IPM20-H8-FWL-1.0
IPM20-H8-FWL-1.0
    PEI-GENESIS(倍捷)
    CBL 8POS FMALE TO WIRE 3.28
IPM20-H8-FWL-1.0 数据手册
7 6 ® IP G O L L A A T E A S C E S R E SU SERI 0 2 M www.peigenesis.com I www.peigenesis.cn sales@peigenesis.com Table of Contents Technical Information................................................................................................................................................................................................. 4 How to Order M20 Molded Cable................................................................................................................................................................................................................. 5 M20 Panel Mount................................................................................................................................................................................................................... 5 M20 Series Molded Cable M20 Male Molded Cable, Straight......................................................................................................................................................................................... 6 M20 Female Molded Cable, Straight..................................................................................................................................................................................... 7 M20 Series Panel Mount M20 Male Panel Mount, Solder, Rear Fastened..................................................................................................................................................................... 8 M20 Female Panel Mount, Solder, Rear Fastened................................................................................................................................................................. 9 M20 Plastic Terminator M20 Plastic Male Terminator................................................................................................................................................................................................ 10 M20 Plastic Female Terminator............................................................................................................................................................................................ 10 M20 Part Numbers..................................................................................................................................................................................................... 11 www.peigenesis.com Technical Information Technical Information Wire Gauge Conversion Chart Conversion between American Wire Gauge (AWG), Circular Mil Area (CMA), and approximate metric millimeter squared (mm2) wire sizes. Diameter Area Diameter AWG in. mm CMA mm2* AWG in. mm CMA mm2* 4/0 (0000) 0.46 11.68 212000 120 14 0.062 1.57 4110 2.5 3/0 (000) 0.41 10.41 168000 95 15 0.057 1.45 3260 - 2/0 (00) 0.365 9.27 133000 70 16 0.051 1.30 2580 1.5 1/0 (0) 0.325 8.26 106000 50 17 0.045 1.14 2050 1 1 0.289 7.34 83700 - 18 0.040 1.02 1620 0.75 2 0.258 6.55 66400 35 19 0.036 0.91 1290 - 3 0.229 5.82 52600 - 20 0.032 0.81 1020 0.5 4 0.204 5.18 41700 25 21 0.0285 0.72 810 - 5 0.182 4.62 33100 - 22 0.0253 0.643 642 0.34 6 0.162 4.11 26300 16 23 0.0226 0.574 509 - 7 0.144 3.66 20800 - 24 0.0201 0.511 404 0.25 8 0.128 3.25 16500 10 25 0.0179 0.45 320 - 9 0.114 2.90 13100 - 26 0.0159 0.404 254 0.14 10 0.102 2.59 10400 6 27 0.0142 0.361 202 - 11 0.091 2.31 8230 - 28 0.0126 0.320 160 0.08 12 0.081 2.06 6530 4 29 0.0113 0.29 127 - 13 0.072 1.83 5180 - 30 0.01 0.254 101 0.05 *Nearest metric wire size Use to Convert American Wire Gauge to Diameter and Circular Mil Area. 4 Area www.peigenesis.com How to Order M20 Series With Molded Cable IPM20 2 - H8 CODING & # CONTACTS SERIES 4 5 M WL GENDER ANGLE - SERIES IPM20 = M20 How to Order 1 6 - 1.5 ASSEMBLY LENGTH ANGLE WL = Straight ASSEMBLY LENGTH* 1.5 = 1.5 meters 2.0 = 2 meters 3.0 = 3 meters 5.0 = 5 meters 10 = 10 meters CODING & # CONTACTS H8 = 3 Power + 5 Signal GENDER M = Male F = Female * Additional lengths are available upon request M20 Series Panel Mount 1 IPM20 SERIES - 2 3 4 H8 M -RF CODING & # CONTACTS GENDER FASTENING SERIES IPM20 = M20 CODING & # CONTACTS H8 = 3 Power + 5 Signal 5 - SC TYPE FASTENING -RF = Rear Fastened TYPE SC = Solder Cup GENDER M = Male F = Female 5 www.peigenesis.com M20 Molded Cable M20 Male Molded Cable, Straight Connector series: M20 Gender: Male Locking type: Fix screw Mounting type: Straight Part No.: IPM20-H8-MWL-XXX X refers to cable length General Information Ambient temperature: -10°C ~ +80°C Insulation resistance: ≥ 100MΩ Connector insert: PBT Contact resistance: ≤ 5mΩ Connector contacts: Brass with gold plated Shielding: Unavailable IP rating: IP67 in locked condition Electrical Data & Mechanical Data Contacts Contact termination Rated current Solder version (signal 5 pins) Voltage Wire gauge / size A/C D/C 300V 300V 4A 3+5 pins 13A (power 3 pins) AWG mm2 26-22AWG 0.14-0.3 18-14 AWG 0.5-2.5 PVC Notes 6 Cable jacket • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2 • Please refer to Page 5 for the products’ part number encoding rule. M20 Female Molded Cable, Straight M20 Molded Cable M20 Molded Cables www.peigenesis.com Connector series: M20 Gender: Female Locking type: Fix screw Mounting type: Straight Part No.: IPM20-H8-FWL-XXX X refers to cable length General Information Ambient temperature: -10°C ~ +80°C Seal/O-ring: Silicone Connector insert: PBT Insulation resistance: ≥ 100MΩ Connector contacts: Brass with gold plated Contact resistance: ≤ 5mΩ Coupling nut/screw: ASA Shielding: Unavailable IP rating: IP67 in locked condition Electrical Data & Mechanical Data Contacts Contact termination Rated current Solder version (signal 5 pins) Voltage Wire gauge / size A/C D/C 300V 300V 4A 3+5 pins 13A (power 3 pins) AWG mm2 26-22AWG 0.14-0.3 18-14 AWG 0.5-2.5 Cable jacket PVC Notes • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2 • Please refer to Page 5 for the products’ part number encoding rule. www.peigenesis.com I www.peigenesis.cn 7 www.peigenesis.com M20 Panel Mount M20 Male Panel Mount, Solder, Rear Fastened Connector series: M20 Gender: Male Locking type: Fix screw Mounting type: Rear fastened Part No.: IPM20-H8M-RF-SC General Information Ambient temperature: -25°C ~ +90°C Connector insert: PBT Seal/O-ring: Insulation resistance: Silicone ≥ 100MΩ Connector contacts: Brass with gold plated Contact resistance: ≤ 5mΩ Coupling nut/screw: PA66 Shielding: Unavailable IP rating: IP67 in locked condition Electrical Data & Mechanical Data Contacts Voltage Contact termination Rated current Solder version (signal 5 pins) Wire gauge / size A/C D/C 300V 300V 4A 3+5 pins 13A (power 3 pins) AWG mm2 26-22AWG 0.14-0.3 18-14 AWG 0.5-2.5 Panel Cut-out Dimensions A M20 +0.1 20 –0 B M20x1.5 Notes 8 • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2 • Please refer to Page 5 for the products’ part number encoding rule. www.peigenesis.com M20 Panel Mount M20 Panel Mount M20 Female Panel Mount, Solder, Rear Fastened Connector series: M20 Gender: Female Locking type: Fix screw Mounting type: Rear fastened Part No.: IPM20-H8F-RF-SC General Information Ambient temperature: -25°C ~ +90°C Connector insert: PBT Seal/O-ring: Insulation resistance: Silicone ≥ 100MΩ Connector contacts: Brass with gold plated Contact resistance: ≤ 5mΩ Coupling nut/screw: ASA Shielding: Unavailable IP rating: IP67 in locked condition Electrical Data & Mechanical Data Contacts Voltage Contact termination Rated current Solder version (signal 5 pins) Wire gauge / size A/C D/C 300V 300V 4A 3+5 pins 13A (power 3 pins) AWG mm2 26-22AWG 0.14-0.3 18-14 AWG 0.5-2.5 Panel Cut-out Dimensions A M20 +0.1 20 –0 B M20x1.5 Notes • Please refer to Page 4 for the Conversion between American Wire Gauge AWG and Wire Cross-section mm2 • Please refer to Page 5 for the products’ part number encoding rule. 9 www.peigenesis.com M20 Plastic Terminators M20 Plastic Terminators M20 Plastic Male & Female Terminator Connector series: M20 Gender: Male Locking type: Fix screw Mounting type: Straight Part No.: IPM20-H8M-TM Connector series: M20 Gender: Female Locking type: Fix screw Mounting type: Straight Part No.: IPM20-H8F-TM General Information Ambient temperature: -10°C ~ +80°C Connector insert: PBT Seal/O-ring: Insulation resistance: Silicone ≥ 100MΩ Connector contacts: Brass with gold plated Contact resistance: ≤ 5mΩ Coupling nut/screw: ASA Pins 2 & 3 are connected via a 120 Ohm Resistor Shielding: Unavailable IP rating: IP67 in locked condition Wiring: Electrical Data & Mechanical Data Voltage Contacts Male Contact termination Rated current Solder version (signal 5 pins) Female A/C D/C 300V 300V 4A 3+5 pins 13A (power 3 pins) 10 www.peigenesis.com I www.peigenesis.cn www.peigenesis.com Catalog Page IPM20-H8-MWL-1.0 6 IPM20-H8-MWL-3.0 6 IPM20-H8-MWL-5.0 6 IPM20-H8-FWL-1.0 7 IPM20-H8-FWL-3.0 7 IPM20-H8-FWL-5.0 7 IPM20-H8M-RF-SC 8 IPM20-H8F-RF-SC 9 IPM20-H8M-TM 10 IPM20-H8F-TM 10 Part Numbers All M20 Series P/Ns M20 Part Numbers Part Numbers 11 Corporate Headquarters, Philadelphia, PA European Headquarters & Production Facility, Southampton, UK North American Production Facility, South Bend, IN Production Facility, Zhuhai, China FilConn, Chandler, AZ PEI-Genesis has sales offices throughout the Americas, Europe and Asia. Visit www.peigenesis.com, call +1 800.675.1214 (North America), +44 (0) 23 8062 1260 (Europe), +86 756 7683 088 (Asia), +1 631.475.5050 (Rest of World), or email: sales@peigenesis.com. www.peigenesis.com | www.peigenesis.cn 12
IPM20-H8-FWL-1.0 价格&库存
很抱歉,暂时无法提供与“IPM20-H8-FWL-1.0”相匹配的价格&库存,您可以联系我们找货
