IPMOD-45FSP
IPMOD-45FSP
    PEI-GENESIS(倍捷)
    JACK, PNL RJ45 WS / PCB
IPMOD-45FSP 数据手册
7 6 ® IP G O L L A A T E A S C E S R E I U R S SE 5 4 RJ www.peigenesis.com I www.peigenesis.cn sales@peigenesis.com Table of Contents Technical Information.................................................................................................................................................................................................. 4 How to Order.................................................................................................................................................................................................................... 5 RJ45 Plug Molded Cable - Composite and Metal RJ45 Molded Straight Plug to RJ45 Plug Cable Assembly.................................................................................................................................................... 6 RJ45 Molded Straight Plug Single Ended Cable Assembly.................................................................................................................................................... 7 RJ45 Molded Straight Plug to Molded Straight Plug Cable Assembly................................................................................................................................... 8 RJ45 Plug Field Wireable RJ45 Field Wireable Plug........................................................................................................................................................................................................ 9 RJ45 Receptacle Molded Cable RJ45 Molded Straight Jamnut Receptacle to RJ45 Plug Cable Assembly.......................................................................................................................... 10 RJ45 Molded Straight Jamnut Receptacle Single Ended Cable Assembly.......................................................................................................................... 10 RJ45 Molded Straight Jamnut Receptacle to Molded Straight Plug Cable Assembly......................................................................................................... 11 RJ45 Receptacles RJ45 Jamnut Receptacle to PCB......................................................................................................................................................................................... 12 RJ45 Jamnut Receptacle to Female Feed Thru.................................................................................................................................................................... 13 RJ45 Jamnut Receptacle to RJ45 Plug................................................................................................................................................................................ 14 RJ45 Jamnut Receptacle to Blunt Cut.................................................................................................................................................................................. 15 Accessories RJ45 Feedthru Adapter......................................................................................................................................................................................................... 16 RJ45 Receptacle Cap........................................................................................................................................................................................................... 17 RJ45 Receptacle Metal Cap................................................................................................................................................................................................. 17 RJ45 Gasket.......................................................................................................................................................................................................................... 18 RJ45 Locknut........................................................................................................................................................................................................................ 18 Assembly Instructions RJ45 Field Wireable Plug Assembly Instructions ................................................................................................................................................................. 19 Part Numbers................................................................................................................................................................................................................. 20 www.peigenesis.com Technical Information Technical Information Wire Gauge Conversion Chart Conversion between American Wire Gauge (AWG), Circular Mil Area (CMA), and approximate metric millimeter squared (mm2) wire sizes. Diameter Area Diameter AWG in. mm CMA mm2* AWG in. mm CMA mm2* 4/0 (0000) 0.46 11.68 212000 120 14 0.062 1.57 4110 2.5 3/0 (000) 0.41 10.41 168000 95 15 0.057 1.45 3260 - 2/0 (00) 0.365 9.27 133000 70 16 0.051 1.30 2580 1.5 1/0 (0) 0.325 8.26 106000 50 17 0.045 1.14 2050 1 1 0.289 7.34 83700 - 18 0.040 1.02 1620 0.75 2 0.258 6.55 66400 35 19 0.036 0.91 1290 - 3 0.229 5.82 52600 - 20 0.032 0.81 1020 0.5 4 0.204 5.18 41700 25 21 0.0285 0.72 810 - 5 0.182 4.62 33100 - 22 0.0253 0.643 642 0.34 6 0.162 4.11 26300 16 23 0.0226 0.574 509 - 7 0.144 3.66 20800 - 24 0.0201 0.511 404 0.25 8 0.128 3.25 16500 10 25 0.0179 0.45 320 - 9 0.114 2.90 13100 - 26 0.0159 0.404 254 0.14 10 0.102 2.59 10400 6 27 0.0142 0.361 202 - 11 0.091 2.31 8230 - 28 0.0126 0.320 160 0.08 12 0.081 2.06 6530 4 29 0.0113 0.29 127 - 13 0.072 1.83 5180 - 30 0.01 0.254 101 0.05 *Nearest metric wire size Use to Convert American Wire Gauge to Diameter and Circular Mil Area. 4 Area www.peigenesis.com How to Order RJ45 Plugs & Cable Assemblies IPMOD - SERIES 2 3 45 WPP TYPE CONNECTOR STYLE SERIES IPMOD = RJ45 COMPOSITE IPMODM = RJ45 METAL How to Order 1 4 - 1M LENGTH LENGTH** 05M = 0.5 meter 1M = 1 meter 5M = 5 meters 10 M = 10 meters TYPE 45 = RJ45 (Cat5e) CONNECTOR STYLE* WPP = RJ45 molded plug to RJ45 plug WPL = RJ45 molded plug to blunt cut WPWP = RJ45 molded plug to RJ45 molded plug WM-FT = RJ45 field installable plug WJP = RJ45 molded receptacle to RJ45 plug WJL = RJ45 molded receptacle to blunt cut WJWP = RJ45 molded receptacle to RJ45 molded plug *Molded receptacle only available in composite. ** Additional lengths are available upon request RJ45 Receptacle 1 IPMOD - SERIES 2 3 4 -45 FSP -0.5M TYPE CONNECTOR STYLE LENGTH SERIES IPMOD = RJ45 Composite IPMODM = RJ45 Metal TYPE -45 = RJ45 (Cat5e) CONNECTOR STYLE FSP = RJ45 jam nut receptacle to printed circuit board FSBHD = RJ45 jam nut receptacle to female RJ45 feed thru FSLP = RJ45 jam nut receptacle to RJ45 plug FSL = RJ45 jam nut receptacle to blunt cut LENGTH* 05M = 0.5 meter 1M = 1 meter *Length only required on “FSLP” and “FSL” options, otherwise leave blank. 5 BL/WH BL GN ±0.1 ±.004 GN/WH OR OR/WH NUT SCHEMATIC GASKET 13/16"-28UN OUT OF SEQUENCE A NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED SCREW NUT: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, OD=O6.50mm 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. B 20.6 O .811" C 3 COLOR: BLACK PIN 8 O6.5 ±.20 [ .26" ±.01 ] 2 19.2 .756" PIN 1 D 1 SHEET 1 OF 1 NTS A VER ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT APPROVED BY KCHOD D.KAPLACHINSKI P.KIM SCHEMATIC GASKET 1 COLOR: BLACK LENGTH O6.5 ±.20 [ .26" ±.01 ] PIN 8 PIN 8 2 19.2 .756" 2180 Hornig Road, Philadelphia, PA 19116 A A B PIN 1 D D D D PIN 8 COLOR: BLACK 56.2 ±0.50 2.21" ±.020 1 E C General Information PIN 1 PIN 1 RJ45 PLUG EX) O6.5 ±.20 [ .26" ±.01 ] X refers to cable length RJ45 JACK O 6.5 ±.20 .26" ±.01 3 F C 63.2 ±0.50 2.49" ±.020 28.0 O 1.10" REV series: RJ45 Gender: Plug Performance: Cat 5e 3 19.2 .756" Mounting type: Straight 2 28.0 O Part No.: IPMODM-45WPP-XM 1.10" E E 1 56.2 ±0.50 2.21" ±.020 3 1 E 1.00" (HEX) Connector 20.6 O .811" 2 13/16"-28UN OR OR/WH 11/10/2016 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED SCREW NUT: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, 2 1 OD=3 O6.50mm REVISIONS REV ZONE ECO#DIAMOND DESCRIPTION ( X ... 1 ) MUST BE INSPECTED. DRAW APPD DATE WITH 6. ITEMS IDENTIFIED INITIAL RELEASE KC PK 11/10/16 SPECIFICATIONS PKG-001 7. REFERENCE PACKAGING A ADDED RoHS NOTE; ADDEDPER CABLEDOC# DIA AND OVERMOLD TOLS KC PK 2/15/17 8. RoHS COMPLIANT. A NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 11/10/2016 A T568-B DATE DATE ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 3 NUT GN/WH PART NUMBER OUT OF SEQUENCE DATE IPMOD-45WJP-XM VER 6 BL GN DRAWN: 11/10/2016 4 SHEET 1 OF 1 (L) LENGTH BL/WH ENGINEER: 11/10/2016 DATE CA, RJ45J WS PNL / RJ45P XM ENGINEER: APPROVED BY NTS OUT OF SEQUENCE BR/WH TITLE SCALE A ±0.1 ±.004 SCALE SIZE 2180 Hornig Road, Philadelphia, PA 19116 11/10/2016 TOLERANCE MM (IN) WH 48V A DATE FEET) A SIZE THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 2A589 KCHOD D.KAPLACHINSKI P.KIM DRAWN: ±0.1 " ±.004 2A589 REV Wiring schematic: CAGE CODE: 5 CAGE CODE: CA, RJ45J WS PNL / RJ45P XM TITLE P2 4 1 2 3 6 4 5 7 8 SHELL Voltage rating: IPMOD-45WJP-XM PART NUMBER UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY P1 5 1 2 3 6 4 5 7 8 SHELL WH ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) 1 2 thread BR/WH OUT OF SEQUENCE 64) 28) 56) 84) .4) E 3 BL/WH C NOTES: (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF RATE: IP67 Contact resistance: ≤ 40MΩ EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) -20vC TO +80vC 2. TEMPERATURE RANGE:Withstanding voltage: AC 1000V/1 minute 3. MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED48SCREW 4. MATERIAL: HOUSING: Salt spray: hr. NUT: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED B 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR Protection class:PVC BLACK, UV RESISTANT, IP67 (mated) OD=3 O6.50mm 2 1 REVISIONS WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. ITEMS IDENTIFIED 1000 REV ZONE Durability: ECO# DESCRIPTION DRAW APPD DATE times INITIAL RELEASE KC PK 11/10/16 SPECIFICATIONS PER DOC# PKG-001 7. REFERENCE PACKAGING A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS KC PK 1A 2/15/17 F 8. RoHS COMPLIANT. Current rating: THIRD ANGLE PROJECTION 6 4 4 5 Screw 7 8 SHELL C 5 ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) 3 6 + GF GN Nylon BL RJ45 PLUG 6 OUT OF SEQUENCE TOLERANCE MM (IN) 56.2 ±0.50 2.21" ±.020 14 2 3 6 4 5 7 8 SHELL Nylon 2 + CF OR GN/WH PIN 1 PIN 1 EX) PIN 8 Metal 25.4 D 3 1 28.0 O 1.10" Screw nut: OR/WH 5 K RJ45 Plug Molded Cable OUT OF SEQUENCE 2180 Hornig Road, Philadelphia, PA 19116 A 6 Contact housing: .764" ±.004 29.3 (REF) 1.15" PIN 1 REV ±0.1number: Contact O 20.8 .819" ±.004 RECOMMENDED PANEL CUT-OUT C 3 .764" ±.004 RECOMMENDED PANEL CUT-OUT Notes 1 19.4 style: ±0.1 Mating OR/WH 1 2 3 3 OUT OF Zinc,6 nickel GNBLplated 6 4 4 SEQUENCE BL/WH 5 5 Screw BR/WH 7 thread 7 WH 8 8 SHELL SHELL 6 Voltage rating: IPMOD-45WJP-XM PART NUMBER CA, RJ45J WS PNL / RJ45P XM TITLE CAGE CODE: 6 5 REV 48V A Wiring Schematic: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 OUT OF SEQUENCE 3 Screw nut: 1 Nylon 2 + GF OR GN/WH 4 .819" ±.004 Contact housing: A F Contact O 20.8 ±0.1number: Copper GASKET alloy, gold plated SCHEMATIC 8 contacts P2 P1 DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 NUT 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS Terminal: B 5 -20°C ~ +80°C 13/16"-28UN 4 • Please refer to Page 5 for part number breakdown. 2A589 SIZE SCALE A 3 NTS SHEET 1 OF 1 VER KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 11/10/2016 DATE 11/10/2016 A T568-B DATE 1 6 Temperature range: (L) LENGTH IEC 60603-7 TOLERANCE MM (IN) Standard: NOTES: IP67 (NO INGRESS resistance: OF DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF RATE: Contact ≤ 40MΩ EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) -20vC TO +80vC 2. TEMPERATURE RANGE: Withstanding voltage: AC 1000V/1 minute 3. MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED 4. MATERIAL: HOUSING: Salt spray: 48SCREW hr. NUT: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED B 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR Protection class:PVC BLACK, UV RESISTANT, IP67 (mated) OD=O6.50mm DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. ITEMS IDENTIFIED WITH Durability: 1000 times 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 1A 8. RoHS COMPLIANT. Current rating: EET) C O 20.6 .811" ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) C 4) 8) 6) 4) .4) D DATE CopperGASKET alloy, gold plated SCHEMATIC P2 8 contacts P1 NUT 19.4 ±0.1 Mating style: ±30 (1.18) PIN 8 DRAWN: Terminal: IPMOD-45WJP-05M .50 (1.64) IPMOD-45WJP-1M 1.00 (3.28) IPMOD-45WJP-2M 2.00 (6.56) IPMOD-45WJP-3M 3.00 (9.84) NOTE: CADIPMOD-45WJP-5M GENERATED DRAWING DO NOT UPDATE MANUALLY. 5.00 (16.4) E IPMOD-45WJP-XM -20°C ~ +80°C METERS (FEET) 7 PIN 8 O 6.5 ±.20 .26" ±.01 O6.5 ±.20 [ .26" ±.01 ] Temperature range: (L) LENGTH A LENGTH D IEC 60603-7 13/16"-28UN PART NUMBER CA, RJ45J WS PNL / RJ45P XM O 20.6 .811" Standard: F TITLE 63.2 ±0.50 2.49" ±.020 COLOR: BLACK C 3 TABLE A 1 D RJ45 JACK 7 E E 1 56.2 ±0.50 series: RJ45 2.21" ±.020 Gender: Plug Performance: Cat 5e 3 19.2 .756" Mounting type: Straight 2 O 28.0 Part No.: IPMOD-45WPP-XM 1.10" General Information B F E X refers to cable length C PART NUMBER ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) 1.00" (HEX) Connector 29.3 (REF) 1.15" PIN 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) Composite 25.4 PIN 8 P2 1 2 3 6 4 5 7 8 TOLERANCE MM (IN) WH D METERS (FEET) 1 DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 RJ45 Molded Straight Plug to RJ45 Plug Cable Assembly IPMOD-45WJP-05M IPMOD-45WJP-1M IPMOD-45WJP-2M IPMOD-45WJP-3M IPMOD-45WJP-5M E 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS BR/WH F (L) LENGTH PART NUMBER 3 4 P1 1 2 3 6 4 5 7 8 5 ±0.1 " ±.004 6 7 TABLE A www.peigenesis.com www.peigenesis.com RJ45 Plug Molded Cable RJ45 Molded Straight Plug Single Ended Cable Assembly Composite E E Connector series: RJ45 Gender: Plug Performance: Cat 5e Mounting type: Straight Part No.: IPMOD-45WPL-XM 63.2 ±0.50 2.49" ±.020 1 LENGTH PIN 8 D D O 6.5 ±.20 .26" ±.01 PIN 1 X refers to cable length RJ45 PLUG General Information C C Standard: IEC 60603-7 Contact resistance: Temperature range: -20°C ~ +80°C Withstanding voltage: AC 1000V/1 minute Terminal: Copper alloy, gold plated Salt spray: 48 hr. Contact number: 8 Contacts Protection class: IP67 (mated) Contact housing: Nylon + CF Durability: 1000 times Screw nut: Nylon + GF Current rating: 1A Mating style: Screw thread Voltage rating: 48V Wiring Schematic: T568-B Metal ≤ 40MΩ E Connector series: RJ45 Gender: Plug Performance: Cat 5e Mounting type: Straight Part No.: IPMODM-45WPL-XM E 63.2 ±0.50 2.49" ±.020 1 LENGTH PIN 8 D D O 6.5 ±.20 .26" ±.01 PIN 1 X refers to cable length RJ45 PLUG General Information C C Standard: IEC 60603-7 Contact resistance: Temperature range: -20°C - +80°C Withstanding voltage: AC 1000V/1 minute Terminal: Copper alloy, gold plated Salt spray: 48 hr. Contact number: 8 contacts Protection class: IP67 (mated) Contact housing: Nylon + GF Durability: 1000 times Screw nut: Zinc, nickel plated Current rating: 1A Mating style: Screw thread Voltage rating: 48V Wiring Schematic: T568-B ≤ 40MΩ Notes • Please refer to Page 5 for part number breakdown. www.peigenesis.com I www.peigenesis.cn 7 OUT OF SEQUENCE 20.8 ±0.1 O .819" ±.004 WH BR/WH BL/WH BL GN GN/WH OR OR/WH 1 19.4 ±0.1 .764" ±.004 APPROVED BY UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY DRAWN: SCHEMATIC KCHOD D.KAPLACHINSKI P.KIM NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY 11/10/2016 DATE 11/10/2016 DATE 11/10/2016 2180 Hornig Road, Philadelphia, PA 19116 DATE CA, RJ45J WS PNL / RJ45P XM TITLE REV IPMOD-45WJP-XM PART NUMBER OUT OF SEQUENCE ENGINEER: A A NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED SCREW NUT: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, OD=O6.50mm 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 B ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) C .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) F 20.6 O .811" TOLERANCE MM (IN) 13/16"-28UN IPMOD-45WJP-05M IPMOD-45WJP-1M IPMOD-45WJP-2M IPMOD-45WJP-3M IPMOD-45WJP-5M METERS (FEET) GASKET PART NUMBER NUT 3 E 1 PIN 8 19.2 .756" D PIN 1 PIN 1 RJ45 PLUG E 63.2 ±0.50 2.49" ±.020 56.2 ±0.50 2.21" ±.020 PIN 8 PIN 8 LENGTH COLOR: BLACK PIN 8 PIN 1 D O6.5 ±.20 [ .26" ±.01 ] D 25.4 1.00" (HEX) O 6.5 ±.20 .26" ±.01 1 1 E C X refers RJ45to JACKcable length D O 6.5 ±.20 .26" ±.01 D RJ45 PLUG PIN 1 D 3 O6.5 ±.20 [ .26" ±.01 ] 29.3 1.15" D PIN 8 2 LENGTH (REF) 63.2 ±0.50 2.49" ±.020 E 28.0 O 1.10" Connector series: RJ45 Plug PINGender: 8 3 Performance: Cat19.2 5e .756" (REF) 2 type: Straight PINMounting 1 O 28.0 1.10" Part No.: IPMOD-45WPWP-XM 1 PIN 1 C 56.2 ±0.50 2.21" ±.020 COLOR: BLACK E C Composite 25.4 (HEX) 1.00" E RJ45 JACK E C 3 BL/WH BL GN GN/WH OR 1000 times SCHEMATIC GASKET 1 48V 13/16"-28UN OUT OF SEQUENCE 2 1A F NUT OR/WH OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 20.8 ±0.1 O .819" ±.004 DATE DRAWN: TITLE 20.6 O .811" REV IPMOD-45WJP-XM 2 3 PART NUMBER F DATE 11/10/16 2/15/17 C 1 NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED SCREW NUT: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, OD=O6.50mm 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. Voltage rating: A 3 11/10/2016 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT OUT OF SEQUENCE WH BR/WH DATE ENGINEER: SHEET 1 OF 1 NTS Current rating: 6 APPROVED BY A 4 IP67 (mated) 1 A REV REVISIONS A ECO# DRAWN: DESCRIPTION DRAW APPD DATE DATE 2180 Hornig Road, Philadelphia, PA 19116 11/10/2016 KCHOD INITIAL RELEASE KC PK 11/10/16 ENGINEER: DATE NOTICE OF CONFIDENTIALITY 11/10/2016 D.KAPLACHINSKI THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL ADDED RoHS NOTE; ADDED CABLE DIADATEAND OVERMOLD RIGHTS TOLSRESERVED. REPRODUCTION KC BY ANYPKMEANS 2/15/17 APPROVED BY P.KIM VER 19.4 ±0.1 .764" ±.004 DATE 2A589 SCALE P2 1 2 3 6 4 5 4 7 8 SHELL SIZE P1 1 2 3 6 4 55 7 8 SHELL PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT REVISIONS A CA, RJ45J WS PNL / RJ45P XM REVIN MMZONE ECO# DESCRIPTION DRAW APPD UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE 2180 Hornig Road, Philadelphia, PA 19116 11/10/2016 KCHOD TOLERANCE EXCEPT AS NOTED: INITIAL RELEASE KC PK DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 - ANGLES ±1v NOTICE OF CONFIDENTIALITY 11/10/2016 IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY DRAWING IS THE PROPERTY OF PEI-Genesis, ALL A ADDED D.KAPLACHINSKI RoHS NOTE; ADDED CABLE DIA AND OVERMOLDTHIS TOLS KC PK RIGHTS RESERVED. REPRODUCTION BY ANY MEANS 11/10/2016 P.KIM OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY A THIRD ANGLE PROJECTION CAGE CODE: (L) LENGTH 1 2 A VER Durability: IPMOD-45WJP-XM 2 3 CA, RJ45J WS PNL / RJ45P XM TITLE 48 hr. 7 SHEET 1 OF 1 NTS SCALE PART NUMBER REVIN MMZONE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 - ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY AC 1000V/1 minute NDED PANEL CUT-OUT 3 A A B 3 PIN 8 2 19.2 .756" D PIN 8 PIN 1 PIN 1 RJ45 PLUG E 56.2 ±0.50 2.21" ±.020 C 25.4 1.00" (HEX) 63.2 ±0.50 2.49" ±.020 LENGTH PIN 8 PIN 8 1 1 E E General Information O 20.6 .811" D PIN 1 D O6.5 ±.20 [ .26" ±.01 ] D 3 O 6.5 ±.20 .26" ±.01 O 6.5 ±.20 .26" ±.01 EF) RJ45 PLUG PIN 1 D COLOR: BLACK C O6.5 ±.20 [ .26" ±.01 ] X refers to cable length RJ45 JACK PIN 8 28.0 O 1.10" LENGTH PIN 1 C 1 63.2 ±0.50 2.49" ±.020 E COLOR: BLACK D E 1 C E (HEX) 56.2 ±0.50 1.00" Connector series: RJ45 2.21" ±.020 Gender: Plug PIN 8 3 Performance: Cat 5e 19.2 .756" (REF) 2 Mounting type:28.0Straight PIN 1 O 1.10" Part No.: IPMODM-45WPWP-XM RJ45 JACK 29.3 1.15" D SIZE Metal 25.4 E 5 THIRD ANGLE PROJECTION .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) 2A589 6 7 IPMOD-45WJP-05M IPMOD-45WJP-1M IPMOD-45WJP-2M IPMOD-45WJP-3M IPMOD-45WJP-5M CAGE CODE: RECOMMENDED PANEL CUT-OUT PART NUMBER F CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE: 4 Screw Thread ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) 6 .764" ±.004 5 (FEET) MatingMETERS style: TOLERANCE MM (IN) Contact housing: 19.4 ±0.1 OUT OF SEQUENCE TOLERANCE MM (IN) 7 OUT OF SEQUENCE plated 6 Screw nut:(L) LENGTH Contact number: TABLE A P2 gold 1 2 3 6 4 5 4 7 8 SHELL P1 OR/WH Copper alloy, 1 OR 2 GN/WH 3 8 contacts GN 6 BL 4 BL/WH Nylon+CF 55 BR/WH 7 WH 8 Nylon + GF SHELL ≤ 40MΩ METERS (FEET) -20°C ~SCHEMATIC +80°C ±0.1 O 20.8 .819" ±.004 Terminal: A GASKET 7 Temperature range: B NUT DRAWING DO NOT UPDATE MANUALLY. IEC 60603-7 13/16"-28UN ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) Standard: C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC Contact CAP CHAIN) resistance: 3. MAX PANEL THICKNESS 4.0mm (WITHOUT 4. MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED SCREW voltage: B NUT: NYLON, BLACK PIN: COPPERWithstanding ALLOY, GOLD PLATED 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, OD=O6.50mm Salt spray: 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. PER DOC# PKG-001class: 7. REFERENCE PACKAGING SPECIFICATIONS Protection 8. RoHS COMPLIANT. T NUMBER O 20.6 General Information .811" .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) C -45WJP-05M D-45WJP-1M D-45WJP-2M D-45WJP-3M D-45WJP-5M 3 CA, RJ45J WS PNL / RJ45P XM TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY CAGE CODE: 2A589 1 • Please refer to Page 5 for part number breakdown. www.peigenesis.com I www.peigenesis.cn SIZE SCALE A 3 NTS Current rating: KCHOD REV DRAWN: SHEET 1 OF 1 VER A D.KAPLACHINSKI P.KIM DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. Voltage rating: ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 11/10/2016 DATE 11/10/2016 1000 times A A 11/10/2016 ENGINEER: APPROVED BY THIRD ANGLE PROJECTION 4 IP67 (mated) Durability: IPMOD-45WJP-XM PART NUMBER Notes 8 3 5 4 Screw Thread 6 5 Mating style: NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. OUT OF SEQUENCE 1 48 hr. 1A 48V 6 RECOMMENDED PANEL CUT-OUT 1 1 OR 2 2 8 contacts GN/WH 3 3 GN OUT OF 6 6 BL 4 4 SEQUENCE Nylon+GF BL/WH 5 5 BR/WH 7 7 Zinc,8 NickelWH Plated8 SHELL SHELL AC 1000V/1 minute B 7 19.4 ±0.1 .764" ±.004 nut: 7 F Contact housing: Screw DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 P1 Copper alloy, goldP2plated OR/WH Contact number: A SCHEMATIC 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS -20°C TOLERANCE MM (IN) NUT (L) LENGTH ±0.1 O 20.8 Terminal: .819" ±.004 ≤ 40MΩ METERS (FEET) Temperature range: B ~GASKET +80°C UMBER IEC 60603-7 13/16"-28UN ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) Standard: C NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) TO +80vC 2. TEMPERATURE RANGE: -20vC Contact resistance: 3. MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) PLUG: 8P8C, GOLD, PLATED, voltage: SHIELDED SCREW 4. MATERIAL: HOUSING: NYLON, BLACK Withstanding NUT: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR Salt spray:PVC BLACK, UV RESISTANT, OD=O6.50mm 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. Protection class: 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) C 5WJP-05M 5WJP-1M 5WJP-2M 5WJP-3M 5WJP-5M RJ45 Plug Molded Cable THIRD ANGLE PROJECTION P2 1 2 3 6 4 5 7 8 SHELL 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS RJ45 Molded Straight Plug to Molded Straight Plug Cable Assembly (L) LENGTH F 3 4 P1 1 2 3 6 4 5 7 8 SHELL 5 MENDED PANEL CUT-OUT 6 7 TABLE A www.peigenesis.com www.peigenesis.com 7 6 5 3 4 2 RJ45 Plug Field Wireable RJ45 Field Wireable Plug 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE Composite DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 F F SEALING NUT Connector series: RJ45 Gender: Plug Performance: CatCLIP5e Mounting type: Straight SEALS Part No.: IPMOD-45WM-FT 41.2 (REF) [ 1.62" ] O 27.2 1.07" O 25.4 1.00" E D E 13/16"-28UN PIN 1 PIN 8 D SCREW NUT General Information HOUSING C Standard: IEC 60603-7 Temperature range: -40°C ~ GASKET +85°C Terminal: Copper alloy, gold plated Contact resistance: C Withstanding voltage: AC 1000V/1 minute NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40vC TO +85vC 3. MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED 4. CABLE DIA: O5.5 - 7.0mm 5. ONE SET UNASSEMBLED IN ONE PE BAG. 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. Salt spray: PLUG B Contact number: 8 contacts Contact housing: Nylon + GF Screw nut: Nylon + GF A Screw Thread Protection class: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION 7 CAGE CODE: 6 5 6 2A589 SIZE SCALE A 4 5 Voltage rating: REV DRAWN: NTS SHEET 1 OF 1 VER 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 11/10/2016 DATE 11/10/2016 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 3 3 4 KCHOD D.KAPLACHINSKI P.KIM A A DATE IP67 (mated) 1000 times Current rating: IPMOD-45WM-FT PLUG, RJ45 WS FIELD TERM TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 48 hr. B Durability: PART NUMBER Mating style: ≤ 40MΩ 1A A 48V 1 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE Metal DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 F F Connector series: SEALING RJ45 NUT Gender: Plug Performance: CatCLIP5e Mounting type: Straight SEALS Part No.: IPMODM-45WM-FT 41.2 (REF) [ 1.62" ] O 27.2 1.07" O 25.4 1.00" E D E 13/16"-28UN PIN 1 PIN 8 D SCREW NUT General Information C Standard: HOUSING IEC 60603-7 Temperature range: -40°C ~ +85°C Contact resistance: C Withstanding voltage: AC 1000V/1 minute GASKET Terminal: Copper alloy, gold plated Contact number: 8 contactsPLUG Contact housing: Nylon + GF Screw nut: Zinc, nickel plated Mating style: Screw thread B A NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40vC TO +85vC 3. MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED 4. CABLE DIA: O5.5 - 7.0mm 5. ONE SET UNASSEMBLED IN ONE PE BAG. 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. Salt spray: Protection class: THIRD ANGLE PROJECTION CAGE CODE: 6 5 2A589 4 SIZE SCALE A 3 NTS SHEET 1 OF 1 VER 1A KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 IP67 (mated) Current rating: REV DRAWN: ENGINEER: APPROVED BY B 1000 times Voltage rating: A PLUG, RJ45 WS FIELD TERM TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 48 hr. Durability: IPMOD-45WM-FT PART NUMBER NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 ≤ 40MΩ DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 11/10/2016 DATE 11/10/2016 A 48V 1 Notes • Please refer to Page 5 for part number breakdown. • Please refer to Page 20 for assembly instructions. www.peigenesis.com I www.peigenesis.cn 9 BL/WH BL GN 20.8 ±0.1 O .819" ±.004 GN/WH OR OR/WH SCHEMATIC NUT PART NUMBER OUT OF SEQUENCE 11/10/2016 2180 Hornig Road, Philadelphia, PA 19116 DATE REV IPMOD-45WJP-XM A A NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED SCREW NUT: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, OD=O6.50mm 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. GASKET B E 1 PIN 8 1 OR/WH ©COPYRIGHT 2004 PEI-GENESIS 2 ENGINEERING PRODUCT DEVELOPMENT REVISIONS 1 2 REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS 1 SCHEMATIC DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 NUT GASKET 11/10/2016 48V OR Voltage rating: 2180 Hornig Road, Philadelphia, PA 19116 DATE REV A B D O 28.0 1.10" PIN 8 1 5 BL/WH BR/WH WH 6 4 5 7 8 SHELL 5 WH OUT OF SEQUENCE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 8. RoHS COMPLIANT. Durability: A NTS SHEET 1 OF 1 2A589 • Please refer to Page 5 for part number breakdown. IP67 (mated) REV VER P.KIM A NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 1 Current rating: A CA, RJ45J WS PNL / RJ45P XM SCALE A 3 NTS DRAWN: KCHOD D.KAPLACHINSKI P.KIM DATE 11/10/2016 Voltage rating: A APPROVED BY SHEET 1 OF 1 1A REV ENGINEER: VER ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 DATE 11/10/2016 DATE 11/10/2016 A 1000 times DATE ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 IPMOD-45WJP-XM UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY SIZE DATE DATE 3 TITLE 2A589 SCALE SIZE DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: 4 PART NUMBER THIRD ANGLE PROJECTION Notes 10 Protection class: PART NUMBER TITLE CAGE CODE: 4 3 6 BL 6 48 hr. 4 Screw Thread NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. GN BL BL/WH BR/WH 5 F Nylon + GF RECOMMENDED PANEL CUT-OUT Mating style: 7 DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 19.4 ±0.1 .764" ±.004 GN/WH Salt spray: GN B Withstanding voltage: AC 1000V/1 minute 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS Nylon+CF OR OR GN/WH ≤ 40MΩ TOLERANCE MM (IN) 3 RECOMMENDED OUT OFPANEL CUT-OUT 6 NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 4 SEQUENCE 7 5 7 8 SHELL Contact housing: A 8 contacts SEQUENCE OR/WH 19.41 ±0.1 .764" 2 ±.004 OR/WH Contact resistance: METERS (FEET) Contact number: A SCHEMATIC ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) OUT OF Copper alloy, P1 gold plated ±0.1 O 20.8 .819" ±.004 Screw nut: P1 1 2 3 P2 6 4 1 5 2 7 8 3 SHELL NOTES: C 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) NOTES: 2. TEMPERATURE RANGE: -20vC TO +80vC 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL 3. MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) EFFECT CAUSED IN 1 4.METER WATER WITHIN 30 MINUTES) MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED SCREW TO +80 vC PIN: COPPER ALLOY, GOLD PLATED 2. TEMPERATURE RANGE: -20 NUT:vCNYLON, BLACK CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, 5. 4.0mm (WITHOUT CAP CHAIN) 3. P2MAX PANEL THICKNESS OD=O6.50mm PLUG: 8P8C, GOLD, SHIELDED SCREW 4. 1 MATERIAL: HOUSING: NYLON, 1 ) MUST BE INSPECTED. IDENTIFIED WITH DIAMOND ( X ...PLATED, 6. ITEMSBLACK 2 COPPER ALLOY, GOLD PLATED PER DOC# PKG-001 B 3 NUT: NYLON, BLACK PIN: PACKAGING SPECIFICATIONS 7. REFERENCE OUT OFFTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, 5. 6 CABLE: CAT.5E 8. RoHS COMPLIANT. 4 OD=O6.50mm SEQUENCE 5 X 1IPMOD-45WJP-XM ) MUST 6. 7 ITEMS IDENTIFIED WITH DIAMOND CA, RJ45J WS (PNL .../ RJ45P XM BE INSPECTED. A 8 2180 Hornig Road, Philadelphia, PA 19116 REFERENCE PACKAGING SPECIFICATIONS PER DOC#KCHOD PKG-001 11/10/2016 7.SHELL 11/10/2016 D.KAPLACHINSKI .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) E Terminal: 1 SCHEMATIC B GASKET NUT ±0.1 O 20.8 .819" ±.004 GASKET -20°CNUT~ +80°C 56.2 ±0.50 2.21" ±.020 Temperature range: C 13/16"-28UN IEC 60603-7 25.4 1.00" (HEX) 3 General Information O 20.6 .811" 13/16"-28UN PIN 1 D PIN 1 RJ45 PLUG O 20.6 .811" 3 B D COLOR: BLACK C Standard: PIN 8 PIN 8 O6.5 ±.20 [ .26" ±.01 ] O6.5 ±.20 [ .26" ±.01 ] RJ45 JACK C E 19.2 .756" X refers to cable length RJ45 JACK 56.2 ±0.50 2.21" ±.020 19.2 .756" D D E 1 56.2 ±0.50 2.21" ±.020 PIN 1 Connector series: RJ45 8 PIN 8 Gender:PINJack 3 19.2 29.3 (REF) 29.3 (REF) .756" 1.15" Locking type: Fix screw 1.15" 2 PIN 1 28.0 PIN 1 O 1.10" Part No.: IPMOD-45WJL-XM 25.4 (HEX) 1.00" F O6.5 ±.20 [ .26" ±.01 ] E F DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 3 ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) 1 2 TOLERANCE MM (IN) .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS COLOR: BLACK METERS (FEET) IPMOD-45WJP-2M IPMOD-45WJP-3M IPMOD-45WJP-5M (HEX) 3 4 28.0 O 1.10" E 5 (L) LENGTH RJ45 JACK Composite25.4 1.00" 6 7 ±30 (1.18) PART NUMBER F±50 (2.0) ±100 (3.94) IPMOD-45WJP-05M ±150 (5.91) IPMOD-45WJP-1M ±250 (9.84) C .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) 20.6 O .811" IPMOD-45WJP-05M IPMOD-45WJP-1M IPMOD-45WJP-2M IPMOD-45WJP-3M IPMOD-45WJP-5M 2180 Hornig Road, Philadelphia, PA 19116 48V NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 1 A 6 A METERS (FEET) (L) LENGTH 1 RJ45 Molded Straight Jamnut Receptacle Single Ended Cable Assembly F 3 A NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 13/16"-28UN 2180 Hornig Road, Philadelphia, PA 19116 11/10/2016 20.8 ±0.1 O .819" ±.004 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS 11/10/2016 DATE NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED SCREW NUT: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, OD=O6.50mm 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 8. RoHS COMPLIANT. VER BL SHEET 1 3OF 1 1A GN 11/10/2016 11/10/2016 DATE IPMOD-45WJP-XM NTS 3 A GN/WH DRAWN: KCHOD D.KAPLACHINSKI P.KIM CA, RJ45J WS PNL / RJ45P XM TITLE PART NUMBER OUT OF SEQUENCE ENGINEER: (L) LENGTH SCALE A 11/10/2016 1 OUT OF SEQUENCE APPROVED BY SIZE DATE DATE DATE WH A 2A589 KCHOD D.KAPLACHINSKI P.KIM REV BL/WH VER 3 CAGE CODE: Current rating: A DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION 4 11/10/2016 BR/WH SHEET 1 OF 1 NTS CA, RJ45J WS PNL / RJ45P XM DATE ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 A 1000 times NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 19.4 ±0.1 .764" ±.004 SCALE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY A P2 1 2 3 6 4 5 7 8 SHELL A SIZE THIRD ANGLE PROJECTION VER IP67 (mated) P1 1 2 3 6 4 5 7 8 SHELL 3 2A589 APPROVED BY SHEET 1 OF 1 NTS IPMOD-45WJP-XM UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 4 CAGE CODE: DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 WH 4 3 TITLE 4 SCALE A 5 SIZE 5 P.KIM Durability: THIRD ANGLE PROJECTION 2A589 PART NUMBER 6 CAGE CODE: 4 DATE DATE 6 E F OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY 2 PROHIBITED WITHOUT THE WRITTEN PERMISSION OF ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT AN AUTHORIZED AGENT OF PEI-GENESIS. REVISIONS 1 REV ZONE2 ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS 8. RoHS COMPLIANT. REV DRAWN: ENGINEER: L CUT-OUT Protection class: TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 48 hr. 7 MANUALLY. Salt spray: PART NUMBER (L) LENGTH BR/WH TOLERANCE MM (IN) OUT OF SEQUENCE METERS (FEET) WH B Withstanding voltage: AC 1000V/1 minute NUMBER BR/WH ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) BL .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) GN ≤ 40MΩ -45WJP-05M -45WJP-1M -45WJP-2M -45WJP-3M -45WJP-5M OR GN/WH BL/WH 6 4 5 5 7 8 SHELL BL BL/WH 5 TOLERANCE TABLE MM (IN)A 56.2 ±0.50 2.21" ±.020 GN 5 PART NUMBER 25.4 1.00" (HEX) OR GN/WH Screw Thread 6 6 TABLE A PIN 8 Mating style: NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 3 D SEQUENCE OR/WH 19.4 1±0.1 Contact number:A 8 contacts .764"2 ±.004 3 PANEL CUT-OUT6 OUT OF Contact housing: NOTE:RECOMMENDED Nylon+CF CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 4 SEQUENCE 6 7 5 ±0.1 Screw nut:19.4 Nylon 7+ GF .764" ±.004 8 SHELL RECOMMENDED PANEL CUT-OUT 19.2 .756" OR/WH SCHEMATIC Copper gold plated OF P1 alloy, OUT .819" ±.004 7 SCHEMATIC P1 1 2 3 P2 6 4 1 5 2 7 3 8 SHELL NOTES: C 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) NOTES: 2. TEMPERATURE RANGE: -20vC TO +80vC 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL MAX PANEL THICKNESS 4.0mm (WITHOUT CAP CHAIN) EFFECT CAUSED IN 1 3.METER WATER WITHIN 30 MINUTES) 4. MATERIAL: HOUSING: NYLON, BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED SCREW TO +80 vC PIN: COPPER ALLOY, GOLD PLATED 2. TEMPERATURE RANGE: -20 NUT:vCNYLON, BLACK CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, 5. 4.0mm (WITHOUT CAP CHAIN) 3. P2MAX PANEL THICKNESS OD=O6.50mm BLACK PLUG: 8P8C, GOLD, PLATED, SHIELDED SCREW 4. 1 MATERIAL: HOUSING: NYLON, 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 2 NUT: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED B 3 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 PVC BLACK, UV RESISTANT, 5. 6 CABLE: CAT.5E OUT OFFTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR 8. RoHS COMPLIANT. 4 OD=O6.50mm SEQUENCE 5 ( X ... 1IPMOD-45WJP-XM ) MUST BE INSPECTED. A 6. 7 ITEMS IDENTIFIED WITH DIAMOND CA, RJ45J WS PNL / RJ45P XM PKG-001 11/10/2016 2180 Hornig Road, Philadelphia, PA 19116 7. 8 REFERENCE PACKAGING SPECIFICATIONS PER DOC#KCHOD SHELL 11/10/2016 D.KAPLACHINSKI Contact resistance: GASKET NUT -20°C ~ +80°C GASKET NUT Terminal: O 20.8 ±0.1 (REF) PIN 1 O6.5 ±.20 [ .26" ±.01 ] C 13/16"-28UN Temperature range: PIN 1 3 IEC 60603-7 PIN 1 RJ45 PLUG COLOR: BLACK General Information O 20.6 D D O6.5 ±.20 [ .26" ±.01 ] O6.5 ±.20 [ .26" ±.01 ] O 20.6 .811" ±0.1 O 20.8 .819" ±.004 2 O 28.0 1.10" 3 13/16"-28UN PIN 8 19.2 .756" C B PIN 8 PIN 1 56.2 ±0.50 2.21" ±.020 RJ45 JACK Standard: E COLOR: BLACK 56.2 ±0.50 2.21" ±.020 28.0 O 1.10" D F RJ45 JACK Connector series: RJ45 PIN 8 PIN 8 Gender: Jack 3 19.2 29.3 (REF) 29.3Locking .756" type: Fix screw 1.15" 1.15" (REF) 2 PIN 1 28.0 PIN 1 O 1.10" Part No.: IPMOD-45WJP-XM C 25.4 (HEX) 1.00" F DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 3 ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS 20.6 O .811" TOLERANCE MM (IN) .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) 2 13/16"-28UN RJ45 Receptacle Molded Cable OUT OF SEQUENCE KCHOD DRAWN: CA, RJ45J WS PNL / RJ45P XM TITLE E 3 4 .811" A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: METERS (FEET) IPMOD-45WJP-3M IPMOD-45WJP-5M 25.4 (HEX) Composite 1.00" 5 (L) LENGTH ±30 (1.18) PART NUMBER F ±50 (2.0) ±100 (3.94) ±150IPMOD-45WJP-05M (5.91) IPMOD-45WJP-1M ±250 IPMOD-45WJP-2M (9.84) RJ45 JACK B P2 1 2 3 6 4 5 7 8 .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) 6 7 X refers to cable length C WH D DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 RJ45 Molded Straight Jamnut Receptacle To RJ45 Plug Cable Assembly TOLERANCE TABLE A MM (IN) METERS (FEET) IPMOD-45WJP-05M IPMOD-45WJP-1M IPMOD-45WJP-2M IPMOD-45WJP-3M IPMOD-45WJP-5M E www.peigenesis.com 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS (L) LENGTH F 2 BR/WH TABLE A PART NUMBER 3 4 P1 1 2 3 6 4 5 7 8 5 19.4 ±0.1 .764" ±.004 6 7 7 6 RECOMMENDED PANEL CUT-OUT RECOMMENDED PANEL CUT-OUT NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 20.8 ±0.1 O .819" ±.004 OUT OFGN SEQUENCE BL GN/WH OR OR/WH A APPROVED BY SIZE ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT DATEVER SCALE DATE ENGINEER: DATE DRAWN: TITLE WH REV REV 2180 Hornig Road, Philadelphia, PA 19116 A A A GN GN/WH OR OR/WH NUT 13/16"-28UN NUT GASKET 20.6 O .811" 20.6 O .811" 3 C COLOR: BLACK 29.3 1.15" (REF) 2 28.0 PIN O 1 1.10" 28.0 O 1.10" 19.2 .756" 3 PIN 8 O6.5 ±.20 [ .26" ±.01 ] PIN 1 D 19.2 .756" 25.4 1.00" (HEX) RJ45 PLUG PIN 1 O6.5 ±.20 [ .26" ±.01 ] D 56.2 ±0.50 2.21" ±.020 56.2 ±0.50 2.21" ±.020 PIN 8 PIN 8 1 E E 6 6 5 5 4 4 48 hr. 3 Protection class: REV UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY CAGE CODE: 7 Salt spray: TITLE TITLE THIRD ANGLE PROJECTION 5 4 1 PART NUMBER PART NUMBER WH TABLE A BR/WH 7 BL OF OUT BL/WH SEQUENCE TABLE A 2 1 3 2 REVISIONS REV ZONE ECO# DESCRIPTION DRAW REVISIONS APPD DATE REV ZONE ECO# DESCRIPTION INITIAL RELEASE KC PK 11/10/16 INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS KC PK 2/15/17 A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS F WH GN B Withstanding voltage: AC 1000V/1 minute X GN/WH ≤ 40MΩ (L) LENGTH BR/WH OR Contact resistance: (L) LENGTH PART NUMBER TOLERANCE TOLERANCE F METERS (FEET) MM (IN) METERS (FEET) MM (IN) BL/WH OR/WH PART NUMBER ±30 (1.18) ±50 (2.0) ±100 (3.94) ±150 (5.91) ±250 (9.84) SCHEMATIC F .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) P1P2 1 21 32 63 46 54 75 87 8 SHELL SHELL .50 (1.64) ±30 (1.18) IPMOD-45WJP-05M 1.00 (3.28) ±50 (2.0) IPMOD-45WJP-1M 2.00 (6.56) ±100 (3.94) IPMOD-45WJP-2M 3.00 (9.84) ±150 (5.91) IPMOD-45WJP-3M 5.00 (16.4) ±250 (9.84) IPMOD-45WJP-5M F DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 1 5 C NOTES: NOTES: RATE: IP67 (NO INGRESS DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF RATE: IP67 1.(NOWATERPROOF INGRESS OF DUST/PROTECTED AGAINSTOFHARMFUL EFFECT WITHIN CAUSED 30 IN 1MINUTES) METER WATER WITHIN 30 MINUTES) EFFECT CAUSED IN 1 METER WATER 2. vC TEMPERATURE TO +80vC RANGE: -20vC TO +80vC 2. TEMPERATURE RANGE: -20 PANEL THICKNESS 3. MAX (WITHOUT CAP CHAIN)4.0mm (WITHOUT CAP CHAIN) 3. MAX PANEL THICKNESS 4.0mm MATERIAL: NYLON,PLATED, BLACK SHIELDED PLUG: 8P8C,SCREW GOLD, PLATED, SHIELDED SCREW 4. BLACK PLUG:HOUSING: 8P8C, GOLD, 4. MATERIAL: HOUSING: NYLON, NUT: ALLOY, NYLON,GOLD BLACKPLATED PIN: COPPER ALLOY, GOLD PLATED NUT: NYLON, BLACK PIN: COPPER B CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR 5. P2 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, PVC BLACK, UV RESISTANT, OD=O6.50mm 1 OD=O6.50mm 6. ITEMS IDENTIFIED WITH DIAMOND ( ... ) MUST BE INSPECTED. 6. 2 ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 3 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 PACKAGING SPECIFICATIONS PER DOC# PKG-001 7.6 REFERENCEOUT OF 8. RoHS COMPLIANT. 8. 4 RoHS COMPLIANT. SEQUENCE 5 IPMOD-45WJP-XM 7 IPMOD-45WJP-XM A CA, RJ45J WS PNL / RJ45P XM A 8 CA, RJ45J WS PNL / RJ45P XM A 2180 Hornig Road, Philadelphia, PA 19116 KCHOD 2180 Hornig Road, Philadelphia, PA 19116 11/10/2016 KCHOD SHELL D.KAPLACHINSKI IPMOD-45WJP-05M IPMOD-45WJP-1M IPMOD-45WJP-2M IPMOD-45WJP-3M IPMOD-45WJP-5M Nylon+CF 6 6 RJ45 JACK OR GN/WH OUT OFGN SEQUENCE BL 8 contacts 7 RJ45 PLUG E 25.4 1.00" (HEX) C 3 OR/WH GASKET Copper alloy, gold plated Contact number: RJ45 JACK SCHEMATIC -20°C ~ +80°C Terminal: D PIN 1 PIN 8 B P1 1 2 3 OUT OF 6 4 SEQUENCE 19.4 ±0.1 5 A 19.4 ±0.1 .764" ±.004 7 .764" ±.004 8 RECOMMENDED PANEL CUT-OUT SHELL RECOMMENDED PANEL CUT-OUT NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. .819" ±.004 Temperature range: C SCHEMATIC GASKET ±0.1 O 20.8 .819" ±.004 PIN 8 D PIN 1 C 13/16"-28UN NUT GASKET IEC 60603-7 O 20.8 ±0.1 B 7 13/16"-28UN NUT NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. SCHEMATIC 13/16"-28UN PIN 8 O6.5 ±.20 [ .26" ±.01 ] O6.5 ±.20 [ .26" ±.01 ] O 20.6 .811" O 20.6 .811" Contact housing: 20.8 ±0.1 28.0 1.10" E 3 3 C General Information A E 1 56.2 ±0.50 2.21" ±.020 19.2 .756" RJ45 JACK RJ45 JACK B F E 11/10/2016 DATE NOTES: NOTES: RATE: IP67 (NO INGRESS DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF RATE: IP67 1.(NOWATERPROOF INGRESS OF DUST/PROTECTED AGAINSTOFHARMFUL EFFECT CAUSED 30 IN 1MINUTES) METER WATER WITHIN 30 MINUTES) EFFECT CAUSED IN 1 METER WATER WITHIN 2. vC TEMPERATURE TO +80vC RANGE: -20vC TO +80vC 2. TEMPERATURE RANGE: -20 PANEL THICKNESS 3. MAX (WITHOUT CAP CHAIN)4.0mm (WITHOUT CAP CHAIN) 3. MAX PANEL THICKNESS 4.0mm PLUG: 8P8C,SCREW GOLD, PLATED, SHIELDED SCREW 4. MATERIAL: HOUSING: NYLON, BLACK SHIELDED BLACK PLUG: 8P8C, GOLD, PLATED, 4. MATERIAL: HOUSING: NYLON, NUT: ALLOY, NYLON,GOLD BLACKPLATED PIN: COPPER ALLOY, GOLD PLATED NUT: NYLON, BLACK PIN: COPPER B 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, PVC BLACK, UV RESISTANT, 5.P2 CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR OD=O6.50mm 1 OD=O6.50mm 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. 2 ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 3 7. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 PACKAGING SPECIFICATIONS PER DOC# PKG-001 7.6 REFERENCEOUT OF 8. RoHS COMPLIANT. 8. 4 RoHS COMPLIANT. SEQUENCE 5 BL OF OUT BL/WH SEQUENCE 56.2 ±0.50 2.21" ±.020 COLOR: BLACK X refers to cable length Standard: DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 D DATE IPMOD-45WJP-XM PART NUMBER 25.4 (HEX) 1.00" (HEX) D C 1 29.3 1.15" (REF) PIN 1 DRAWN: 1 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. E Connector series: RJ45 PIN 8 PIN 8 Gender: Jack 3 19.2 29.3 (REF) 29.3 (REF) .756" 1.15" type: Fix1.15"screw Locking 2 28.0 PIN PIN 1 O O 1 1.10" Part No.: IPMOD-45WJWP-XM D 2 1 3 2 REVISIONS REV ZONE ECO# DESCRIPTION DRAW REVISIONS APPD DATE REV ZONE ECO# DESCRIPTION INITIAL RELEASE KC PK 11/10/16 INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS KC PK 2/15/17 A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS F (L) LENGTH PART NUMBER TOLERANCE TOLERANCE F METERS (FEET) MM (IN) METERS (FEET) MM (IN) .50 (1.64) ±30 (1.18) .50 (1.64) IPMOD-45WJP-05M ±30 (1.18) 1.00 (3.28) ±50 (2.0) IPMOD-45WJP-1M 1.00 (3.28) ±50 (2.0) 2.00 (6.56) ±100 (3.94) 2.00 (6.56) IPMOD-45WJP-2M ±100 (3.94) 3.00 (9.84) ±150 (5.91) 3.00 (9.84) IPMOD-45WJP-3M ±150 (5.91) 5.00 (16.4) ±250 (9.84) 5.00 (16.4) IPMOD-45WJP-5M ±250 (9.84) Composite 25.4 1.00" E 3 4 D ENGINEER: KCHOD D.KAPLACHINSKI P.KIM TITLE PART NUMBER BR/WH 2180 Hornig Road, Philadelphia, PA 11/10/2016 19116 NOTICE OF CONFIDENTIALITY APPROVED BY DATE 11/10/2016 THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION ©COPYRIGHT 2004 PEI-GENESISBY ANY MEANS ENGINEERING OR DISTRIBUTION TO PRODUCT THIRDDEVELOPMENT PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN 2 AUTHORIZED AGENT OF PEI-GENESIS. IPMOD-45WJP-05M IPMOD-45WJP-1M IPMOD-45WJP-2M IPMOD-45WJP-3M IPMOD-45WJP-5M 4 C BL/WH 3 7 IPMOD-45WJP-XM CA, RJ45J WS PNL / RJ45P XM 8 CA, RJ45J WS PNL / RJ45P XMUNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM A TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v 11/10/2016 KCHOD SHELL IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY THIRD ANGLE PROJECTION 11/10/2016 D.KAPLACHINSKI P.KIMNTS SHEET 1 OF 1 11/10/2016A CAGE CODE: PART NUMBER 5 B WH BR/WH 2A589 VER A SHEET 1 OF 1 NTS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY F 5 6 B P1P2 1 21 32 63 46 54 75 87 8 SHELL SHELL 1 2 SCALE THIRD ANGLE PROJECTION O .819" ±.004 P1 1 2 3 OUT OF 6 4 SEQUENCE 19.4 ±0.1 5 .764" ±.004 7 8 SHELL 19.4 ±0.1 .764" ±.004 SIZE 2A589 4 A 6 (L) LENGTH A CAGE CODE: 7 TABLE A A 3 5 4 5 6 7 NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. RJ45 Molded Straight Jamnut Receptacle To RJ45 Plug Cable Assembly 7 TABLE A RJ45 Receptacle Molded Cable www.peigenesis.com SCALE SIZE 2A589 4 A 3 NTS CAGE CODE: 2A589 VER A SHEET 1 OF 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DRAWN: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1DATE v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY ENGINEER: D.KAPLACHINSKI THIRD ANGLE PROJECTION DATE 11/10/2016 DRAWN: DATE ENGINEER: DATE SCALE A NTS DATEVER SHEET 1 OF 1 11/10/2016 A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 3 11/10/2016 11/10/2016 NOTICE OF CONFIDENTIALITY DATE 11/10/2016 THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION ©COPYRIGHT 2004 PEI-GENESISBY ANY MEANS ENGINEERING OR DISTRIBUTION TO PRODUCT THIRDDEVELOPMENT PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN 2 AUTHORIZED AGENT OF PEI-GENESIS. APPROVED BY P.KIM Durability: APPROVED BY SIZE REV P.KIM 2 1 A IP67 (mated) NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 1000 times 1 Screw nut: Nylon + GF Current rating: 1A Mating style: Screw Thread Voltage rating: 48V Notes • Please refer to Page 5 for part number breakdown. 11 RJ45 Receptacle Molded Cable www.peigenesis.com 6 7 5 3 4 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE RJ45 Jamnut Receptacle To PCB DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 F F Composite 33.9 ±0.50 1.33" ±.02 29.3 (REF) 1.15" RJ45 Connector series: Gender: Receptacle Performance: Cat 5e & Cat 6a 25.4 (HEX) 1.00" Straight Mounting type: O Part No.: IPMOD-45FSP 19.7 .776" (REF) WITH LIQUID GLUE E D PIN 8 O 20.6 .811" 28.0 1.10" PIN 1 13/16"-28UN D RJ45 JACK 2 1 General Information 19.2 .756" C Standard: IEC 60603-7 Temperature Range: -40°C ~ +105°C Terminal: Copper alloy, gold plated Contact Number: B Contact Housing: Mating Style: GROUND Contact resistance: 7 8 GASKET 8 contacts Protection Class: IP68 (mated) Nylon+CF Durability: 1000 times Current Rating: 6 5 Screw Thread CAGE CODE: 6 5 A NTS SHEET 1 OF 1 28.0 1.10" 2180 Hornig Road, Philadelphia, PA 19116 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 11/10/2016 11/10/2016 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 F 1 E 13/16"-28UN D 2 1 19.2 .756" Standard: IEC 60603-7 Temperature Range: -40°C ~ +105°C Terminal: Copper alloy, gold plated ContactB Number: 8 contacts Contact Housing: ±0.1 O 20.8 .819" ±.004 Nylon+GF GROUND Contact Resistance: 7 8 GASKET NUT Salt Spray: 48 hr. Protection Class: IP68 (mated) Durability: 1000 times 1A Zinc, Nickel Plated Current Rating: Mating Style: Screw Thread Voltage Rating: 19.4 ±0.1 .764" ±.004 JACK, PNL RJ45 WS / PCB TITLE REV UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY RECOMMENDED PANEL CUT-OUT DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: 6 5 • Please refer to Page 5 for part number breakdown. www.peigenesis.com I www.peigenesis.cn 4 2A589 SIZE SCALE A 3 NTS SHEET 1 OF 1 B 48V IPMOD-45FSP PART NUMBER NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. C ≤ 40MΩ Withstanding Voltage: AC 1000V/1 minute Screw Nut: 7 A DATE DATE DATE 19.7 .776" (REF) General Information Notes VER KCHOD D.KAPLACHINSKI P.KIM DRAW APPD DATE KC PK 11/10/16 A KC PK 2/15/17 A O 20.6 .811" RJ45 JACK 12 SCALE REV WITH LIQUID GLUE PIN 1 A DRAWN: ENGINEER: APPROVED BY 3 E PIN 8 2A589 SIZE 4 33.9 ±0.50 1.33" ±.02 29.3 1.15" (REF) Connector series: RJ45 Gender: Receptacle Performance: Cat 5e & Cat 6a 25.4 (HEX) 1.00" Straight Mounting type: O Part No.: IPMODM-45FSP C IPMOD-45FSP / PCB 1 48V REVISIONS INITIAL RELEASE ADDED RoHS NOTE THIRD ANGLE PROJECTION NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. D RJ45A WS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY RECOMMENDED PANEL CUT-OUT Metal JACK, PNL TITLE F 7 2 REV ZONE ECO# DESCRIPTION Voltage Rating: PART NUMBER B 1A 3 4 19.4 ±0.1 .764" ±.004 A Withstanding Voltage: AC 1000V/1 minute 48 hr. Nylon + GF 7 C ≤ 40MΩ Salt Spray: NUT ±0.1 O 20.8 .819" ±.004 Screw Nut: E VER KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 11/10/2016 DATE 11/10/2016 1 www.peigenesis.com 6 7 5 3 4 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 RJ45 Jamnut Receptacle To Female Feed Thru F F 4.0 .16" 29.3 (REF) 1.15" Connector series: RJ45 Gender: Plug E Performance: 5e & Cat 6a 25.4 Cat 1.00" (HEX) Mounting type: Straight Part No.: IPMOD-45FSBHD PIN 8 O 28.0 1.10" WITH LIQUID GLUE E O 20.6 .811" PIN 1 D PIN 1 13/16"-28UN General Information PIN 8 GASKET NUT RJ45 JACK D RJ45 JACK Contact resistance: Standard: IEC 60603-7 C Temperature range: -40°C ~ +105°C 19.2 .756" ≤ 40MΩ Withstanding voltage: AC 1000V/1 minute Terminal: Copper alloy, gold plated Contact number: 8 contacts Contact housing: Nylon+CF Screw nut: Zinc alloy, nickel plated B ±0.1 Mating style: Screw Thread O 20.8 .819" ±.004 6 5 7 Max panel thickness 4.0 mm (without cap chain) Salt spray: 48 hr. Protection class: IP68 (mated) 23.2 (REF) .915" Durability: 37.4 ±0.5 1.47" ±.02 4 C 1000 times Current rating: 1A Voltage rating: 3 48V2 B 1 Insulation resistance ≥ 5000MΩ at DC 100v REV ZONE ECO# DESCRIPTION DRAW APPD REVISIONS A INITIAL RELEASE ADDED RoHS NOTE KC KC PK PK DATE 11/10/16 2/15/17 7. F 19.4 ±0.1 .764" ±.004 A Metal RECOMMENDED PANEL CUT-OUT29.3 1.15" F IPMOD-45FSBHD PART NUMBER JACK, PNL RJ45 WS COUPLER TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 4.0 .16" (REF) NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 6 7 Connector series: RJ45 E Gender: Plug 25.4 Cat Performance: 1.00" (HEX) 5e & Cat 6a Mounting type: Straight Part No.: IPMODM-45FSBHD PIN 8 O 28.0 1.10" 5 APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: SIZE 2A589 WITH LIQUID GLUE 4 SCALE A NTS REV DRAWN: ENGINEER: SHEET 1 OF 1 VER KCHOD D.KAPLACHINSKI P.KIM A A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 11/10/2016 DATE 11/10/2016 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 3 1 E O 20.6 .811" PIN 1 D PIN 1 13/16"-28UN PIN 8 GASKET NUT RJ45 JACK D RJ45 JACK General Information Standard: IEC 60603-7 Temperature range: -40°C ~ +105°C C RJ45 Receptacles Composite Contact resistance: 19.2 .756" Terminal: Copper alloy, gold plated Contact number: 8 contacts Contact housing: Nylon+CF ScrewB nut: Zinc alloy, nickel plated ±0.1 O 20.8 Mating style: Screw .819" ±.004 Thread Max panel thickness 4.0 mm (without cap chain) ≤ 40MΩ Withstanding voltage: AC 1000V/1 minute Salt spray: Protection 23.2 (REF) .915" 37.4 ±0.5 1.47" ±.02 C 48 hr. class: IP68 (mated) Durability: 1000 times Current rating: 1A Voltage rating: 48V Insulation resistance ≥ 5000MΩ at DC 100v B 7. 19.4 ±0.1 .764" ±.004 Notes A JACK, PNL RJ45 WS COUPLER TITLE RECOMMENDED PANEL CUT-OUT • Please refer to Page 5 for part6 number breakdown. 5 CAGE CODE: 4 2A589 SIZE SCALE A 3 NTS REV DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 IPMOD-45FSBHD PART NUMBER UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY SHEET 1 OF 1 VER KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 11/10/2016 DATE 11/10/2016 1 13 6 7 5 3 4 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA AND OVERMOLD TOLS TABLE A (L) LENGTH F PART NUMBER www.peigenesis.com 1 DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 TOLERANCE MM (IN) METERS (FEET) F RJ45 Receptacles RJ45 Jamnut Receptacle To RJ45 Plug IPMOD-45WJP-05M IPMOD-45WJP-1M IPMOD-45WJP-2M IPMOD-45WJP-3M IPMOD-45WJP-5M ±30 (1.18) ±50 (2.0) 7 ±100 (3.94) ±150 (5.91) ±250 (9.84) 6 5 3 4 Composite 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA TOLS 1 DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 F F E D .50 (1.64) 1.00 (3.28) 2.00 (6.56) 3.00 (9.84) 5.00 (16.4) 33.9 ±0.50 [ 1.33" ±.02 ] 25.4 Connector 1.00" (HEX) series: RJ45 25.4 (HEX) 56.2 ±0.50 2.21" ±.020 1.00" Gender: Receptacle PIN 8 Performance: Cat 5e PIN 8 3 29.3 19.2 1.15" .756" (REF) Mounting type: Straight (REF) 2 PIN 1 2 PIN 1 Part No.: IPMOD-45FSLP-XM O 28.0 500 ±20 1 E PIN 8 E 29.3 1.15" 1.10" X refers to cable length E 19.2 .76" D PIN 1 COLOR: BLACK RJ45 JACK D 6.5 ±.20 .26" ±.01 O6.5 ±.20 [ .26" ±.01 ] O 28.0 1.10" D RJ45 JACK General Information 3 C B O 20.6 .811" O 20.6 .811" C NOTES: Standard: C IEC 60603-7 ≤ 40MΩ IP67 (NO INGRESSresistance: OF DUST/PROTECTED AGAINST HARMFUL 1. WATERPROOF RATE:Contact C EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 13/16"-28UN NOTES: Temperature Range: -20°C ~ +80°C Withstanding Voltage: AC 1000V/1 minute 2. TEMPERATURE RANGE: -20vC TO +80vC 1. WATERPROOF RATE: IP68 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL GASKET NUT 13/16"-28UN CHAIN) 3. MAX PANEL THICKNESS 4.0mm EFFECT(WITHOUT CAUSED IN CAP 1 METER WATER WITHIN 24 HOURS) Terminal: Salt Spray: 48 SCREW hr. GASKET gold plated NUT Copper alloy, C TO +85 vC 2. RANGE: -40vGOLD, BLACK PLUG: 8P8C, PLATED, SHIELDED 4. MATERIAL: HOUSING: NYLON,TEMPERATURE MAX PANEL THICKNESS: 3. COPPER NUT: NYLON, BLACK PIN: ALLOY, GOLD 4.0mm PLATED(WITHOUT CAP CHAIN) B SCHEMATIC Contact Number: 8 contacts (mated) NYLON, BLACK PVC PIN: COPPER GOLD PLATED SCREW 4. MATERIAL: HOUSING: Class: ±0.1 SCHEMATIC 24AWG*4P+MYLAR+DRAIN+AI.MYLAR BLACK, ALLOY, UV IP68 RESISTANT, 5. CABLE: CAT.5E FTP Protection B P2 P1 B O 20.8 NUT: NYLON, BLACK .819" ±.004 6 5 7 3 2 1 4 20.8 ±0.1 OD=O6.50mm OR/WH P1 O 1 1 REVISIONS PVC BLACK, times UV RESISTANT, 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR Contact Housing: Nylon+CF .819" ±.004 Durability: 1000 OR/WH TABLE A OR REV ZONE ECO#DIAMOND DESCRIPTION DRAW APPD DATE WITH ( X ... 1 ) MUST BE INSPECTED. 6. ITEMS IDENTIFIED 1 OD=O6.50mm 2 2 OR INITIAL RELEASE KC PK 11/10/16 2 (L) LENGTH 3 + GF GN/WH 3 PKG-001 7. REFERENCE PACKAGING ITEMSRoHSIDENTIFIED WITH DIAMOND ( ...TOLS) MUST BE KC1A INSPECTED. 6. SPECIFICATIONS GN/WH A ADDED NOTE;Rating: ADDEDPER CABLEDOC# DIA AND OVERMOLD PK 2/15/17 Screw Nut: Nylon Current GN 3 PART NUMBER OUT OF 6 6 GN REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. TOLERANCEOUT OF F 8. RoHS COMPLIANT. OUT OF 6 BL METERS (FEET) BL 4 4 SEQUENCE MM (IN)SEQUENCE RoHS COMPLIANT. 8. 4 SEQUENCE BL/WH BL/WH Voltage Rating: 48V Mating Style: Screw 5 Thread 5 5 IPMOD-45WJP-05M .50 (1.64) 19.4 ±0.1 19.4 ±0.1 A ±30 (1.18) IPMOD-45FSL BR/WH BR/WH IPMOD-45WJP-XM A A 7 7 .764" 7±.004 IPMOD-45WJP-1M 1.00 (3.28)±.004 ±50 (2.0) A PNL RJ45 WS / PC TL 0.5M A .764" CA, RJ45J WS PNL / RJ45P XM JACK, WH WH 6 3 4 8 2180 Hornig Road, 1Philadelphia, PA 19116 KCHOD2 2180 HornigREVISIONS 8 8 5 IPMOD-45WJP-2M*Cable 2.00 (6.56) Length:±100 (3.94)7 500 mm Road, Philadelphia, PA 19116 11/10/2016 KCHOD SHELL D.KAPLACHINSKI REV ZONE ECO# DESCRIPTION DRAW APPD DATE RECOMMENDED PANEL CUT-OUT IPMOD-45WJP-3M 3.00 (9.84) ±150 (5.91) SHELL SHELL 11/10/2016 D.KAPLACHINSKI P.KIM RECOMMENDED PANEL CUT-OUT INITIAL RELEASE KC PK 11/10/16 X F PART NUMBER A PART NUMBER TITLE TITLE IPMOD-45WJP-5M 7 E 5.00 (16.4) NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. ±250 (9.84) F Metal 25.4 THIRD ANGLE PROJECTION 6 7 6 5 (HEX) CAGE CODE: 5 2A589 SIZE 4 4 CAGE CODE: NTS THIRD ANGLE PROJECTION APPROVED BY SIZE 2A589 SHEET 1 OF 1 VER SCALE A A P.KIMSHEET NTS A 1 OF 1 33.9 ±0.50 [ 1.33" ±.02 ] DRAWN: DATE DATE 11/10/2016 NOTICE OF CONFIDENTIALITY NOTICE OF11/10/2016 CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL APPROVED BY RIGHTS RESERVED. REPRODUCTION BY ANY MEANS THIS DRAWING IS THEDATE PROPERTY OF PEI-Genesis, ALL 11/10/2016 OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY DATE RIGHTS RESERVED. REPRODUCTION BY ANYPROHIBITED MEANS WITHOUT THE WRITTEN PERMISSION OF ©COPYRIGHT 2004 PEI-GENESIS 11/10/2016 OR CABLE DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PRODUCT DEVELOPMENT AN AUTHORIZED AGENT ADDED RoHS NOTE;ENGINEERING ADDED DIA TOLS KCOF PEI-GENESIS. PK 2/15/17 ENGINEER: DATE DATE VER A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 3 PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 2 2 3 56.2 ±0.50 1.00" Connector series: RJ45 25.4 1.00" (HEX) 2.21" ±.020 Gender: Receptacle PIN 8 PIN 8 3 Performance: Cat 5e 29.3 19.2 1.15" .756" (REF) Mounting type: Straight (REF) 2 PIN 1 2 28.0 PIN 1 O 1.10" Part No.: IPMODM-45FSLP-XM O 28.0 SCALE A REV REV UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCEDRAWN: EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v ENGINEER: IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 1 1 F 1 500 ±20 1 E PIN 8 E D 29.3 1.15" E 19.2 .76" 1.10" X refers to cableD length 6.5 ±.20 .26" ±.01 O6.5 ±.20 [ .26" ±.01 ] D PIN 1 COLOR: BLACK RJ45 JACK D RJ45 JACK General Information 3 C Standard: O 20.6 .811" Terminal: 13/16"-28UN -40°C ~ +85°C NUT GASKET ±0.1 B Contact Number: O 20.8 .819" ±.004 Copper alloy, gold plated SCHEMATIC P2 P1 8 contacts Contact Housing: Nylon+GF 2 NUT Screw Nut: A C IEC 60603-7 C Temperature13/16"-28UN Range: B O 20.6 .811" ±0.1 O 20.8 1 .819" ±.004 OUT OF SEQUENCE 3 OR/WH OR GN/WH GN 6 Zinc alloy, nickel BL 4 BL/WH 5 Thread 19.4 ±0.1 19.4Style: ±0.1 A Mating Screw BR/WH 7 .764" ±.004 .764" ±.004 WH 8 *Cable Length: 500 mm RECOMMENDED PANEL CUT-OUT SHELL RECOMMENDED PANEL CUT-OUT NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 5 X SEQUENCE 4 5 7 8 SHELL 5 8. RoHS COMPLIANT. PART NUMBER PART NUMBER TITLE WH UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 2A589 4 • Please refer to Page 5 for part number breakdown. * If no cable length is defined, the standard is 500 mm. 48V A A JACK, PNL RJ45 WS / PC TL 0.5M A CA, RJ45J WS PNL / RJ45P UNLESS XMOTHERWISE SPECIFIED, DIMENSIONS ARE IN MM 2180 Hornig Road, Philadelphia, PA 19116 KCHOD 2180 Hornig Road,11/10/2016 TOLERANCE EXCEPT AS NOTED: Philadelphia, PA 19116NOTICE OF CONFIDENTIALITY 11/10/2016 KCHOD DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v D.KAPLACHINSKI NOTICE OF11/10/2016 IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL 11/10/2016 RIGHTS RESERVED. REPRODUCTION BY ANY MEANS D.KAPLACHINSKI DRAWING IS THE 11/10/2016 PROPERTY OF PEI-Genesis, ALL P.KIM THISRIGHTS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY RESERVED. REPRODUCTION BY ANYPROHIBITED MEANS WITHOUT THE WRITTEN PERMISSION OF THIRD ANGLE PROJECTION 11/10/2016 P.KIM OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY A NTS 2A589 SHEET 1 OF 1 A AN AUTHORIZED AGENT OF PEI-GENESIS. TITLE CAGE CODE: 1 Voltage Rating: IPMOD-45FSL IPMOD-45WJP-XM BL/WH BR/WH Notes 14 BL SIZE 4 SCALE A 3 NTS SHEET 1 OF 1 A DATE DATE DATE APPROVED BY THIRD ANGLE PROJECTION APPROVED BY SCALE SIZE DRAWN: ENGINEER: DATE ENGINEER: VER REV REV DRAWN: CAGE CODE: 6 7 6 7 1 2 3 plated OUT6 OF 4 SEQUENCE 5 7 8 SHELL NOTES: IP67 (NO INGRESSresistance: OF DUST/PROTECTED AGAINST ≤ HARMFUL 1. WATERPROOF RATE:Contact C 40MΩ EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) NOTES: -20vC TO +80vC 2. TEMPERATURE RANGE: Withstanding Voltage: AC AGAINST 1000V/1 minute 1. WATERPROOF RATE: IP68 (NO INGRESS OF DUST/PROTECTED HARMFUL GASKET CHAIN) 3. MAX PANEL THICKNESS 4.0mm EFFECT(WITHOUT CAUSED IN CAP 1 METER WATER WITHIN 24 HOURS) C TO +85 vC 2. TEMPERATURE RANGE: -40vGOLD, NYLON, BLACK PLUG: 8P8C, PLATED, SHIELDED 4. MATERIAL: HOUSING:Salt Spray: 48 SCREW hr. MAX PANEL THICKNESS: 3. COPPER NUT: NYLON, BLACK PIN: ALLOY, GOLD 4.0mm PLATED(WITHOUT CAP CHAIN) B PIN: COPPER ALLOY, GOLD PLATED SCREW 4. MATERIAL: HOUSING: NYLON, BLACK PVC SCHEMATIC 24AWG*4P+MYLAR+DRAIN+AI.MYLAR BLACK, UV RESISTANT, 5. CABLE: CAT.5E FTP Protection IP68 (mated) B NUT: NYLON, BLACK Class: OD=O6.50mm P1 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, OR/WH WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. ITEMS IDENTIFIED Durability: 1 1000 times OD=O6.50mm OR 2 PKG-001 7. REFERENCE PACKAGING6. SPECIFICATIONS ITEMS IDENTIFIEDPER WITHDOC# DIAMOND ( ... ) MUST BE INSPECTED. GN/WH 3 OUT SPECIFICATIONS PER DOC# PKG-001 7. REFERENCE PACKAGING Rating: 1A 8.GN RoHS COMPLIANT. Current 6 OF VER ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 3 2 DATE DATE ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 1 1 A www.peigenesis.com RJ45 Jamnut Receptacle To Blunt Cut 6 7 5 3 4 1 DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 F F Composite Connector series: RJ45 25.4 1.00" Gender: Receptacle Performance: Cat 5e PIN 8 Mounting type: Straight 29.3 1.15" Part No.: IPMOD-45FSL-XM (REF) 500 ±20 33.9 ±0.50 [ 1.33" ±.02 ] (HEX) E E 19.2 .76" PIN 1 X refers to cable length 6.5 ±.20 .26" ±.01 2 O 28.0 1.10" General Information RJ45 JACK D D Standard: IEC 60603-7 Temperature CRange: -20°C ~ +80°C Withstanding Voltage: AC 1000V/1 minute Terminal: 13/16"-28UN Copper alloy, gold plated Salt Spray: NOTES: Contact Number: 8 contacts Contact Housing: Nylon+CF Screw Nut: Nylon20.8+±0.1GF B *Cable Length: ≤ 40MΩ C 500 mm P1 1 2 5 3 OUT OF 6 4 SEQUENCE 5 7 8 SHELL 33.9 ±0.50 6 RECOMMENDED PANEL CUT-OUT Connector series: RJ45 25.4 1.00" (HEX) Gender: Receptacle Performance: Cat 5ePIN 8 29.3 Mounting type: Straight 1.15" (REF) Part No.: IPMODM-45FSL-XM PIN 1 1. WATERPROOF RATE: IP68 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL Protection Class: (mated) EFFECT CAUSED IN 1 METERIP68 WATER WITHIN 24 HOURS) Durability:3. MAX PANEL THICKNESS: 4.0mm 1000 (WITHOUTtimes CAP CHAIN) 4. MATERIAL: HOUSING: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED SCHEMATICCurrent Rating: 1A OR/WH OR 6 5 Voltage GN/WH 4 GN BL BL/WH SCREW NUT: NYLON, BLACK 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, Rating: 48V OD=O6.50mm IDENTIFIED WITH DIAMOND ( 2X ... 1 ) MUST BE INSPECTED. 1 6. ITEMS 3 REVISIONS PER DOC# PKG-001 7. REFERENCE PACKAGING REV ZONE ECO#SPECIFICATIONS DESCRIPTION DRAW APPD DATE INITIAL RELEASE KC PK 11/10/16 8. RoHS COMPLIANT. A JACK, PNL RJ45 WS / PC TL 0.5M TITLE WH ADDED RoHS NOTE; ADDED CABLE DIA TOLS IPMOD-45FSL PART NUMBER BR/WH UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 500 ±20 [ 1.33" ±.02 ] NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 48 hr. 2. TEMPERATURE RANGE: -40vC TO +85vC 19.4 ±0.1 .764" ±.004 F A GASKET NUT Screw Thread 7 Contact resistance: O 20.6 .811" O .819" ±.004 Mating Style: Metal DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: 2A589 SIZE SCALE A 4 NTS SHEET 1 OF 1 VER REV KCHOD D.KAPLACHINSKI P.KIM A KC FA DATE 2180 Hornig Road, Philadelphia, PA 19116 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 11/10/2016 DATE 11/10/2016 2 1 E 19.2 .76" 6.5 ±.20 .26" ±.01 2 O 28.0 1.10" X refers to cable length D General Information RJ45 JACK D Standard: IEC 60603-7 Temperature CRange: -20°C ~ +85°C O 20.6 .811" Contact resistance: Copper alloy, gold plated Contact Number: 8 contacts Contact Housing: Nylon+GF B NUT ±0.1 nickel plated Zinc alloy, O 20.8 .819" ±.004 Mating Style: Screw Thread *Cable Length: 500 mm OUT OF SEQUENCE 19.4 ±0.1 .764" ±.004 A NOTES: Salt Spray: 48 hr. 1. WATERPROOF RATE: IP68 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL GASKET EFFECT CAUSED IN 1 METER WATER WITHIN 24 HOURS) Protection2. Class: IP68 (mated) TEMPERATURE RANGE: -40vC TO +85vC MAX PANEL THICKNESS: 4.0mm (WITHOUTtimes CAP CHAIN) 3. Durability: 1000 4. MATERIAL: HOUSING: NYLON, BLACK PIN: COPPER ALLOY, GOLD PLATED SCREW SCHEMATIC NUT: NYLON, BLACK Current Rating: 1A P1 5. CABLE: CAT.5E FTP 24AWG*4P+MYLAR+DRAIN+AI.MYLAR PVC BLACK, UV RESISTANT, OR/WH 1 O 6.50mm OD= OR Voltage Rating: 48V 2 6. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. GN/WH 3 GN REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. 6 BL 8. RoHS COMPLIANT. 4 BL/WH 5 IPMOD-45FSL BR/WH 7 A JACK, PNL RJ45 WS / PC TL 0.5M WH 8 2180 Hornig Road, Philadelphia, PA 19116 11/10/2016 KCHOD 11/10/2016 SHELL D.KAPLACHINSKI C B PART NUMBER REV TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY RECOMMENDED PANEL CUT-OUT CAGE CODE: 6 5 • Please refer to Page 5 for part number breakdown. * If no cable length is defined, the standard is 500 mm. 4 2A589 SIZE SCALE A 3 NTS DRAWN: DATE ENGINEER: DATE APPROVED BY THIRD ANGLE PROJECTION NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 ≤ 40MΩ Withstanding Voltage: AC 1000V/1 minute 13/16"-28UN Terminal: Notes B 2/15/17 DATE ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 3 PK A E Screw Nut: RJ45 Receptacles 2 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE; ADDED CABLE DIA TOLS SHEET 1 OF 1 VER P.KIM A DATE 11/10/2016 ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 A NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 1 15 www.peigenesis.com RJ45 Feedthru Adapter 6 7 5 3 4 2 1 REVISIONS REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE DRAW APPD DATE KC PK 11/10/16 KC PK 2/15/17 F Accessories Connector series: RJ45 Gender: Adapter Locking type: Fix screw Part No.: IPMOD-45FSWBHD F 62.0 2.44" 14.4 (REF) [ .567" ] 29.3 (REF) 1.15" O 28.0 1.10" O 6.2 [ .24" ] E E 25.4 (HEX) 1.00" O 20.6 .811" PIN 8 D PIN 1 D 13/16"-28UN RJ45 JACK General Information Standard: IEC 60603-7 Temperature range: -20°C ~ +80°C 3 NUT Terminal: Copper alloy, gold plated Contact number: 8 contacts Contact housing: Nylon+GF Screw nut: Nylon + GF A 16 Screw Thread IP67 (mated) Durability: RECOMMENDED PANEL CUT-OUT 6 5 1000IPMOD-45FSWBHD times PART NUMBER JACK, PNL RJ45 WS/WS COUPLER TITLE Current rating: NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. B 48 hr. Protection class: 7 Mating style: Salt spray: 19.4 ±0.1 .764" ±.004 ≤ 40MΩ NOTES: 1. WATERPROOF RATE: IP67 (NO INGRESS OF DUST/PROTECTED AGAINST HARMFUL EFFECT CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -20vC TO +80vC 3. MATERIAL: PIN: COPPER ALLOY, GOLD PLATED HOUSING: NYLON, BLACK SCREW NUT: NYLON, BLACK 4. MAX PANEL THICKNESS: 4.0mm (WITHOUT CAP CHAIN) 5. ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. 6. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 7. RoHS COMPLIANT. Withstanding voltage: AC 1000V/1 minute GASKET B ±0.1 O 20.8 .819" ±.004 C RJ45 JACK Contact resistance: 13/16"-28UN PIN 1 PIN 8 29.3 1.15" 19.2 .756" C 4 Voltage rating: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 1A DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION CAGE CODE: 2A589 SIZE SCALE A NTS SHEET 1 OF 1 VER KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 3 48V REV A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/10/2016 11/10/2016 DATE 11/10/2016 1 www.peigenesis.com F E 4 TITLE A SCALE 1 NTS VER A DRAWN: ENGINEER: APPROVED BY REVISIONS ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT REV A 11/11/16 DATE 11/11/16 11/11/16 DATE DATE 1 DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 2180 Hornig Road, Philadelphia, PA 19116 1 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. F E D C B A F E D C B A 6 6 4 4 CAGE CODE: SIZE 3 3 SCALE 1 NTS 2 REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE. SHEET 1 OF 1 VER A DRAWN: ENGINEER: APPROVED BY 2 REVISIONS ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT KCHOD D.KAPLACHINSKI P.KIM IPCAP-1316 A 11/11/16 11/11/16 DATE DATE 11/11/16 DATE REV 1 DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 1 NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 2180 Hornig Road, Philadelphia, PA 19116 NOTES: 1. WATERPROOF RATE: ACCORDING TO THE RATE OF MATING CONNECTOR, HIGHEST WATERPROOF RATE IP67 (NO INGRESS OF DUST/PROECTED AGAINST HARMFUL EFFECTS CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40vC TO +105vC 3. MATERIAL: SCREW NUT: NYLON, BLACK HOLDER: NYLON, BLACK GASKET: EPDM, BLACK WASHER: STAINLESS STEEL METAL CHAIN: STAINLESS STEEL, Ø3.0 METAL CHAIN LENGTH: 80+/-5mm ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 RoHS COMPLIANT. 4. 5. 6. 7. SEALING CAP 13/16 28UN A THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY TITLE PART NUMBER Material, chain: 2A589 Nylon, black 5 18.8 .742" 5 Material, holder: 7 7 NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. Material, gasket: 2 2 KCHOD D.KAPLACHINSKI P.KIM Copper alloy, nickel plated REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE. SHEET 1 OF 1 Stainless steel Material, cap: 3 3 IPCAP-1316 NOTES: 1. WATERPROOF RATE: ACCORDING TO THE RATE OF MATING CONNECTOR, HIGHEST WATERPROOF RATE IP67 (NO INGRESS OF DUST/PROECTED AGAINST HARMFUL EFFECTS CAUSED IN 1 METER WATER WITHIN 30 MINUTES) 2. TEMPERATURE RANGE: -40vC TO +105vC 3. MATERIAL: SCREW NUT: NYLON, BLACK HOLDER: NYLON, BLACK GASKET: EPDM, BLACK WASHER: STAINLESS STEEL METAL CHAIN: STAINLESS STEEL, Ø3.0 METAL CHAIN LENGTH: 80+/-5mm ITEMS IDENTIFIED WITH DIAMOND ( X ... 1 ) MUST BE INSPECTED. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 RoHS COMPLIANT. 4. 5. 6. 7. SEALING CAP 13/16 28UN PART NUMBER SIZE THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY EPDM, black -40°C ~ +105°C 5 2A589 O 27.2 1.07" Accessories 6 CAGE CODE: IP67 Protection class: Temperature range: 7 4 Nylon, black D 18.8 .742" 5 General Information Stainless steel Material, chain: Material, holder: 19.4 .764" O 24.5 .965" EPDM, black Nylon, black 13/16"-28UN 31.3 [1.23"] Connector series: RJ45 Part No.: IPCAPM-1316 Material, gasket: Material, cap: C 6 RJ45 Receptacle Metal Cap IP67 -40°C ~ +105°C B A Connector series: RJ45 Part No.: IPCAP-1316 Protection class: Temperature range: O 27.2 1.07" 7 General Information 19.4 .764" O 24.5 .965" 13/16"-28UN 31.3 [1.23"] NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. RJ45 Receptacle Cap O 20.8 .819" 10.0 [.394"] O 20.8 .819" 10.0 [.394"] F E D C B A 17 www.peigenesis.com 6 7 6 7 RJ45 Gasket 5 3 4 5 3 4 2 REVISIONS 1 REVREVISIONS ZONE ECO# DESCRIPTION INITIAL RELEASE DRAW APPD DATE A ADDED RoHS NOTE KC PK 11/11/16 KC PK 2/13/17 2 REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE F DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 F F F O 28.0 1.10" O 28.0 1.10" Connector series: RJ45 O Part No.: IPGSK-1316 19.5 .768" E O 22.0 .866" O 19.5 .768" E O 22.0 .866" B B E E O 26.7 1.05" O 26.7 1.05" Accessories 1 D D D D SECTION A-A SECTION A-A C C C C 2.6 .10" 2.6 .10" General Information 2.0 .08" 2 2.0 .08" 2 NOTES: 3 NOTES: 1. MATERIAL: SILICONE (UL94V-0) 1. MATERIAL: SILICONE (UL94V-0) 2. COLOR: GRAY B 2. COLOR: GRAY 4 3. 10 PCS GASKET PUT INTO ONE PE BAG BAGIDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 4 3. 10 PCS GASKET PUT INTO ONE 4. PE ITEMS 4. ITEMS IDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 5. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 5. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 6. RoHS COMPLIANT. 6. RoHS COMPLIANT. 3 B B Material: Silicone (UL94V-0) Packaging: Color: Pack of 10 DETAIL B DETAIL B A CAGE CODE: THIRD ANGLE PROJECTION 6 6 5 5 6 7 TITLE CAGE CODE: 2A589 4A 5 SCALE SIZE 4 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MMREV TOLERANCE EXCEPT AS NOTED: .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES DATE ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY 11/11/16 A KCHOD THIRD ANGLE PROJECTION 11/11/16 D.KAPLACHINSKI AP.KIM NTS SHEET 1 OF11/11/16 2A589 1 A GASKET CIRCULAR 13/16 10PK UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. 7 IPGSK-1316 IPGSK-1316GASKET CIRCULAR 13/16 10PK PART NUMBER TITLE 7 Gray PART NUMBER A NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. SHEET 1 OF 1 NTS DECIMAL DRAWN: ENGINEER: DATE SCALE SIZE BY APPROVED VER 3 A DATE VER ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 3 4 REV KCHOD DRAWN: A DATE A A 2180 Hornig Road, Philadelphia, PA 19116 11/11/16 2180 Hornig Road, Philadelphia, PA 19116 11/11/16 D.KAPLACHINSKI ENGINEER: NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. DATE APPROVED BY P.KIM DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL 11/11/16 ©COPYRIGHT 2004 PEI-GENESIS RIGHTS RESERVED. REPRODUCTION BY ANY MEANS PRODUCT DEVELOPMENT OR DISTRIBUTION TOENGINEERING THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT 2 THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 2 3 1 1 2 1 REVISIONS RJ45 Lock Nut REV ZONE ECO# DESCRIPTION INITIAL RELEASE A ADDED RoHS NOTE DRAW APPD DATE KC PK 11/11/16 KC PK 2/13/17 F F Connector series: RJ45 Part No.: IPNT-1316 29.3 1.15" 4.0 .16" E E 25.4 1.00" D D 13/16"-28 UN C C B General Information 3 NOTES: 1. MATERIAL: NYLON 2. COLOR: BLACK 3. BURR: 0.15mm MAX 4. ITEMS IDENTIFIED WITH DIAMOND ( 1 ... X ) MUST BE INSPECTED. 5. REFERENCE PACKAGING SPECIFICATIONS PER DOC# PKG-001 6. 10 PCS NUT PUT INTO ONE PE BAG 7. RoHS COMPLIANT. IPNT-1316 PART NUMBER A Nylon Packaging: Pack of 10 Color: NOTE: CAD GENERATED DRAWING DO NOT UPDATE MANUALLY. CAGE CODE: 6 5 4 2A589 SIZE SCALE A 3 NTS SHEET 1 OF 1 REV DRAWN: ENGINEER: APPROVED BY THIRD ANGLE PROJECTION 7 18 NUT 13/16 28UN PLASTIC 10PK TITLE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM TOLERANCE EXCEPT AS NOTED: DECIMAL .X ±0.25 .XX ±0.1 .XXX ±0.05 ANGLES ±1v IMPERIAL DIMENSIONS ARE FOR REFERENCE ONLY Material: B VER KCHOD D.KAPLACHINSKI P.KIM A ©COPYRIGHT 2004 PEI-GENESIS ENGINEERING PRODUCT DEVELOPMENT 2 B A A DATE 2180 Hornig Road, Philadelphia, PA 19116 DATE NOTICE OF CONFIDENTIALITY THIS DRAWING IS THE PROPERTY OF PEI-Genesis, ALL RIGHTS RESERVED. REPRODUCTION BY ANY MEANS OR DISTRIBUTION TO THIRD PARTIES IS S TRICTLY PROHIBITED WITHOUT THE WRITTEN PERMISSION OF AN AUTHORIZED AGENT OF PEI-GENESIS. 11/11/16 11/11/16 DATE 11/11/16 Black 1 www.peigenesis.com RJ45 Assembly Instructions RJ45 Field Wireable Assembly Instructions Step 1 Step 2 Step 3 Strip the cable sheath and insulation. Insert the cable through the sealing nut, clip, seal, screw nut and housing. Insert cable into plug using hand tool. Step 4 Step 5 Step 6 Step 7 Insert the screw nut. Connect the seal and the clip respectively. Connect the sealing nut and tighten using hand tool (optional) or your hand while holding assy. Insert the gasket. 19 www.peigenesis.com Part Numbers Part Numbers 20 All RJ45 Series P/Ns Catalog Page All RJ45 Series P/Ns Catalog Page All RJ45 Series P/Ns Catalog Page IPMOD-45WPP-1M 6 IPMOD-45WJWP-1M 11 IPGSK-1316 18 IPMOD-45WPP-3M 6 IPMOD-45WJWP-3M 11 IPNT-1316 18 IPMOD-45WPP-5M 6 IPMOD-45WJWP-5M 11 IPMODM-45WPP-1M 6 IPMOD-45FSP 12 IPMODM-45WPP-3M 6 IPMODM-45FSP 12 IPMODM-45WPP-5M 6 IPMOD-45FSBHD 13 IPMOD-45WPL-1M 7 IPMODM-45FSBHD 13 IPMOD-45WPL-3M 7 IPMOD-45FSLP 14 IPMOD-45WPL-5M 7 IPMOD-45FSLP-1M 14 IPMODM-45WPL-1M 7 IPMOD-45FSLP-3M 14 IPMODM-45WPL-3M 7 IPMOD-45FSLP-5M 14 IPMODM-45WPL-5M 7 IPMODM-45FSLP 14 IPMOD-45WPWP-1M 8 IPMODM-45FSLP-1M 14 IPMOD-45WPWP-3M 8 IPMODM-45FSLP-3M 14 IPMOD-45WPWP-5M 8 IPMODM-45FSLP-5M 14 IPMODM-45WPWP-1M 8 IPMOD-45FSL 15 IPMODM-45WPWP-3M 8 IPMOD-45FSL-1M 15 IPMODM-45WPWP-5M 8 IPMOD-45FSL-3M 15 IPMOD-45WM-FT 9 IPMOD-45FSL-5M 15 IPMODM-45WM-FT 9 IPMODM-45FSL 15 IPMOD-45WJP-1M 10 IPMODM-45FSL-1M 15 IPMOD-45WJP-3M 10 IPMODM-45FSL-3M 15 IPMOD-45WJP-5M 10 IPMODM-45FSL-5M 15 IPMOD-45WJL-1M 10 IPMOD-45FSWBHD 16 IPMOD-45WJL-3M 10 IPCAP-1316 17 IPMOD-45WJL-5M 10 IPCAPM-1316 17 Corporate Headquarters, Philadelphia, PA European Headquarters & Production Facility, Southampton, UK North American Production Facility, South Bend, IN Production Facility, Zhuhai, China FilConn, Chandler, AZ PEI-Genesis has sales offices throughout the Americas, Europe and Asia. Visit www.peigenesis.com, call +1 800.675.1214 (North America), +44 (0) 23 8062 1260 (Europe), +86 756 7683 088 (Asia), +1 631.475.5050 (Rest of World), or email: sales@peigenesis.com. www.peigenesis.com | www.peigenesis.cn 21
IPMOD-45FSP 价格&库存
很抱歉,暂时无法提供与“IPMOD-45FSP”相匹配的价格&库存,您可以联系我们找货
