35HDLSN17
35HDLSN17
    SWITCHCRAFT
    3.50mm(0.141",1/8",迷你型插头)- 耳机 电话插头 立体声(3 导体,TRS) 连接器 焊接孔眼
35HDLSN17 数据手册
2.43 61.7 0.43 10.8 1.61 40.8 0.50 12.7 "A" REF CABLE HOLE SEE TABLE 0.14 3.5 0.30 7.6 0.50 12.7 OVERMOLDED HANDLE & TUBULAR INSULATOR SHIPPED UNASSEMBLED CABLE CLAMP SLEEVE TERMINAL O-RING RING TERMINAL 3 5 H D L S __ __ NOTES: LOCKING TIP TERMINAL 1. SPECIFICATIONS: CONTACT RESISTANCE: 20 MILIOHMS MAX. DIELECTRIC WITHSTANDING VOLTAGE - 250 VAC MIN INSULATION RESISTANCE @ 500 VDC - 2,000 MEGAOHMS MIN MAX WORKING VOLTAGE - 250 VAC, 140VDC CURRENT CARRY @ WORKING VOLTAGE - 4 AMPS INSERT / WITHDRAWAL FORCE - TYPICAL 2.5/2 LBS TEMPERATURE RANGE: -20°C TO 85°C (OPERATING) PASSES IP67 & IP68 AFTER: THERMAL SHOCK - MIL-STD-202, METHOD 107G VIBRATION - MIL-STD-202, METHOD 201 LIFE - 5,000 CYCLES SEALED 1.09 27.8 CABLE OD RANGE 0.125" - 0.150" 0.150" - 0.175" 0.175 - 0.210" PLUG FINISH N - TIN PLATED AU- GOLD PLATED 1.94 49.3 CUSTOMER DRAWING 2. MATERIALS: PLUG BODY, TIP ROD & RING - COPPER ALLOY, TIN OR GOLD PLATED PLUG INSULATION - THERMOPLASTIC, BLACK RING TERMINAL - COPPER ALLOY, TIN PLATED CABLE CLAMP - STEEL, TIN PLATED COUPLING RING - COPPER ALLOY, NICKEL PLATED HANDLE - COPPER ALLOY, NICKEL PLATED OVERMOLDED THERMOPLASTIC TUBULAR INSULATOR - MYLAR THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] SIZE REV * * ECO NUMBER DATE REVISIONS * BY FINISH - TWO PLACE DECIMALS 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] SPEC No. FIRST USED ON 05/17/18 * APVD WIDTH * DATE DRAWN * 3. THESE PRODUCTS ARE RoHS COMPLIANT. 12 15 17 - DO NOT SCALE DRAWING SolidWorks CAD File NAME B * * * AM LBS/M * TEMPER * * * MATERIAL SPEC No. * SCALE 1:1 * BY MULT CHKD * * APVD * * 3.5MM LOCKING SEALED STEREO PLUG, RoHS SHEET PART No. 1 OF 35HDLS SERIES 1 REV 0A
35HDLSN17 价格&库存
很抱歉,暂时无法提供与“35HDLSN17”相匹配的价格&库存,您可以联系我们找货
35HDLSN17
    • 1+221.637941+28.78965
    • 10+177.6836310+23.08021
    • 25+166.5605625+21.63538
    • 100+160.10777100+20.79719
    • 300+148.17702300+19.24745
    • 500+142.93826500+18.56696
    库存:39
