IPJNR-08-SRFT
IPJNR-08-SRFT
    PEI-GENESIS(倍捷)
    IP68 CABLE JOINER / 8 PIN
IPJNR-08-SRFT 数据手册
7 6 5 3 4 2 1 REVISIONS REV ZONE ECO# DESCRIPTION A INITIAL RELEASE DRAW APPD KC - DATE F F E E D D C C NOTES: B 1. 2. 3. 4. 5. 6. WATERPROOF RATE: IP68 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECTS CAUSED IN 5 METER WATER WITHIN 30 MINUTES OF MATING) TEMPERATURE RANGE: -25°C TO +85°C CURRENT RATING: 7A MAX CONDUCTOR RANGE: 18AWG~26AWG CABLE DIAMETER: Ø6.5~Ø8.5mm MATERIAL: B HOUSING: NYLON, BLACK PIN: BRASS, NICKEL PLATED A SCREW: STEEL, NICKEL PLATED 7. A TITLE CABLE JOINER, ASSY, 8PIN SCREW TORQUE: 3.0 Kgf. cm MIN 8. NUT TORQUE: 19.6 Kgf. cm MIN 9. ONE SET UNASSEMBLED IN ONE PE BAG UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: ANGULAR ± X° DECIMAL .XX ± .XX DECIMAL .X ± .X DECIMAL .XXX ± .XXX IPJNR-08-SRFT DRWN THIRD ANGLE PROJECTION CAGE CODE: 2A589 NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 PART NUMBER 6 5 4 SIZE SCALE A 3 NTS SHEET 1 OF 1 KC APVD - DATE 8/23/2019 ©COPYRIGHT 2018 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 REV 2180 Hornig Road, Philadelphia, PA 19116 A NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS STRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 1
IPJNR-08-SRFT 价格&库存
很抱歉,暂时无法提供与“IPJNR-08-SRFT”相匹配的价格&库存,您可以联系我们找货
