2.17
55.2
0.50
12.7
1.61
40.8
0.50
12.7
"A" REF
CABLE HOLE
SEE TABLE
0.14
3.5
OVERMOLDED HANDLE AND TUBULAR INSULATOR
SHIPPED UNASSEMBLED
CABLE CLAMP
SLEEVE TERMINAL
0.53
13.5
O-RING
RING TERMINAL
3 5 H D S __ __
TIP TERMINAL
NOTES:
1. SPECIFICATIONS:
CONTACT RESISTANCE: 20 MILIOHMS MAX.
DIELECTRIC WITHSTANDING VOLTAGE - 250 VAC MIN
INSULATION RESISTANCE @ 500 VDC - 2,000 MEGAOHMS MIN
MAX WORKING VOLTAGE - 250 VAC, 140VDC
CURRENT CARRY @ WORKING VOLTAGE - 4 AMPS
INSERT / WITHDRAWAL FORCE - TYPICAL 2.5/2 LBS
TEMPERATURE RANGE: -20°C TO 85°C (OPERATING)
PASSES IP67 & IP68 AFTER:
THERMAL SHOCK - MIL-STD-202, METHOD 107G
VIBRATION - MIL-STD-202, METHOD 201
LIFE - 5,000 CYCLES
2. MATERIALS:
PLUG BODY, TIP ROD & RING - COPPER ALLOY, TIN OR GOLD PLATED
PLUG INSULATION - THERMOPLASTIC, BLACK
RING TERMINAL - COPPER ALLOY, TIN PLATED
CABLE CLAMP - STEEL, TIN PLATED
COUPLING RING - COPPER ALLOY, NICKEL PLATED
HANDLE - COPPER ALLOY, NICKEL PLATED
OVERMOLDED THERMOPLASTIC
TUBULAR INSULATOR - MYLAR
3. THESE PRODUCTS ARE RoHS COMPLIANT.
SEALED
1.06
27.0
12 15 17 -
1.62
41.2
CABLE OD RANGE
0.125" - 0.150"
0.150" - 0.175"
0.175 - 0.210"
PLUG FINISH
N - TIN PLATED
AU- GOLD PLATED
CUSTOMER DRAWING
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES [mm]
SIZE
FINISH
- TWO PLACE DECIMALS
0.02
[0.5]
- THREE PLACE DECIMALS
0.005 [0.13]
SPEC No.
FIRST USED ON
DATE DRAWN
REV
ECO NUMBER
DATE
REVISIONS
BY
05/24/18
APVD
WIDTH
DO NOT SCALE DRAWING
SolidWorks CAD File
NAME
B
AM
LBS/M
TEMPER
MATERIAL
SPEC No.
SCALE
2:1
BY
MULT
CHKD
APVD
3.5MM SEALED, RoHS
STEREO PLUG
SHEET
PART No.
1
OF
35HDS SERIES
1
REV
0A
很抱歉,暂时无法提供与“35HDSN15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+140.200581+18.13709
- 10+119.1485810+15.41369
