TG-A486C-640-320-10.0-1A
    T-GLOBAL
    THERM PAD 640MMX320MM W/ADH GRAY
TG-A486C-640-320-10.0-1A 数据手册
H48-6C Thermal Conductive Pad Features Very good thermal conductivity Very soft and compressible Natural tack Easy to assemble Very good insulator Applications Electronic components: IC / CPU / MOS LED / M/B / P/S / Heat Sink / LCD-TV / Notebook PC / PC / Telecom Device / Wireless Hub etc.... DDR II Module / DVD Applications / Hand-Set applications etc... Thermal Resistance V.S Pressure V.S Deflection REACH Compliant Properties RoSH Compliant Thermal Conductivity: 3.2 W/mK (W/mK - Z Axis) Hardness: 15 (Shore A) (Shore A) In the thermal resistance vs pressure vs deflection charts H48-6C provides low thermal impedance.  As the pressure increases the thermal impedance decreases. H48-6C provides good compliance and softness. Property H48-6C Unit Tolerance Colour Thickness (Available thickness range) Test Method Dark grey - - Visual 0.3 - 20 mm - ASTM D374 0.0118 - 0.787 inch - ASTM D374 Thermal Conductivity 3.2 W/mK - ASTM D5470 Flammability Rating V-0 - - UL 94 Dielectric Breakdown Voltage ›5 kV/mm - ASTM D149 Weight Loss ‹1 % - ASTM E595 Specific Gravity 2.42 g/cm3 ±0.2 ASTM D792 Working Temperature -40 to 200 ˚C - - Volume Resistance ›1011 Ohm-cm - ASTM D257 Elongation 130 % ±13 ASTM D412 Tensile Strength 8 Kgf/cm ±2 ASTM D412 Standard Shape - Sheets 320-320mm - - Hardness 15 Shore A ±5 ASTM D2240 2 Available with an adhesive backing 1. Part Number 2. Size X-Y-Z 3. Adhesive backing – 0-None, 1A-one side, 2A-two sides 4. Quantity Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
TG-A486C-640-320-10.0-1A 价格&库存
很抱歉,暂时无法提供与“TG-A486C-640-320-10.0-1A”相匹配的价格&库存,您可以联系我们找货
