IPUSBM-2WJAPA-05M
IPUSBM-2WJAPA-05M
    PEI-GENESIS(倍捷)
    CBL USB2.0 A RCPT-A PLUG W/COUPL
IPUSBM-2WJAPA-05M 数据手册
7 6 ® IP G O L L A A T E A S C E S R E SU SERI B S U www.peigenesis.com I www.peigenesis.cn sales@peigenesis.com Table of Contents Technical Information................................................................................................................................................................................................ 4 How to Order USB Cable Assemblies................................................................................................................................................................................................ 5 USB Receptacles......................................................................................................................................................................................................... 5 USB Cable Mounted Plug Assemblies USB-A Circular Plug to USB-A Plug Cable Assembly................................................................................................................................................. 6 USB-A Metal Circular Plug to USB-A Plug Cable Assembly....................................................................................................................................... 6 USB-A Circular Plug to USB-B Plug Cable Assembly................................................................................................................................................. 7 USB-A Metal Circular Plug to USB-B Plug Cable Assembly....................................................................................................................................... 7 USB-A Circular Plug to Circular USB-A Plug Cable Assembly.................................................................................................................................... 8 USB-A Metal Circular Plug to Metal Circular USB-A Plug Cable Assembly................................................................................................................ 8 USB-A Circular Plug to Circular USB-B Plug Cable Assembly.................................................................................................................................... 9 USB-B Circular Plug to Circular USB-B Plug Cable Assembly.................................................................................................................................... 9 USB-B Circular Plug to USB-A Plug Cable Assembly............................................................................................................................................... 10 USB-B Circular Plug to USB-B Plug Cable Assembly .............................................................................................................................................. 10 USB Cable Mounted Receptacle Assemblies USB-A Circular Cable Mounted Receptacle to USB-A Plug Cable Assembly........................................................................................................... 11 USB-A Metal Circular Cable Mounted Receptacle to USB-A Plug Cable Assembly................................................................................................. 11 USB-A Circular Cable Mounted Receptacle to USB-B Plug Cable Assembly.......................................................................................................... 12 USB-A Metal Circular Cable Mounted Receptacle to USB-B Plug Cable Assembly................................................................................................ 12 USB-A Circular Cable Mounted Receptacle to Circular Cable Mounted USB-A Plug Cable Assembly................................................................... 13 USB-A Metal Circular Cable Mounted Receptacle to Metal Circular USB-A Plug Cable Assembly......................................................................... 13 USB-A Circular Cable Mounted Receptacle to Circular Cable Mounted USB-B Plug Cable Assembly................................................................... 14 USB-B Circular Cable Mounted Receptacle to USB-A Plug Cable Assembly.......................................................................................................... 14 USB-B Circular Cable Mounted Receptacle to USB-B Plug Cable Assembly.......................................................................................................... 15 USB-B Circular Cable Mounted Receptacle to Circular Cable Mounted USB-A Plug Cable Assembly................................................................... 15 USB-B Circular Cable Mounted Receptacle to Circular Cable Mounted USB-B Plug Cable Assembly................................................................... 16 USB Jamnut Receptacles USB-A Circular Receptacle Feed Thru ...................................................................................................................................................................... 17 USB-A Metal Circular Receptacle Feed Thru............................................................................................................................................................. 17 USB A Circular Receptacle to PCB Contacts............................................................................................................................................................ 18 USB-A Metal Circular Receptacle to PCB Contacts.................................................................................................................................................. 18 USB-A Circular Receptacle to Screw Terminals........................................................................................................................................................ 19 USB-A Metal Circular Receptacle to Screw Terminals............................................................................................................................................... 19 USB-A Circular Receptacle to Flying Leads.............................................................................................................................................................. 20 USB-A Metal Circular Receptacle to Flying Leads.................................................................................................................................................... 20 USB-B Circular Receptacle Feed Thru...................................................................................................................................................................... 21 USB-B Circular Receptacle to PCB Contacts............................................................................................................................................................ 21 USB-B Circular Receptacle to Flying Leads.............................................................................................................................................................. 22 Accessories USB Receptacle Cap................................................................................................................................................................................................. 23 USB Receptacle Metal Cap....................................................................................................................................................................................... 23 Gasket........................................................................................................................................................................................................................ 24 Locknut ...................................................................................................................................................................................................................... 24 USB PCB Layout....................................................................................................................................................................................................... 25 Part Numbers............................................................................................................................................................................................................ 26 www.peigenesis.com Technical Information Technical Information Wire Gauge Conversion Chart Conversion between American Wire Gauge (AWG), Circular Mil Area (CMA), and approximate metric millimeter squared (mm2) wire sizes. Diameter Area Diameter AWG in. mm CMA mm2* AWG in. mm CMA mm2* 4/0 (0000) 0.46 11.68 212000 120 14 0.062 1.57 4110 2.5 3/0 (000) 0.41 10.41 168000 95 15 0.057 1.45 3260 - 2/0 (00) 0.365 9.27 133000 70 16 0.051 1.30 2580 1.5 1/0 (0) 0.325 8.26 106000 50 17 0.045 1.14 2050 1 1 0.289 7.34 83700 - 18 0.040 1.02 1620 0.75 2 0.258 6.55 66400 35 19 0.036 0.91 1290 - 3 0.229 5.82 52600 - 20 0.032 0.81 1020 0.5 4 0.204 5.18 41700 25 21 0.0285 0.72 810 - 5 0.182 4.62 33100 - 22 0.0253 0.643 642 0.34 6 0.162 4.11 26300 16 23 0.0226 0.574 509 - 7 0.144 3.66 20800 - 24 0.0201 0.511 404 0.25 8 0.128 3.25 16500 10 25 0.0179 0.45 320 - 9 0.114 2.90 13100 - 26 0.0159 0.404 254 0.14 10 0.102 2.59 10400 6 27 0.0142 0.361 202 - 11 0.091 2.31 8230 - 28 0.0126 0.320 160 0.08 12 0.081 2.06 6530 4 29 0.0113 0.29 127 - 13 0.072 1.83 5180 - 30 0.01 0.254 101 0.05 *Nearest metric wire size Use to Convert American Wire Gauge to Diameter and Circular Mil Area. 4 Area www.peigenesis.com How to Order USB 2.0 & 3.0 Cable Assemblies USB - SERIES 2 3 4 3 WPA PA USB VERSION CONNECTOR STYLE (END A) CONNECTOR STYLE (END B) SERIES USB = USB Composite USBM = USB Metal* How to Order 1 5 - 1M LENGTH CONNECTOR STYLE (END A) WPA = Molded Plug USB-A WPB = Molded Plug USB-B PA = USB-A PB = USB-B USB VERSION 2 = USB 2.0 3 = USB 3.0 LENGTH** 1M = 1 meters 2M = 2 meters 3M = 3 meters CONNECTOR STYLE (END A) WPA = Molded Plug USB-A WPB = Molded Plug USB-B WJA = Molded Receptacle USB-A WJB = Molded Receptacle USB-B * Molded USB-B only available in composite ** Additional lengths are available upon request USB 2.0 & 3.0 Receptacles 1 IPUSB SERIES SERIES IPUSB = USB Composite IPUSBM = USB Metal* USB VERSION 2 = USB 2.0 3 = USB 3.0 - 2 3 2 JAFL USB VERSION STYLE STYLE JAFL = Molded Receptacle USB-A to 500 mm Flying Leads JBFL = Molded Receptacle USB-B to 500 mm Flying Leads JAPC = Molded Receptacle A to PC Contacts JBPC = Molded Receptacle B to PC Contacts AABHD = Molded Receptacle A to A Feed Thru BABHD = Molded Receptacle B to A Feed Thru ASTB = Molded Receptacle A to Terminal Block * Molded USB-B only available in composite 5 USB Cable Mounted Plug Assemblies www.peigenesis.com 77 77 66 66 TABLE TABLEAA TABLE A A TABLE TABLE A (L) LENGTH LENGTH PART PARTNUMBER NUMBER (L) 55 55 7 44 6 44 33 5 4 (L) (L) LENGTH LENGTH 33 22 11 REVISIONS REVISIONS 22 11 REVISIONS REV ZONE ZONE ECO# ECO#DESCRIPTION DESCRIPTION DRAWAPPD APPD DATE DATE 3 REVISIONS 2 REV DRAW REV ZONE ZONE ECO# ECO# DESCRIPTION DESCRIPTION DRAW APPD APPD DATE DATE INITIALRELEASE RELEASE 11/14/16 -INITIAL KCKCREVISIONS PKPK 11/14/16 REV DRAW INITIAL RELEASE RELEASE KC PK 11/1/16 ADDEDRoHS RoHSNOTE; NOTE;ADDED ADDEDOVERMOLD OVERMOLD TOLS; ADDEDPK CABLEDIADIA TOLS KCKC PKPK 12/13/17 12/13/17 REV ZONE ECO# DESCRIPTION AA ADDED TOLS; ADDED CABLE TOLS -INITIAL KC 11/1/16 ADDED RoHS RoHS NOTE; NOTE; ADDED ADDED OVERMOLD OVERMOLD TOLS; TOLS; ADDED ADDED CABLE CABLE DIA TOLS TOLS INITIAL KC RELEASE PK 2/13/17 - DIA AA ADDED KC PK 2/13/17 FF A ADDED RoHS NOTE; ADDED FOVERMOLD TOLS, ADDED CABLE DIA TOLS F 1 DRAW APPD DATE KC PK 11/14/16 KC PK 2/13/17 USB-A Circular Plug to USB-A Plug Cable Assembly TOLERANCE TOLERANCE (L) LENGTH PART NUMBER NUMBER METERS (FEET) PART METERS (FEET) TOLERANCE MM TOLERANCE MM(IN) (IN) PART NUMBER METERS (FEET) METERS (FEET) F TOLERANCE MM (IN) (IN) IPUSB-2WPAWPB-1M 1.00 ±50 MM IPUSB-2WPAWPB-1M 1.00(3.28) (3.28) ±50 (2.0) (2.0) METERS (FEET) MM (IN) IPUSBM-2WJAPA-05M 0.50 (1.6) ±30 (1.2) IPUSB-2WPAWPB-2M 2.00 ±100 IPUSB-2WPAWPB-2M 2.00(6.56) (6.56) ±100 (3.94) (3.94) IPUSBM-2WJAPA-05M 0.50 (1.6) ±30 (1.2) IPUSB-2WPBPB-1M 1.00 ±50 (2.0) IPUSBM-2WJAPA-1M 1.00 (3.28) (3.28) ±50 (2.0) (2.0) IPUSB-2WPAWPB-5M 5.00 ±250 (9.84) IPUSB-2WPAWPB-5M 5.00(16.4) (16.4) ±250(3.28) (9.84) IPUSBM-2WJAPA-1M 1.00 ±50 IPUSB-2WPBPB-2M 2.00 (6.56) ±100 (3.94) IPUSBM-2WJAPA-2M 2.00 (6.56) (6.56) ±100 (3.94) (3.94) IPUSBM-2WJAPA-2M 2.00 ±100 IPUSB-2WPBPB-5M 5.00 (16.4) ±250 (9.84) IPUSBM-2WJAPA-3M 3.00 (9.84) (9.84) ±150 (5.90) (5.90) IPUSBM-2WJAPA-3M 3.00 ±150 IPUSBM-2WJAPA-5M 5.00 (16.4) (16.4) ±250 (9.84) (9.84) IPUSBM-2WJAPA-5M 5.00 ±250 FF FF EE EE 25.4 E (HEX) 1.00" 27.2 O O 27.2 1.07" 1.07" Connector series: USB O 27.2 PIN 11 PIN PIN 4 1.07" Gender: Male 29.3 PIN 2 1.15" Part No.: IPUSB-*WPAPA-#M (REF) 59.7 52.0 ±0.50 ±0.50 2.35" 2.05"±.020 ±.020 PIN 44 PIN *refers to use version (2.0 orD 3.0) # refers to cable length PIN 1 PIN 1 General Information C Connector Type: 33 O 20.6 .813" Temperature range: NUT WASHER ±0.1 O 20.8 .819" ±.004 -20°C ~ +80°C B P1 P1 11 22 33 44 SHELL SHELL SCHEMATIC SCHEMATIC P2 P2 P1 REDP1 Copper alloy, gold plated RED WHITE Screw nut: 19.4 ±0.1 .764" ±.004 Nylon + GF AA style:RECOMMENDED PANEL CUT-OUT Screw thread A DO NOT UPDATE MANUALLY. NOTE: CAD GENERATED DRAWING CADUPDATE GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE: CAD CAD GENERATED GENERATED DRAWING DRAWINGNOTE: DO NOT NOT MANUALLY. NOTE: DO UPDATE MANUALLY. Contact resistance: 77 ≤ 30MΩ 7 7 6 6 66 PIN PIN1 1 PIN 2 WHITE11 GREEN2 GREEN 2 BLACK3 BLACK 3 44 SHELL SHELL 5 5 55 11 RED RED 22WHITE P1 WHITE 33GREEN GREEN 1 44BLACK BLACK 2 SHELL SHELL 3 4 SHELL 66 PIN 4 USB-B 2.0 PLUG CC NOTES: CC NOTES: NOTES: (NO AGAINST HARMFUL 1.1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST 1.IP67WATERPROOF WATERPROOF RATE: RATE:IP67 (NOINGRESS INGRESSOF OFDUST/PROTECTED DUST/PROTECTED AGAINST HARMFUL WATERPROOF RATE: RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL 1.1. WATERPROOF EFFECT ININ 11 METER WATER WITHIN 30AGAINST EFFECT CAUSED METER WATEREFFECT WITHINCAUSED 30MINUTES) MINUTES) INHARMFUL 1 METER WATER WITHIN 30 MINUTES) IP67CAUSED (NO INGRESS OFHARMFUL DUST/PROTECTED EFFECT CAUSED CAUSED IN 1 METER WATER WITHIN 30 MINUTES) (CONN 1 ONLY) EFFECT IN 1 METER WATER WITHIN 30 MINUTES) (CONN 1 ONLY) v C TO +80 v C RANGE: -20 2.2. TEMPERATURE vC TO +80vC RANGE: -20vC TO +80vC TEMPERATURE RANGE: TEMPERATURE 2. -20 TO +80 +80 vC NYLON,BLACK TEMPERATURE RANGE: -20SCREW vvSCREW CC TO -20 2.2. TEMPERATURE MATERIAL: NUT: 3.3. RANGE: MATERIAL: NUT: BLACK MATERIAL: SCREW NUT: NYLON, BLACK 3.vCNYLON, MAX PANEL PANEL THICKNESS: THICKNESS: 4.0mm 4.0mm (WITHOUT CAP CHAIN) (WITHOUT CAP 3.3. MAX CONN.1: USB-A GOLD PLATED CONN.1: USB-APLUG, PLUG,CHAIN) GOLD PLATED CONN.1: USB-B PLUG, GOLD PLATING MATERIAL: HOUSING: HOUSING: ZINC ZINC ALLOY, ALLOY, NICKEL PLATED SCREW NUT: ZINC ZINC ALLOY, ALLOY, 4.4. MATERIAL: SCREW NUT: CONN.2: USB-B PLUG, PLATED CONN.2:NICKEL USB-BPLATED PLUG,GOLD GOLD PLATED BB NICKEL PLATED PLATED CONN1: CONN1: USB-A USB-A JACK, JACK, GOLD GOLD PLATED PLATED CONN.2: CONN2:USB-B USB-APLUG, PLUG,GOLD GOLDPLATING NICKEL CONN2: USB-A PLUG, GOLD GASKET: SILICONE, GRAY GASKET: SILICONE, GRAY GASKET: SILICONE, GRAY BB PLATED GASKET: SILICONE, GRAY WASHER: STAINLESS STEEL PLATED GASKET: SILICONE, GRAY WASHER: STAINLESS STEEL CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, RESISTANT, 4. USB2.0 CABLE: UL2725 UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV PVC JACKET,UVUVRESISTANT, CABLE: UL2725PVC USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 4. 28AWG*1P+24AWG*2C+AI+D+B, JACKET, UV 5.5. CABLE: BLACK, OD=5.5mm BLACK, OD=5.5mm RESISTANT, BLACK, BLACK, OD=5.5mm RESISTANT, BLACK, OD=5.5mm RESISTANT, OD=5.5mm DIAMOND ( ( INSPECTED. ...... ) )MUST BE INSPECTED. 5.5. ITEMS ITEMS IDENTIFIED DIAMOND MUST INSPECTED. ITEMS IDENTIFIED IDENTIFIED WITHIDENTIFIED DIAMOND WITH MUSTIDENTIFIED BE WITH BE DIAMOND ( X ... 1 ) MUST BE INSPECTED. 5. ...... ITEMS WITH DIAMOND ((WITH )) MUST BE INSPECTED. 6.6. ITEMS REFERENCE PACKAGING SPECIFICATIONS PER PKG-001 6. REFERENCE PACKAGING SPECIFICATIONS PERDOC# DOC# PKG-001 PER DOC# PKG-001 REFERENCE 6.PACKAGING PACKAGING SPECIFICATIONS PER DOC# DOC# PKG-001 PKG-001 7. P2 PACKAGING SPECIFICATIONS 6. REFERENCE REFERENCE SPECIFICATIONS PER 7. RoHS COMPLIANT. 7. 7. RoHS COMPLIANT. 7. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RoHS COMPLIANT. COMPLIANT. 8. RoHS 8. 1 IPUSB-2WPAWPB-XM AA IPUSB-2WPAWPB-XM RESISTANT, BLACK, OD=5.5mm IPUSBM-2WJAPA-XM IPUSBM-2WJAPA-XM 2 AA CA, USB AP WW//BPBPWWXM AA USB XM CA, USB A W PNL MTLCA, STDAPXM XM 2180 Hornig Road, Philadelphia, PA 19116 AA CA, 3USB A W PNL MTL // AA STD COMPLIANT. 8. RoHSKCHOD 2180 Hornig Road, Philadelphia, PA 19116 KCHOD 2180 Hornig Hornig Road, Road, Philadelphia, Philadelphia, PA PA 19116 19116 KCHOD 2180 KCHOD D.KAPLACHINSKI D.KAPLACHINSKI 4 D.KAPLACHINSKI D.KAPLACHINSKI P.KIM IPUSB-2WPBPB-XM P.KIM P.KIM SHELL 2A589 AA NTS P.KIM 1 1OFOF1 1 AA CA, USB BP W / B STD XM A NTS SHEET 2A589 SHEET Protection class: P2 P2 SCHEMATIC 1 1 1 1 2 2 RED 33 WHITE 44 GREEN SHELL SHELL BLACK 44 CAGE CODE: CAGE CODE: X 1000 times PART NUMBER PART NUMBER SIZE SIZE REV TITLE TITLE REV REV DRAWN: DRAWN: DATE DATE ENGINEER: 11/1/2016 ENGINEER: 11/1/2016 DATE APPROVED BY DATE 11/1/2016 APPROVED BY 11/1/2016 DATE DATE Current rating: SCALE SCALE AA 33 NTS NTS THIRD ANGLE PROJECTION SCALE SCALE VER VER SIZE SIZE APPROVED BY APPROVED BY VER TITLE VER ©COPYRIGHT 2004 PEI-GENESIS ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT OTHERWISE ENGINEERINGUNLESS PRODUCT DEVELOPMENT AA 22 REV CAGE CODE: 66 55 55 7 5 11/14/16 DATE DATE 11/14/16 44 6 2A589 SIZE SCALE A 44 33 5 4 NTS TABLE A (L) LENGTH LENGTH PART PARTNUMBER NUMBER (L) (L) (L) LENGTH LENGTH TOLERANCE TOLERANCE (L) LENGTH PART NUMBER NUMBER METERS (FEET) PART METERS (FEET) TOLERANCE MM TOLERANCE MM(IN) (IN) PART NUMBER METERS (FEET) METERS (FEET) F TOLERANCE MM (IN) (IN) IPUSB-2WPAWPB-1M 1.00 ±50 MM IPUSB-2WPAWPB-1M 1.00(3.28) (3.28) ±50 (2.0) (2.0) METERS (FEET) MM (IN) IPUSBM-2WJAPA-05M 0.50 (1.6) ±30 (1.2) IPUSB-2WPAWPB-2M 2.00 (6.56) ±100 (3.94) IPUSB-2WPAWPB-2M 2.00 (6.56) ±100 (3.94) IPUSBM-2WJAPA-05M 0.50 (1.6) ±30 (1.2) IPUSB-2WPBPB-1M 1.00 ±50 (2.0) IPUSBM-2WJAPA-1M 1.00 (3.28) (3.28) ±50 (2.0) (2.0) IPUSB-2WPAWPB-5M 5.00 ±250 (9.84) IPUSB-2WPAWPB-5M 5.00(16.4) (16.4) ±250(3.28) (9.84) IPUSBM-2WJAPA-1M 1.00 ±50 IPUSB-2WPBPB-2M 2.00 (6.56) ±100 (3.94) IPUSBM-2WJAPA-2M 2.00 (6.56) (6.56) ±100 (3.94) (3.94) IPUSBM-2WJAPA-2M 2.00 ±100 IPUSB-2WPBPB-5M 5.00 (16.4) ±250 (9.84) IPUSBM-2WJAPA-3M 3.00 (9.84) (9.84) ±150 (5.90) (5.90) IPUSBM-2WJAPA-3M 3.00 ±150 IPUSBM-2WJAPA-5M 5.00 (16.4) (16.4) ±250 (9.84) (9.84) IPUSBM-2WJAPA-5M 5.00 ±250 FF FF 11 ENGINEER: APPROVED BY SHEET 1 OF 1 VER 30V 1 KCHOD D.KAPLACHINSKI P.KIM A 11/14/16 DATE 11/14/16 DATE 11/14/16 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2180 Hornig Road, Philadelphia, PA 19116 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 2 3 1 33 22 11 REVISIONS REVISIONS 22 11 REVISIONS REV ZONE ZONE ECO# ECO#DESCRIPTION DESCRIPTION DRAWAPPD APPD DATE DATE 3 REVISIONS 2 REV DRAW REV ZONE ZONE ECO# ECO# DESCRIPTION DESCRIPTION DRAW APPD APPD DATE DATE INITIALRELEASE RELEASE 11/14/16 -INITIAL KCKCREVISIONS PKPK 11/14/16 REV DRAW INITIAL RELEASE RELEASE KC PK 11/1/16 ADDEDRoHS RoHSNOTE; NOTE;ADDED ADDEDOVERMOLD OVERMOLD TOLS; ADDEDPK CABLEDIADIA TOLS KCKC PKPK 12/13/17 12/13/17 REV ZONE ECO# DESCRIPTION AA ADDED TOLS; ADDED CABLE TOLS -INITIAL KC 11/1/16 ADDED RoHS RoHS NOTE; NOTE; ADDED ADDED OVERMOLD OVERMOLD TOLS; TOLS; ADDED ADDED CABLE CABLE DIA TOLS TOLS INITIAL KC RELEASE PK 2/13/17 - DIA AA ADDED KC PK 2/13/17 FF A ADDED RoHS NOTE; ADDED FOVERMOLD TOLS, ADDED CABLE DIA TOLS F 25.4 E (HEX) 1.00" 27.2 O O 27.2 1.07" 1.07" Connector series: USB O 27.2 PIN 11 PIN PIN 4 1.07" Gender: Male 29.3 19.2 PIN 2 .756" 1.15" Part No.: IPUSBM-*WPAPA-#M (REF) 59.7 52.0 ±0.50 ±0.50 2.35" 2.05"±.020 ±.020 PIN 44 PIN 13/16"-28UN 13/16"-28UN 33 CC General Information C Connector Type: BB BB Temperature range: HOUSING USB-A to USB-A NUT B Terminal: AA -20°C ~ +80°C 19.4 ±0.1 .764" ±.004 P1 P1 11 22 33 44 SHELL SHELL SCHEMATIC SCHEMATIC P2 P2 P1 REDP1 RED WHITE1 WHITE 1 GREEN2 GREEN 2 BLACK3 BLACK 3 Zinc alloy, nickel plated44 AA RECOMMENDED PANEL CUT-OUT Mating style: Screw thread A DO NOT UPDATE MANUALLY. NOTE: CAD GENERATED DRAWING CADUPDATE GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE: CAD CAD GENERATED GENERATED DRAWING DRAWINGNOTE: DO NOT NOT MANUALLY. NOTE: DO UPDATE MANUALLY. 7 Contact resistance: 77 7 ≤ 30MΩ 66 6 6 DD PIN 3 DD PIN PIN22 PIN 1 USB-A 2.0 PLUG2.0 USB-B USB-B 2.0PLUG PLUG D PIN 4 USB-B 2.0 PLUG CC NOTES: CC NOTES: NOTES: (NO AGAINST HARMFUL 1.1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST 1.IP67WATERPROOF WATERPROOF RATE: RATE:IP67 (NOINGRESS INGRESSOF OFDUST/PROTECTED DUST/PROTECTED AGAINST HARMFUL WATERPROOF RATE: RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL 1.1. WATERPROOF EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) EFFECT IN 1 METER WATEREFFECT WITHINCAUSED 30 MINUTES) INHARMFUL 1 METER WATER WITHIN 30 MINUTES) IP67CAUSED (NO INGRESS OFHARMFUL DUST/PROTECTED AGAINST EFFECT CAUSED CAUSED IN 11 METER METER WATER WATER WITHIN 30 MINUTES) (CONN 1 ONLY) EFFECT IN WITHIN 30 MINUTES) (CONN 1 ONLY) v C TO +80 v C RANGE: -20 2.2. TEMPERATURE v C TO +80 v C TEMPERATURE RANGE: -20 2. TEMPERATURE RANGE: -20vC TO +80vC TO +80 +80 vC NYLON,BLACK TEMPERATURE RANGE: -20SCREW vvSCREW CC TO -20 2.2. TEMPERATURE MATERIAL: NUT: 3.3. RANGE: MATERIAL: NUT: BLACK MATERIAL: SCREW NUT: NYLON, BLACK 3.vCNYLON, MAX PANEL PANEL THICKNESS: THICKNESS: 4.0mm 4.0mm (WITHOUT CAP CHAIN) (WITHOUT CAP 3.3. MAX CONN.1: USB-A GOLD PLATED CONN.1: USB-APLUG, PLUG,CHAIN) GOLD PLATED CONN.1: USB-B PLUG, GOLD PLATING MATERIAL: HOUSING: HOUSING: ZINC ZINC ALLOY, ALLOY, NICKEL PLATED SCREW NUT: ZINC ZINC ALLOY, ALLOY, 4.4. MATERIAL: SCREW NUT: CONN.2: USB-B PLUG, PLATED CONN.2:NICKEL USB-BPLATED PLUG,GOLD GOLD PLATED BB NICKEL PLATED PLATED CONN1: CONN1: USB-A USB-A JACK, JACK, GOLD GOLD PLATED PLATED CONN.2: CONN2:USB-B USB-APLUG, PLUG,GOLD GOLDPLATING NICKEL CONN2: USB-A PLUG, GOLD GASKET: SILICONE, GRAY GASKET: SILICONE, GRAY BB PLATED GASKET: GASKET: SILICONE, SILICONE,GASKET: GRAY SILICONE, WASHER:GRAY STAINLESS STEEL PLATED GRAY WASHER: STAINLESS STEEL CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, RESISTANT, 4. USB2.0 CABLE: UL2725 UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV PVC JACKET,UVUVRESISTANT, CABLE: UL2725PVC USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 4. 28AWG*1P+24AWG*2C+AI+D+B, JACKET, UV 5.5. CABLE: BLACK, OD=5.5mm BLACK, OD=5.5mm RESISTANT, BLACK, BLACK, OD=5.5mm RESISTANT, BLACK, OD=5.5mm RESISTANT, OD=5.5mm DIAMOND ( ( INSPECTED. ...... ) )MUST BE INSPECTED. 5.5. ITEMS ITEMS IDENTIFIED DIAMOND MUST INSPECTED. ITEMS IDENTIFIED IDENTIFIED WITHIDENTIFIED DIAMOND WITH MUSTIDENTIFIED BE WITH BE DIAMOND ( X ... 1 ) MUST BE INSPECTED. 5. ...... ITEMS WITH DIAMOND ((WITH )) MUST BE INSPECTED. 6.6. ITEMS REFERENCE PACKAGING SPECIFICATIONS PER PKG-001 6. REFERENCE PACKAGING SPECIFICATIONS PERDOC# DOC# PKG-001 PER DOC# PKG-001 REFERENCE 6.PACKAGING PACKAGING SPECIFICATIONS PER DOC# DOC# PKG-001 PKG-001 7. P2 PACKAGING SPECIFICATIONS 6. REFERENCE REFERENCE SPECIFICATIONS PER 7. RoHS COMPLIANT. 7. 7. RoHS COMPLIANT. 7. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RoHS COMPLIANT. COMPLIANT. 8. RoHS 8. 1 IPUSB-2WPAWPB-XM AA IPUSB-2WPAWPB-XM RESISTANT, BLACK, OD=5.5mm IPUSBM-2WJAPA-XM IPUSBM-2WJAPA-XM 2 AA CA, USB AP WW//BPBPWWXM AA USB XM CA, USB A W PNL MTLCA, STDAPXM XM 2180 Hornig Road, Philadelphia, PA 19116 AA CA, 3USB A W PNL MTL // AA STD COMPLIANT. 8. RoHSKCHOD 2180 Hornig Road, Philadelphia, PA 19116 KCHOD 2180 Hornig Hornig Road, Road, Philadelphia, Philadelphia, PA PA 19116 19116 KCHOD 2180 KCHOD D.KAPLACHINSKI D.KAPLACHINSKI 4 D.KAPLACHINSKI D.KAPLACHINSKI P.KIM IPUSB-2WPBPB-XM P.KIM P.KIM SHELL 2A589 AA NTS P.KIM 1 1OFOF1 1 AA CA, USB BP W / B STD XM A NTS SHEET 2A589 SHEET SHELL SHELL 5 5 55 11 RED RED 22WHITE P1 WHITE 33GREEN GREEN 1 44BLACK BLACK 2 SHELL SHELL 3 4 SHELL Salt spray: P2 P2 SCHEMATIC 11 22 RED 33 WHITE 44 GREEN SHELL SHELL BLACK 4 4 44 CAGE CODE: CAGE CODE: Protection class: X X X 1 SIZE SIZE AA SCALE SCALE 33 NTS NTS REV REV REV DRAWN: DRAWN: DATE DATE ENGINEER: 11/1/2016 ENGINEER: 11/1/2016 DATE APPROVED BY DATE 11/1/2016 APPROVED BY 11/1/2016 DATE DATE THIRD ANGLE PROJECTION SIZE SIZE SCALE SCALE VER VER APPROVED BY APPROVED BY AA Voltage rating: 22 TOLERANCE EXCEPT AS NOTED: 2 DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 4 2A589 SIZE SCALE A 3 NTS 1.5A 11 ENGINEER: APPROVED BY THIRD ANGLE PROJECTION 5 REV DATE DATE 11/14/16 11/14/16 DATE NOTICE OF CONFIDENTIALITY DATE 11/14/16 OF CONFIDENTIALITY THIS DRAWING ISNOTICE THE PROPERTY OF PEI-Genesis, ALL NOTICE OF CONFIDENTIALITY 11/14/16 THIS DRAWING IS THE PROPERTY OF NOTICE OF CONFIDENTIALITY RIGHTS REPRODUCTION BY PEI-Genesis, ANY MEANS ALL THIS DRAWING IS THEDATEPROPERTY OF PEI-Genesis, ALL RESERVED. DATE RESERVED. REPRODUCTION ANY MEANS THIS DRAWING IS THE11/14/16 PROPERTY OF PEI-Genesis, ALL ORRIGHTS DISTRIBUTION TO THIRD PARTIES ISBYS TRICTLY RIGHTS RESERVED. REPRODUCTION BY ANY MEANS 11/14/16 BY OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY RESERVED. REPRODUCTION ANY MEANS VER PROHIBITED WITHOUT THE WRITTEN PERMISSION PEI-GENESIS 11/1/2016 ©COPYRIGHT 2004RIGHTS REV OF TITLE OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY 11/1/2016 ENGINEERING VER PROHIBITED WITHOUT THE OF WRITTEN PERMISSION OF PRODUCT ©COPYRIGHT 2004 PEI-GENESIS ORDEVELOPMENT DISTRIBUTION TO THIRD PARTIES IS S TRICTLY AUTHORIZED AGENT PEI-GENESIS. PROHIBITED WITHOUT THE WRITTEN PERMISSION OFAN AN ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT AUTHORIZED AGENT OF PEI-GENESIS. PROHIBITED WITHOUT THE WRITTEN PERMISSION OF ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT AN AUTHORIZED AGENTDRAWN: OF PEI-GENESIS. DATE OTHERWISE SPECIFIED, 2 DIMENSIONS ARE IN MMAN ENGINEERINGUNLESS PRODUCT DEVELOPMENT 1 AUTHORIZED AGENT OF PEI-GENESIS. Current rating: SHEET 11 OF OF 113 SHEET 3 SHEET 1 OF 1 B 1000 times PART NUMBER PART NUMBER TITLE TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM UNLESS OTHERWISE DIMENSIONS ARE IN MM TOLERANCE ASSPECIFIED, NOTED:DRAWN: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM EXCEPT TOLERANCE EXCEPT AS UNLESS OTHERWISE IN MM.X ±0.25 DECIMAL .XXNOTED: ±0.1 DRAWN:.XXX ±0.05 ANGLES ±1v TOLERANCE EXCEPT SPECIFIED, AS NOTED: DIMENSIONS ARE DECIMAL DIMENSIONS .X ±0.25 ARE .XX FOR ±0.1 REFERENCE .XXX ±0.05 TOLERANCE EXCEPT AS NOTED: ONLY ANGLES ±1v ENGINEER: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05IMPERIAL ANGLES ±1v IMPERIAL ARE FOR REFERENCE ONLY ENGINEER: DECIMAL ±0.25 .XX .XXX ±0.05 ANGLESDIMENSIONS ±1v PART NUMBER IMPERIAL.XDIMENSIONS ARE±0.1 FOR REFERENCE ONLY THIRD ANGLE PROJECTION IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY CAGE CODE: 6 C IP67 (unmated) 1 Durability: PART NUMBER PART NUMBER TITLE TITLE CAGE CODE: THIRD ANGLE PROJECTION THIRD ANGLE PROJECTION CAGE CODE: 2A589 2A589 48 hr. X 1 1 NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 PIN PIN1 1 PIN 2 Withstanding voltage: AC 500V/1 minute GASKET WASHER Copper alloy, gold plated Screw nut: E NOTES: NOTES: O 20.6 .813" ±0.1 O 20.8 .819" ±.004 EE PIN 4 ±.15 O 5.5 .22" ±.01 DRAW APPD DATE KC PK 11/14/16 KC PK 2/13/17 PIN 1 PIN PIN33 5.55.5±.15 ±.15 ±.15 OO 5.5 .22" .22" ±.01 .22"±.01 ±.01 PIN 4 13/16"-28UN 13/16"-28UN USB-A 2.0 JACK CC 50.0 ±0.50 1.97" ±.020 PIN PIN44 PIN 1 *refers to use version (2.0 orD 3.0) PINPIN1 1 # refers to cable length EE 27.2 OO 27.2 1.07" 1.07" PIN 3 DD DD 52.0 ±0.50 ±0.50 52.0 LENGTH50.9 2.00" 2.05" ±.020 ±.020 2.05" 52.0 ±0.50 LENGTH LENGTH 2.05" ±.020 1 F EE EE A RESERVED. REPRODUCTION BY ANY MEANS PROHIBITED WITHOUT THE WRITTEN PERMISSION ©COPYRIGHT 2004RIGHTS PEI-GENESIS REV OF OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE OF WRITTEN PERMISSION ENGINEERING PRODUCT ©COPYRIGHT 2004 PEI-GENESIS ORDEVELOPMENT DISTRIBUTION TO THIRD PARTIES IS S TRICTLY AUTHORIZED AGENT PEI-GENESIS. PROHIBITED WITHOUT THE WRITTEN PERMISSION OFAN AN ENGINEERING PRODUCT DEVELOPMENT AUTHORIZED AGENT OF PEI-GENESIS. TOLERANCE EXCEPT AS NOTED: 2 DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 4 1.5A DATE DATE 11/14/16 NOTICE OF CONFIDENTIALITY OF CONFIDENTIALITY THIS DRAWING ISNOTICE THE PROPERTY OF PEI-Genesis, ALL NOTICE OF CONFIDENTIALITY 11/14/16 THIS DRAWING IS THE PROPERTY OF NOTICE OF CONFIDENTIALITY RIGHTS REPRODUCTION BY PEI-Genesis, ANY MEANS ALL THIS DRAWING IS THEDATEPROPERTY OF PEI-Genesis, ALL RESERVED. DATE RESERVED. REPRODUCTION ANY MEANS THIS DRAWING IS THE11/14/16 PROPERTY OF PEI-Genesis, ALL ORRIGHTS DISTRIBUTION TO THIRD PARTIES ISBYS TRICTLY RIGHTS RESERVED. REPRODUCTION 11/14/16 BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY OF PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENTDRAWN: OF PEI-GENESIS. DATE SPECIFIED, 2 DIMENSIONS ARE IN MMAN 1 AUTHORIZED AGENT OF PEI-GENESIS. 11/1/2016 11/1/2016 Voltage rating: SHEET 11 OF OF 113 SHEET 3 B IP67 (unmated) 1 Durability: PART NUMBER PART NUMBER TITLE TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM UNLESS OTHERWISE DIMENSIONS ARE IN MM TOLERANCE ASSPECIFIED, NOTED:DRAWN: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM EXCEPT TOLERANCE EXCEPT AS UNLESS OTHERWISE IN MM.X ±0.25 DECIMAL .XXNOTED: ±0.1 DRAWN:.XXX ±0.05 ANGLES ±1v TOLERANCE EXCEPT SPECIFIED, AS NOTED: DIMENSIONS ARE DECIMAL DIMENSIONS .X ±0.25 ARE .XX FOR ±0.1 REFERENCE .XXX ±0.05 TOLERANCE EXCEPT AS NOTED: ONLY ANGLES ±1v ENGINEER: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05IMPERIAL ANGLES ±1v IMPERIAL ARE FOR REFERENCE ONLY ENGINEER: DECIMAL ±0.25 .XX .XXX ±0.05 ANGLESDIMENSIONS ±1v PART NUMBER IMPERIAL.XDIMENSIONS ARE±0.1 FOR REFERENCE ONLY THIRD ANGLE PROJECTION IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY CAGE CODE: THIRD ANGLE PROJECTION THIRD ANGLE PROJECTION CAGE CODE: 2A589 2A589 X X 1 USB-A Metal Circular Plug to USB-A Plug Cable Assembly TABLE A A TABLE C 48 hr. X THIRD ANGLE PROJECTION 77 D PIN 1 USB-A 2.0 PLUG2.0 USB-B USB-B 2.0PLUG PLUG Salt spray: 4 4 6 7 TABLE TABLEAA PIN PIN22 PIN 4 ±.15 O 5.5 .22" ±.01 NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 77 PIN 3 DD DD Withstanding voltage: AC 500V/1 minute GASKET Terminal: AA E NOTES: NOTES: USB-A to USB-A HOUSING BB BB 5.55.5±.15 ±.15 ±.15 OO 5.5 .22" .22" ±.01 .22"±.01 ±.01 PIN 4 EE PIN 1 PIN PIN33 13/16"-28UN 13/16"-28UN USB-A 2.0 JACK 50.0 ±0.50 1.97" ±.020 PIN 3 13/16"-28UN 13/16"-28UN CC CC 52.0 ±0.50 ±0.50 52.0 LENGTH50.9 2.00" 2.05" ±.020 ±.020 2.05" 52.0 ±0.50 LENGTH LENGTH 2.05" ±.020 EE 27.2 OO 27.2 1.07" 1.07" PIN PIN44 19.2 .756" DD DD Mating F VER 1 KCHOD D.KAPLACHINSKI P.KIM 30V A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 11/14/16 DATE 11/14/16 DATE 11/14/16 A 2180 Hornig Road, Philadelphia, PA 19116 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 1 Notes 6 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. USB Cable Mounted Plug Assemblies www.peigenesis.com 6 7 5 3 4 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS TABLE A (L) LENGTH 1 DRAW APPD DATE KC PK 11/14/16 KC PK 2/13/17 USB-A Circular Plug to USB-B Plug Cable Assembly PART NUMBER F TOLERANCE MM (IN) ±50 (2.0) ±100 (3.94) ±250 (9.84) METERS (FEET) IPUSB-2WPAPB-1M IPUSB-2WPAPB-2M IPUSB-2WPAPB-5M 1.00 (3.28) 2.00 (6.56) 5.00 (16.4) F E E 52.0 ±0.50 2.05" ±.020 Connector series: USB PIN 1 Gender: Male to Male Part No.: IPUSB-*WPAPB-#M 50.0 ±0.50 1.97" ±.020 LENGTH PIN 2 PIN 3 PIN 1 PIN 4 D D PIN 4 *refers to use version (2.0 or 3.0) # refers to cable lengthO 27.2 1.07" ±.15 O 5.5 .22" ±.01 13/16"-28UN USB-B 2.0 PLUG USB-A 2.0 PLUG C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MATERIAL: SCREW NUT: NYLON, BLACK CONN.1: USB-A PLUG, GOLD PLATED CONN.2: USB-B PLUG, GOLD PLATED GASKET: SILICONE, GRAY 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. General Information Connector Type: USB-A to USB-B Temperature range: -20°C ~ +80°C B Withstanding voltage: AC 500V/1 minute SCHEMATIC P1 1 2 3 4 SHELL Terminal: Copper alloy, gold plated Screw nut: Nylon + GF Mating style: A RED WHITE GREEN BLACK P2 1 2 3 4 SHELL 6 Contact resistance: Protection class: IP67 (unmated) IPUSB-2WPAPB-XM 6 5 SIZE SCALE A NTS VER A 1000 times A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/14/2016 11/14/2016 DATE 11/14/2016 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 3 3 4 1.5A 1 Voltage rating: 30V 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADD OVERMOLD TOLS; ADD CABLE DIA TOL (L) LENGTH 1 DRAW APPD DATE KC PK 11/1/16 KC PK 2/13/17 TOLERANCE MM (IN) ±50 (2.0) ±100 (3.94) ±250 (9.84) METERS (FEET) IPUSBM-2WPAPB-1M IPUSBM-2WPAPB-2M IPUSBM-2WPAPB-5M KCHOD D.KAPLACHINSKI P.KIM Current rating: SHEET 1 OF 1 2A589 4 TABLE A F DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: 5 PART NUMBER REV TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY ≤ 30MΩ 7 48 hr. Durability: CA, USB AP W / B STD XM Screw thread 1.00 (3.28) 2.00 (6.56) 5.00 (16.4) F USB-A Metal Circular Plug to USB-B Plug Cable Assembly E 52.0 ±0.50 2.05" ±.020 O 27.2 1.07" E 50.0 ±0.50 1.97" ±.020 LENGTH Connector series: USB PIN 1 Gender: Male to Male Part No.: IPUSBM-*WPAPB-#M D *refers to use version (2.0 or 3.0) C # refers to cable length D PIN 2 PIN 3 PIN 1 PIN 4 O 5.5 ±.15 .22" ±.01 PIN 4 USB-B 2.0 PLUG 13/16"-28UN General Information Connector Type: B USB-A to USB-B SCHEMATIC Temperature range: -20°C ~ +80°C Terminal: Copper alloy, gold plated Screw nut: A P1 1 2 3 4 SHELL Zinc alloy, nickel plated RED WHITE GREEN BLACK Withstanding voltage: AC 500V/1 minute Salt spray: P2 1 2 3 4 SHELL Contact resistance: Screw thread 6 CA, USB AP MTL / B STD XM REV Durability: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY ≤ 30MΩ CAGE CODE: 5 IP67 (mated) PART NUMBER TITLE 4 DRAWN: ENGINEER: APPROVED BY KCHOD D.KAPLACHINSKI P.KIM Current rating: 2A589 SIZE SCALE A NTS SHEET 1 OF 1 VER B 48 hr. Protection class: IPUSBM-2WPAPB-XM NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) (CONN. 1 ONLY) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MATERIAL: SCREW NUT: ZINC ALLOY, NICKEL PLATED CONN.1: USB-A PLUG, GOLD PLATED CONN.2: USB-B PLUG, GOLD PLATED CASKET: SILICONE, GRAY 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. THIRD ANGLE PROJECTION Mating style: B Salt spray: PART NUMBER NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 C A 3 Voltage rating: ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 A A 1000 times DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/1/2016 11/1/2016 DATE 11/1/2016 1.5A 1 30V Notes • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. 7 USB Cable Mounted Plug Assemblies www.peigenesis.com 77 66 SNOISIVER 1 TABLE TABLEAA ETAD 7 55 7 2 3 44 NOITPIRCSE6D #OCETABLE ENOZ A VER ESAELER LAITINI A 6 5 33 4 5 5 4 6 7 3 2 22 4 11 REVISIONS REVISIONS REVISIONS A EZONE LBATECO#1 DESCRIPTION 3 2 REV DRAW REV ZONE ZONE ECO# ECO# DESCRIPTION DESCRIPTION DRAW APPD APPD DATE DATE REV INITIAL RELEASE -INITIAL KCKC REVISIONS PKPK 11/14/16 INITIALRELEASE RELEASE 11/14/16 H T G N E L ) L ( REV OVERMOLD ZONE ECO# DRAW RoHS APPDNOTE;DATE ADDED ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS AA ADDED TOLS; ADDED KCKC PKPK 12/13/17 ADDEDRoHS RoHSNOTE; NOTE;ADDED ADDED OVERMOLD TOLS;DESCRIPTION ADDEDCABLE CABLEDIA DIATOLS TOLS 12/13/17 A INITIAL RELEASE KC PK 11/14/16 REBMUN TRAP FF F ECNARAELOT ADDED OVERMOLD TOLS, ADDED CABLE DIA TOLS KC PK 2/13/17 )ADDED TEEFRoHS ( SRNOTE; ETEM USB-A Circular Plug to Circular USB-A Plug Cable Assembly DPPA WARD KP CK TABLE KP CK A 61/41/11 71/31/21 FF PART PARTNUMBER NUMBER F SLOT AID ELBAC DE(L) D(L) DA ;LENGTH SLENGTH LOT DLOMREVO DEDDA ;ETON SHoR DEDDA METERS METERS(FEET) (FEET) PART NUMBER F IPUSB-2WPAWPB-1M 1.00 IPUSB-2WPAWPB-1M 1.00(3.28) (3.28) IPUSB-2WPAWPB-2M 2.00 IPUSB-2WPAWPB-2M 2.00(6.56) (6.56) IPUSB-2WPBPB-1M IPUSB-2WPAWPB-5M 5.00 IPUSB-2WPAWPB-5M 5.00(16.4) (16.4) IPUSB-2WPBPB-2M IPUSB-2WPBPB-5M EE 1.00 ±250 (9.84) ±250(3.28) (9.84) 2.00 (6.56) 5.00 (16.4) ±50 (2.0) IPUSB-2WPAWPB-5M ±100 (3.94) ±250 (9.84) E PIN 1 )82.3( 00.1 )65.6( 00.2 )4.61( 00.5 C .1 .2 .3 Screw nut: Nylon + GF Screw thread A Contact resistance: A ≤ 30MΩ 77 IKSNIHCALPAK.D MIK.P ETAD 61/41/11 ETAD 61/41/11 :RE ENIGNE YB DEVORPPA 66 P1WHITE .7 WHITE GREEN GREEN 1 BLACK 2BLACK 3 4 NOTE: MANUALLY. STN DO NOTAUPDATE SHELL 1 FCAD O 1GENERATED TEEHS DRAWING 985A2 22 2 RED 33 3 WHITE 44 4 GREEN SHELL LLEHS SHELL BLACK ELTIT ELACS REV 557 2 EZIS 44 3 TABLE TABLEAA ETAD DPPA WARD KP CK TABLE KP CK A IP67 (unmated) Durability: 1000 times Current rating: 6 4 44 6 1.5A REV REV TITLE TITLE UNLESSOTHERWISE OTHERWISESPECIFIED, SPECIFIED,DIMENSIONS DIMENSIONSARE AREININMM MM UNLESS TOLERANCEEXCEPT EXCEPTASASNOTED: NOTED: TOLERANCE DECIMAL.X.X±0.25 ±0.25 .XX.XX±0.1 ±0.1 .XXX .XXX±0.05 ±0.05 ANGLES ANGLES±1±1v v DECIMAL IMPERIALDIMENSIONS DIMENSIONSARE AREFOR FORREFERENCE REFERENCEONLY ONLY IMPERIAL DRAWN: DRAWN: DATE DATE Voltage rating: SCALE SCALE SIZE SIZE APPROVEDBYBY APPROVED COPYRIGHT2004 2004PEI-GENESIS PEI-GENESIS ©© COPYRIGHT ENGINEERINGPRODUCT PRODUCTDEVELOPMENT DEVELOPMENT ENGINEERING 2 4 ARE IN MM6 UNLESS OTHERWISE SPECIFIED, 2 DIMENSIONS TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 55 33 2A589 SIZE DRAWN: ENGINEER: APPROVED BY A NTS SHEET 1 OF 1 VER 11 KCHOD D.KAPLACHINSKI P.KIM A 5 4 3 DATE 7 11/14/16 DATE 11/14/16 DATE 11/14/16 22 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT DATE ENGINEER: DATE APPROVED BY DATE ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT FF PART PARTNUMBER NUMBER F METERS METERS(FEET) (FEET) PART NUMBER F IPUSB-2WPAWPB-1M 1.00 IPUSB-2WPAWPB-1M 1.00(3.28) (3.28) IPUSB-2WPAWPB-2M 2.00 IPUSB-2WPAWPB-2M 2.00(6.56) (6.56) IPUSB-2WPBPB-1M IPUSB-2WPAWPB-5M 5.00 IPUSB-2WPAWPB-5M 5.00(16.4) (16.4) IPUSB-2WPBPB-2M IPUSB-2WPBPB-5M EE F TOLERANCE TOLERANCE (L) LENGTH MM MM(IN) (IN) TOLERANCE ±50 IPUSB-2WPAWPB-1M ±50(2.0) (2.0) METERS (FEET) MM (IN) ±100 IPUSB-2WPAWPB-2M ±100(3.94) (3.94) 1.00 ±50 (2.0) ±250 (9.84) IPUSB-2WPAWPB-5M ±250(3.28) (9.84) 2.00 (6.56) ±100 (3.94) 5.00 (16.4) ±250 (9.84) 1 6 REVISIONS REVISIONS 11 7 2 REVISIONS A EZONE LBATECO#1 DESCRIPTION 3 2 REV DRAW REV ZONE ZONE ECO# ECO# DESCRIPTION DESCRIPTION DRAW APPD APPD DATE DATE REV -INITIAL KCKC REVISIONS PKPK 11/14/16 INITIAL RELEASE INITIALRELEASE RELEASE 11/14/16 HTGECO# NTOLS; ETOLS; LDESCRIPTION )ADDED L( CABLE REV OVERMOLD ZONE DRAW RoHS APPDNOTE;DATE AA ADDED KCKC PKPK 12/13/17 ADDED ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS ADDEDRoHS RoHSNOTE; NOTE;ADDED ADDED OVERMOLD ADDED CABLEDIA DIATOLS TOLS 12/13/17 A INITIAL RELEASE KC PK 11/14/16 REBMUN TRAP FF F ECNARAELOT ADDED OVERMOLD TOLS, ADDED CABLE DIA TOLS KC PK 2/13/17 )ADDED TEEFRoHS ( SRNOTE; ETEM 4 3 Connector series: USB 27.2 Gender: Male to MalePINPIN1 NI1P1 O 1.07" 4 NIP PIN 2 Part No.: IPUSBM-*WPAWPA-#M PIN 1 PIN 4 .1 .2 .3 Screw thread YTILAITNEDIFNOC FO ECITON LLA ,siseneG-IEP FO YTREPORP EHT SI GNIWARD SIHT SNAEM YNA YB NOITCUDORPER .DEVRESER STHGIR YLTCIRT S SI SEITRAP DRIHT OT NOITUBIRTSID RO FO NOISSDO IMDO RENOT PNOT NETUPDATE TUPDATE IRW EHT TMANUALLY. UMANUALLY. OHTIW DETIBIHORP NOTE:CAD CADGENERATED GENERATEDDRAWING DRAWING NOTE: .SISENEG-IEP FO TNEGA DEZIROHTUA NA Contact resistance: A 77 ≤ 30MΩ 1 61/41/11 ETAD 61/41/11 IKSNIHCALPAK.D MIK.P :RE ENIGNE YB DEVORPPA P1WHITE .7 WHITE GREEN GREEN 1 BLACK 2BLACK 3 4 NOTE: MANUALLY. STN DO NOTAUPDATE SHELL 1 FCAD O 1GENERATED TEEHS DRAWING 985A2 22 2 RED 33 3 WHITE 44 4 GREEN SHELL SHELL LLEHS BLACK ELTIT ELACS REV 557 2 PI PIN 4 USB-B 2.0 PLUG USB-B 2.0 PLUG EZIS 48 hr. Protection class: IP67 (unmated) Durability: 1000 times Current rating: 44 6 4 PART NUMBER REV REV TITLE TITLE UNLESSOTHERWISE OTHERWISESPECIFIED, SPECIFIED,DIMENSIONS DIMENSIONSARE AREININMM MM UNLESS TOLERANCEEXCEPT EXCEPTASASNOTED: NOTED: TOLERANCE DECIMAL.X.X±0.25 ±0.25 .XX.XX±0.1 ±0.1 .XXX .XXX±0.05 ±0.05 ANGLES ANGLES±1±1v v DECIMAL IMPERIALDIMENSIONS DIMENSIONSARE AREFOR FORREFERENCE REFERENCEONLY ONLY IMPERIAL CAGECODE: CODE: CAGE :EDOC EGAC 3 DRAWN: DRAWN: DATE DATE ENGINEER: ENGINEER: DATE DATE Voltage rating: SIZE SIZE PART NUMBER SCALE SCALE 33 APPROVEDBYBY APPROVED VERVER TITLE 4 2A589 SIZE SCALE A 3 NTS 30V DATE DATE ©© DRAWN: ENGINEER: APPROVED BY SHEET 1 OF 1 VER REV TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: NOTICEOFOFCONFIDENTIALITY CONFIDENTIALITY DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v NOTICE THISDRAWING DRAWINGISISTHE THEPROPERTY PROPERTY PEI-Genesis, ALLFOR REFERENCE ONLY IMPERIALOFOFDIMENSIONS ARE THIS PEI-Genesis, ALL RIGHTSRESERVED. RESERVED. REPRODUCTION REPRODUCTIONBYBYANY ANYMEANS MEANS RIGHTS THIRD ANGLE PROJECTION DISTRIBUTIONTOTOTHIRD THIRD PARTIESISISS STRICTLY TRICTLY ORORDISTRIBUTION PARTIES CAGE CODE: SCALE SIZE PROHIBITED WITHOUTTHE THE WRITTENPERMISSION PERMISSION VER PROHIBITED WITHOUT WRITTEN REV OFOF AUTHORIZEDAGENT AGENTOFOFPEI-GENESIS. PEI-GENESIS. ANANAUTHORIZED COPYRIGHT2004 2004PEI-GENESIS PEI-GENESIS COPYRIGHT ENGINEERINGPRODUCT PRODUCTDEVELOPMENT DEVELOPMENT ENGINEERING 2 4 ARE IN MM6 UNLESS OTHERWISE SPECIFIED, 2 DIMENSIONS TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 55 CAGE CODE: 5 1.5A PARTNUMBER NUMBER PART 11 KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 3 DATE 7 11/14/16 DATE 11/14/16 DATE 11/14/16 DRAWN: DATE ENGINEER: DATE APPROVED BY DATE ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 2180 Hornig Road, Philadelphia, PA 19116 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 1 Notes 8 PIN 3 D Salt spray: NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 6 PIN CC NOTES: NOTES: WATERPROOF RATE: RATE: IP67 (NO INGRESS INGRESS OF OF DUST/PROTECTED DUST/PROTECTED AGAINST HARMFUL (NO AGAINST HARMFUL WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HA 1.1. WATERPROOF RATE: IP67 (NO INGRESS OF1. DUST/PROTECTED AGAINST 1.IP67WATERPROOF C EFFECT CAUSED CAUSED ININ 11 METER METER WATEREFFECT WITHINCAUSED 30 MINUTES) MINUTES) EFFECT WATER WITHIN 30 IN 1 METER WATER WITHIN 30 MINUTES) HARMFUL IN 1 METER WATEREFFECT WITHINCAUSED 30 MINUTES) TO +80 +80vvCC RANGE: -20vC TO +80vC 2. TEMPERATURE RANGE: -20vC TO +80vC TEMPERATURE RANGE: RANGE: -20 vvCC TO 2.2. TEMPERATURE TEMPERATURE 2. -20 MATERIAL: SCREW SCREW NUT: NUT: NYLON, BLACK NYLON, BLACK MATERIAL: SCREW NUT: NYLON, BLACK 3.3. MATERIAL: 3. 3. MATERIAL: SCREW NUT: NYLON, BLACK CONN.1: USB-A USB-A PLUG, PLUG, GOLD GOLDCONN.1: PLATEDUSB-B PLUG, GOLD PLATING CONN.1: PLATED CONN.1: USB-A PLUG, GOLD PLATED CONN.2: USB-B USB-B PLUG, PLUG, GOLD GOLD PLATEDUSB-B PLUG, GOLD PLATING CONN.2: PLATED CONN.2: USB-B PLUG, GOLD PLATED CONN.2: B BB GASKET: SILICONE, SILICONE, GRAY GRAY GASKET: SILICONE, GRAY GASKET: GASKET: SILICONE, GRAY CABLE: UL2725 UL2725 USB2.0 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, 28AWG*1P+24AWG*2C+AI+D+B, PVC PVC JACKET, JACKET,4.UV UV RESISTANT, RESISTANT, CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV R 4.4. CABLE: CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 4. BLACK, OD=5.5mm OD=5.5mmSCHEMATIC BLACK, OD=5.5mm B CITAMEHCS BLACK, RESISTANT, BLACK, OD=5.5mm ITEMS1P1 IDENTIFIED WITH WITH DIAMOND DIAMOND (( XX ......P21 1 )) MUST MUST BE BE INSPECTED. INSPECTED. 5.5. ITEMS 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. PIDENTIFIED 1 X 5. ITEMS IDENTIFIED WITH DIAMOND ( ... ) MUST BE INSPECTED. REFERENCE PACKAGINGRED SPECIFICATIONS PER DOC# PKG-001 PKG-001 SPECIFICATIONS 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 DER 6.6. REFERENCE 11 PACKAGING 1PER DOC# REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 6.WHITE P2 ETIHW 7.7. RoHS RoHS COMPLIANT. 7. RoHS COMPLIANT. 2COMPLIANT. 2 2 CABLE: UL2725 3USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 7. NEERG GREEN 1 33 IPUSB-2WPAWPB-XM IPUSB-2WPAWPB-XM AA IPUSB-2WPAWPB-XM BLACK RESISTANT, BLACK, A 4 WW // BPBP WW XM 4 OD=5.5mm 2 KCALB AA A CA, USB USB4AP AP XM CA, CA, USB AP W / BP W XM 2180Hornig HornigRoad, Road,Philadelphia, Philadelphia,PAPA19116 19116 2180 2180 Hornig Road, Philadelp 11/14/16 11/14/16 KCHOD COMPLIANT. 8. RoHSKCHOD KCHOD LSHELL LEHS SHELL 11/14/16 3 11/14/16 11/14/16 11/14/16 D.KAPLACHINSKI D.KAPLACHINSKI D.KAPLACHINSKI 4 11/14/16 11/14/16 11/14/16 P.KIM P.KIM P.KIM IPUSB-2WPBPB-XM A SHELL 2A589 .Y2A589 LLAUNAM ETADPUATON OD GNTS NIWARD DESHEET TARENEG1DOF AC :E1TON A NTS SHEET 2A589 SHEET11OFOF 11 AA CA, USB BP W / B STD XM AA NTS A THIRD ANGLE PROJECTION 7 PIN 4PINNI2P2 PIN 1 USB-B 2.0 2.0 PLUG PLUG USB-B THIRDANGLE ANGLEPROJECTION PROJECTION THIRD NOITCEJORP ELGNA DRIHT A SISENEG-IEP 4002 THGIRYPOC© TNEMPOLEVED TCUDORP GNIREENIGNE 66 SCHEMATIC SCHEMATIC .5 P2 2P P2 SCHEMATIC .6 RED RED 11 1 MM NI ERA SNOISNEMID ,DEIFICEPS ESIWREHTO SSELNU :DETON SA TPECXE ECNARELOT v1± SELGNA 50.0± XXX. 1.0± XX. 52.0± X. LAMICED YLNO ECNEREFER ROF ERA SNOISNEMID LAIREPMI :NWARD ETAD ETAD .4 REBMUN TRAP VER PIN 4 D Withstanding voltage: AC 500V/1 minute -20°C ~ +80°C Zinc alloy, nickel plated A PIN 3 NOTES: NOTES: :SETON LUFMRAH TSNIAGA DETCETORP/TSUD FO SSERGNI ON( 76PI :ETAR FOORPRETAW C )SETUNIM 03 NIHTIW RETAW RETEM 1 NI DESUAC TCEFFE Cv08+ OT Cv02- :EGNAR ERUTAREPMET KCALB ,NOLYN :TUN WERCS :LAIRETAM DETALP DLOG ,GULP A-BSU :1.NNOC DETALP DLOG ,GULP B-BSU :2.NNOC B YARG ,ENOCILIS :TEKSAG ,TNATSISER VU ,TEKCAJ CVP ,B+D+IA+C2*GWA42+P1*GWA82 0.2BSU 5272LU :ELBAC B mm5.5=DO ,KCALB .DETCEPSNI EB TSUM ) 1 ... X ( DNOMAID HTIW DEIFITNEDP1IP1SMETI 100-GKP #COD REP SNOITACIFICEPS GNIGAKCAP ECNE11REFER .TNAILPMO2C2 SHoR 33 MX-BPWAPW2-A BSUPI A MX W PB / W P4A4BSU ,AC 61191 AP ,aihpledalihP ,daoR ginroH 0812 61/41/11 DOHCK SHELL SHELL Copper alloy, gold plated AA O 21 E C USB-A to USB-A Screw nut: Mating style: C PIN 33 5.5 ±.15 PIN O .22" ±.01 NU82-"61/31 ±.15 O 5.5 .22" ±.01 13/16"-28UN C Terminal: 5.5 ±.15 ±.15 51.± 5.5 OO 5.5 .22" ±.01 ±.01 10.± "22. O .22" 13/16"-28UN DRAW KC KC E DD PIN 4 13/16"-28UN 13/16"-28UN General Information B 1 NI11P PIN PIN PIN 2 PIN 44 PIN 1 F M1-BPWAPW2-BSUPI M2-BPWAPW2-BSUPI M5-BPWAPW2-BSUPI 27.2 O O 27.2 1.07" 1.07" 52.0 2.72±0.50 O 2.05" "70.1 ±.020 50.0 ±0.50LENGTH 1.97" ±.020 52.0 05.0±0.50 ±±0.50 0.25 LENGTH52.0 2.05" 02.05" 20.± ±.020 ±.020 "50.2 PIN 1 GULP 0.2 B-BSU BB )82.3( 00.1 )65.6( 00.2 )4.61( 00.5 PIN 3D 3 NIP 2PIN PINNI4P4 *refers to use version (2.0 or D3.0) # refers to cable length Temperature range: )NI( MM )0.2( 05± )49.3( 001± )48.9( 052± 52.0 ±0.50 LENGTH HTGNEL 2.05" ±.020LENGTH 52.0 05.0±0.50 ±±0.50 0.25 52.0 27.2 ±.020 2.05" 02.05" 2O0.± ±.020 "50.2 1.07" D Connector Type: 1.00 (3.28) 2.00 (6.56) 5.00 (16.4) EE 2.72 "70.1 O 27.2 O 27.2 O 1.07" 1.07" E CC TOLERANCE MM (IN) ±50 (2.0) ±100 (3.94) ±250 (9.84) METERS (FEET) E E DD (L) LENGTH PART NUMBER 1 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. USB-A Metal Circular Plug to Metal Circular USB-A Plug Cable Assembly 61/41/11 71/31/21 NOTICE OF CONFIDENTIAL THIS DRAWING IS THE PROPERTY OF RIGHTS RESERVED. REPRODUCTION OR DISTRIBUTION TO THIRD PARTIE PROHIBITED WITHOUT THE WRITTEN AN AUTHORIZED AGENT OF PEI 2 2180 Hornig Road, Philadelphia, PA 19116 2 3 5 33 4 5 SCALE REV DRAWN: 30V DATE DATE VERVER TITLE PART NUMBER TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: NOTICEOFOFCONFIDENTIALITY CONFIDENTIALITY DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v NOTICE THISDRAWING DRAWINGISISTHE THEPROPERTY PROPERTY PEI-Genesis, ALLFOR REFERENCE ONLY IMPERIALOFOFDIMENSIONS ARE THIS PEI-Genesis, ALL RIGHTSRESERVED. RESERVED. REPRODUCTION REPRODUCTIONBYBYANY ANYMEANS MEANS RIGHTS THIRD ANGLE PROJECTION DISTRIBUTIONTOTOTHIRD THIRD PARTIESISISS STRICTLY TRICTLY ORORDISTRIBUTION PARTIES CAGE CODE: SCALE SIZE PROHIBITED WITHOUTTHE THE WRITTENPERMISSION PERMISSION VER PROHIBITED WITHOUT WRITTEN REV OFOF AUTHORIZEDAGENT AGENTOFOFPEI-GENESIS. PEI-GENESIS. ANANAUTHORIZED DATE DATE ENGINEER: ENGINEER: PART NUMBER 4 3 NOITPIRCSE6D #OCETABLE ENOZ A VER ESAELER LAITINI SLOT AID ELBAC DE(L) D(L) DA ;LENGTH SLENGTH LOT DLOMREVO DEDDA ;ETON SHoR DEDDA A 7 C Protection class: PARTNUMBER NUMBER PART 5 55 7 2 USB-B 2.0 PLUG USB-B 2.0 PLUG 48 hr. CAGECODE: CODE: CAGE :EDOC EGAC 6 66 SNOISIVER PI PIN 4 Salt spray: CAGE CODE: 7 PIN 3 NOTES: NOTES: WATERPROOF RATE: RATE: IP67 (NO INGRESS INGRESS OF OF DUST/PROTECTED DUST/PROTECTED AGAINST HARMFUL WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HA (NO AGAINST HARMFUL 1.1. WATERPROOF RATE: IP67 (NO INGRESS OF1. DUST/PROTECTED AGAINST 1.IP67WATERPROOF C EFFECT CAUSED CAUSED ININ 11 METER METER WATEREFFECT WITHINCAUSED 30 MINUTES) MINUTES) IN 1 METER WATER WITHIN 30 MINUTES) EFFECT WATER WITHIN 30 HARMFUL IN 1 METER WATEREFFECT WITHINCAUSED 30 MINUTES) TO +80 +80vvCC RANGE: -20vC TO +80vC 2. TEMPERATURE RANGE: -20vC TO +80vC TEMPERATURE RANGE: RANGE: -20 vvCC TO 2.2. TEMPERATURE TEMPERATURE 2. -20 MATERIAL: SCREW SCREW NUT: NUT: NYLON, BLACK BLACK 3.3. MATERIAL: MATERIAL: SCREW NUT: NYLON, BLACK 3. MATERIAL: SCREW NUT: NYLON, BLACK 3. NYLON, CONN.1: USB-A USB-A PLUG, PLUG, GOLD GOLDCONN.1: PLATEDUSB-B PLUG, GOLD PLATING CONN.1: USB-A PLUG, GOLD PLATED CONN.1: PLATED CONN.2: USB-B USB-B PLUG, PLUG, GOLD GOLD PLATEDUSB-B PLUG, GOLD PLATING CONN.2: USB-B PLUG, GOLD PLATED CONN.2: PLATED CONN.2: B BB GASKET: SILICONE, SILICONE, GRAY GRAY GASKET: SILICONE, GRAY GASKET: SILICONE, GRAY GASKET: CABLE: UL2725 UL2725 USB2.0 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, 28AWG*1P+24AWG*2C+AI+D+B, PVC PVC JACKET, JACKET,4.UV UV RESISTANT, RESISTANT, CABLE: UL2725 USB2.0 PVC JACKET, UV R 4.4. CABLE: PVC JACKET, 28AWG*1P+24AWG*2C+AI+D+B, UV 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, BLACK, OD=5.5mm OD=5.5mmSCHEMATIC BLACK, OD=5.5mm B CITAMEHCS BLACK, RESISTANT, BLACK, OD=5.5mm X ... 1 ) MUST BE INSPECTED. XX ...... 1 1 )) MUST ITEMS1P1 IDENTIFIED WITH DIAMOND ( MUST BE INSPECTED. ITEMS IDENTIFIED WITH DIAMOND ( IDENTIFIED WITH DIAMOND ( BE INSPECTED. 5. 5.5. ITEMS P2 WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. P 5. ITEMS IDENTIFIED REFERENCE PACKAGINGRED SPECIFICATIONS PER DOC# PKG-001 PKG-001 SPECIFICATIONS 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 DER 6.6. REFERENCE 11 PACKAGING 1PER DOC# REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 6.WHITE P2 ETIHW 7.7. RoHS RoHS COMPLIANT. 7. RoHS COMPLIANT. 2COMPLIANT. 2 2 CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 7. NEERG GREEN 1 33 3 IPUSB-2WPAWPB-XM IPUSB-2WPAWPB-XM AA IPUSB-2WPAWPB-XM BLACK RESISTANT, BLACK, A 4 WW // BPBP WW XM 4 OD=5.5mm 2 KCALB A AA CA, USB USB4AP AP XM CA, USB AP W / BP W XM CA, 2180Hornig HornigRoad, Road,Philadelphia, Philadelphia,PAPA19116 19116 2180 Hornig Road, Philadelp 2180 11/14/16 11/14/16 11/14/16 KCHOD RoHS COMPLIANT. 8. KCHOD KCHOD L SHELL L E H S SHELL 3 11/14/16 11/14/16 11/14/16 D.KAPLACHINSKI D.KAPLACHINSKI D.KAPLACHINSKI 4 11/14/16 11/14/16 11/14/16 P.KIM P.KIM P.KIM IPUSB-2WPBPB-XM A SHELL 2A589 .Y2A589 LLAUNAM ETADPUATON OD GNTS NIWARD DESHEET TARENEG1DOF AC :E1TON A NTS SHEET 2A589 SHEET11OFOF 11 AA CA, USB BP W / B STD XM AA NTS A NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 1 PIN D CC THIRD ANGLE PROJECTION 77 PIN 4PINNI2P2 PIN 1 USB-B 2.0 2.0 PLUG PLUG USB-B THIRDANGLE ANGLEPROJECTION PROJECTION THIRD NOITCEJORP ELGNA DRIHT A SISENEG-IEP 4002 THGIRYPOC© TNEMPOLEVED TCUDORP GNIREENIGNE 1 SCHEMATIC SCHEMATIC .5 P2 2P P2 SCHEMATIC .6 RED RED 11 1 MM NI ERA SNOISNEMID ,DEIFICEPS ESIWREHTO SSELNU :DETON SA TPECXE ECNARELOT v1± SELGNA 50.0± XXX. 1.0± XX. 52.0± X. LAMICED YLNO ECNEREFER ROF ERA SNOISNEMID LAIREPMI :NWARD ETAD YTILAITNEDIFNOC FO ECITON LLA ,siseneG-IEP FO YTREPORP EHT SI GNIWARD SIHT SNAEM YNA YB NOITCUDORPER .DEVRESER STHGIR YLTCIRT S SI SEITRAP DRIHT OT NOITUBIRTSID RO FO NOISSDO IMDO RENOT PNOT NETUPDATE TUPDATE IRW EHT TMANUALLY. UMANUALLY. OHTIW DETIBIHORP NOTE:CAD CADGENERATED GENERATEDDRAWING DRAWING NOTE: .SISENEG-IEP FO TNEGA DEZIROHTUA NA .4 REBMUN TRAP VER PIN 4 D Withstanding voltage: AC 500V/1 minute -20°C ~ +80°C Copper alloy, gold plated O 21 E PIN 3 NOTES: NOTES: :SETON USB-A to USB-A PIN 33 5.5 ±.15 PIN O .22" ±.01 NU82-"61/31 ±.15 O 5.5 .22" ±.01 13/16"-28UN LUFMRAH TSNIAGA DETCETORP/TSUD FO SSERGNI ON( 76PI :ETAR FOORPRETAW C )SETUNIM 03 NIHTIW RETAW RETEM 1 NI DESUAC TCEFFE Cv08+ OT Cv02- :EGNAR ERUTAREPMET KCALB ,NOLYN :TUN WERCS :LAIRETAM DETALP DLOG ,GULP A-BSU :1.NNOC DETALP DLOG ,GULP B-BSU :2.NNOC B YARG ,ENOCILIS :TEKSAG ,TNATSISER VU ,TEKCAJ CVP ,B+D+IA+C2*GWA42+P1*GWA82 0.2BSU 5272LU :ELBAC B mm5.5=DO ,KCALB .DETCEPSNI EB TSUM ) 1 ... X ( DNOMAID HTIW DEIFITNEDP1IP1SMETI 100-GKP #COD REP SNOITACIFICEPS GNIGAKCAP ECNE11REFER .TNAILPMO2C2 SHoR 33 MX-BPWAPW2-A BSUPI A MX W PB / W P4A4BSU ,AC 61191 AP ,aihpledalihP ,daoR ginroH 0812 61/41/11 DOHCK SHELL SHELL Terminal: 1 NI11P PIN PIN PIN 2 DRAW KC KC E DD 5.5 ±.15 ±.15 51.± 5.5 OO 5.5 .22" ±.01 ±.01 10.± "22. O .22" 13/16"-28UN PIN 4 13/16"-28UN 13/16"-28UN General Information B 50.0 ±0.50LENGTH 1.97" ±.020 52.0 05.0±0.50 ±±0.50 0.25 LENGTH52.0 02.05" 20.± ±.020 ±.020 "50.2 2.05" 1 F M1-BPWAPW2-BSUPI M2-BPWAPW2-BSUPI M5-BPWAPW2-BSUPI 27.2 O O 27.2 1.07" 1.07" 52.0 2.72±0.50 O 2.05" "70.1 ±.020 PIN 44 PIN PIN 4 C Connector Type: 52.0 ±0.50 LENGTH HTGNEL 2.05" ±.020LENGTH PIN 1 GULP 0.2 B-BSU AA )NI( MM )0.2( 05± )49.3( 001± )48.9( 052± PIN 3D 3 NIP 2 NIP Mating style: 1.00 (3.28) 2.00 (6.56) 5.00 (16.4) EE 05.0±0.50 ±±0.50 0.25 52.0 52.0 27.2 ±.020 02.05" 2O0.± ±.020 "50.2 2.05" 1.07" D BB METERS (FEET) 2.72 O PIN 44 PIN *refers to use version (2.0 or D3.0) # refers to cable length Temperature range: TOLERANCE MM (IN) ±50 (2.0) ±100 (3.94) ±250 (9.84) E E CC PART NUMBER F TOLERANCE TOLERANCE (L) LENGTH MM MM(IN) (IN) TOLERANCE IPUSB-2WPAWPB-1M ±50 ±50(2.0) (2.0) METERS (FEET) MM (IN) IPUSB-2WPAWPB-2M ±100 ±100(3.94) (3.94) "70.1 Connector series: USB 27.2 O 27.2 O 1.07" 1.07" 27.2 Gender: Male to MalePINPIN1 NI1P1 O 1.07" 4 NIP Part No.: IPUSB-*WPAWPA-#M PIN 2 DD (L) LENGTH • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. NOTICE OF CONFIDENTIAL THIS DRAWING IS THE PROPERTY OF RIGHTS RESERVED. REPRODUCTION OR DISTRIBUTION TO THIRD PARTIE PROHIBITED WITHOUT THE WRITTEN AN AUTHORIZED AGENT OF PEI 1 USB Cable Mounted Plug Assemblies www.peigenesis.com 6 7 5 3 4 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS 1 USB-A Circular Plug to Circular USB-B Plug Cable Assembly TABLE A (L) LENGTH PART NUMBER F METERS (FEET) IPUSB-2WPAWPB-1M IPUSB-2WPAWPB-2M IPUSB-2WPAWPB-5M DRAW APPD DATE KC PK 11/14/16 KC PK 12/13/17 TOLERANCE MM (IN) ±50 (2.0) ±100 (3.94) ±250 (9.84) 1.00 (3.28) 2.00 (6.56) 5.00 (16.4) F E E Connector series: USB O 27.2 1.07" Gender: Male to Male PIN 1 Part No.: IPUSB-*WPAWPB-#M 52.0 ±0.50 2.05" ±.020 O 27.2 1.07" 52.0 ±0.50 2.05" ±.020 LENGTH PIN 4 PIN 1 PIN 3 PIN 2 D PIN 4 *refers to use version (2.0 or 3.0) # refers to cable length D ±.15 O 5.5 .22" ±.01 13/16"-28UN USB-B 2.0 PLUG General Information C Connector Type: C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MATERIAL: SCREW NUT: NYLON, BLACK CONN.1: USB-A PLUG, GOLD PLATED CONN.2: USB-B PLUG, GOLD PLATED GASKET: SILICONE, GRAY 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. IPUSB-2WPAWPB-XM USB-A to USB-B Withstanding voltage: AC 500V/1 minute Temperature range: -20°C ~ +80°C Salt spray: 48 hr. Terminal: Copper alloy, gold platedP1 Protection class: IP67 (unmated) B Screw nut: 1 2 3 4 SHELL Nylon + GF A Mating style: SCHEMATIC Screw thread P2 1 2 3 4 SHELL RED WHITE GREEN BLACK Durability: 1000 times PART NUMBER CA, USB AP W / BP W XM TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY ≤ 30MΩ DRAWN: ENGINEER: APPROVED BY Voltage rating: NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 7 TABLE A 7 7 CAGE CODE: 6 6 5 6 6 5 4 5 5 4 2A589 SIZE SCALE A NTS (L) LENGTH (L) LENGTH PART NUMBER PART NUMBER PART NUMBER F TOLERANCE SHEET 1 OF 1 VER KCHOD D.KAPLACHINSKI P.KIM A 3 4 4 3 (L) LENGTH A 1.5A DATE A 2180 Hornig Road, Philadelphia, PA 19116 11/14/16 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. DATE 11/14/16 DATE 11/14/16 30V ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 3 TABLE A TABLE A REV Current rating: THIRD ANGLE PROJECTION Contact resistance: B 1 3 2 1 2 2 1 REVISIONS REVISIONS REVISIONS REV ZONE ECO# DESCRIPTION REV ZONE ECO# DESCRIPTION DRAW APPD DATE REV ZONE ECO# DESCRIPTION DRAW APPD DATE INITIAL RELEASE INITIAL RELEASE KC PK 11/14/16 INITIAL RELEASE KC PK 11/14/16 A ADDED ADDED CABLE DIA TOLS A ADDED RoHS NOTE; ADDED OVERMOLD TOLS, ADDED CABLERoHS DIA NOTE; TOLS ADDEDKCOVERMOLD PK TOLS, 2/13/17 A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS KC PK 12/13/17 F F 1 DRAW APPD DATE KC PK 11/14/16 KC PK 2/13/17 USB-B Circular Plug to Circular USB-B Plug Cable Assembly F TOLERANCE MM (IN) ±50 (2.0) ±100 (3.94) ±250 (9.84) F TOLERANCE METERS (FEET) METERS (FEET) METERS (FEET)MM (IN) MM (IN) IPUSB-2WPBPB-1M IPUSB-2WPBPB-1M 1.00 (3.28) 1.00 (3.28) ±50 (2.0) 1.00 IPUSB-2WPAWPB-1M ±50(3.28) (2.0) IPUSB-2WPBPB-2M IPUSB-2WPBPB-2M 2.00 (6.56) 2.00 (6.56)±100 (3.94)2.00 IPUSB-2WPAWPB-2M ±100(6.56) (3.94) IPUSB-2WPBPB-5M IPUSB-2WPBPB-5M 5.00 (16.4) 5.00 (16.4)±250 (9.84)5.00 IPUSB-2WPAWPB-5M ±250(16.4) (9.84) E E E 52.0 ±0.50 2.05" ±.020 52.0 ±0.50 2.05" ±.020 Connector series: USB Gender: Male to Male PIN 1 PINPIN2 3 PIN 2 Part No.: IPUSB-*WPBWPB-#M O 27.2 1.07" O 27.2 1.07" D D D PIN 1 PIN 4 *refers to use version (2.0 or 3.0) # refers to cable length O 27.2 1.07" 52.0 ±0.50 LENGTH 2.05" ±.020 LENGTH PIN 3 PIN 4 PINPIN1 4 13/16"-28UN 13/16"-28UN 5.5 ±.15 5.5 ±.15 O O .22" .22" ±.01 ±.01 13/16"-28UN C -20°C ~ +80°C B B B Terminal: Copper alloy, gold platedSCHEMATICSCHEMATIC SCHEMATIC Screw nut: Nylon + GF Mating style: Screw thread A A A Contact resistance: ≤ 30MΩ P1 1 2 3 4 SHELL P1 RED 1WHITE 2GREEN 3BLACK 4 SHELL P1 P2 1RED 1 WHITE 2 2 GREEN 3 3 BLACK 4 4 SHELL SHELL P2 6 7 6 PIN 2 PIN 4PIN 1 D D D PIN 4 USB-B 2.0 PLUG 48 hr. Protection class: IP67 (mated) 5 6 5 1 C Current rating: TITLE PART NUMBER 1.5A Voltage rating: SHEET 1 OF 1 CAGE CODE: 2A589 A 2A589 4 REV PART NUMBER DRAWN: DATE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM 11/14/16 REV REV TITLE TITLE TOLERANCE EXCEPT AS NOTED: ENGINEER: DATE DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v NOTICE OF CONFIDENTIALITY 11/14/16 DRAWN: DRAWN: OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM DATE DATE UNLESS IMPERIAL DIMENSIONS ARE FOR THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL UNLESS OTHERWISE SPECIFIED, DIMENSIONS AREREFERENCE IN MM ONLY 2180 Hornig Road, Philadelphia, PABY19116 11/14/16 11/14/16 DATE APPROVED RIGHTS RESERVED. REPRODUCTION ANY MEANS TOLERANCE EXCEPT ASBYNOTED: TOLERANCE EXCEPT AS NOTED: THIRD ANGLE PROJECTION 11/14/16 ENGINEER: ENGINEER: .X ±0.25 OR DISTRIBUTION TO THIRD PARTIES ISDATE S TRICTLY DECIMAL .XX ±0.1 .XXX ±0.05 ANGLESDATE ±1v DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v NOTICE OF CONFIDENTIALITY 11/14/16 SIZE ARE FORSCALE VER PROHIBITED WITHOUT THE WRITTEN PERMISSION OF ©COPYRIGHT IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY2004 PEI-GENESIS11/14/16 IMPERIAL DIMENSIONS REFERENCE ONLY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL ENGINEERING PRODUCT DEVELOPMENT AN AUTHORIZED AGENT APPROVED BYRIGHTS RESERVED. APPROVEDABY DATE DATE REPRODUCTION BY OF ANYPEI-GENESIS. MEANS THIRD ANGLE PROJECTION THIRD ANGLE PROJECTION 11/14/16 OR DISTRIBUTION TO THIRD PARTIES1 IS S TRICTLY11/14/16 2 3 CAGE CODE: SCALE SCALE SIZE SIZE VER VER PROHIBITED WITHOUT THE 2004 WRITTEN PERMISSION OF ©COPYRIGHT PEI-GENESIS ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCTOFDEVELOPMENT ENGINEERING PRODUCT DEVELOPMENT AN AUTHORIZED AGENT PEI-GENESIS. CA, USB BP W / B STD XM 3 A NTS NTS SHEET 1 OF 12A589A B 1000 times PART NUMBER 4 SHELL 4 5 4 X Durability: RED 1 WHITE 2 GREEN 3 BLACK NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 PIN 3 PIN 1 PIN 3 Salt spray: CAGE CODE: NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 PIN 3PIN 2 PIN 1 Withstanding voltage: AC 500V/1 minute USB-B to USB-B Temperature range: PIN 2 PIN 4 NOTES: NOTES: RATE: IP67 (NO INGRESS INGRESS OF DUST/PROTECTED AGAINSTOF DUST/PROTECTED 1. WATERPROOF RATE: IP67 1.(NOWATERPROOF C AGAINST NOTES: EFFECT CAUSED IN HARMFUL EFFECT WITHIN CAUSED30IN MINUTES) 1 METER WATER WITHIN C30 MINUTES) HARMFUL 1 METER WATER RATE: INGRESS DUST/PROTECTED 1. WATERPROOF vC HARMFUL RANGE: -20vC TO +80AGAINST 2.IP67 vC TEMPERATURE TO(NO+80 vC OF RANGE: -20 2. TEMPERATURE EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 3. MATERIAL: BLACK SCREW NUT: NYLON, BLACK 3. MATERIAL: SCREW NUT: NYLON, 2. TEMPERATURE RANGE: -20vC TO +80vC CONN.1: USB-B PLUG, GOLD PLATING CONN.1: USB-B PLUG, GOLD PLATING 3. MATERIAL: SCREW NUT: NYLON, BLACK CONN.2: CONN.2:CONN.1: USB-BUSB-A PLUG,PLUG, GOLDGOLD PLATING PLATEDUSB-B PLUG, GOLD PLATING GASKET: GASKET: SILICONE, CONN.2: USB-BGRAY PLUG, GOLD PLATEDSILICONE, GRAY CABLE:GRAY UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVCB JACKET, UV 4.SILICONE, PVC JACKET, UV 4. CABLE: UL2725 USB2.0 GASKET:28AWG*1P+24AWG*2C+AI+D+B, B RESISTANT, BLACK, OD=5.5mmRESISTANT, BLACK, OD=5.5mm PVC JACKET, UV RESISTANT, 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, DIAMOND ( X ... 1 ) MUST BE INSPECTED. 5. ITEMS( XIDENTIFIED IDENTIFIED WITH DIAMOND ... 1 ) MUSTWITH BE INSPECTED. 5. ITEMSBLACK, OD=5.5mm PACKAGING SPECIFICATIONS 6. REFERENCE P2 6. REFERENCE IDENTIFIED SPECIFICATIONS WITH DIAMOND ( PER ... DOC# ) MUSTPKG-001 BE INSPECTED. PER DOC# PKG-001 5. ITEMS PACKAGING CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 7. SPECIFICATIONS UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV PACKAGING PER DOC# PKG-001 6. REFERENCE 1 7. CABLE: RESISTANT, BLACK, OD=5.5mmRESISTANT, BLACK, OD=5.5mm 7. RoHS COMPLIANT. 2 8. RoHS COMPLIANT. 3 8. RoHS COMPLIANT. IPUSB-2WPAWPB-XM A 4 A CA, USB AP W /IPUSB-2WPBPB-XM BP W XM IPUSB-2WPBPB-XM 2180 Hornig Road, Philadelphia, PA 19116 A SHELL KCHOD C Connector Type: ±.15 O 5.5 .22" ±.01 E E O 27.2 1.07" USB-B 2.0 PLUG USB-B 2.0 PLUG General Information C E 50.0 ±0.50 1.97" ±.020 50.0 ±0.50 LENGTH 1.97" ±.020 52.0 ±0.50 2.05" ±.020 F CA, USB BP W / B STD XMA D.KAPLACHINSKI KCHODP.KIM D.KAPLACHINSKI P.KIM A NTS 3 2 SHEET 1 OF 1 KCHOD 30V D.KAPLACHINSKI P.KIM A 2 1 A A 2180 Hornig Road, Philadelphia, PA 19116 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 1 Notes • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. 9 USB Cable Mounted Plug Assemblies www.peigenesis.com 7 TABLE A7 7 7 TABLE A TABLE A 6 6 6 6 5 5 5 5 4 4 4 3 4 3 2 1 2 2 1 REVISIONS REVISIONS REVISIONS 2 DESCRIPTION REV ZONE ECO# 1DESCRIPTION REV ZONE ECO# DRAW APPD DATE REVISIONS REV ZONE ECO# DESCRIPTION DRAW APPD DATE INITIAL RELEASE INITIAL RELEASE KC PK 11/14/16 REV ZONE ECO# DESCRIPTIONDRAW APPD DATE INITIAL RELEASE KC PK 11/14/16 A ADDED ADDED CABLE DIA TOLS A ADDED RoHS NOTE; ADDED OVERMOLD TOLS, ADDED CABLERoHS DIA NOTE; TOLS ADDEDKCOVERMOLD PK TOLS, 2/13/17 INITIAL RELEASE 11/1/16 A ADDED RoHS NOTE; ADDED OVERMOLD TOLS;KCADDEDPKCABLE DIA TOLS KC PK 12/13/17 A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS KC PK 2/13/17 F F F 3 3 1 DRAW APPD DATE KC PK 11/14/16 KC PK 2/13/17 USB-B Circular Plug to USB-A Plug Cable Assembly TABLE A (L) LENGTH (L) LENGTH (L) LENGTH PART NUMBER PART NUMBER (L) LENGTH PART NUMBER F F TOLERANCE TOLERANCE F TOLERANCE METERS (FEET) METERS (FEET) PART NUMBER METERS (FEET)MM (IN) MM (IN) F TOLERANCE MM (IN) METERS (FEET) IPUSB-2WPBPB-1M IPUSB-2WPBPB-1M 1.00 (3.28) 1.00 (3.28) ±50 (2.0) 1.00 MM (IN) IPUSB-2WPAWPB-1M ±50(3.28) (2.0) IPUSB-2WPBPB-2M IPUSB-2WPBPB-2M 2.00 (6.56) 2.00 (6.56) ±100 (3.94)2.00 IPUSBM-2WJAPA-05M 0.50 (1.6) ±30 (1.2) IPUSB-2WPAWPB-2M ±100(6.56) (3.94) IPUSB-2WPBPB-5M IPUSB-2WPBPB-5M 5.00 (16.4) 5.00 (16.4) ±250 (9.84)5.00 IPUSBM-2WJAPA-1M 1.00 (3.28) ±50 (2.0) IPUSB-2WPAWPB-5M ±250(16.4) (9.84) IPUSBM-2WJAPA-2M IPUSBM-2WJAPA-3M IPUSBM-2WJAPA-5M E 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) ±100 (3.94) ±150 (5.90) ±250 (9.84) E E E D D D D C 13/16"-28UN B B 3 O 20.6 .813" -20°C ~ +80°C NUT WASHER Terminal: Copper alloy, goldP1 Screw nut: Nylon + GF Mating style: Screw thread A A A 19.4 ±0.1 .764" ±.004 A RECOMMENDED PANEL CUT-OUT Contact resistance: GASKET SCHEMATIC plated SCHEMATIC SCHEMATICSCHEMATIC P2 P1 1 2 1 3 2 4 3 SHELL 4 SHELL REDP1 WHITE RED 1 GREENWHITE 2 BLACKGREEN 3BLACK 4 SHELL P1 P2 1 2 1RED 1 2 2 3WHITE 3 3 4GREEN BLACK SHELL 4 4 SHELL SHELL P2 6 7 6 7 5 5 6 6 7 7 USB-B 2.0 PLUG 4 4 2A589 TITLE X X TITLE PART NUMBER PART NUMBER 1.5A REV REV CA, USB BP W / B STD XMA CA, USB BP W / B STDKCHOD XM D.KAPLACHINSKI KCHODD.KAPLACHINSKI P.KIM P.KIM D.KAPLACHINSKI Voltage rating: SHEET 1 OF 1 SHEET 1 OF 1 NTS 2A589 A A 2A589 A ANTS A NTS SHEET 1 OF 12A589A A NTS 3 4 A KCHOD 30V D.KAPLACHINSKI P.KIM P.KIM 3 3 1.00 (3.28) 2.00 (6.56) 5.00 (16.4) E Connector series:27.2USB O 1.07" Gender: Male to Male PIN 2 PIN 3 Part No.: IPUSB-*WPBPB-#M *refers to use Dversion (2.0 or 3.0) PIN 1 # refers to cable length 52.0 ±0.50 2.05" ±.020 SHEET 1 OF 1 A 2 2 1 1 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED OVERMOLD TOLS, ADDED CABLE DIA TOLS 1 DRAW APPD DATE KC PK 11/14/16 KC PK 2/13/17 Connector Type: USB-B to USB-B Temperature range: -20°C ~ +80°C Terminal: Copper alloy, gold plated Nylon + GF Mating style: Screw thread Contact resistance: ≤ 30MΩ E SCHEMATIC P1 1 2 3 4 SHELL RED WHITE GREEN BLACK P2 1 2 3 4 SHELL Notes 10 PIN 1 PIN 4 Voltage rating: IPUSB-2WPBPB-XM CA, USB BP W / B STD XM TITLE CAGE CODE: 5 4 30V PART NUMBER REV DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 6 PIN 3 NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST C HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC BLACK 3. MATERIAL: SCREW NUT: NYLON, Withstanding voltage: AC 500V/1 minute CONN.1: USB-B PLUG, GOLD PLATING CONN.2: USB-B PLUG, GOLD PLATING 48 hr. Salt spray: GASKET: SILICONE, GRAY 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 4. CABLE: UL2725 USB2.0 Protection class: IP67 (unmated) B RESISTANT, BLACK, OD=5.5mm 1 X 5. ITEMS IDENTIFIED WITH DIAMOND ( ... ) MUST BE INSPECTED. Durability: PKG-001 times 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC#1000 7. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT,rating: BLACK, OD=5.5mm Current 1.5A 8. RoHS COMPLIANT. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 7 PIN 2 USB-B 2.0 PLUG C Screw nut: F ±.15 O 5.5 .22" ±.01 General Information A NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. D PIN 4 13/16"-28UN B 2180 Hornig Road, Philadelphia, PA 19116 50.0 ±0.50 1.97" ±.020 LENGTH 2A589 SIZE SCALE A 3 NTS SHEET 1 OF 1 VER B 1 TOLERANCE MM (IN) ±50 (2.0) ±100 (3.94) ±250 (9.84) METERS (FEET) C 1000 times Current rating: 4 5 1 DRAWN: DATE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM DRAWN: DATE UNLESS OTHERWISE SPECIFIED,TITLE DIMENSIONS ARETOLERANCE IN MM EXCEPT AS NOTED: REV REV TITLE 2180 Hornig Road, 11/14/16 Philadelphia, PA 19116 11/1/2016 TOLERANCE EXCEPT AS NOTED: ENGINEER: DATE DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v NOTICE OF CONFIDENTIALITY ENGINEER: DATE DECIMAL .X ±0.25 .XX ±0.1UNLESS .XXXOTHERWISE ±0.05 IMPERIAL ANGLES ±1v DIMENSIONS NOTICE OF CONFIDENTIALITY 11/14/16 DRAWN: DRAWN: OTHERWISE SPECIFIED, DATE UNLESS DIMENSIONS ARE IN MM DATE DIMENSIONS ARE FOR THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL SPECIFIED, AREREFERENCE IN MM ONLY 11/1/2016 IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY Hornig Philadelphia, PABY19116 THIS DRAWING IS THE PROPERTY OF2180 PEI-Genesis, ALL Road, 11/14/16 11/14/16 APPROVED DATE RIGHTS RESERVED. REPRODUCTION ANY MEANS TOLERANCE EXCEPT ASBYNOTED: TOLERANCE EXCEPT AS NOTED: THIRD ANGLE PROJECTION APPROVED BY DATE RESERVED. REPRODUCTION 11/14/16 ENGINEER: BY ANY MEANS ENGINEER: .X ±0.25 DATE OR DISTRIBUTION TO THIRD PARTIES ISDATE S TRICTLY DECIMAL .XX ±0.1 .XXX ±0.05 RIGHTS ANGLES ±1v DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v THIRD ANGLE PROJECTION NOTICE OF CONFIDENTIALITY 11/1/2016 OR DISTRIBUTION IS S TRICTLY 11/14/16 OF CAGE CODE: IMPERIAL DIMENSIONS 11/14/16TO THIRD PARTIESTHIS SIZE ARE FORSCALE VER PROHIBITED WITHOUT THE WRITTEN PERMISSION ©COPYRIGHT 2004 PEI-GENESIS IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY REFERENCE ONLY DRAWING IS THE PROPERTY OF PEI-Genesis, ALL SCALE SIZE VER PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. ©COPYRIGHTAPPROVED 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT APPROVED BYRIGHTS RESERVED. BY DATE DATE REPRODUCTION BY ANY MEANS ENGINEERINGTHIRD PRODUCTANGLE DEVELOPMENT AN AUTHORIZED PROJECTION THIRD ANGLE PROJECTION 11/14/16 11/14/16 AGENT OF PEI-GENESIS. OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY 2 3 1PERMISSION OF CAGE CODE: CAGE CODE: 3 SCALE SCALE SIZE SIZE 2VER VER PROHIBITED WITHOUT THE 2004 WRITTEN 1 ©COPYRIGHT PEI-GENESIS ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCTOFDEVELOPMENT ENGINEERING PRODUCT DEVELOPMENT AN AUTHORIZED AGENT PEI-GENESIS. 5 4 5 IP67 (unmated) USB-B Circular Plug To USB-B Plug Cable Assembly PART NUMBER D PIN 4 Protection class: (L) LENGTH IPUSB-2WPBPB-1M IPUSB-2WPBPB-2M IPUSB-2WPBPB-5M D 48 hr. TABLE A F D Salt spray: PART NUMBER PART NUMBER 4 SHELL CAGE CODE: 6 7 NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. PIN 2 PIN 4PIN 1 PIN 4 PIN 3 NOTES: NOTES: RATE: IP67 (NO INGRESS INGRESS OF DUST/PROTECTED AGAINSTOF DUST/PROTECTED 1. WATERPROOF RATE: IP67 1.(NOWATERPROOF C AGAINST C NOTES: EFFECT CAUSED IN HARMFUL EFFECT WITHIN CAUSED30IN MINUTES) 1 METER WATER WITHIN C30 MINUTES) HARMFUL 1 METER WATER NOTES: RATE: IP67 (NO+80 INGRESS OF DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF v C TO +80 v C TEMPERATURE RANGE: -20 2. v C TO v C TEMPERATURE RANGE: -20 2. IP67CAUSED (NO INGRESS OF DUST/PROTECTED HARMFUL 1. WATERPROOF RATE: EFFECT IN 1 METER WATER WITHIN AGAINST 30 MINUTES) NUT: 1NYLON, 3. MATERIAL: MATERIAL: NUT: NYLON, BLACK SCREW(CONN 3. CAUSED EFFECT IN 1 SCREW METER WATER ONLY) BLACK +80vC RANGE:WITHIN -20vC30TOMINUTES) 2. TEMPERATURE CONN.1: USB-B PLUG, GOLD PLATING CONN.1: PLUG, GOLDBLACK PLATING C USB-B TO +80 vC NYLON, -20vSCREW 2. TEMPERATURE MATERIAL: NUT: 3. RANGE: CONN.2: CONN.2: USB-B PLUG,CAP GOLD PLATING 4.0mm (WITHOUT CHAIN) 3. MAX PANEL THICKNESS: CONN.1: USB-A PLUG, GOLD PLATEDUSB-B PLUG, GOLD PLATING ALLOY, NICKEL PLATED SCREW NUT: ZINC ALLOY, 4. MATERIAL: HOUSING: ZINC GASKET: SILICONE, GRAY GASKET: SILICONE, CONN.2: USB-BGRAY PLUG, GOLD PLATED NICKEL4. PLATED CONN1: USB-A JACK, GOLD PLATED CONN2: GOLD UV CABLE: UL2725 USB2.0USB-A 28AWG*1P+24AWG*2C+AI+D+B, PVCB JACKET, UV 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVCPLUG, JACKET, B GASKET: SILICONE, GRAY B PLATED RESISTANT, GASKET: SILICONE, GRAY WASHER: STAINLESS STEEL BLACK, OD=5.5mmRESISTANT, BLACK, OD=5.5mm CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET,1 UV RESISTANT, 4. USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 5. CABLE:5. UL2725 1 X X DIAMOND ( ... ) MUST BE INSPECTED. 5. ITEMS( IDENTIFIED ITEMSBLACK, IDENTIFIED WITH DIAMOND ... ) MUSTWITH BE INSPECTED. OD=5.5mm RESISTANT, BLACK, OD=5.5mm PACKAGING SPECIFICATIONS 6. ... REFERENCE REFERENCE IDENTIFIED WITH DIAMOND ... DOC# ) MUSTPKG-001 BE INSPECTED. PER DOC# PKG-001 5. ITEMS ITEMS6.IDENTIFIED WITHPACKAGING DIAMOND (SPECIFICATIONS ) MUST BE( PER INSPECTED. 6. P2 CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 7. SPECIFICATIONS UL2725SPECIFICATIONS USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV REFERENCE PACKAGING PER DOC# PKG-001 6.PACKAGING PER DOC# PKG-001 7. REFERENCE 1 7. CABLE: RESISTANT, BLACK, OD=5.5mmRESISTANT, BLACK, OD=5.5mm 7. RoHS COMPLIANT. 2 COMPLIANT. 8. RoHS 8. RoHS COMPLIANT. 3 8. RoHS COMPLIANT. IPUSB-2WPAWPB-XM A IPUSBM-2WJAPA-XM A 4 A BP W XM A CA, USB A W PNL MTLCA, / AUSB STDAPXMW /IPUSB-2WPBPB-XM IPUSB-2WPBPB-XM 2180 Hornig Road, Philadelphia, PA 19116 A SHELL KCHOD Durability: RED 1 WHITE 2 GREEN 3 BLACK ≤ 30MΩ CADUPDATE GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE: CAD GENERATED DRAWINGNOTE: DO NOT MANUALLY. PIN 3PIN 2 PIN 1 D PIN 3 PIN 1 ±.15 O 5.5 .22" ±.01 E E Withstanding voltage: AC 500V/1 minute HOUSING ±0.1 OB 20.8 .819" ±.004 PIN 1 E O 27.2 1.07" USB-B 2.0 PLUG USB-A 2.0 PLUG USB-B 2.0 PLUG USB-B to USB-A Temperature range: B 5.55.5±.15 5.5O ±.15 ±.15 O O .22" .22" ±.01 .22"±.01 ±.01 13/16"-28UN C Connector Type: 19.2 .756" 13/16"-28UN 13/16"-28UN E PIN 2 PIN 4 PIN 4 General Information C 50.0 ±0.50 1.97" ±.020 50.0 ±0.50 LENGTH 1.97" ±.020 50.9 52.0 ±0.50 ±0.50 2.00" 2.05" ±.020 ±.020 PIN 3 PINPIN1 4 PIN 1 USB-A 2.0 JACK C 52.0 ±0.50 LENGTH 2.05" ±.020 LENGTH LENGTH 52.0 ±0.50 2.05" ±.020 59.7 52.0 ±0.50 ±0.50 2.35" 2.05"±.020 ±.020 25.4 (HEX) Connector series: USB 1.00" O 27.2 O 27.2 1.07" 1.07" O 27.2 1.07" Gender: Male to Male PIN 42 3 PIN 1 PINPIN PIN 2 Part No.: IPUSB-*WPBPA-#M 29.3 1.15" (REF) (2.0 PIN 1 or 3.0) *refers to use version PIN 4 # refers to cable length F ±50 (2.0) ±100 (3.94) ±250 (9.84) KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/14/16 11/14/16 DATE 11/14/16 1 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. A USB Cable Mounted Receptacle Assemblies www.peigenesis.com 6 7 5 3 4 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS 1 USB-A Circular Cable Mounted Receptacle to USB-A Plug Cable Assembly TABLE A (L) LENGTH PART NUMBER F F TOLERANCE MM (IN) ±30 (1.2) ±50 (2.0) ±100 (3.94) ±150 (5.90) ±250 (9.84) METERS (FEET) IPUSB-2WJAPA-05M IPUSB-2WJAPA-1M IPUSB-2WJAPA-2M IPUSB-2WJAPA-3M IPUSB-2WJAPA-5M DRAW APPD DATE KC PK 11/14/16 KC PK 2/13/17 0.50 (1.6) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) 25.4 (HEX) Connector series: USB 1.00" Gender: Female to Male PIN 4 Part No.: IPUSB-*WJAPA-#M 29.3 1.15" E (REF) *refers to use version (2.0 or 3.0) # refers to cable length D 50.9 ±0.50 2.00" ±.020 LENGTH D ±.15 O 5.5 .22" ±.01 NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS: 7.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK NUT: NYLON, BLACK CONN.1: USB-A JACK, GOLD PLATED CONN.2: USB-B PLUG, GOLD PLATED GASKET: SILICONE, GRAY 5. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. 3 O 20.6 .813" -20°C ~ +80°C GASKET NUT ±0.1 O 20.8 .819" ±.004 Terminal: SCHEMATIC Copper alloy, goldP1 plated Screw nut: 19.4 ±0.1 .764" ±.004 Mating style: RED WHITE GREEN BLACK 1 2 3 4 SHELL Nylon + GF Screw thread A COLOR: BLACK P2 1 2 3 4 SHELL ≤ 30MΩ Protection class: IP67 (unmated) Durability: 1000 times A CurrentKCHODrating: CA, USB A W PNL / A STD XM 5 6 2A589 SIZE 4 5 SCALE A DRAWN: DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/14/16 ENGINEER: D.KAPLACHINSKI P.KIM 11/14/16 APPROVED BY SHEET 1 OF 1 NTS VER A DATE 11/14/16 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 3 3 4 B 1.5A A REV Voltage rating: THIRD ANGLE PROJECTION CAGE CODE: 6 7 48 hr. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 Salt spray: IPUSB-2WJAPA-XM PART NUMBER TITLE RECOMMENDED PANEL CUT-OUT Contact resistance: C Withstanding voltage: AC 500V/1 minute USB-A to USB-A B PIN 4 USB-A 2.0 PLUG 13/16"-28UN C Temperature range: PIN 1 19.2 .756" PIN 1 General Information Connector Type: E 59.7 ±0.50 2.35" ±.020 1 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS 30V 1 USB-A Metal Circular Cable Mounted Receptacle to USB-A Plug Cable Assembly TABLE A (L) LENGTH F PART NUMBER METERS (FEET) IPUSBM-2WJAPA-05M IPUSBM-2WJAPA-1M IPUSBM-2WJAPA-2M IPUSBM-2WJAPA-3M IPUSBM-2WJAPA-5M E 0.50 (1.6) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) (REF) D *refers to use version (2.0 or 3.0) # refers to cable length E 59.7 ±0.50 2.35" ±.020 D USB-A 2.0 PLUG 13/16"-28UN O 20.6 .813" NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) (CONN 1 ONLY) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS: 4.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: ZINC ALLOY, NICKEL PLATED SCREW NUT: ZINC ALLOY, NICKEL PLATED CONN1: USB-A JACK, GOLD PLATED CONN2: USB-A PLUG, GOLD PLATED GASKET: SILICONE, GRAY WASHER: STAINLESS STEEL 5. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm 6. ITEMS IDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. HOUSING Terminal: ±0.1 O 20.8 -20°C ~ +80°C .819" ±.004 NUT WASHER GASKET SCHEMATIC Copper alloy, gold P11plated RED Screw nut: 2 3 4 SHELL 19.4 alloy, ±0.1 Zinc nickel plated .764" ±.004 RECOMMENDED PANEL CUT-OUT Screw Contact resistance: thread ≤ 30MΩ WHITE GREEN BLACK P2 1 2 3 4 SHELL 6 Salt spray: 48 hr. Protection class: IP67 (unmated) Durability: 1000 times IPUSBM-2WJAPA-XM PART NUMBER Current KCHOD rating: D.KAPLACHINSKI CA, USB A W PNL MTL / A STD XM TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY THIRD ANGLE PROJECTION NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 C Withstanding voltage: AC 500V/1 minute USB-A to USB-A B PIN 4 3 C Temperature range: PIN 1 O 5.5 ±.15 .22" ±.01 PIN 1 General Information Connector Type: 50.9 ±0.50 2.00" ±.020 LENGTH 19.2 .756" USB-A 2.0 JACK Mating style: F 25.4 1.00" (HEX) Connector series: USB Gender: Female to Male PIN 4 29.3 Part No.: IPUSBM-*WJAPA-#M 1.15" A DRAW APPD DATE KC PK 11/1/16 KC PK 2/13/17 TOLERANCE MM (IN) ±30 (1.2) ±50 (2.0) ±100 (3.94) ±150 (5.90) ±250 (9.84) CAGE CODE: 5 4 2A589 SIZE SCALE A 3 NTS REV DRAWN: DATE 2180 Hornig Road, Philadelphia, PA 19116 ENGINEER: DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. APPROVED BY 11/1/2016 P.KIM DATE 11/1/2016 Voltage rating: SHEET 1 OF 1 VER A 1.5A A 11/1/2016 A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 B 1 30V Notes • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. 11 USB Cable Mounted Receptacle Assemblies www.peigenesis.com 6 7 5 3 4 2 TABLE A (L) LENGTH 6 7 F 1 REVISIONS PART NUMBER 5 TOLERANCE MM (IN) 6 (L) LENGTH ±50 (2.0) 1.00 (3.28) 2.00 (6.56) ±100 (3.94) TOLERANCE METERS (FEET) 5.00(L) (16.4) ±250 LENGTH MM(9.84) (IN) TABLE A REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE;2 ADD OVERMOLD TOLS; ADD CABLE DIA TOL 3 4 DRAW APPD DATE KC PK 11/1/16 2/13/17 1 KC PK REVISIONS F REV ZONE ECO# DESCRIPTION DRAW APPD DATE KC PK 11/1/16 2 INITIAL RELEASE 1 A ADDED RoHS REVISIONS NOTE; ADD OVERMOLD TOLS; ADD CABLE DIA TOL KC PK 2/13/17 REV ZONE ECO# DESCRIPTION DRAW APPD DATE F INITIAL RELEASE KC PK 11/14/16 A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS KC PK 2/13/17 METERS (FEET) USB-A Circular Cable Mounted Receptacle to USB-B Plug Cable Assembly 7 IPUSBM-2WPAPB-1M TABLE A PART NUMBER IPUSBM-2WPAPB-2M F IPUSBM-2WPAPB-5M F PART NUMBER IPUSBM-2WPAPB-1M 1.00 (3.28) (FEET) IPUSBM-2WPAPB-2M METERS2.00 (6.56) IPUSBM-2WPAPB-5M 5.00 (16.4) IPUSB-2WJAPA-05M 0.50 (1.6) IPUSB-2WJAPA-1M 1.00 (3.28) E IPUSB-2WJAPA-2M 2.00 (6.56) IPUSB-2WJAPA-3M 3.00 (9.84) IPUSB-2WJAPA-5M 5.00 (16.4) 5 ±50 (2.0) TOLERANCE MM±100 (IN) (3.94) ±250 (9.84) ±30 (1.2) ±50 (2.0) ±100 (3.94) ±150 (5.90) ±250 (9.84) F E E Connector series: USB Gender: Female to Male PIN 1 O 27.2 1.07" PIN 4 Part No.: IPUSB-*WJAPB-#M 29.3 PIN 1 E 25.4 (HEX) O 27.2 1.07" 1.00" D D D C 13/16"-28UN 52.0 ±0.50 2.05" ±.020 LENGTH 52.0 ±0.50 59.7 ±0.50 2.05" ±.0202.35" ±.020 LENGTHLENGTH PIN 4 O 5.5 ±.15 .22" ±.01 13/16"-28UN C 3 O 20.6 .813" USB-A to USB-B GASKET NUT P1 1 2 3 P1 P1 1 41 2 2SHELL 33 44 SHELL SHELL ±0.1~ +80°C -20°C O 20.8 .819" ±.004 Terminal: Copper alloy, gold plated Screw nut: A Mating style: A Nylon 19.4 ±0.1 + GF .764" ±.004 NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. RECOMMENDED PANELScrew CUT-OUT 7 Contact resistance: 7 SCHEMATIC SCHEMATIC 6 ≤ 30MΩ 7 6 P2 RED WHITE GREEN BLACK RED RED WHITE WHITE GREEN GREEN BLACK BLACK thread NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. PIN 4 PIN 1USB-B 2.0 PLUGPIN 4 USB-A 2.0 PLUG Protection class: THIRD ANGLE PROJECTION PART NUMBER TABLE A APPROVED BY DATE TITLE SIZE 2A589 6 TOLERANCE METERS (FEET) MM (IN) 6 (L) LENGTH ±50 (2.0) 1.00 (3.28) 2.00 (6.56) ±100 (3.94) TOLERANCE METERS (FEET) 5.00(L) (16.4) ±250 (9.84) LENGTH MM (IN) 1.00 (3.28) ±50 (2.0) TOLERANCE METERS2.00 (FEET) (6.56) MM±100 (IN) (3.94) 5.00 (16.4) ±250 (9.84) 0.50 (1.6) ±30 (1.2) 1.00 (3.28) ±50 (2.0) 2.00 (6.56) ±100 (3.94) 3.00 (9.84) ±150 (5.90) 5.00 (16.4) ±250 (9.84) B SCALE VER 11/1/2016 ©COPYRIGHT 2004 PEI-GENESIS REV ENGINEERING PRODUCT DEVELOPMENT DRAWN: 2A589 CAGE CODE: SIZE A 2A589NTS SCALE ASHEET 1NTS OF 1 SHEET A 1 OF 1 SCALE SIZE VER A© COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 5 4 3 5 4 3 A 1.5A 11/1/2016 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL THIS DRAWING PEI-Genesis, ALL REPRODUCTION BY ANY MEANS DATE IS THE PROPERTY OFRIGHTS RESERVED. DATE RIGHTS 11/1/2016 RESERVED. REPRODUCTION OR BY DISTRIBUTION ANY MEANS TO THIRD PARTIES IS S TRICTLY OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF ©COPYRIGHT 2004 PEI-GENESIS OF ENGINEERING PRODUCT DEVELOPMENT PROHIBITED WITHOUT THE WRITTEN PERMISSION AN AUTHORIZED AGENT OF PEI-GENESIS. APPROVED BY VER A DATE DATE Voltage rating: 3 3 REV A 2180 Hornig Road, Philadelphia, PA 19116 11/1/2016 1 2180 Hornig Road, Philadelphia, PA NOTICE 19116 OF CONFIDENTIALITY DATE DATE ENGINEER: B 1000 times NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN A PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/1/2016 Current rating: APPROVED BY 6 7 DATE DATE CA, USB AP MTL / B STD XM A CA, USB A WA PNL /NTS A STD SHEET XM 1 OF 1 A 2 KCHOD 11/14/16 KCHOD 11/14/16 D.KAPLACHINSKID.KAPLACHINSKI THIRD ANGLE PROJECTION P.KIM THIRD ANGLE PROJECTION 11/14/16 P.KIM CAGE CODE: TITLE CAGE CODE: (L) LENGTH PART NUMBER DRAWN: ENGINEER: D.KAPLACHINSKI Durability: IPUSBM-2WPAPB-XM P.KIM IPUSB-2WJAPA-XM UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM DRAWN: 3EXCEPT UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE AS IN MM TOLERANCE NOTED: TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v ENGINEER: DECIMAL .X ±0.25 .XX ±0.1 ±0.05 ANGLES v IMPERIAL.XXXDIMENSIONS ARE FOR±1REFERENCE ONLY IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 4 4 C IP67 (unmated) REV TITLE 4 5 5 C 48 hr. PART NUMBER DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY PART NUMBER AN AUTHORIZED AGENT OF PEI-GENESIS. 2 1 30V 1 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE;2 ADD OVERMOLD TOLS; ADD CABLE DIA TOL TABLE A F PIN 4D PIN 3 Salt spray: 1 2 P2 P2 3 1 41 2 2 SHELL 3 3 4 4 SHELL SHELL 5 6 7 PIN 1 PIN 2 Withstanding voltage: AC 500V/1 minute SCHEMATIC COLOR: BLACK Temperature range: A PIN 3 NOTES: USB-B 2.0 PLUG NOTES: RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF C RATE: IP67 (NOWITHIN INGRESS30 OF DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF EFFECT CAUSED IN 1 METER WATER MINUTES) EFFECT CAUSED IN v1CMETER WITHIN 30 MINUTES) (CONN. 1 ONLY) TO +80WATER vC RANGE: -20 2. TEMPERATURE NOTES: v C TO +80 v C TEMPERATURE RANGE: -20 2. 3. MAX PANEL THICKNESS: 7.0mm (WITHOUT CAP CHAIN) RATE:NUT: IP67 (NOALLOY, INGRESS OF DUST/PROTECTED HARMFUL MATERIAL: ZINC NICKEL PLATED CONN.1:AGAINST USB-A PLUG, GOLD 3.1. WATERPROOF HOUSING:SCREW NYLON, BLACK 4. MATERIAL: EFFECT CAUSED IN USB-B 1 METERPLUG, WATER (CONN. 1 ONLY) PLATED CONN.2:BLACK GOLDWITHIN PLATED30 MINUTES) CASKET: SILICONE, GRAY NUT: NYLON, vC TO +80vC RANGE: -20 2.4. TEMPERATURE CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, CONN.1: USB-A JACK, GOLD PLATED SCREW NUT: ZINC ALLOY, NICKEL PLATED CONN.1: USB-A PLUG, GOLD 3. MATERIAL: BLACK, OD=5.5mm CONN.2: USB-B PLUG, GOLD CONN.2: USB-BDIAMOND PLUG,PLATED GOLD SILICONE, GRAYB 1 ) MUST CASKET: ITEMS IDENTIFIED WITH ( X ...PLATED BE INSPECTED. 5. PLATED GASKET: SILICONE, UL2725 USB2.0GRAY 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, 4. CABLE: REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 6. UL2725OD=5.5mm USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 5. CABLE: BLACK, COMPLIANT. 7. RoHSBLACK, RESISTANT, OD=5.5mm ( X ... 1 ) MUST BE INSPECTED. 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. ITEMS IDENTIFIED WITH DIAMOND IPUSBM-2WPAPB-XM PACKAGING SPECIFICATIONS PER DOC# APKG-001 6. REFERENCE CA, USB AP MTL / BSPECIFICATIONS STD XM PACKAGING PER DOC# PKG-001 7. REFERENCE OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM 2180 Hornig Road, Philadelphia, PA 19116 COMPLIANT. 7. UNLESSRoHS 11/1/2016 KCHOD EXCEPT AS NOTED: COMPLIANT. 8. RoHSTOLERANCE B B D PIN 1 PIN 2 D O 5.5 ±.15 5.5 ±.15 .22" O ±.01 .22" ±.01 C B E 50.0 ±0.50 ±0.50 50.9 2.00" 1.97" ±.020 ±.020 PIN 1 PIN 4 13/16"-28UN General Information Connector Type: E 50.0 ±0.50 1.97" ±.020 19.2 .756" 1.15" (REF)(2.0 or 3.0) *refers to use version # refers to cable length 3 4 1 DRAW APPD DATE KC PK 11/1/16 2/13/17 1 KC PK REVISIONS F REV ZONE ECO# DESCRIPTION DRAW APPD DATE KC PK 11/1/16 2 INITIAL RELEASE 1 A ADDED RoHS REVISIONS NOTE; ADD OVERMOLD TOLS; ADD CABLE DIA TOL KC PK 2/13/17 REV ZONE ECO# DESCRIPTION DRAW APPD DATE F INITIAL RELEASE KC PK 11/14/16 A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS KC PK 2/13/17 USB-A Metal Circular Cable Mounted Receptacle to USB-B Plug Cable Assembly 7 IPUSBM-2WPAPB-1M TABLE A PART NUMBER IPUSBM-2WPAPB-2M F IPUSBM-2WPAPB-5M F PART NUMBER IPUSBM-2WPAPB-1M IPUSBM-2WPAPB-2M IPUSBM-2WPAPB-5M IPUSB-2WJAPA-05M IPUSB-2WJAPA-1M E IPUSB-2WJAPA-2M IPUSB-2WJAPA-3M IPUSB-2WJAPA-5M E 25.4 (HEX) Connector series: USB O 27.2 1.07" 1.00" Gender: Female to OMale PIN 1 27.2 1.07" PIN 4 Part No.: IPUSBM-*WJAPB-#M 29.3 PIN 1 E D D C 13/16"-28UN E 52.0 ±0.50 2.05" ±.020 LENGTH 52.0 ±0.50 59.7 ±0.50 2.05" ±.0202.35" ±.020 LENGTHLENGTH PIN 4 13/16"-28UN 3 O 20.6 .813" -20°C ~ +80°C O 20.8 ±0.1 Terminal: Copper alloy, gold plated REDBLACK RED A Screw nut: Mating style: A A RED WHITE SCHEMATIC SCHEMATIC GREEN Zinc 19.4 alloy, nickel plated ±0.1 .764" ±.004 NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. RECOMMENDEDScrew PANEL CUT-OUT thread 6 7 Contact resistance: 7 7 WHITE WHITE GREEN GREEN BLACK BLACK P2 ≤ 30MΩ 6 PIN 4D PIN 3 5 NOTES: USB-B 2.0 PLUG NOTES: RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF C RATE: IP67 (NOWITHIN INGRESS30 OF DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF EFFECT CAUSED IN 1 METER WATER MINUTES) EFFECT CAUSED IN v1CMETER WITHIN 30 MINUTES) (CONN. 1 ONLY) TO +80WATER vC RANGE: -20 2. TEMPERATURE NOTES: vC TO +80 TEMPERATURE 2. PANEL THICKNESS:RANGE: 7.0mm-20 (WITHOUT CAPvCCHAIN) 3. MAX RATE:NUT: IP67 (NOALLOY, INGRESS OF DUST/PROTECTED HARMFUL MATERIAL: ZINC NICKEL PLATED CONN.1:AGAINST USB-A PLUG, GOLD 3.1. WATERPROOF HOUSING:SCREW NYLON, BLACK 4. MATERIAL: EFFECT CAUSED IN USB-B 1 METERPLUG, WATER (CONN. 1 ONLY) PLATED CONN.2:BLACK GOLDWITHIN PLATED30 MINUTES) CASKET: SILICONE, GRAY NUT: NYLON, v C TO +80 v C RANGE: -20 2.4. TEMPERATURE CABLE: UL2725 USB2.0 PVC JACKET, UV RESISTANT, CONN.1: USB-A JACK,28AWG*1P+24AWG*2C+AI+D+B, GOLD PLATED SCREW NUT: ZINC ALLOY, NICKEL PLATED CONN.1: USB-A PLUG, GOLD 3. MATERIAL: BLACK, OD=5.5mm CONN.2: USB-B PLUG, GOLD CONN.2: USB-BDIAMOND PLUG,PLATED GOLD SILICONE, GRAYB 1 ) MUST CASKET: ITEMS IDENTIFIED WITH ( X ...PLATED BE INSPECTED. 5. PLATED GASKET: SILICONE, UL2725 USB2.0GRAY 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, 4.6. CABLE: PACKAGING SPECIFICATIONS PER DOC# PKG-001 UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 5. CABLE: REFERENCE BLACK, OD=5.5mm COMPLIANT. 7. RoHSBLACK, RESISTANT, OD=5.5mm ( X ... 1 ) MUST BE INSPECTED. 5. ITEMS IDENTIFIED WITH DIAMOND 1 X ( ... ) MUST BE INSPECTED. 6. ITEMS IDENTIFIED WITH DIAMOND IPUSBM-2WPAPB-XM PACKAGING SPECIFICATIONS PER DOC# APKG-001 6. REFERENCE CA, USB AP MTL / BSPECIFICATIONS STD XM PACKAGING PER DOC# PKG-001 7. REFERENCE OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM 2180 Hornig Road, Philadelphia, PA 19116 COMPLIANT. 7. UNLESSRoHS 11/1/2016 KCHOD EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v COMPLIANT. 8. RoHSTOLERANCE NOTICE OF CONFIDENTIALITY 11/1/2016 D.KAPLACHINSKI IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS IPUSBM-2WPAPB-XM 11/1/2016 P.KIM OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY IPUSB-2WJAPA-XM Salt spray: 1 2 P2 P2 3 1 41 2 2 SHELL 3 3 4 4 SHELL SHELL 48 hr. Protection class: 5 5 REV TITLE Durability: PART NUMBER DRAWN: DATE ENGINEER: DATE APPROVED BY THIRD ANGLE PROJECTION PART NUMBER 4 C B 2A589 TITLE SIZE SCALE VER ©COPYRIGHT 2004 PEI-GENESIS REV ENGINEERING PRODUCT DEVELOPMENT Current rating: DRAWN: DATE ENGINEER: 2A589 CAGE CODE: SIZE A 2A589NTS SIZE ASHEET 1NTS OF 1 SHEET A 1 OF 1 SCALE APPROVED BY VER A© Voltage rating: SCALE 3 VER 3 COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 2 B REV A 1000 times DATE CA, USB AP MTL / B STD XM A CA, USB A WA PNL /NTS A STD SHEET XM 1 OF 1 A 2 KCHOD 11/14/16 KCHOD 11/14/16 D.KAPLACHINSKID.KAPLACHINSKI THIRD ANGLE PROJECTION P.KIM 11/14/16 THIRD ANGLE PROJECTION P.KIM CAGE CODE: TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM DRAWN: 3EXCEPT UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE AS IN MM TOLERANCE NOTED: TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v ENGINEER: DECIMAL .X ±0.25 .XX ±0.1 ±0.05 ANGLES v IMPERIAL.XXXDIMENSIONS ARE FOR±1REFERENCE ONLY IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 4 4 C IP67 (unmated) PART NUMBER CAGE CODE: 6 PIN 1 PIN 2 PIN 4 PIN 1USB-B 2.0 PLUGPIN 4 USB-A 2.0 PLUG APPROVED BY NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. PIN 3 Withstanding voltage: AC 500V/1 minute SCHEMATIC COLOR: BLACK GASKET NUT P1 1 2 3 P1 P1 1 41 2 2SHELL 33 44 SHELL SHELL Temperature range: .819" ±.004 D PIN 1 PIN 2 D USB-A to USB-B B E 50.9 50.0 ±0.50 ±0.50 2.00" 1.97" ±.020 ±.020 O 5.5 ±.15 .22" ±.01 C B E 50.0 ±0.50 1.97" ±.020 O 5.5 ±.15 5.5 ±.15 .22" O ±.01 .22" ±.01 13/16"-28UN General Information B F PIN 1 PIN 4 C Connector Type: 3 4 19.2 .756" 1.15" D (REF) or 3.0) *refers to use version (2.0 # refers to cable length 5 A PROHIBITED WITHOUT THE WRITTEN A PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. A 1.5A DATE 2180 Hornig Road, Philadelphia, PA 19116 11/1/2016 1 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY DATE 11/1/2016 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL THIS DRAWING PEI-Genesis, ALL REPRODUCTION BY ANY MEANS DATE IS THE PROPERTY OFRIGHTS RESERVED. DATE RIGHTS 11/1/2016 RESERVED. REPRODUCTION OR BY DISTRIBUTION ANY MEANS TO THIRD PARTIES IS S TRICTLY OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF ©COPYRIGHT 2004 PEI-GENESIS OF ENGINEERING PRODUCT DEVELOPMENT PROHIBITED WITHOUT THE WRITTEN PERMISSION AN AUTHORIZED AGENT OF PEI-GENESIS. AN AUTHORIZED AGENT OF PEI-GENESIS. 1 30V 1 Notes 12 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. USB Cable Mounted Plug Assemblies www.peigenesis.com 1 2 3 7 6 4 5 5 6 4 7 3 2 REVISIONS A EZONE LBATECO# DESCRIPTION REV INITIAL RELEASE A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS 1 USB-A Circular Cable Mounted Receptacle to Circular Cable Mounted USB-A Plug Cable Assembly SNOISIVER NOITPIRCSED5 #OCETABLE ENOZ A VER ESAELER LAITINI SLOT AID ELBAC DEDDA ;SLOT DLOMREVO DEDDA ;ETON SHoR DEDDA A ETAD DPPA WARD 61/41/11 KP CK 71/31/21 KP CK 7 TABLE A 6 F IPUSB-2WJAPA-05M IPUSB-2WJAPA-1M IPUSB-2WJAPA-2M IPUSB-2WJAPA-3M IPUSB-2WJAPA-5M 0.50 (1.6) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) IPUSB-2WPAWPB-1M IPUSB-2WPAWPB-2M IPUSB-2WPAWPB-5M 1.00 (3.28) 2.00 (6.56) 5.00 (16.4) 1 REVISIONS HTG NEL )L( REV ZONE ECO# DESCRIPTION INITIAL RELEASE ECNARELOT A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS TOLERANCE MM (IN) ±50 (2.0) ±100 (3.94) ±250 (9.84) METERS (FEET) TOLERANCE MM (IN) ±30 (1.2) ±50 (2.0) ±100 (3.94) ±150 (5.90) ±250 (9.84) METERS (FEET) 2 (L) LENGTH PART NUMBER F (L) LENGTH PART NUMBER F 3 4 DRAW APPD DATE KC PK 11/14/16 KC )TPKEEF ( 2/13/17 SRETEM )NI( MM )0.2( 05± )49.3( 001± )48.9( 052± )82.3( 00.1 )65.6( 00.2 )4.61( 00.5 D 059.7 5.0±27.2 0.25 ±0.50 2.35" 02O 0.± 1.07" "5±.020 0.2 19.2 .756" Connector Type: B B Terminal: Mating style: 3 C :SETON O 20.6 .813" LUFMRAH TSNIAGA DETCETORP/TSUD FO SSERGNI ON( 76PI :ETAR FOORPRETAW .1 )SETUNIM 03 NIHTIW RETAW RETEM 1 NI DESUAC TCEFFE Cv08+ OT Cv02- :EGNAR ERUTAREPMET .2 KCALB ,NOLYN :TUN WERCS :LAIRETAM .3 COLOR: BLACK DETALP DLOG ,GULP A-BSU :1.NNOC GASKET DETALP DLOG ,GULP NUT B-BSU :2.NNOC B ±0.1 O 20.8 Y A R G , E N O C I L I S : T E K S A G .819" ±.004 SCHEMATIC ,TNATSISER VU ,TEKCAJ CVP ,B+D+IA+C2*GWA42+P1*GWA82 P10.2BSU 5272LU :ELBAC .4 P2 mm5.5=DORED,KCALB 1 1 .DETCEPSNI EB TSUM ) 1 ... X ( DNOMAID HT2IW DEIFITNEDWHITE I SMETI .5 2 100-GKP #COD REP SNOITACIFICEPS G3NIGAKCAP ECNGREEN EREFER .6 3 BLACK 4 .TNAILPMOC SHoR .7 4 19.4 ±0.1 SHELL SHELL .764" ±.004 MX-BPWAPW2-A BSUPI -20°C ~ +80°C A Screw thread A Contact resistance: NOTE: CAD GENERATED DRAWING DO NOT 7 ≤ 30MΩ YTILAITNEDIFNOC FO ECITON LLA ,sMANUALLY. iseneG-IEP FO YTREPORP EHT SI GNIWARD SIHT UPDATE SNAEM YNA YB NOITCUDORPER .DEVRESER STHGIR YLTCIRT S SI SEITRAP DRIHT OT NOITUBIRTSID RO FO NOISSIMREP NETTIRW EHT TUOHTIW DETIBIHORP .SISENEG-IEP FO TNEGA DEZIROHTUA NA MX W PB / W PA BSU ,AC DOHCK IKSNIHCALPAK.D MIK.P ETAD 61/41/11 ETAD 61/41/11 ETAD 6 61/41/11 :RE ENIGNE YB DEVORPPA A SISENEG-IEP 4002 THGIRYPOC© TNEMPOLEVED TCUDORP GNIREENIGNE 1 CAGE CODE: NOITCEJORP ELGNA DRIHT 5 7 2 D USB-B 2.0 PLUG C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MATERIAL: SCREW NUT: NYLON, BLACK CONN.1: USB-A PLUG, GOLD PLATED CONN.2: USB-B PLUG, GOLD PLATED B GASKET: SILICONE, GRAY 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. IPUSB-2WPAWPB-XM A IP67 (unmated) LLSHELL EHS D.KAPLACHINSKI P.KIM ENGINEER: Voltage rating: APPROVED BY THIRD ANGLE PROJECTION SIZE SCALE A NTS SHEET 1 OF 1 VER A 6 REV DATE DATE 11/14/16 DATE 11/14/16 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 3 2180 Hornig Road, Philadelphia, PA 19116 4 SHELL 1.5A 4 5 CAGE CODE: CA, USB AP W / BP W XM APPROVED BY KCHOD D.KAPLACHINSKI P.KIM A 3 A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/14/16 11/14/16 DATE 11/14/16 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 7 3 6 4 REV DRAWN: ENGINEER: THIRD ANGLE PROJECTION .Y2A589 LLAUNAM ETSIZE ADPUATON SCALE OD GNTS NIWARD DESHEET TARENEG1DOF AC :E1TONVER 2 7 SNOISIVER TABLE A NOITPIRCSED5 #OCETABLE ENOZ A VER ESAELER LAITINI SLOT AID ELBAC DEDDA ;SLOT DLOMREVO DEDDA ;ETON SHoR DEDDA A F F 6 IPUSB-2WJAPA-05M IPUSB-2WJAPA-1M IPUSB-2WJAPA-2M IPUSB-2WJAPA-3M IPUSB-2WJAPA-5M 0.50 (1.6) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) IPUSB-2WPAWPB-1M IPUSB-2WPAWPB-2M IPUSB-2WPAWPB-5M 1.00 (3.28) 2.00 (6.56) 5.00 (16.4) 1 REVISIONS HTG NEL )L( REV ZONE ECO# DESCRIPTION INITIAL RELEASE ECNARELOT A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS TOLERANCE MM (IN) ±50 (2.0) ±100 (3.94) ±250 (9.84) METERS (FEET) TOLERANCE MM (IN) ±30 (1.2) ±50 (2.0) ±100 (3.94) ±150 (5.90) ±250 (9.84) METERS (FEET) 2 (L) LENGTH PART NUMBER F (L) LENGTH PART NUMBER 3 4 DRAW APPD DATE KC PK 11/14/16 KC )TPKEEF ( 2/13/17 SRETEM 2 REVISIONS A EZONE LBATECO# DESCRIPTION REV INITIAL RELEASE A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS )NI( MM )0.2( 05± )49.3( 001± )48.9( 052± )82.3( 00.1 )65.6( 00.2 )4.61( 00.5 (REF) *refers to use version (2.0 or 3.0)2 NIP # refers to cable length General Information C C Connector Type: 05.0±0.50 ±±0.50 0.25 50.9 52.0 2.00" 02.05" 20.±±.020 "50.2 ±.020 HLENGTH TGNEL B B Terminal: C :SETON O 20.6 .813" LUFMRAH TSNIAGA DETCETORP/TSUD FO SSERGNI ON( 76PI :ETAR FOORPRETAW .1 )SETUNIM 03 NIHTIW RETAW RETEM 1 NI DESUAC TCEFFE Cv08+ OT Cv02- :EGNAR ERUTAREPMET .2 KCALB ,NOLYN :TUN WERCS :LAIRETAM .3 COLOR: BLACK DETALP DLOG ,GULP A-BSU :1.NNOC GASKET DETALP DLOG ,GULP NUT B-BSU :2.NNOC B 20.8 ±0.1 O .819" ±.004 YARG ,ENOCILIS :TEKSAG SCHEMATIC ,TNATSISER VU ,TEKCAJ CVP ,B+D+IA+C2*GWA42+P1*GWA82 P10.2BSU 5272LU :ELBAC .4 P2 mm5.5=DORED,KCALB 1 1 .DETCEPSNI EB TSUM ) 1 ... X ( DNOMAID HT2IW DEIFITNEDWHITE I SMETI .5 2 100-GKP #COD REP SNOITACIFICEPS G3NIGAKCAP ECNGREEN EREFER .6 3 BLACK 4 .TNAILPMOC SHoR .7 4 19.4 ±0.1 SHELL SHELL .764" ±.004 MX-BPWAPW2-A BSUPI A Screw thread A Contact resistance: ≤ 30MΩ ETAD 61/41/11 YTILAITNEDIFNOC FO ECITON ETAD 61/41/11 LLA ,sMANUALLY. iseneG-IEP FO YTREPORP EHT SI GNIWARD SIHT NOTE: CAD GENERATED DRAWING DO NOT UPDATE 7 SNAEM YNA YB NOITCUDORPER .DEVRESER STHGIR YLTCIRT S SI SEITRAP DRIHT OT NOITUBIRTSID RO FO NOISSIMREP NETTIRW EHT TUOHTIW DETIBIHORP .SISENEG-IEP FO TNEGA DEZIROHTUA NA 1 MX W PB / W PA BSU ,AC VER 6 ETAD 61/41/11 DOHCK IKSNIHCALPAK.D MIK.P :RE ENIGNE YB DEVORPPA A SISENEG-IEP 4002 THGIRYPOC© TNEMPOLEVED TCUDORP GNIREENIGNE 2 ELTIT MM NI ERA SNOISNEMID ,DEIFICEPS ESIWREHTO SSELNU :DETON SA TPECXE ECNARELOT v1± SELGNA 50.0± XXX. 1.0± XX. 52.0± X. LAMICED YLNO ECNEREFER ROF ERA SNOISNEMID LAIREPMI :NWARD 5 NOITCEJORP ELGNA DRIHT 2P 1 2 3 4 LLEHS CAGE CODE: 2A589 4 7 3 PIN 3 PIN 2 D 4 NIP USB-A 2.0 PLUG USB-B 2.0 PLUG C C C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MATERIAL: SCREW NUT: NYLON, BLACK CONN.1: USB-A PLUG, GOLD PLATED CONN.2: USB-B PLUG, GOLD PLATED B GASKET: SILICONE, GRAY 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. IPUSB-2WPAWPB-XM A Salt spray: 48 hr. Protection class: IP67 (unmated) Durability: ETIHW 22 IPUSB-2WJAPA-XM NEERG 33 UNLESS OTHERWISE SPECIFIED, KCADIMENSIONS LB ARE IN MM KCHOD TOLERANCE EXCEPT AS NOTED: PART NUMBER DRAWN: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY LLSHELL EHS D.KAPLACHINSKI P.KIM A SCALE NTS SHEET 1 OF 1 VER 6 4 REV DATE ENGINEER: DATE APPROVED BY DATE Voltage rating: THIRD ANGLE PROJECTION SIZE WHITE GREEN A BLACK 11/14/16 Current rating: 44 CA, USB A W PNL / A STD XM TITLE A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 11/14/16 11/14/16 55 B B 1000 times 2 3 2180 Hornig Road, Philadelphia, PA 19116 4 SHELL 1.5A NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 2 3 :EDOC EGAC ELACS EZIS NOTE: MANUALLY. STN DO NOTAUPDATE 1 FCAD O 1GENERATED TEEHS DRAWING 985A2 REV PIN 1 Withstanding voltage: AC 500V/1 minute -20°C ~ +80°C REBMUN TRAP PIN 4 D ±.15 O 5.5 .22"PIN±.01 4 NU82-"61/31 NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS: 7.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK NUT: NYLON, BLACK CONN.1: USB-A JACK, GOLD PLATED CONN.2: USB-B PLUG, GOLD PLATED GASKET: SILICONE, GRAY 5. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm X ITEMS ... 1 ) MUST BE INSPECTED. 6.CIT AMEIDENTIFIED HCS WITH DIAMOND (SCHEMATIC PSPECIFICATIONS PER DOC# PKG-001 P2 7. REFERENCE PACKAGING1P1 R RED 8. RoHSDECOMPLIANT. 11 1 3 RECOMMENDED 61PANEL CUT-OUT 191 AP ,aihpledalihP ,daoR ginroH 0812 E O 27.2 1.07" 1 NIP D 51.± 5.5 O 5.5 ±.15 10.± "22. O .22" ±.01 13/16"-28UN PIN 4 Zinc alloy, nickel plated A PIN 1 D Copper alloy, gold plated Screw nut: F 52.0 2.72±0.50 O 2.05" "70.1 ±.020 LENGTH PIN 1 USB-A to USB-A Temperature range: Mating style: 059.7 5.0±27.2 0.25 ±0.50 2.35" 02O 0.± 1.07" "5±.020 0.2 13/16"-28UN GULP 0.2 B-BSU F E 3 NIP PIN 1 DRAW APPD DATE KC PK 11/14/16 KC PK 12/13/17 E E D 1 M1-BPWAPW2-BSUPI M2-BPWAPW2-BSUPI M5-BPWAPW2-BSUPI E E .72 (HEX) 70.1 O Connector series: USB "225.4 1.00" Gender: Female to Male PIN 4 4 NIP 1 NIP 19.2 Part No.: IPUSBM-*WJAWPA-#M 29.3 .756" 1.15" D F REBMUN TRAP A 1 USB-A Metal Circular Cable Mounted Receptacle to Metal Circular USB-A Plug Cable Assembly ETAD DPPA WARD 61/41/11 KP CK 71/31/21 KP CK 7 B PART NUMBER TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 30V 1 6 4 5 A NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 2 55 4 B 1000 times WHITE GREEN A BLACK 11/14/16 Current44rating: 3 3 Protection class: DRAWN: 2A589 6 48 hr. DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 4 3 7 PIN 2 C C Salt spray: ETIHW 22 IPUSB-2WJAPA-XM NEERG CA, USB A W PNL / A STD XM 33 UNLESS OTHERWISE SPECIFIED, KCADIMENSIONS LB ARE IN MM KCHOD TOLERANCE EXCEPT AS NOTED: PART NUMBER TITLE :EDOC EGAC ELACS EZIS NOTE: MANUALLY. STN DO NOTAUPDATE 1 FCAD O 1GENERATED TEEHS DRAWING 985A2 REV 2 1 ELTIT MM NI ERA SNOISNEMID ,DEIFICEPS ESIWREHTO SSELNU :DETON SA TPECXE ECNARELOT v1± SELGNA 50.0± XXX. 1.0± XX. 52.0± X. LAMICED YLNO ECNEREFER ROF ERA SNOISNEMID LAIREPMI :NWARD PIN 3 USB-A 2.0 PLUG Durability: 2P 1 2 3 4 LLEHS REBMUN TRAP VER RECOMMENDED 61PANEL CUT-OUT 191 AP ,aihpledalihP ,daoR ginroH 0812 PIN 1 Withstanding voltage: AC 500V/1 minute Nylon + GF A PIN 4 D 4 NIP ±.15 O 5.5 .22"PIN±.01 4 NU82-"61/31 NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS: 7.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK NUT: NYLON, BLACK CONN.1: USB-A JACK, GOLD PLATED CONN.2: USB-B PLUG, GOLD PLATED GASKET: SILICONE, GRAY 5. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm X ITEMS ... 1 ) MUST BE INSPECTED. 6.CIT AMEIDENTIFIED HCS WITH DIAMOND (SCHEMATIC PSPECIFICATIONS PER DOC# PKG-001 P2 7. REFERENCE PACKAGING1P1 D E R RED 8. RoHS COMPLIANT. 11 1 Copper alloy, gold plated Screw nut: 1 NIP D USB-A to USB-A Temperature range: PIN 1 51.± 5.5 O 5.5 ±.15 10.± "22. O .22" ±.01 13/16"-28UN PIN 4 13/16"-28UN General Information C E O 27.2 1.07" 52.0 2.72±0.50 O 2.05" "70.1 ±.020 LENGTH D 3 NIP PIN 1 05.0±0.50 ±±0.50 0.25 50.9 52.0 2.00" 02.05" 20.±±.020 "50.2 ±.020 HLENGTH TGNEL PIN 1 4 NIP GULP 0.2 B-BSU C F M1-BPWAPW2-BSUPI M2-BPWAPW2-BSUPI M5-BPWAPW2-BSUPI E D or 3.0) 2 NIP DRAW APPD DATE KC PK 11/14/16 KC PK 12/13/17 F E E *refers to use version # refers to cable length F E E .72 Connector series: USB"225.4 (HEX) 70.1 O 1.00" Gender: Female to Male PIN 4 1 NIP Part No.: IPUSB-*WJAWPA-#M 29.3 1.15" (REF) (2.0 REBMUN TRAP 1 4 6 30V CAGE CODE: A PART NUMBER TITLE CA, USB AP W / BP W XM REV UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION .Y2A589 LLAUNAM ETSIZE ADPUATON SCALE OD GNTS NIWARD DESHEET TARENEG1DOF AC :E1TONVER 3 KCHOD D.KAPLACHINSKI P.KIM A 7 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/14/16 11/14/16 DATE 11/14/16 1 Notes • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. 13 A USB Cable Mounted Plug Assemblies www.peigenesis.com USB-A Circular Cable Mounted Receptacle to Circular Cable Mounted USB-B Plug Cable Assembly 6 7 TABLE A 7 3 2 REVISIONS REV 2ZONE ECO# DESCRIPTION 1 INITIAL RELEASE REVISIONS REV ZONE ECO# DESCRIPTION A DRAW ADDED APPD CABLE DATEDIA TOLS ADDED RoHS NOTE; ADDED OVERMOLD TOLS; 4 5 3 4 (L) LENGTH TABLE A F 5 6 PART NUMBER A F TOLERANCE (L) LENGTH METERS (FEET) MM (IN) PART NUMBER TOLERANCE IPUSB-2WPAWPB-1M ±50 (2.0) METERS (FEET)1.00 (3.28) MM (IN) IPUSB-2WPAWPB-2M 2.00 (6.56) ±100 (3.94) IPUSB-2WJAPA-05M 0.50 (1.6) ±30 (1.2) IPUSB-2WPAWPB-5M 5.00 (16.4) ±250 (9.84) IPUSB-2WJAPA-1M IPUSB-2WJAPA-2M IPUSB-2WJAPA-3M IPUSB-2WJAPA-5M 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) INITIAL RELEASE ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS KC KC PK PK 1 DRAW APPD DATE KC PK 11/14/16 KC PK 12/13/17 11/14/16 2/13/17 F F ±50 (2.0) ±100 (3.94) ±150 (5.90) ±250 (9.84) Connector series: USB 25.4 (HEX) 1.00" Gender: Female to Male O 27.2 1.07" Part No.: IPUSB-*WJAWPB-#M PIN 1 PIN 4 E E E 59.7±0.50 ±0.50 52.0 2.35"±.020 ±.020 2.05" 50.9 52.0±0.50 ±0.50 2.00" 2.05"±.020 ±.020 LENGTH LENGTH PIN 1 PIN 4 13/16"-28UN General Information Temperature range: Terminal: SCHEMATIC P1 1 2 3 4 SHELL Nylon19.4+±0.1GF .764" ±.004 A 2 3 4 SHELL A Mating style: RED WHITE P1 GREEN 1 BLACK RECOMMENDED PANEL CUT-OUT Screw thread P2 SCHEMATIC 1 2 RED 3 WHITE 4 GREEN SHELL BLACK P2 1 2 3 4 SHELL CAGE CODE: ≤ 30MΩ 5 5 66 55 Protection class: IP67 (unmated) 7. RoHS COMPLIANT. Durability: IPUSB-2WJAPA-XM 5 REV D.KAPLACHINSKI Current rating: P.KIM 2A589 SIZE SCALE A NTS APPROVED BY DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY SHEET THIRD 1 OFANGLE1 PROJECTIONA SCALE SIZE A NTS 2A589 VER ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT Voltage rating: 3 CAGE CODE: SHEET2 1 OF 1 VER 33 REV DATE 2180 Hornig Road, Philadelphia, PA 19116 11/14/16 DRAWN:DATE DATE DATE ENGINEER: DATE 11/14/16 APPROVED BY 1 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 22 A DATE A 3 30V PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 1 11 REVISIONS REVISIONS 2 1 REV ZONE ZONE ECO# ECO# DESCRIPTION DESCRIPTION DRAW APPD APPD DATE DATE REVISIONS REV DRAW INITIAL RELEASE RELEASE KCAPPD PK PK DATE 11/1/16 11/1/16 REV-- ZONE ECO# DESCRIPTION DRAWKC INITIAL ADDEDRELEASE RoHS NOTE; NOTE; ADDED ADDED OVERMOLD OVERMOLD TOLS; TOLS; ADDED ADDED CABLE CABLE DIA DIA TOLS TOLS KC KC KCPK PK PK11/14/162/13/17 2/13/17 -AA INITIAL ADDED RoHS A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS KC PK 2/13/17 FF F 3 4 1.5A A NOTICE OF CONFIDENTIALITY 11/14/16 IS THE PROPERTY OF PEI-Genesis, ALL 2180 Hornig Road, Philadelphia, PA 19116 KCHOD THISRIGHTSDRAWING RESERVED. REPRODUCTION BY ANY MEANS NOTICE OF CONFIDENTIALITY 11/14/16 11/14/16 IS S TRICTLY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL OR DISTRIBUTION TO THIRD PARTIES D.KAPLACHINSKI PROHIBITED WITHOUT THE WRITTEN PERMISSION OF RIGHTS RESERVED. REPRODUCTION BY ANY MEANS AN AUTHORIZED AGENT 11/14/16 OF PEI-GENESIS. P.KIM OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY CA, USB AP W KCHOD / BP W XM 4 A A IPUSB-2WPAWPB-XM PART NUMBER CA, USB A W PNL / A STD XM B 1000 times PART NUMBER TITLE 44 6 7 48 hr. DRAWN: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARETITLE IN MM TOLERANCE EXCEPT AS NOTED: ENGINEER: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 UNLESS ANGLES ±1v OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY TOLERANCE EXCEPT AS NOTED: 4 6 7 77 TABLE A A TABLE 6 NOTE:7CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. Salt spray: THIRD ANGLE PROJECTION NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. Contact resistance: C Withstanding voltage: AC 500V/1 minute COLOR: BLACK GASKET NUT Copper alloy, gold plated Screw nut: PIN 4 NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL C EFFECT CAUSED NOTES:IN 1 METER WATER WITHIN 30 MINUTES) +80vIP67 C (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL -20vC TORATE: 2. TEMPERATURE WATERPROOF 1. RANGE: 7.0mm (WITHOUT CAP CHAIN) 3. MAX PANEL THICKNESS: EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) NYLON, BLACK 4. MATERIAL: HOUSING: RANGE: -20vC TO +80vC 2. TEMPERATURE NUT: BLACK MATERIAL: SCREW NUT: NYLON, BLACK 3. NYLON, CONN.1: USB-A JACK, GOLD PLATEDPLUG, GOLD PLATED CONN.1: USB-A CONN.2: USB-B PLUG, GOLDUSB-B PLATEDPLUG, GOLD PLATED CONN.2: B GASKET: SILICONE,GASKET: GRAY SILICONE, GRAY 5. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, 4. RESISTANT, BLACK, OD=5.5mm BLACK, OD=5.5mm 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. O 20.6 .813" 20.8 +80°C ±0.1 -20°CO ~ .819" ±.004 B PIN 2 USB-B 2.0 PLUG USB-A to USB-B B D D USB-A 2.0 PLUG 3 C Connector Type: PIN 1 PIN 3 5.5±.15 ±.15 OO 5.5 .22"±.01 ±.01 .22" 13/16"-28UN C PIN 1 PIN 4 19.2 .756" 29.3 *refers to use versionD (2.0 1.15" D or 3.0) # refers to cable length (REF) O 27.2 1.07" E USB-B Circular Cable Mounted Receptacle to USB-A Plug Cable Assembly TABLE A FF EE (L) LENGTH LENGTH (L) (L) LENGTH TOLERANCE TOLERANCE MMTOLERANCE (IN) MM (IN) MM (IN) IPUSBM-2WJAPA-05M 0.50 (1.6) (1.6) ±30 (1.2) (1.2) IPUSBM-2WJAPA-05M 0.50 ±30 IPUSB-2WJAPA-05M 0.50 (1.6) ±30 (1.2) IPUSBM-2WJAPA-1M 1.00 (3.28) (3.28) ±50 (2.0) (2.0) IPUSBM-2WJAPA-1M 1.00 ±50 IPUSB-2WJAPA-1M 1.00 (3.28) ±50 (2.0) IPUSBM-2WJAPA-2M 2.00 (6.56) ±100 (3.94) IPUSBM-2WJAPA-2M 2.00 (6.56) ±100 (3.94) IPUSB-2WJAPA-2M 2.00 (6.56) ±100 (3.94) IPUSBM-2WJAPA-3M 3.00 (9.84) ±150 (5.90) (5.90) IPUSBM-2WJAPA-3M ±150 IPUSB-2WJAPA-3M 3.00 (9.84) 3.00 (9.84) ±150 (5.90) IPUSBM-2WJAPA-5M 5.00 (16.4) (16.4) ±250 (9.84) (9.84) IPUSBM-2WJAPA-5M 5.00 ±250 IPUSB-2WJAPA-5M 5.00 (16.4) ±250 (9.84) PART NUMBER NUMBER PART PART NUMBER METERS (FEET) METERS (FEET) F METERS (FEET) 25.4 25.4 (HEX) (HEX) E (HEX) 1.00" 1.00" Connector series: USB Gender: Female to Male PIN 4PIN 4 29.3 29.3 Part No.: IPUSB-*WJBPA-#M 1.15" 1.15" DD D (REF) (REF) *refers to use version (2.0 or 3.0) # refers to cable length PIN 1 59.7 59.7±0.50 ±0.50 2.35"±.020 ±.020 2.35" PIN 1 O 5.5 5.5±.15 ±.15 O .22" .22"±.01 ±.01 C Connector Type: O 20.6 .813" O 20.6 .813" -20°C ~ +80°C O 20.8O±0.120.8 ±0.1 B O .819" ±.004 .819" ±.004 Terminal: NUT NUT WASHER Mating style: AA 19.4 ±0.1 .764" ±.004 .764" ±.004 RECOMMENDED PANEL CUT-OUT Screw thread RECOMMENDED PANEL CUT-OUT NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. Contact resistance: 7 ≤ 30MΩ GASKET 4 SHELL SHELL COLOR: BLACK GASKET SCHEMATIC SCHEMATIC plated P1 P1 1 P1 11 2 22 43 33 4SHELL Zinc 19.4 alloy, nickel plated ±0.1 A RED WHITE RED RED GREEN WHITE WHITE BLACK GREEN GREEN BLACK BLACK P2 P2 1 P2 11 2 22 43 33 SHELL 4 66 Salt spray: 48 hr. Protection class: IP67 (unmated) Durability: 1000 times RoHS COMPLIANT. COMPLIANT. 8. RoHS IPUSB-2WJAPA-XM 8. CA, USB A W PNL / A STD XM IPUSBM-2WJAPA-XM IPUSBM-2WJAPA-XM KCHOD TITLE Current rating: PART NUMBER PART NUMBER UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: TITLE DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v TITLE IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY DRAWN: CA, USB USB AA W W PNL PNL MTL MTL // AA STD STD XM XM D.KAPLACHINSKI CA, UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM UNLESS OTHERWISE KCHOD TOLERANCE EXCEPT SPECIFIED, AS NOTED: DIMENSIONS ARE IN MM P.KIM KCHOD TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v DECIMAL ±0.25 NTS .XX .XXX ±0.05 D.KAPLACHINSKI A.XDIMENSIONS SHEET 1 OFANGLES 1 ±1v A IMPERIAL ARE±0.1 FOR REFERENCE ONLY D.KAPLACHINSKI IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY THIRD ANGLE PROJECTION 2 3 P.KIM THIRD ANGLE PROJECTION P.KIM ENGINEER: DRAWN: APPROVED BY DRAWN: THIRD ANGLE PROJECTION CAGE CODE: 6 5 2A589 44 Voltage rating: SCALE SIZE ENGINEER: ENGINEER: VER ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT APPROVED BY APPROVED BY 4 CAGE CODE: CAGE CODE: 55 BB PART NUMBER 4 SHELL SHELL NOTE: CAD CAD GENERATED GENERATED DRAWING DRAWING DO DO NOT NOT UPDATE UPDATE MANUALLY. MANUALLY. NOTE: 77 CC Withstanding voltage: AC 500V/1 minute Copper alloy, gold Screw nut: USB-A 2.0 PLUG 3 HOUSING BB DD PIN 4 NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL C EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) TEMPERATURE RANGE: -20vC TO +80vC 2. NOTES: NOTES: PANEL THICKNESS: 7.0mm (WITHOUT CAP CHAIN) 3.1.1. MAX WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED CAUSED IN 11NYLON, METERBLACK WATER WITHIN WITHIN 30 30 MINUTES) MINUTES) (CONN (CONN 11 ONLY) ONLY) HOUSING: 4. MATERIAL: EFFECT IN METER WATER NUT: RANGE: NYLON, BLACK TO +80 +80vvCC TEMPERATURE RANGE: -20vvCC TO -20 2.2. TEMPERATURE USB-A JACK, GOLD PLATED MAX PANEL PANELCONN.1: THICKNESS: 4.0mm (WITHOUT CAP CHAIN) 3.3. MAX THICKNESS: 4.0mm (WITHOUT CAP CHAIN) PLATED MATERIAL: CONN.2: HOUSING:USB-B ZINCPLUG, ALLOY,GOLD NICKEL PLATED SCREW SCREW NUT: NUT: ZINC ZINC ALLOY, ALLOY, HOUSING: ZINC ALLOY, NICKEL PLATED 4.4. MATERIAL: B NICKEL PLATED PLATED CONN1: USB-A JACK, GOLD GOLD PLATED PLATED CONN2: CONN2: USB-A USB-A PLUG, PLUG, GOLD GOLD GASKET:CONN1: SILICONE, GRAYJACK, NICKEL USB-A PLATEDUL2725 GASKET: SILICONE, GRAY WASHER: WASHER: STAINLESS STAINLESS STEEL UV PLATED GASKET: SILICONE, GRAY STEEL USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, 5. CABLE: BLACK, OD=5.5mm CABLE: UL2725 UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC PVC JACKET, JACKET, UV UV CABLE: USB2.0 28AWG*1P+24AWG*2C+AI+D+B, 5.5. RESISTANT, RESISTANT, BLACK,WITH OD=5.5mm IDENTIFIED DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. ITEMS RESISTANT, BLACK, OD=5.5mm X X ) DOC# ITEMS IDENTIFIED IDENTIFIED WITHSPECIFICATIONS DIAMOND (( 11 ......PER MUST PKG-001 BE INSPECTED. INSPECTED. PACKAGING ITEMS WITH DIAMOND ) MUST BE 6.6.7. REFERENCE COMPLIANT. REFERENCE PACKAGING SPECIFICATIONS SPECIFICATIONS PER PER DOC# DOC# PKG-001 PKG-001 7.8. RoHS REFERENCE PACKAGING 7. USB-B to USB-A Temperature range: D USB-A 2.02.0 PLUGPLUG USB-A 13/16"-28UN 13/16"-28UN General Information EE PIN 4 PIN 4 .22" ±.01 33 E PIN PIN 1 1 19.219.2 .756".756" USB-A 2.0 JACK CC 50.9±0.50 ±0.50 50.9 2.00" 2.00"±.020 ±.020 LENGTH LENGTH 2A589 2A589 SIZE SIZE AA SCALE SCALE 33 NTS NTS SHEET 11 OF OF 11 SHEET VER VER AA 22 ©COPYRIGHT 2004 PEI-GENESIS ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT ENGINEERING PRODUCT DEVELOPMENT REV A A DATE 11/14/16 DATE REV REV DATE DATE DATE 11/14/16 AA 11/1/2016 11/14/16 11/1/2016 DATE DATE 11/1/2016 11/1/2016 DATE DATE 11/1/2016 11/1/2016 1.5A 2180 Hornig Road, Philadelphia, PA 19116 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. BY ANY MEANS PA 19116 2180 HornigREPRODUCTION Road, Philadelphia, Philadelphia, Hornig Road, OR 2180 DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PA 19116 NOTICE OF CONFIDENTIALITY PROHIBITED WITHOUTNOTICE THE WRITTEN PERMISSION OF OF CONFIDENTIALITY THIS DRAWING IS THE OFPROPERTY OF PEI-Genesis, ALL AN AUTHORIZED PEI-GENESIS. THIS DRAWING AGENT IS THE PROPERTY OF PEI-Genesis, ALL AA 30V RIGHTS RESERVED. REPRODUCTION BY ANY MEANS RIGHTS RESERVED.1 REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. AN AUTHORIZED AGENT OF PEI-GENESIS. 11 Notes 14 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. 6 7 5 4 5 4 2 1 REVISIONS REV ZONE ECO# DESCRIPTION DRAW INITIAL RELEASE KC A ADDED RoHS NOTE;2 ADD OVERMOLD TOLS; ADD CABLE DIA TOL 3 1 KC REVISIONS REV ZONE ECO# DESCRIPTION DRAW KC 2 INITIAL RELEASE 1 A ADDED RoHS REVISIONS NOTE; ADD OVERMOLD TOLS; ADD CABLE DIA TOL KC REV ZONE ECO# DESCRIPTION DRAW APPD DATE INITIAL RELEASE KC PK 11/14/16 A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS KC PK 2/13/17 3 TABLE A (L) LENGTH 6 7 F PART NUMBER TOLERANCE MM (IN) 6 (L) LENGTH ±50 (2.0) 1.00 (3.28) 2.00 (6.56) ±100 (3.94) TOLERANCE METERS (FEET) 5.00(L) (16.4) ±250 LENGTH MM(9.84) (IN) TABLE A METERS (FEET) 7 IPUSBM-2WPAPB-1M TABLE AIPUSBM-2WPAPB-2M PART NUMBER F IPUSBM-2WPAPB-5M 5 USB Cable Mounted Plug Assemblies www.peigenesis.com 3 4 APPD DATE PK 11/1/16 PK 2/13/17 APPD DATE PK 11/1/16 PK 2/13/17 F USB-B Circular Cable Mounted Receptacle to USB-B Plug Cable Assembly F PART NUMBER IPUSBM-2WPAPB-1M 1.00 (3.28) (FEET) IPUSBM-2WPAPB-2M METERS2.00 (6.56) IPUSBM-2WPAPB-5M 5.00 (16.4) IPUSB-2WJAPA-05M 0.50 (1.6) IPUSB-2WJAPA-1M 1.00 (3.28) E IPUSB-2WJAPA-2M 2.00 (6.56) IPUSB-2WJAPA-3M 3.00 (9.84) IPUSB-2WJAPA-5M 5.00 (16.4) ±50 (2.0) TOLERANCE MM±100 (IN) (3.94) ±250 (9.84) ±30 (1.2) ±50 (2.0) ±100 (3.94) ±150 (5.90) ±250 (9.84) E E E 25.4 (HEX) O 27.2 1.07" 1.00" Connector series: USB PIN 1 27.2 1.07" PIN 4 Gender: Female toO Male 29.3 PIN 1 1.15" Part No.: IPUSB-*WJBPB-#M (REF) D C LENGTH 52.0 ±0.5059.7 ±0.50 2.05" ±.0202.35" ±.020 LENGTHLENGTH PIN 4 3 B ±0.1 O 20.8 .819" ±.004 Temperature range: Terminal: Screw nut: Mating style: A GASKET WHITE SCHEMATIC SCHEMATIC GREEN RED REDBLACK WHITE WHITE GREEN GREEN BLACK BLACK Copper alloy, gold plated 19.4 ±0.1 ±.004 Zinc.764"alloy, nickel plated NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 6 7 RECOMMENDED PANEL CUT-OUT Screw thread NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 7 6 Contact resistance: 1 2 P2 P2 3 1 41 2 2 SHELL 3 3 4 4 SHELLSHELL 5 D PIN 4 PIN 1USB-B 2.0 PLUGPIN 4 USB-A 2.0 PLUG Protection class: PART NUMBER THIRD ANGLE PROJECTION VER CA, USB AP MTL / B STD XM 2A589 CA, USB A WA PNL / NTS A STD SHEET XM 1 OF 1 A TITLE SIZE SCALE 2A589 CAGE CODE: SIZE DRAWN: DATE ENGINEER: DATE APPROVED BY Durability: KCHOD PART NUMBER CAGE CODE: TITLE DRAWN: DATE ENGINEER: B REV THIRD ANGLE PROJECTION SCALE 3 APPROVED BY ASHEET 1 NTS OF 1 SHEET A 1 OF 1 SCALE SIZE VER VER A© COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 3 2 2 3 6 4 1000 times A A PERMISSION OF PROHIBITED WITHOUT THE WRITTEN AN AUTHORIZED AGENT OF PEI-GENESIS. DATE A 1.5A 1 1 30V 5 5 A 11/1/2016 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL THIS DRAWING PEI-Genesis, ALL REPRODUCTION BY ANY MEANS DATE IS THE PROPERTY OF RIGHTS RESERVED. DATE RIGHTS RESERVED. BY ANY MEANS TO THIRD PARTIES IS S TRICTLY 11/1/2016 REPRODUCTION OR DISTRIBUTION OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF ©COPYRIGHT 2004 PEI-GENESIS OF ENGINEERING PRODUCT DEVELOPMENTPROHIBITED WITHOUT THE WRITTEN PERMISSION AN AUTHORIZED AGENT OF PEI-GENESIS. AN AUTHORIZED AGENT OF PEI-GENESIS. DATE APPROVED BY Voltage rating: 7 B 2180 Hornig Road, Philadelphia, PA 19116 11/1/2016 1 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY Current rating: A 2A589NTS ≤ 30MΩ 2 C IP67 (unmated) DATE ©COPYRIGHT 2004 PEI-GENESIS REV ENGINEERING PRODUCT DEVELOPMENT A KCHOD 2 11/14/16 11/14/16 D.KAPLACHINSKID.KAPLACHINSKI P.KIM 11/14/16 P.KIM UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM DRAWN: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN 3EXCEPT TOLERANCE AS MM NOTED: TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v ENGINEER: DECIMAL .X ±0.25 .XX ±0.1 .XXXDIMENSIONS ±0.05 ANGLES IMPERIAL ARE FOR±1vREFERENCE ONLY IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY THIRD ANGLE PROJECTION 1 C 48 hr. REV TITLE 4 4 PIN 4D PIN 3 PART NUMBER 4 5 5 PIN 3 PIN 1 PIN 2 Salt spray: CAGE CODE: 6 PIN 2 Withstanding voltage: AC 500V/1 minute P2 RED 1 2 P1 P1 3 1 41 2 2SHELL 3 3 4 4 SHELL SHELL -20°C ~ +80°C A A SCHEMATIC COLOR: BLACK USB-B to USB-B NUT P1 B D PIN 1 NOTES: USB-B 2.0 PLUG NOTES: RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF C EFFECT CAUSED IN 1 METER WATER 30 OF MINUTES) RATE: IP67 (NOWITHIN INGRESS DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF EFFECT RANGE: CAUSED-20 IN v1C METER WITHIN 30 MINUTES) (CONN. 1 ONLY) TO +80WATER vC 2. TEMPERATURE NOTES: vC TO +80 TEMPERATURE 2. PANEL THICKNESS:RANGE: 7.0mm-20 (WITHOUT CAPvCCHAIN) 3. MAX RATE:NUT: IP67 (NOALLOY, INGRESS OF DUST/PROTECTED HARMFUL MATERIAL: ZINC NICKEL PLATED CONN.1:AGAINST USB-A PLUG, GOLD 3.1. WATERPROOF HOUSING:SCREW NYLON, BLACK 4. MATERIAL: EFFECT CAUSED IN USB-B 1 METERPLUG, WATER (CONN. 1 ONLY) PLATED CONN.2: GOLDWITHIN PLATED30 MINUTES) CASKET: SILICONE, GRAY NUT: NYLON, BLACK v C TO +80 v C RANGE: -20 2.4. TEMPERATURE CABLE: UL2725 USB2.0 PVC JACKET, UV RESISTANT, CONN.1: USB-A JACK,28AWG*1P+24AWG*2C+AI+D+B, GOLD PLATED MATERIAL: SCREW NUT: ZINC ALLOY, NICKEL PLATED CONN.1: USB-A PLUG, GOLD 3. BLACK, OD=5.5mm CONN.2: USB-B PLUG, PLATED CONN.2: USB-BGOLD PLUG,PLATED GOLD CASKET: SILICONE, GRAYB 1 ) MUST BE INSPECTED. IDENTIFIED WITH DIAMOND ( X ...PLATED 5. ITEMS GASKET: SILICONE, UL2725 USB2.0GRAY 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, 4.6. CABLE: PACKAGING SPECIFICATIONS PER DOC# PKG-001 UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV 5. CABLE: REFERENCE BLACK, OD=5.5mm COMPLIANT. 7. RoHSBLACK, RESISTANT, OD=5.5mm 1 X ( ... ) MUST BE INSPECTED. 5. ITEMS IDENTIFIED WITH DIAMOND 1 X ( ... ) MUST BE INSPECTED. 6. ITEMS IDENTIFIED WITH DIAMOND IPUSBM-2WPAPB-XM SPECIFICATIONS PER DOC# APKG-001 6. REFERENCE PACKAGING CA, USB AP MTL / BSPECIFICATIONS STD XM PACKAGING PER DOC# PKG-001 7. REFERENCE OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM 2180 Hornig Road, Philadelphia, PA 19116 COMPLIANT. 7. UNLESSRoHS 11/1/2016 KCHOD EXCEPT AS NOTED: COMPLIANT. 8. RoHSTOLERANCE DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v NOTICE OF CONFIDENTIALITY 11/1/2016 D.KAPLACHINSKI IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS IPUSBM-2WPAPB-XM 11/1/2016 P.KIM OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY IPUSB-2WJAPA-XM O 20.6 .813" General Information B E 50.0 ±0.50 ±0.50 50.9 2.00" 1.97" ±.020 ±.020 O 5.5 ±.15 .22" ±.01 13/16"-28UN 13/16"-28UN Connector Type: E 50.0 ±0.50 1.97" ±.020 O 5.5 ±.15 5.5 ±.15 .22" O±.01 .22" ±.01 PIN 1 PIN 4 *refers to use version (2.0 or 3.0) C # refers to cable length 13/16"-28UN C 52.0 ±0.50 2.05" ±.020 19.2 .756" D D F F 6 4 3 7 SNOISIVER 2 REVISIONS A EZONE LBATECO# DESCRIPTION REV INITIAL RELEASE A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS USB-B Circular Cable Mounted Receptacle to Circular Cable Mounted USB-A Plug Cable Assembly ETAD DPPA WARD 61/41/11 KP CK 71/31/21 KP CK 7 TABLE A NOITPIRCSED5 #OCETABLE ENOZ A VER ESAELER LAITINI SLOT AID ELBAC DEDDA ;SLOT DLOMREVO DEDDA ;ETON SHoR DEDDA A F F 6 IPUSB-2WJAPA-05M IPUSB-2WJAPA-1M IPUSB-2WJAPA-2M IPUSB-2WJAPA-3M IPUSB-2WJAPA-5M 0.50 (1.6) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) IPUSB-2WPAWPB-1M IPUSB-2WPAWPB-2M IPUSB-2WPAWPB-5M 1.00 (3.28) 2.00 (6.56) 5.00 (16.4) 1 REVISIONS HTG NEL )L( REV ZONE ECO# DESCRIPTION INITIAL RELEASE ECNARELOT A ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS TOLERANCE MM (IN) ±50 (2.0) ±100 (3.94) ±250 (9.84) METERS (FEET) TOLERANCE MM (IN) ±30 (1.2) ±50 (2.0) ±100 (3.94) ±150 (5.90) ±250 (9.84) METERS (FEET) 2 (L) LENGTH PART NUMBER F (L) LENGTH PART NUMBER 3 4 DRAW APPD DATE KC PK 11/14/16 KC )TPKEEF ( 2/13/17 SRETEM )NI( MM )0.2( 05± )49.3( 001± )48.9( 052± )82.3( 00.1 )65.6( 00.2 )4.61( 00.5 E E D 2 NIP General Information C C Connector Type: Temperature range: B B Terminal: A 13/16"-28UN C :SETON O 20.6 .813" LUFMRAH TSNIAGA DETCETORP/TSUD FO SSERGNI ON( 76PI :ETAR FOORPRETAW .1 )SETUNIM 03 NIHTIW RETAW RETEM 1 NI DESUAC TCEFFE Cv08+ OT Cv02- :EGNAR ERUTAREPMET .2 KCALB ,NOLYN :TUN WERCS :LAIRETAM .3 COLOR: BLACK DETALP DLOG ,GULP A-BSU :1.NNOC GASKET DETALP DLOG ,GULP NUT B-BSU :2.NNOC B ±0.1 O 20.8 Y A R G , E N O C I L I S : T E K S A G .819" ±.004 SCHEMATIC ,TNATSISER VU ,TEKCAJ CVP ,B+D+IA+C2*GWA42+P1*GWA82 P10.2BSU 5272LU :ELBAC .4 P2 mm5.5=DORED,KCALB 1 1 .DETCEPSNI EB TSUM ) 1 ... X ( DNOMAID H2TIW DEIFITNEDWHITE I SMETI .5 2 100-GKP #COD REP SNOITACIFICEPS G3NIGAKCAP ECNGREEN EREFER .6 3 BLACK 4 .TNAILPMOC SHoR .7 4 19.4 ±0.1 SHELL SHELL .764" ±.004 MX-BPWAPW2-A BSUPI 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MATERIAL: SCREW NUT: NYLON, BLACK CONN.1: USB-A PLUG, GOLD PLATED CONN.2: USB-B PLUG, GOLD PLATED B GASKET: SILICONE, GRAY 4. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. IPUSB-2WPAWPB-XM A 48 hr. Protection class: IP67 (unmated) ≤ 30MΩ ETAD YTILAITNEDIFNOC FO ECITON SNAEM YNA YB NOITCUDORPER .DEVRESER STHGIR YLTCIRT S SI SEITRAP DRIHT OT NOITUBIRTSID RO FO NOISSIMREP NETTIRW EHT TUOHTIW DETIBIHORP .SISENEG-IEP FO TNEGA DEZIROHTUA NA 1 MX W PB / W PA BSU ,AC VER 61/41/11 ETAD 61/41/11 LLA ,sMANUALLY. iseneG-IEP FO YTREPORP EHT SI GNIWARD SIHT NOTE: CAD GENERATED DRAWING DO NOT UPDATE 7 NOTES: Salt spray: Screw thread A 6 ETAD 61/41/11 DOHCK IKSNIHCALPAK.D MIK.P :RE ENIGNE YB DEVORPPA A SISENEG-IEP 4002 THGIRYPOC© TNEMPOLEVED TCUDORP GNIREENIGNE 2 ELTIT MM NI ERA SNOISNEMID ,DEIFICEPS ESIWREHTO SSELNU :DETON SA TPECXE ECNARELOT v1± SELGNA 50.0± XXX. 1.0± XX. 52.0± X. LAMICED YLNO ECNEREFER ROF ERA SNOISNEMID LAIREPMI :NWARD 5 NOITCEJORP ELGNA DRIHT CAGE CODE: 4 NOTE: STN DO NOTAUPDATE MANUALLY. 1 FCAD O 1GENERATED TEEHS DRAWING 985A2 ELACS REV 7 EZIS 3 2A589 Durability: ETIHW 22 IPUSB-2WJAPA-XM NEERG CA, USB A W PNL / A STD XM 33 UNLESS OTHERWISE SPECIFIED, KCADIMENSIONS LB ARE IN MM KCHOD TOLERANCE EXCEPT AS NOTED: PART NUMBER Current rating: 44 DRAWN: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY LLSHELL EHS D.KAPLACHINSKI P.KIM APPROVED BY Voltage rating: SCALE A NTS SHEET 1 OF 1 VER A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 6 4 REV DATE DATE 11/14/16 DATE 11/14/16 55 B 1000 times 2 3 2180 Hornig Road, Philadelphia, PA 19116 4 SHELL 1.5A NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 30V 2 3 :EDOC EGAC WHITE GREEN A BLACK 11/14/16 ENGINEER: THIRD ANGLE PROJECTION SIZE PIN 2 C -20°C ~ +80°C TITLE PIN 3 USB-B 2.0 PLUG C Withstanding voltage: AC 500V/1 minute REBMUN TRAP PIN 1 USB-A 2.0 PLUG USB-B to USB-A 2P 1 2 3 4 LLEHS PIN 4 D 4 NIP ±.15 O 5.5 .22"PIN±.01 4 NU82-"61/31 NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS: 7.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK NUT: NYLON, BLACK CONN.1: USB-A JACK, GOLD PLATED CONN.2: USB-B PLUG, GOLD PLATED GASKET: SILICONE, GRAY 5. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, BLACK, OD=5.5mm X ... 1 ) MUST BE INSPECTED. 6.CIITEMS TAMEIDENTIFIED HCS WITH DIAMOND (SCHEMATIC 7. REFERENCE PACKAGING1P1 PSPECIFICATIONS PER DOC# PKG-001 P2 D E R RED 8. RoHS COMPLIANT. 11 1 3 RECOMMENDED 61PANEL CUT-OUT 191 AP ,aihpledalihP ,daoR ginroH 0812 Contact resistance: 1 NIP D 51.± 5.5 O 5.5 ±.15 10.± "22. O .22" ±.01 13/16"-28UN PIN 4 Zinc alloy, nickel plated A PIN 1 D 3 NIP GULP 0.2 B-BSU 52.0 2.72±0.50 O 2.05" "70.1 ±.020 LENGTH PIN 1 4 NIP PIN 1 50.9 05.±0.50 0±±0.50 0.25 52.0 2.00" 02.05" 20.±±.020 "50.2 ±.020 HLENGTH TGNEL Copper alloy, gold plated Screw nut: Mating style: ±0.50 059.7 5.0±27.2 0.25 2.35" 02O 0.± 1.07" "±.020 50.2 D *refers to use version (2.0 or 3.0) # refers to cable length O 27.2 1.07" E 19.2 .756" DRAW APPD DATE KC PK 11/14/16 KC PK 12/13/17 F M1-BPWAPW2-BSUPI M2-BPWAPW2-BSUPI M5-BPWAPW2-BSUPI E E .72 (HEX) Connector series: USB "225.4 70.1 O 1.00" Gender: Female to Male PIN 4 1 NIP Part No.: IPUSB-*WJBWPA-#M 29.3 1.15" (REF) F REBMUN TRAP 1 1 4 6 A PART NUMBER TITLE CA, USB AP W / BP W XM REV UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: .Y2A589 LLAUNAM ETSIZE ADPUATON SCALE OD GNTS NIWARD DESHEET TARENEG1DOF AC :E1TONVER 3 KCHOD D.KAPLACHINSKI P.KIM A 7 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/14/16 11/14/16 DATE 11/14/16 2 1 Notes • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. 15 USB Cable Mounted Plug Assemblies www.peigenesis.com USB-B Circular Cable Mounted Receptacle to Circular Cable Mounted USB-B Plug Cable Assembly 6 7 TABLE A 7 3 2 REVISIONS REV 2 ZONE ECO# DESCRIPTION 1 INITIAL RELEASE REVISIONS REV ZONE ECO# DESCRIPTION A APPD CABLE DATEDIA TOLS ADDED RoHS NOTE; ADDED OVERMOLD DRAW TOLS; ADDED 4 5 3 4 (L) LENGTH TABLE A F 5 6 PART NUMBER A F TOLERANCE (L) LENGTH METERS (FEET) MM (IN) PART NUMBER TOLERANCE IPUSB-2WPAWPB-1M ±50 (2.0) METERS (FEET)1.00 (3.28) MM (IN) IPUSB-2WPAWPB-2M 2.00 (6.56) ±100 (3.94) IPUSB-2WJAPA-05M 0.50 (1.6) ±30 (1.2) IPUSB-2WPAWPB-5M 5.00 (16.4) ±250 (9.84) IPUSB-2WJAPA-1M IPUSB-2WJAPA-2M IPUSB-2WJAPA-3M IPUSB-2WJAPA-5M 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) INITIAL RELEASE ADDED RoHS NOTE; ADDED OVERMOLD TOLS; ADDED CABLE DIA TOLS KC KC PK PK 1 DRAW APPD DATE KC PK 11/14/16 KC PK 12/13/17 11/14/16 2/13/17 F F ±50 (2.0) ±100 (3.94) ±150 (5.90) ±250 (9.84) E E Connector series: USB 25.4 1.00" (HEX) O 27.2 1.07" Gender: Female to Male PIN 1 PIN 4 Part No.: IPUSB-*WJBWPB-#M 29.3 E 1.15" D (REF)or (2.0 *refers to use version # refers to cable length D 3.0) E 59.7±0.50 ±0.50 52.0 2.35" ±.020 ±.020 2.05" Connector Type: B B Temperature range: Terminal: Screw nut: Mating style: GASKET NUT ±0.1 O 20.8 .819" ±.004 -20°C ~ +80°C P1 1 2 3 4 SHELL SCHEMATIC Copper alloy, gold plated 19.4 ±0.1 .764" ±.004 A A Zinc alloy, nickel plated RECOMMENDED PANEL CUT-OUT Screw thread RED WHITE P1 GREEN 1 BLACK 2 3 4 SHELL COLOR: BLACK Salt spray: P2 SCHEMATIC 1 2 3RED WHITE 4 GREEN SHELL BLACK Contact resistance: 7 P2 1 2 3 4 SHELL ≤ 30MΩ TITLE CAGE CODE: 5 6 4 5 2A589 Durability: CA, USB AP WKCHOD / BP W XM PART NUMBER SCALE NTS CAGE CODE: VER 3 VER Voltage rating: A DATE 11/14/16 DATE ENGINEER: ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT SHEET2 1 OF 1 REV 11/14/16 DRAWN:DATE APPROVED BY SHEET 1THIRDOFANGLE1 PROJECTION A SCALE SIZE A NTS 2A589 A 2180 Hornig Road, Philadelphia, A PA 19116 NOTICE OF CONFIDENTIALITY IS THE PROPERTY11/14/16 OF PEI-Genesis, ALL 2180 Hornig Road, Philadelphia, PA 19116 KCHOD THISRIGHTSDRAWING RESERVED. REPRODUCTION BY ANY MEANS NOTICE OF CONFIDENTIALITY 11/14/16D.KAPLACHINSKI OR DISTRIBUTION TO THIRD PARTIES 11/14/16IS S TRICTLY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL PROHIBITED WITHOUT THE WRITTEN PERMISSION OF RIGHTS RESERVED. REPRODUCTION BY ANY MEANS AN AUTHORIZED AGENT OF PEI-GENESIS. 11/14/16 P.KIM OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY DATE D.KAPLACHINSKI DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v P.KIMONLY IMPERIAL DIMENSIONS ARE FOR REFERENCE Current rating: A 1000 times REV DRAWN: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARETITLE IN MM TOLERANCE EXCEPT AS NOTED: ENGINEER:DIMENSIONS ARE IN MM DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 UNLESS ANGLESOTHERWISE ±1v SPECIFIED, IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLYTOLERANCE EXCEPT AS NOTED: SIZE IP67 (unmated) 7. RoHS COMPLIANT. IPUSB-2WJAPA-XM A IPUSB-2WPAWPB-XM CA, USB A W PNL / A STD XM 3 4 B 48 hr. Protection class: PART NUMBER THIRD ANGLE PROJECTION 6 C Withstanding voltage: AC 500V/1 minute NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE:7 CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. PIN 4 USB-B 2.0 PLUG O 20.6 .813" USB-B to USB-B PIN 2 NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL C EFFECT CAUSED NOTES:IN 1 METER WATER WITHIN 30 MINUTES) +80vCIP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL -20vC TORATE: 2. TEMPERATURE1. RANGE: WATERPROOF CAP CHAIN) 3. MAX PANEL THICKNESS: EFFECT7.0mm CAUSED(WITHOUT IN 1 METER WATER WITHIN 30 MINUTES) NYLON, BLACKRANGE: -20vC TO +80vC 4. MATERIAL: HOUSING: 2. TEMPERATURE NUT: BLACKSCREW NUT: NYLON, BLACK MATERIAL: 3. NYLON, CONN.1: USB-A JACK, GOLDUSB-A PLATEDPLUG, GOLD PLATED CONN.1: CONN.2: USB-B PLUG, GOLDUSB-B PLATEDPLUG, GOLD PLATED CONN.2: B GASKET: SILICONE,GASKET: GRAY SILICONE, GRAY 5. CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV CABLE: UL2725 USB2.0 28AWG*1P+24AWG*2C+AI+D+B, PVC JACKET, UV RESISTANT, 4. RESISTANT, BLACK, OD=5.5mm BLACK, OD=5.5mm 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. 3 General Information D D USB-A 2.0 PLUG 13/16"-28UN C PIN 1 PIN 3 5.5 ±.15 ±.15 OO 5.5 .22" ±.01 ±.01 .22" 13/16"-28UN C PIN 1 PIN 4 19.2 .756" PIN 1 PIN 4 50.9 52.0±0.50 ±0.50 2.00" 2.05"±.020 ±.020 LENGTH LENGTH O 27.2 1.07" 1.5A DATE APPROVED BY DATE A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 1 PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 30V 1 Notes 16 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. www.peigenesis.com 6 7 5 3 4 2 1 REVISIONS DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 USB Jamnut Receptacles REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE F F USB-A Circular Receptacle Feed Thru E Connector series: USB Gender: Female Part No.: IPUSB-*AABHD E 29.3 (REF) 1.15" 24.7 .972" 25.4 1.00" (HEX) D *refers to use version (2.0 or 3.0) 11.5 (REF) [.453"] WITH LIQUID GLUE COLOR: BLACK O 20.6 .811" PIN 1 PIN 1 PIN 4 D 13/16"-28UN PIN 4 7.0 (REF) .28" USB-A 2.0 JACK C C General Information NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40vC TO +85vC 3. MAX PANEL THICKNESS: 7.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK NUT: NYLON, BLACK USB: USB-A JACK, GOLD PLATED GASKET: SILICONE, GRAY 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. IPUSB-2AABHD 3 19.2 .756" Connector Type: Withstanding voltage: AC 500V/1 minute USB-A to USB-A B ±0.1 O 20.8 .819" ±.004 Temperature range: -20°C ~ +80°C Terminal: Copper alloy, gold plated Screw nut: Nylon + GF Mating style: Salt spray: NUT GASKET Protection class: ≤ 30MΩ THIRD ANGLE PROJECTION CAGE CODE: 6 7 5 6 7 JACK, PNL USB W 2.0 A / A BHD TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY Current rating: Screw thread RECOMMENDED PANEL CUT-OUT 1000 times PART NUMBER NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. Contact resistance: IP67 (unmated) Durability: 19.4 ±0.1 .764" ±.004 A 2A589 SIZE SCALE A 4 3 Voltage rating: 5 B 48 hr. DRAWN: 1.5A NTS SHEET 1 OF 1 ENGINEER: APPROVED BY VER A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/11/16 11/11/16 DATE 11/11/16 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 30V 3 4 REV KCHOD D.KAPLACHINSKI P.KIM A 1 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE DRAW APPD DATE KC PK 10/28/16 KC PKC 2/13/17 F F USB-A Metal Circular Receptacle Feed Thru Connector series: USB Gender: Female Part No.: IPUSBM-*AABHD *refers to use version (2.0 or 3.0) E 29.3 (REF) 1.15" 25.4 1.00" (HEX) D WITH LIQUID GLUE COLOR: BLACK O 20.6 .811" PIN 4 General Information E 11.5 (REF) [.453"] 24.7 .972" PIN 1 D PIN 1 7.0 .28" (REF) 13/16"-28UN C C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40vC TO +85vC 3. MATERIAL: HOUSING: ZINC ALLOY, NICKEL PLATED SCREW NUT: ZINC ALOY, NICKEL PATED USB: USB-A JACK, GOLD PLATED GASKET: SILICONE, GRAY WASHER: STAINLESS STEEL 4. MAX PANEL THICKNESS: 4.0mm (WITHOUT CAP CHAIN) 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. 3 19.2 .756" Connector Type: USB-A to USB-A Temperature range: -20°C ~ +80°C Terminal: Copper alloy, gold plated Screw nut: Mating style: Withstanding voltage: AC 500V/1 minute ±0.1 O 20.8 .819" ±.004 B Salt spray: HOUSING Zinc alloy, nickel plated A NUT GASKET Protection class: 19.4 ±0.1 .764" ±.004 ≤ 30MΩ 5 JACK PNL USB 2.0 A MTL / A BHD TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY Voltage rating: 4 DRAWN: 1.5A ENGINEER: APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: 6 IPUSBM-2AABHD 1000 times PART NUMBER Current rating: Screw thread 7 IP67 (unmated) Durability: RECOMMENDED PANEL CUT-OUT B 48 hr. WASHER NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. Contact resistance: PIN 4 USB-A 2.0 JACK 2A589 SIZE SCALE A 3 NTS SHEET 1 OF 1 30V VER KCHOD D.KAPLACHINSKI P.KIM A REV A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 10/28/2016 10/28/2016 DATE 10/28/2016 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 1 Notes • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. 17 www.peigenesis.com 6 USB Jamnut Receptacles 7 5 3 4 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 USB-A Circular Receptacle to PCB Contacts F F Connector series: USB Gender: Female Part No.: IPUSB-*JAPC 29.3 (REF) 1.15" 24.7 .972" E 3.5 ±0.5 .14" ±.02 E WITH LIQUID GLUE COLOR: BLACK 25.4 1.00" (HEX) *refers to use version (2.0 or 3.0) O 20.6 .811" D PIN 4 13/16"-28UN General Information 19.2 .756" USB-A to USB-A Temperature range: -20°C ~ +80°C Screw nut: Mating style: Contact resistance: GASKET NUT Salt spray: ±0.1 O 20.8 .819" ±.004 Copper alloy, gold plated 48 hr. Protection class: 4.20 1.00 .039" Durability: Screw thread 19.4 ±0.1 .764" ±.004 A Current rating: 8.00 .315" RECOMMENDED PANEL CUT-OUT PCB LAYOUTVoltage NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 6 7 1000 times 5X O 0.90 [ .04" ] 2.00 .079" 5 rating: 1.5A IPUSB-2JAPC PART NUMBER JACK, PNL USB W 2.0 A/PC TAIL TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY THIRD ANGLE PROJECTION CAGE CODE: 2A589 SIZE SCALE A 4 NTS 30V SHEET 1 OF 1 DRAWN: ENGINEER: APPROVED BY VER REV KCHOD D.KAPLACHINSKI P.KIM A A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/11/16 11/11/16 DATE 11/11/16 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 3 1 USB-A Metal Circular Receptacle to PCB Contacts 6 7 5 3 4 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE. DRAW APPD DATE KC PK 10/31/16 KC PK 2/13/17 F F 29.3 (REF) 1.15" E *refers to use version (2.0 or 3.0) 3.5 ±0.5 .14" ±.02 24.7 .972" PIN 5 PIN 1 E O 20.6 .811" 25.4 1.00" (HEX) 7.0 .28" (REF) PIN 1 PIN 4 WITH LIQUID GLUE COLOR: BLACK 13/16"-28UN D General Information Connector Type: D 3 19.2 .756" C Withstanding voltage: AC 500V/1 minute USB-A to USB-A HOUSING NUT Salt WASHER Temperature range: -20°C ~ +80°C Terminal: Copper alloy, gold plated B Screw nut: Zinc alloy, nickel Mating style: Screw thread Contact resistance: ≤ 30MΩ GASKET spray: CENTER OF CONNECTOR Durability: 1.00 .039" Current rating: 19.4 ±0.1 .764" ±.004 RECOMMENDED PANEL CUT-OUT 7 6 1.5A 0.90 5X O .04" 8.00 .315" Voltage rating: 5 30V IPUSBM-2JAPC PART NUMBER JACK, PNL USB W 2.0 A MTL/PC TAIL TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY PCB LAYOUT NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. IP67 (unmated) 1000 times 4.20 .165" 2.00 .079" DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: 4 C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40vC TO +85vC 3. MATERIAL: HOUSING: ZINC ALLOY, NICKEL PLATED SCREW NUT: ZINC ALOY, NICKEL B PATED USB: USB-A JACK, GOLD PLATED GASKET: SILICONE, GRAY WASHER: STAINLESS STEEL PIN: COPPER ALLOY, GOLD PATED 4. MAX PANEL THICKNESS: 4.0mm (WITHOUT CAP CHAIN) 5. ITEMS IDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. 48 hr. Protection class: ±0.1 O 20.8 plated .819" ±.004 A 2A589 SIZE SCALE A 3 NTS SHEET 1 OF 1 VER REV KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 10/31/2016 10/31/2016 DATE 10/31/2016 2 Notes 18 B IP67 (unmated) .165" Nylon + GF Connector series: USB Gender: Female Part No.: IPUSBM-*JAPC C Withstanding voltage: AC 500V/1 minute B ≤ 30MΩ D PIN 5 NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40vC TO +85vC 3. MAX PANEL THICKNESS: 7.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK NUT: NYLON, BLACK USB: USB-A JACK, GOLD PLATED PIN: COPPER ALLOY, GOLD PLATED GASKET: SILICONE, GRAY 5. ITEMS IDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. 3 C Connector Type: Terminal: PIN 1 7.0 (REF) .28" PIN 1 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. 1 6 7 5 3 4 2 1 REVISIONS USB-A Circular Receptacle to Screw Terminals REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 F F Connector series: USB Gender: Female Part No.: IPUSB-*ASTB 29.3 (REF) 1.15" 25.4 1.00" (HEX) PIN 1 D PIN 4 13/16"-28UN 3 19.2 .756" C C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS: 4.0mm (WITHOUT CAP CHAIN) 4. CONNECTOR: USB-A 2.0, JACK 5. SCREW TERMINAL: WIRE RANGE 24-18AWG 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 8. RoHS COMPLIANT. Withstanding voltage: AC 500V/1 minute Connector Type: USB-A type Temperature range: -20°C ~ +80°C SCREW TERMINAL Salt spray: NUT WASHER B Terminal: ±0.1 Copper alloy, gold plated O 20.8 .819" ±.004 Screw nut: Nylon + GF 48 hr. GASKET Protection class: IP67 (unmated) Durability: SCHEMATIC Screw thread ≤ 30MΩ E PIN 1 O 20.6 .811" General Information Contact resistance: WITH LIQUID GLUE COLOR: BLACK PIN 5 D Mating style: 10 .39" (REF) 24.7 .972" E *refers to use version (2.0 or 3.0) Current rating: 19.4 ±0.1 .764" ±.004 A 1.5A PART NUMBER Voltage rating: RECOMMENDED PANEL CUT-OUT 5 6 7 30V SIZE 5 SCALE A REV DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION 2A589 4 USB-A Metal Circular Receptacle to Screw Terminals IPUSBM-2ASTB JACK PNL USB 2.0 A MTL / STB TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY CAGE CODE: 6 7 SHEET 1 OF 1 NTS VER KCHOD D.KAPLACHINSKI P.KIM A 2180 Hornig Road, Philadelphia, PA 19116 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/11/16 11/11/16 DATE 11/11/16 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 3 3 4 A A DATE DATE 1 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 F F 29.3 (REF) 1.15" 10 .39" (REF) 24.7 .972" WITH LIQUID GLUE COLOR: BLACK E E PIN 1 25.4 1.00" (HEX) *refers to use version (2.0 or 3.0) D General Information B 1000 times HOUSING 1 2 3 4 5 CONN 1 2 3 4 SHLD NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. Connector series: USB Gender: Female Part No.: IPUSBM-*ASTB USB Jamnut Receptacles USB Jamnut Receptacles www.peigenesis.com O 20.6 .811" PIN 1 PIN 4 D 13/16"-28UN 3 19.2 .756" C C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS: 4.0mm (WITHOUT CAP CHAIN) 4. CONNECTOR: USB-A 2.0, JACK 5. SCREW TERMINAL: WIRE RANGE 24-18AWG 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 8. RoHS COMPLIANT. Withstanding voltage: AC 500V/1 minute Connector Type: USB-A type Temperature range: -20°C ~ +80°C NUT WASHER B Terminal: ±0.1 O 20.8 Copper alloy, gold plated .819" ±.004 Screw nut: Zinc alloy, nickel plated Mating style: Screw thread Contact resistance: ≤ 30MΩ IP67 (unmated) SCHEMATIC Durability: Current rating: 5 4 IPUSBM-2ASTB JACK PNL USB 2.0 A MTL / STB TITLE 30V UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 2A589 SIZE SCALE A 3 NTS SHEET 1 OF 1 REV DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: 6 1.5A PART NUMBER Voltage rating: NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. B 1000 times HOUSING 1 2 3 4 5 CONN 1 2 3 4 SHLD RECOMMENDED PANEL CUT-OUT 7 48 hr. GASKET Protection class: 19.4 ±0.1 .764" ±.004 A SCREW TERMINAL Salt spray: VER KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/11/16 11/11/16 DATE 11/11/16 2 1 Notes • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. 19 www.peigenesis.com 6 USB Jamnut Receptacles 7 5 3 4 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE DRAW APPD DATE KC PK 11/14/16 KC PK 2/13/17 USB-A Circular Receptacle to Flying Leads F F Connector series: USB Gender: Female Part No.: IPUSB-*JAFL 24.7 .972" 500 ±50 19.7" ±2.0 E E 25.4 (HEX) 1.00" PIN 4 19.2 .756" 29.3 1.15" (REF) *refers to use version (2.0 or 3.0) D D FLYING LEADS PIN 1 13/16"-28UN General Information 7.0 (REF) .28" NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS: 7.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK NUT: NYLON, BLACK USB: USB-A JACK, GOLD PLATED GASKET: SILICONE, GRAY 5. WIREHARNESS: UL1007 (28AWG & 20AWG) 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. C 3 O 20.6 .811" Connector Type: USB-A type Temperature range: -20°C ~ +80°C Terminal: B Nylon + GF Mating style: Screw thread Contact resistance: GASKET NUT Copper alloy, gold plated Screw nut: Withstanding voltage: AC 500V/1 minute Salt spray: ±0.1 O 20.8 .819" ±.004 48 hr. Protection class: SCHEMATIC IP67 (unmated) RED 20AWG Durability: 1000 times P1 1 2 3 4 SHLD 19.4 ±0.1 .764" ±.004 WHITE 28AWG GREEN 28AWG BLACK 20AWG YELLOW 20AWG Current rating: A RECOMMENDED PANEL CUT-OUT Voltage rating: ≤ 30MΩ NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. CAGE CODE: 6 7 5 2A589 IPUSB-2JAFL 1.5A PART NUMBER JACK, PNL USB W 2.0 A/0.5M FL TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY SIZE SCALE A SHEET 1 OF 1 NTS A 5 2180 Hornig Road, Philadelphia, PA 19116 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/14/16 11/14/16 DATE 11/14/16 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 1 500 mm 3 4 B A A DATE DATE 2 3 Cable length: VER REV KCHOD D.KAPLACHINSKI P.KIM 30V APPROVED BY THIRD ANGLE PROJECTION 4 DRAWN: ENGINEER: USB-A Metal Circular Receptacle to Flying Leads 6 7 C 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE DRAW APPD DATE KC PK 10/31/16 KC PK 2/12/17 F F Connector series: USB Gender: Female Part No.: IPUSBM-*JAFL 24.7 .972" 25.4 (HEX) 1.00" 500 ±50 19.7" ±2.0 PIN 4 E E 19.2 .756" 29.3 1.15" (REF) *refers to use version (2.0 or 3.0) PIN 1 General Information D 3 O 20.6 .811" C Connector Type: USB-A type Temperature range: -20°C ~ +80°C Terminal: Copper alloy, gold plated Screw nut: Zinc alloy, nickel plated Mating style: Screw thread Contact resistance: FLYING LEADS 7.0 .28" (REF) 13/16"-28UN D ≤ 30MΩ A NUT ±0.1 O 20.8 .819" ±.004 B Withstanding voltage: AC 500V/1 minute NOTES: WASHER Salt spray: 48 hr. GASKET Protection class: IP67 (unmated) Durability: 1000 times SCHEMATIC Current RED 20AWG rating: P1 1 2 3 4 SHLD 19.4 ±0.1 .764" ±.004 WHITE 28AWG GREEN 28AWG BLACK 20AWG YELLOW 20AWG Voltage rating: RECOMMENDED PANEL CUT-OUT CAGE CODE: 6 5 4 30V PART NUMBER JACK PNL USB 2.0 A MTL/0.5M FL TITLE THIRD ANGLE PROJECTION 2A589 SIZE SCALE A 3 NTS DRAWN: REV KCHOD D.KAPLACHINSKI P.KIM 500 mm ENGINEER: APPROVED BY SHEET 1 OF 1 VER A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 10/31/2016 10/31/2016 DATE 10/31/2016 1 Notes 20 B 1.5A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY Cable length: NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS: 4.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: ZINC ALLOY, NICKEL PLATED SCREW NUT: ZINC ALLOW, NICKEL PLATED USB: USB-A JACK, GOLD PLATED GASKET: SILICONE, GRAY WASHER: STAINLESS STEEL 5. WIREHARNESS: UL1007 (28AWG & 20AWG) 6. ITEMS IDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. IPUSBM-2JAFL C • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. A www.peigenesis.com 5 3 4 USB-B Circular Receptacle Feed Thru 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE DRAW APPD DATE KC PK 11/14/16 KC PK 2/13/17 F F Connector series: USB Gender: Female Part No.: IPUSB-*BABHD 21.2 .830" 29.3 (REF) 1.15" USB Jamnut Receptacles 6 7 12.0 (REF) [.472"] WITH LIQUID GLUE COLOR: BLACK E E PIN 4 25.4 1.00" (HEX) *refers to use version (2.0 or 3.0) PIN 3 O 20.6 .811" PIN 1 PIN 2 D 7.0 (REF) .28" 13/16"-28UN PIN 4 USB-A 2.0 JACK PIN 1 D General Information 19.2 .755" C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40°C TO +85°C 3. MAX PANEL THICKNESS: 4.5mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK NUT: NYLON, BLACK USB: USB-B JACK, GOLD PLATED USB: USB-A JACK, GOLD PLATED GASKET: SILICONE, GRAY 5. ITEMS IDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. IPUSB-2BABHD Withstanding voltage: AC 500V/1 minute Connector Type: USB-B to USB-A Temperature range: -20°C ~ +80°C Terminal: Copper alloy, gold platedO Screw nut: Nylon + GF Mating style: Screw thread Contact resistance: ≤ 30MΩ SaltGASKET spray: 48 hr. NUT B Protection class: 20.8 ±0.1 .819" ±.004 IP67 (unmated) Durability: Current rating: 19.4 ±0.1 .764" ±.004 1.5A PART NUMBER Voltage rating: A RECOMMENDED PANEL CUT-OUT 30V JACK, PNL USB W 2.0 B / A BHD TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: 6 7 5 2A589 SIZE SCALE A 4 NTS SHEET 1 OF 1 VER REV KCHOD D.KAPLACHINSKI P.KIM A 5 2180 Hornig Road, Philadelphia, PA 19116 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/14/16 11/14/16 DATE 11/14/16 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 3 4 A DATE DATE 2 3 USB-B Circular Receptacle to PCB Contacts 6 7 2 1 REVISIONS DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 F F PIN 4 29.3 (REF) 1.15" 21.2 .835" PIN 3 3.5 ±0.5 .14" ±.02 WITH LIQUID GLUE COLOR: BLACK E E 25.4 1.00" (HEX) *refers to use version (2.0 or 3.0) O 20.6 .811" PIN 1 PIN 2 PIN 5 13/16"-28UN PIN 1 D D General Information 3 19.2 .756" C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST C 2. TEMPERATURE RANGE: -40vC TO +85vC 3. MAX PANEL THICKNESS: 4.5mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK NUT: NYLON, BLACK USB: USB-B JACK, GOLD PLATED PIN: COPPER ALLOY, GOLD PLATED GASKET: SILICONE, GRAY 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. B Connector Type: USB-B type Withstanding voltage:HARMFUL AC 500V/1 EFFECT CAUSED IN 1 METERminute WATER WITHIN 30 MINUTES) Temperature range: -20°C ~ +80°C NUT Terminal: Copper alloy, gold plated GASKET Salt spray: B ±0.1 O 20.8 .819" ±.004 Nylon + GF 2.00 .079" 48 hr. Protection class: 8.00 .315" IP67 (unmated) Durability: 5X O 0.90 1000 times [ .04" ] Mating style: Screw thread Current rating: Contact resistance: ≤ 30MΩ Voltage6.40rating: 19.4 u 0.1 [.764" u.004] A 30V IPUSB-2JBPC JACK, PNL USB W 2.0 B/PC TAIL TITLE .252" RECOMMENDED PANEL CUT-OUT 7 1.5A PART NUMBER UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY PCB LAYOUT CAGE CODE: 6 5 4 2A589 SIZE SCALE A 3 NTS REV DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. Notes A 1 REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE Screw nut: B 1000 times NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. Connector series: USB Gender: Female Part No.: IPUSB-*JBPC C SHEET 1 OF 1 VER KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/11/16 11/11/16 DATE 11/11/16 2 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. 1 21 USB Jamnut Receptacles www.peigenesis.com USB-B Circular Receptacle to Flying Leads 7 6 7 6 5 5 4 3 4 3 2 2 1 REVISIONS REVISIONS REV ZONE REV ECO# ZONE DESCRIPTION ECO# DESCRIPTION INITIAL RELEASE INITIAL RELEASE A A ADDED RoHS ADDEDNOTE RoHS NOTE F F Connector series: USB Gender: Female Part No.: IPUSB-*JBFL E E *refers to use version (2.0 or 3.0) 21.2 21.2 .835".835" 25.4 25.4(HEX)(HEX) 1.00"1.00" PIN 1PIN 1 29.3 29.3 1.15" 1.15" (REF)(REF) PIN 2PIN 2 PIN 4PIN 4 19.2 19.2 .756".756" C Temperature range: Screw nut: Mating style: D NOTES:NOTES: voltage: Withstanding AC 500V/1 minute RATE:RATE: IP67 IP67 (NO INGRESS (NO INGRESS OF DUST/PROTECTED OF DUST/PROTECTED AGAINST AGAINST HARMFUL HARMFUL 1. WATERPROOF 1. WATERPROOF USB-B type C Nylon + GF B NUT NUT P1 P1 1 1 2 2 3 3 4 4 SHLDSHLD A 19.4 19.4 ±0.1 ±0.1 .764".764" ±.004±.004 SCHEMATIC SCHEMATIC RED 20AWG RED 20AWG WHITEWHITE 28AWG28AWG GREENGREEN 28AWG28AWG BLACK BLACK 20AWG20AWG YELLOWYELLOW 20AWG20AWG IP67 (unmated) Durability: 1000 times 5. Current rating: 6. 7. 8. 7 Cable length: CAGE CODE: 6 6 PART NUMBER 5 5 4 4 CAGE CODE: SIZE 2A589 2A589A B B A A 30V IPUSB-2JBFL IPUSB-2JBFL A 500 mm A JACK, PNL JACK,USB PNLWUSB 2.0 WB/0.5M 2.0 B/0.5M FL FL UNLESS OTHERWISE UNLESS SPECIFIED, OTHERWISEDIMENSIONS SPECIFIED, DIMENSIONS ARE IN MM ARE IN MM 11/14/16 chodzkchodzk TOLERANCE EXCEPT TOLERANCE AS NOTED: EXCEPT AS NOTED: DECIMAL .X ±0.25 DECIMAL .X.XX±0.25 ±0.1 .XX .XXX±0.1 ±0.05 .XXXANGLES ±0.05 ±1v ANGLES ±1v D.KAPLACHINSKI D.KAPLACHINSKI 11/14/16 IMPERIAL DIMENSIONS IMPERIAL ARE DIMENSIONS FOR REFERENCE ARE FOR ONLY REFERENCE ONLY THIRD ANGLE PROJECTION THIRD ANGLE PROJECTION 11/14/16 P.KIM P.KIM NOTE: CADNOTE: GENERATED CAD GENERATED DRAWING DRAWING DO NOT UPDATE DO NOTMANUALLY. UPDATE MANUALLY. C 1.5A Voltage rating: PART NUMBER C 48 hr. Protection class: TITLE RECOMMENDED RECOMMENDED PANEL PANEL CUT-OUT CUT-OUT 7 EFFECT EFFECT CAUSED CAUSED IN 1 METER IN 1 METER WATER WATER WITHIN WITHIN 30 MINUTES) 30 MINUTES) TOvC+80 TOvC+80vC TEMPERATURE RANGE: RANGE: -20vC-20 2. TEMPERATURE MAX PANELPANEL THICKNESS: THICKNESS: 4.5mm4.5mm (WITHOUT (WITHOUT CAP CHAIN) CAP CHAIN) 3. MAX MATERIAL: HOUSING: HOUSING: NYLON,NYLON, BLACKBLACK 4. MATERIAL: NUT: NUT: NYLON,NYLON, BLACKBLACK USB: USB: USB-BUSB-B JACK,JACK, GOLDGOLD PLATED PLATED GASKET: GASKET: SILICONE, SILICONE, GRAYGRAY WIREHARNESS: UL1007, UL1007, 28AWG. 28AWG. UL1007, UL1007, 20AWG 20AWG 5. WIREHARNESS: X ) MUST ITEMS IDENTIFIED IDENTIFIED WITHWITH DIAMOND DIAMOND ( 1 ...( X1 )... MUST BE INSPECTED. BE INSPECTED. 6. ITEMS REFERENCE PACKAGING PACKAGING SPECIFICATIONS SPECIFICATIONS PER DOC# PER DOC# PKG-001 PKG-001 7. REFERENCE RoHS COMPLIANT. COMPLIANT. 8. RoHS Salt spray: 2. GASKET GASKET 3. 4. 20.820.8 ±0.1 ±0.1 O O .819".819" ±.004±.004 ≤ 30MΩ A D 20.6 O O20.6 .811".811" Screw thread Contact resistance: E 3 3 Copper alloy, gold plated B E FLYING LEADSLEADS FLYING 7.0 7.0 (REF)(REF) [ .28"[ .28" ] ] D -20°C ~ +80°C Terminal: F PIN 3PIN 3 General Information Connector Type: F 500 500 ±50 ±50 19.7"19.7" ±2.0 ±2.0 13/16"-28UN 13/16"-28UN D 1 DRAW APPD DRAW APPD DATE DATE KC PKKC PK 11/14/16 11/14/16 KC PKKC PK 2/13/17 2/13/17 TITLE SIZESCALE 3 ANTS 3 SCALE REV NTS SHEET SHEET 1 OF 1 1 VEROFA1 DRAWN: DRAWN: ENGINEER: ENGINEER: APPROVED BY APPROVED BY VER A DATE NOTICE OF CONFIDENTIALITY NOTICE OF CONFIDENTIALITY 11/14/16 THIS DRAWINGTHIS IS THE DRAWING PROPERTY IS THEOFPROPERTY PEI-Genesis, OF PEI-Genesis, ALL ALL DATE RIGHTS RESERVED. RIGHTS REPRODUCTION RESERVED. REPRODUCTION BY ANY MEANS BY ANY MEANS 11/14/16 OR DISTRIBUTION OR DISTRIBUTION TO THIRD PARTIES TO THIRD IS STRICTLY PARTIES IS STRICTLY PROHIBITED WITHOUT PROHIBITED THEWITHOUT WRITTENTHE PERMISSION WRITTEN OF PERMISSION OF AN AUTHORIZED AN AUTHORIZED AGENT OF PEI-GENESIS. AGENT OF PEI-GENESIS. DATE ©COPYRIGHT 2004©PEI-GENESIS COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT ENGINEERING DEVELOPMENT PRODUCT DEVELOPMENT 2 2 REV DATE DATE 11/14/16 2180 Hornig 2180Road, Hornig Philadelphia, Road, Philadelphia, PA 19116 PA 19116 DATE 1 1 Notes 22 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2. • Please refer to Page 5 for part number breakdown. www.peigenesis.com F 6 5 4 CAGE CODE: 2A589 TITLE A 3 3 SCALE 1 NTS 2 REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE. SHEET 1 OF 1 VER A DRAWN: ENGINEER: APPROVED BY 2 REVISIONS ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT KCHOD D.KAPLACHINSKI P.KIM IPCAP-1316 A 11/11/16 11/11/16 DATE DATE 11/11/16 DATE REV 1 DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 1 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 2180 Hornig Road, Philadelphia, PA 19116 NOTES: 1. WATERPROOF RATE: ACCORDING TO THE RATE OF MATING CONNECTOR, HIGHEST WATERPROOF RATE IP67 (NO INGRESS OF DUST/PROECTED AGAINST HARMFUL EFFECTS CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40vC TO +105vC 3. MATERIAL: SCREW NUT: NYLON, BLACK HOLDER: NYLON, BLACK GASKET: EPDM, BLACK WASHER: STAINLESS STEEL METAL CHAIN: STAINLESS STEEL, Ø3.0 METAL CHAIN LENGTH: 80+/-5mm ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 RoHS COMPLIANT. 4. 5. 6. 7. SEALING CAP 13/16 28UN PART NUMBER SIZE THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY F E D C B A F E D C B A 7 O 27.2 1.07" 7 NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 6 6 5 5 18.8 .742" USB Accessories 7 4 4 4 CAGE CODE: 2A589 PART NUMBER SIZE 3 3 SCALE 1 NTS 2 REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE. SHEET 1 OF 1 VER A DRAWN: ENGINEER: APPROVED BY 2 REVISIONS ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT KCHOD D.KAPLACHINSKI P.KIM IPCAP-1316 A 11/11/16 11/11/16 DATE DATE 11/11/16 DATE REV 1 DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 1 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 2180 Hornig Road, Philadelphia, PA 19116 NOTES: 1. WATERPROOF RATE: ACCORDING TO THE RATE OF MATING CONNECTOR, HIGHEST WATERPROOF RATE IP67 (NO INGRESS OF DUST/PROECTED AGAINST HARMFUL EFFECTS CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40vC TO +105vC 3. MATERIAL: SCREW NUT: NYLON, BLACK HOLDER: NYLON, BLACK GASKET: EPDM, BLACK WASHER: STAINLESS STEEL METAL CHAIN: STAINLESS STEEL, Ø3.0 METAL CHAIN LENGTH: 80+/-5mm ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 RoHS COMPLIANT. 4. 5. 6. 7. SEALING CAP 13/16 28UN A THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY TITLE Nylon, black E 18.8 .742" 5 Stainless steel Material, chain: Material, holder: D 6 EPDM, black Copper alloy, nickel plated C 7 Material, gasket: Material, cap: Stainless steel Nylon, black IP67 -40°C ~ +105°C Material, chain: Material, holder: Protection class: Temperature range: EPDM, black Nylon, black 19.4 .764" O 24.5 .965" Material, gasket: Material, cap: 13/16"-28UN 31.3 [1.23"] Connector series: USB Part No.: IPCAPM-1316 IP67 -40°C ~ +105°C O 27.2 1.07" NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. USB Receptacle Metal Cap Protection class: Temperature range: 19.4 .764" O 24.5 .965" 13/16"-28UN 31.3 [1.23"] Connector series: USB Part No.: IPCAP-1316 B A USB Receptacle Cap O 20.8 .819" 10.0 [.394"] General Information O 20.8 .819" 10.0 [.394"] General Information F E D C B A 23 www.peigenesis.com 6 7 6 7 USB Accessories Gasket 5 3 4 5 3 4 2 REVISIONS 1 REVREVISIONS ZONE ECO# DESCRIPTION INITIAL RELEASE DRAW APPD DATE A ADDED RoHS NOTE KC PK 11/11/16 KC PK 2/13/17 2 REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE F 1 DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 F F F O 28.0 1.10" O 28.0 1.10" Connector series: USB Part No.: IPGSK-1316 E O 19.5 .768" O 22.0 .866" O 19.5 .768" E O 22.0 .866" B B E E O 26.7 1.05" O 26.7 1.05" D D D D SECTION A-A SECTION A-A C C C General Information C 2.6 .10" 2.6 .10" Material: Packaging: NOTES: 3 NOTES: 1. MATERIAL: SILICONE (UL94V-0) 1. MATERIAL: SILICONE (UL94V-0) 2. COLOR: GRAY B 2. COLOR: GRAY 4 3. 10 PCS GASKET PUT INTO ONE PE BAG BAGIDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 4 3. 10 PCS GASKET PUT INTO ONE 4. PE ITEMS 4. ITEMS IDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 5. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 5. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 6. RoHS COMPLIANT. 6. RoHS COMPLIANT. 3 B B 2.0 .08" 2 2.0 .08" 2 Silicone (UL94V-0) Color: Pack of 10 DETAIL B DETAIL B A PART NUMBER TITLE CAGE CODE: THIRD ANGLE PROJECTION 6 7 6 5 5 6 7 TITLE CAGE CODE: 2A589 4A 5 SCALE SIZE 4 SHEET 1 OF 1 NTS ENGINEER: APPROVED BY DATE SCALE 3 A DATE VER ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT DRAWN: KCHOD DATE P.KIM DATE 3 A A 2180 Hornig Road, Philadelphia, PA 19116 11/11/16 ENGINEER: NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL 11/11/16 ©COPYRIGHT 2004 PEI-GENESIS RIGHTS RESERVED. REPRODUCTION BY ANY MEANS PRODUCT DEVELOPMENT OR DISTRIBUTION TOENGINEERING THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT 2 THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 2 3 4 A 2180 Hornig Road, Philadelphia, PA 19116 11/11/16 D.KAPLACHINSKI SIZE BY APPROVED VER REV UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MMREV TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES DRAWN: DATE ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 11/11/16 A KCHOD THIRD ANGLE PROJECTION 11/11/16 D.KAPLACHINSKI AP.KIM NTS SHEET 1 OF11/11/16 2A589 1 A GASKET CIRCULAR 13/16 10PK UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 IPGSK-1316 IPGSK-1316GASKET CIRCULAR 13/16 10PK PART NUMBER A NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 1 1 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE Lock Nut DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 F F Connector series: USB Part No.: IPNT-1316 29.3 1.15" 4.0 .16" E E 25.4 1.00" D D 13/16"-28 UN C C General Information B 3 Material: Packaging: Nylon IPNT-1316 PART NUMBER A NUT 13/16 28UN PLASTIC 10PK TITLE Pack of 10 7 24 NOTES: 1. MATERIAL: NYLON 2. COLOR: BLACK 3. BURR: 0.15mm MAX 4. ITEMS IDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 5. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 6. 10 PCS NUT PUT INTO ONE PE BAG 7. RoHS COMPLIANT. Color: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY CAGE CODE: 6 5 4 2A589 SIZE SCALE A 3 NTS REV DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. B Gray SHEET 1 OF 1 VER KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 B Black A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/11/16 11/11/16 DATE 11/11/16 1 www.peigenesis.com USB PCB Layout USB PCB Layout USB-A Type, PCB USB-B Type, PCB 25 www.peigenesis.com USB Part Numbers 26 All HDMI Series P/Ns Catalog Page All HDMI Series P/Ns Catalog Page All HDMI Series P/Ns Catalog Page IPUSB-2WPAPA-1M 6 IPUSBM-2WPAWPA-1M 8 IPUSB-2WJAPA-1M 11 IPUSB-2WPAPA-2M 6 IPUSBM-2WPAWPA-2M 8 IPUSB-2WJAPA-2M 11 IPUSB-2WPAPA-3M 6 IPUSBM-2WPAWPA-3M 8 IPUSB-2WJAPA-3M 11 IPUSB-3WPAPA-1M 6 IPUSBM-3WPAWPA-1M 8 IPUSB-3WJAPA-1M 11 IPUSB-3WPAPA-2M 6 IPUSBM-3WPAWPA-2M 8 IPUSB-3WJAPA-2M 11 IPUSB-3WPAPA-3M 6 IPUSBM-3WPAWPA-3M 8 IPUSB-3WJAPA-3M 11 IPUSBM-2WPAPA-1M 6 IPUSB-2WPAWPB-1M 9 IPUSBM-2WJAPA-1M 11 IPUSBM-2WPAPA-2M 6 IPUSB-2WPAWPB-2M 9 IPUSBM-2WJAPA-2M 11 IPUSBM-2WPAPA-3M 6 IPUSB-2WPAWPB-3M 9 IPUSBM-2WJAPA-3M 11 IPUSBM-3WPAPA-1M 6 IPUSB-3WPAWPB-1M 9 IPUSBM-3WJAPA-1M 11 IPUSBM-3WPAPA-2M 6 IPUSB-3WPAWPB-2M 9 IPUSBM-3WJAPA-2M 11 IPUSBM-3WPAPA-3M 6 IPUSB-3WPAWPB-3M 9 IPUSBM-3WJAPA-3M 11 IPUSB-2WPAPB-1M 7 IPUSB-2WPBWPB-1M 9 IPUSB-2WJAPB-1M 12 IPUSB-2WPAPB-2M 7 IPUSB-2WPBWPB-2M 9 IPUSB-2WJAPB-2M 12 IPUSB-2WPAPB-3M 7 IPUSB-2WPBWPB-3M 9 IPUSB-2WJAPB-3M 12 IPUSB-3WPAPB-1M 7 IPUSB-3WPBWPB-1M 9 IPUSB-3WJAPB-1M 12 IPUSB-3WPAPB-2M 7 IPUSB-3WPBWPB-2M 9 IPUSB-3WJAPB-2M 12 IPUSB-3WPAPB-3M 7 IPUSB-3WPBWPB-3M 9 IPUSB-3WJAPB-3M 12 IPUSBM-2WPAPB-1M 7 IPUSBM-2WPBPA-1M 10 IPUSBM-2WJAPB-1M 12 IPUSBM-2WPAPB-2M 7 IPUSBM-2WPBPA-2M 10 IPUSBM-2WJAPB-2M 12 IPUSBM-2WPAPB-3M 7 IPUSBM-2WPBPA-3M 10 IPUSBM-2WJAPB-3M 12 IPUSBM-3WPAPB-1M 7 IPUSBM-3WPBPA-1M 10 IPUSBM-3WJAPB-1M 12 IPUSBM-3WPAPB-2M 7 IPUSBM-3WPBPA-2M 10 IPUSBM-3WJAPB-2M 12 IPUSBM-3WPAPB-3M 7 IPUSBM-3WPBPA-3M 10 IPUSBM-3WJAPB-3M 12 IPUSB-2WPAWPA-1M 8 IPUSBM-2WPBPB-1M 10 IPUSB-2WJAWPA-1M 13 IPUSB-2WPAWPA-2M 8 IPUSBM-2WPBPB-2M 10 IPUSB-2WJAWPA-2M 13 IPUSB-2WPAWPA-3M 8 IPUSBM-2WPBPB-3M 10 IPUSB-2WJAWPA-3M 13 IPUSB-3WPAWPA-1M 8 IPUSBM-3WPBPB-1M 10 IPUSB-3WJAWPA-1M 13 IPUSB-3WPAWPA-2M 8 IPUSBM-3WPBPB-2M 10 IPUSB-3WJAWPA-2M 13 IPUSB-3WPAWPA-3M 8 IPUSBM-3WPBPB-3M 10 IPUSB-3WJAWPA-3M 13 M12 Part Numbers Part Numbers www.peigenesis.com Catalog Page All HDMI Series P/Ns Catalog Page IPUSBM-2WJAWPA-1M 13 IPUSBM-2WJBWPB-3M 16 IPUSBM-2WJAWPA-2M 13 IPUSBM-3WJBWPB-1M 16 IPUSBM-2WJAWPA-3M 13 IPUSBM-3WJBWPB-2M 16 IPUSBM-3WJAWPA-1M 13 IPUSBM-3WJBWPB-3M 16 IPUSBM-3WJAWPA-2M 13 IPUSB-2AABHD 17 IPUSBM-3WJAWPA-3M 13 IPUSB-3AABHD 17 IPUSBM-2WJAWPB-1M 14 IPUSBM-2AABHD 17 IPUSBM-2WJAWPB-2M 14 IPUSBM-3AABHD 17 IPUSBM-2WJAWPB-3M 14 IPUSB-2JAPC 18 IPUSBM-3WJAWPB-1M 14 IPUSB-3JAPC 18 IPUSBM-3WJAWPB-2M 14 IPUSBM-2JAPC 18 IPUSBM-3WJAWPB-3M 14 IPUSBM-3JAPC 18 IPUSBM-2WJBPA-1M 14 IPUSB-2ASTB 19 IPUSBM-2WJBPA-2M 14 IPUSB-3ASTB 19 IPUSBM-2WJBPA-3M 14 IPUSBM-2ASTB 19 IPUSBM-3WJBPA-1M 14 IPUSBM-3ASTB 19 IPUSBM-3WJBPA-2M 14 IPUSB-2JAFL 20 IPUSBM-3WJBPA-3M 14 IPUSB-3JAFL 20 IPUSBM-2WJBPB-1M 15 IPUSBM-2JAFL 20 IPUSBM-2WJBPB-2M 15 IPUSBM-3JAFL 20 IPUSBM-2WJBPB-3M 15 IPUSB-2BABHD 21 IPUSBM-3WJBPB-1M 15 IPUSB-3BABHD 21 IPUSBM-3WJBPB-2M 15 IPUSB-2JBPC 21 IPUSBM-3WJBPB-3M 15 IPUSB-3JBPC 21 IPUSBM-2WJBWPA-1M 15 IPUSB-2JBFL 22 IPUSBM-2WJBWPA-2M 15 IPUSB-3JBFL 22 IPUSBM-2WJBWPA-3M 15 IPCAP-1316 23 IPUSBM-3WJBWPA-1M 15 IPCAPM-1316 23 IPUSBM-3WJBWPA-2M 15 IPGSK-1316 24 IPUSBM-3WJBWPA-3M 15 IPNT-1316 24 IPUSBM-2WJBWPB-1M 16 IPUSBM-2WJBWPB-2M 16 USB Part Numbers All HDMI Series P/Ns 27 Corporate Headquarters, Philadelphia, PA European Headquarters & Production Facility, Southampton, UK North American Production Facility, South Bend, IN Production Facility, Zhuhai, China FilConn, Chandler, AZ PEI-Genesis has sales offices throughout the Americas, Europe and Asia. Visit www.peigenesis.com, call +1 800.675.1214 (North America), +44 (0) 23 8062 1260 (Europe), +86 756 7683 088 (Asia), +1 631.475.5050 (Rest of World), or email: sales@peigenesis.com. www.peigenesis.com | www.peigenesis.cn 28
IPUSBM-2WJAPA-05M
1. 物料型号:文档列出了多种USB连接器型号,包括USB 2.0和3.0的电缆组件、插座、以及不同长度和类型的USB A和B连接器。
2. 器件简介:SURE-SEAL®系列USB连接器提供高防护等级(IP67)的连接解决方案,适用于恶劣环境,支持USB 2.0和3.0标准。
3. 引脚分配:文档中未明确列出每个连接器的引脚分配图,但通常USB A型和B型连接器有标准的引脚分配
4. 参数特性: - 工作温度范围:-20°C至+80°C。 - 接触电阻:不超过30mΩ。 - 耐电压:交流500V,持续1分钟。 - 防护等级:IP67(未连接时)。 - 耐久性:1000次插拔。 - 电流额定值:1.5A。 - 电压额定值:30V。
5. 功能详解:文档详细介绍了各种USB连接器的配置,包括电缆组件、插座、以及金属和非金属版本。每种连接器都有不同的安装选项和电缆长度。
6. 应用信息:SURE-SEAL®系列USB连接器适用于需要高防护等级的应用,如工业、医疗和户外设备。
7. 封装信息:文档提供了各种连接器的尺寸和公差信息,以及PCB布局指南,帮助设计工程师在PCB设计中正确放置这些连接器。
IPUSBM-2WJAPA-05M 价格&库存
很抱歉,暂时无法提供与“IPUSBM-2WJAPA-05M”相匹配的价格&库存,您可以联系我们找货
