (ozone depleting substances) 2 Chlorinated Organic Solvent 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 Criteria Forbidden Forbidden Plastic (Frame, Impeller, wire harness, etc.)
SA000-12004 价格&库存
很抱歉,暂时无法提供与“SA000-12004”相匹配的价格&库存,您可以联系我们找货
