NOTES:
1. ALL PARTS TO BE BULK PACKED.
2. CONTACTS ASSEMBLED INTO CONNECTOR.
SOLDER CUPS FACING TOP KEY.
3. ALL DIMENSIONS ARE REFERENCE ONLY
EXCEPT WHERE NOTED WITH A TOLERANCE.
DIMENSIONS IN BRACKETS [ ] ARE METRIC.
ASS'Y P/N
CONTACTS
W4282-10PG-300
W4282-11PG-300
W4282-12PG-300
W4282-1XPG-300
10 - #20
11 - #20
12 - #20
HOLE POS.
CLOSED
11, 12
12
NONE
NO. OF CONTACTS
3
3
2
10
9
4
CUSTOMER PRINT
6
10
4
9
8
5
8
5
2
11
6
7
7
FACE VIEW
FACE VIEW
W4282-10PG-300
10-POS.
.980
W4282-11PG-300
11-POS.
TOP
KEY
.550
.153
.205
[5.2mm]
[14.0mm]
[3.9mm]
[26.8mm]
.104±.020
[2.6 0.5mm]
3
2
11
10
4
9
TOP
KEY
0D
6
12
3
10
[25.4mm]
FLATS
11
5
8
7
7
.793
[20.1mm]
4
9
8
5
2
1
1.000
12
PIN CONTACT
SOLDER CUP
GOLD PLATED
6
.742
[18.9mm]
FACE VIEW
W4282-12PG-300
12-POS.
HEX NUT
MAT'L: UV THERMOPLASTIC,
BLACK 0B
0C
O-RING
MAT'L: RUBBER,
BLACK
13/16-27 UNS-2A
MOD. THREAD
PANEL INSERT, PIN
0B BLACK
0C
WIRE VIEW
W4282-10PG-300 - 10-POS. (11&12 CLOSED)
W4282-11PG-300 - 11-POS. (12 CLOSED)
W4282-12PG-300 - 12-POS. (ALL OPEN)
.188 MAX
[4.8mm]
.750
.003
PANEL THICKNESS
[19.1mm]
PRELIMINARY
.790±.003
PART
NUMBER:
W4282-1XPG-300
FLAT
[20.0mm]
CUSTOMER APPROVAL
RECOMMENDED
PANEL CUTOUT
STANDARD MULTI-CON-X
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
APPROVED BY:
DATE:
0D
PAK
02/27/17
MODIFIED CONTACT TOLERANCE
0C
PAK
10/07/16
CHANGED MATERIAL FROM CHARCOAL BLACK TO BLACK
0B
PAK
02/18/15
CHANGED MATERIAL FROM BLACK TO CHARCOAL BLACK
0A
PAK
10/13/14
DRAWING CREATED PER DOR 10-2523JS-1
REV. INIT.
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
DESCRIPTION
ORIG. DRAWN BY:
DATE:
10/07/14
PAK
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
SHEET
NTS
B
1 OF 1
FILE:
W4282-1XPG-300
DIRECTORY:
SLW
PANEL PIN, E-KEY
#20 SOLDER, 12-POS. PATTERN
MULTI-CON-X, WEATHER RESISTANT
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
W4282-1XPG-300
REV
0D
很抱歉,暂时无法提供与“W4282-12PG-300”相匹配的价格&库存,您可以联系我们找货
