IPHDM-WJP-1M
IPHDM-WJP-1M
    PEI-GENESIS(倍捷)
    CABLE F-M HDMI-A 1M SHLD
IPHDM-WJP-1M 数据手册
7 6 ® IP G O L L A A T E A S C E S R E I U R S SE I M D H www.peigenesis.com I www.peigenesis.cn sales@peigenesis.com Table of Contents Technical Information............................................................................................................................................................ 4 How to Order HDMI Cable Assemblies.................................................................................................................................................................. 5 HDMI Receptacles.......................................................................................................................................................................... 5 HDMI Cable Assemblies HDMI Cable Assembly Molded Plug to HDMI Plug........................................................................................................................ 6 HDMI Cable Assembly Molded Plug to Molded Plug..................................................................................................................... 6 HDMI Cable Assembly Molded Receptacle to HDMI Plug............................................................................................................. 7 HDMI Receptacles HDMI Molded Receptacle to Flying Leads..................................................................................................................................... 7 HDMI Molded Receptacle Feed Thru.............................................................................................................................................. 8 HDMI Molded Receptacle to PC Tails............................................................................................................................................. 8 HDMI Accessories HDMI Receptacle Cap..................................................................................................................................................................... 9 www.peigenesis.com Technical Information Technical Information Wire Gauge Conversion Chart Conversion between American Wire Gauge (AWG), Circular Mil Area (CMA), and approximate metric millimeter squared (mm2) wire sizes. Diameter Area Diameter AWG in. mm CMA mm2* AWG in. mm CMA mm2* 4/0 (0000) 0.46 11.68 212000 120 14 0.062 1.57 4110 2.5 3/0 (000) 0.41 10.41 168000 95 15 0.057 1.45 3260 - 2/0 (00) 0.365 9.27 133000 70 16 0.051 1.30 2580 1.5 1/0 (0) 0.325 8.26 106000 50 17 0.045 1.14 2050 1 1 0.289 7.34 83700 - 18 0.040 1.02 1620 0.75 2 0.258 6.55 66400 35 19 0.036 0.91 1290 - 3 0.229 5.82 52600 - 20 0.032 0.81 1020 0.5 4 0.204 5.18 41700 25 21 0.0285 0.72 810 - 5 0.182 4.62 33100 - 22 0.0253 0.643 642 0.34 6 0.162 4.11 26300 16 23 0.0226 0.574 509 - 7 0.144 3.66 20800 - 24 0.0201 0.511 404 0.25 8 0.128 3.25 16500 10 25 0.0179 0.45 320 - 9 0.114 2.90 13100 - 26 0.0159 0.404 254 0.14 10 0.102 2.59 10400 6 27 0.0142 0.361 202 - 11 0.091 2.31 8230 - 28 0.0126 0.320 160 0.08 12 0.081 2.06 6530 4 29 0.0113 0.29 127 - 13 0.072 1.83 5180 - 30 0.01 0.254 101 0.05 *Nearest metric wire size Use to Convert American Wire Gauge to Diameter and Circular Mil Area. 4 Area www.peigenesis.com How to Order HDMI Cable Assemblies 2 IPHDM - SERIES WPP 3 - CONNECTOR STYLE SERIES IPHDM = HDMI CONNECTOR STYLE WPP = Molded Plug to HDMI Plug WPWP = Molded Plug to Molded Plug WJP = Molded Receptacle to HDMI Plug How to Order 1 1M LENGTH LENGTH* 1M - 1 Meter 2M - 2 Meter 3M - 3 Meter *Additional lengths are available upon request HDMI Receptacles 1 IPHDM SERIES SERIES IPHDM = HDMI 2 - FPC CONNECTOR STYLE CONNECTOR STYLE FL = Molded Receptacle to 500 mm flying leads FBHD = HDMI Feed Thru FPC = Molded Receptacle to PC Tails 5 www.peigenesis.com HDMI Cable Assembly HDMI Cable Assembly Molded Plug to HDMI Plug Connector series: HDMI Gender: Male Part No.: IPHDM-WPP-#M # refers to cable length General Information Connector type: HDMI A type Withstanding voltage: AC 300V/1 minute Temperature range: -20°C ~ +80°C Salt spray: 48 hr. Terminal: Copper alloy, gold plated Protection class: IP67 (unmated) Shell / screw nut: Nylon + GF Durability: 1000 times Mating style: Bayonet Current rating: 0.5A Contact resistance: ≤ 20MΩ Voltage rating: 30V HDMI Cable Assembly Molded Plug to Molded Plug Connector series: HDMI Gender: Male Part No.: IPHDM-WPWP-#M # refers to cable length General Information Connector type: HDMI A type Withstanding voltage: AC 300V/1 minute Temperature range: -20°C ~ +80°C Salt spray: 48 hr. Terminal: Copper alloy, gold plated Protection class: IP67 (unmated) Shell / screw nut: Nylon + GF Durability: 1000 times Mating style: Bayonet Current rating: 0.5A Contact resistance: ≤ 20MΩ Voltage rating: 30V Notes 6 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2 • Please refer to Page 5 for part number breakdown. www.peigenesis.com I www.peigenesis.cn HDMI Cable Assembly & Receptacle www.peigenesis.com HDMI Cable Assembly Receptacle to HDMI Plug Connector series: HDMI Gender: Female Part No.: IPHDM-WJP-#M # refers to cable length General Information Connector type: HDMI A type Withstanding voltage: AC 300V/1 minute Temperature range: -20°C ~ +80°C Salt spray: 48 hr. Terminal: Copper alloy, gold plated Protection class: IP67 (unmated) Shell / screw nut: Nylon + GF Durability: 1000 times Mating style: Bayonet Current rating: 0.5A Max panel thickness: 4.5 mm2 (without cap chain) Voltage rating: 30V Contact resistance: ≤ 20MΩ HDMI Molded Receptacle to Flying Leads Connector series: HDMI Gender: Female Part No.: IPHDM-FL # refers to cable length General Information Connector type: HDMI A type Withstanding voltage: AC 300V/1 minute Temperature range: -20°C ~ +80°C Salt spray: 48 hr. Terminal: Copper alloy, gold plated Protection class: IP67 (unmated) Shell / screw nut: Nylon + GF Durability: 1000 times Mating style: Bayonet Current rating: 0.5A Max panel thickness: 4.5 mm (without cap chain) Voltage rating: 30V Contact resistance: ≤ 20MΩ Cable length: 500 mm 2 Notes • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2 • Please refer to Page 5 for part number breakdown. www.peigenesis.com I www.peigenesis.cn 7 www.peigenesis.com HDMI Receptacle HDMI Receptacle Feed Thru Connector series: HDMI Gender: Female Part No.: IPHDM-FBHD General Information Connector type: HDMI A type Withstanding voltage: AC 300V/1 minute Temperature range: -40°C ~ +105°C Salt spray: 48 hr. Terminal: Copper alloy, gold plated Protection class: IP67 (unmated) Shell / screw nut: Nylon + GF Durability: 1000 times Mating style: Bayonet Current rating: 0.5A Max panel thickness: 4.5 mm2 (without cap chain) Voltage rating: 30V Contact resistance: ≤ 20MΩ HDMI Receptacle to PC Tails Connector series: HDMI Gender: Female Part No.: IPHDM-FPC General Information Connector type: HDMI A type Withstanding voltage: AC 300V/1 minute Temperature range: -40°C ~ +105°C Salt spray: 48 hr. Terminal: Copper alloy, gold plated Protection class: IP67 (unmated) Shell / screw nut: Nylon + GF Durability: 1000 times Mating style: Bayonet Current rating: 0.5A Max panel thickness: 4.5 mm2 (without cap chain) Voltage rating: 30V Contact resistance: ≤ 20MΩ Notes 8 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2 • Please refer to Page 5 for part number breakdown. www.peigenesis.com I www.peigenesis.cn HDMI Accessories & Part Numbers www.peigenesis.com HDMI Receptacle Cap Connector series: HDMI Locking type: Bayonet Part No.: IPCAP-3PT General Information Temperature range: -40°C ~ +105°C Protection class: IP67 Material, cap: Nylon, black Material, gasket: EPDM, black Material, holder: Nylon, black Material, chain: EPDM, black Part Numbers All HDMI Series P/Ns Catalog Page IPHDM-WPP-1M 6 IPHDM-WPP-2M 6 IPHDM-WPP-3M 6 IPHDM-WPWP-1M 6 IPHDM-WPWP-2M 6 IPHDM-WPWP-3M 6 IPHDM-WJP-1M 7 IPHDM-WJP-2M 7 IPHDM-WJP-3M 7 IPHDM-FL 7 IPHDM-FBHD 8 IPHDM-FPC 8 IPCAP-3PT 9 9 Corporate Headquarters, Philadelphia, PA European Headquarters & Production Facility, Southampton, UK North American Production Facility, South Bend, IN Production Facility, Zhuhai, China FilConn, Chandler, AZ PEI-Genesis has sales offices throughout the Americas, Europe and Asia. Visit www.peigenesis.com, call +1 800.675.1214 (North America), +44 (0) 23 8062 1260 (Europe), +86 756 7683 088 (Asia), +1 631.475.5050 (Rest of World), or email: sales@peigenesis.com. www.peigenesis.com | www.peigenesis.cn 10
IPHDM-WJP-1M 价格&库存
很抱歉,暂时无法提供与“IPHDM-WJP-1M”相匹配的价格&库存,您可以联系我们找货
