TG4040-D-30CC
TG4040-D-30CC
    T-GLOBAL
    SILICONE PUTTY IN 30CC SYRINGE
TG4040-D-30CC 数据手册
TG4040 & TG6060 PUTTY Thermal Putty Features Silicone-type spacer with great long term reliability Lower thermal resistance than thermal pads Physical property between liquid and solid state Elimination of different gap between heat source and the heatsink Can be applied with dispenser Applications Electronic components: IC, CPU, MOS,LED,Mother Board, Power Supply, Heat Sink, LCD-TV, Notebook , PC, Telecom Device, Wireless Hub etc. Properties Operation Manual - Gel Gun TAKE OFF INSERT TWIST PUSH STEP1-Push the latch and STEP 2-Put the tube in and twist STEP3-Close the cover STEP4-Take off the Reliability-Thermal Impendence Properties Thermal Conductivity Color Solid content Viscosity 0.5rpm Density Volume Resistivity Working Temperature Standard package Need Samples? TG4040 Putty TG6060 Putty 3 6 Unit W / mK Blue Blue - - Visual 100(one-part) 100(one-part) % - - 2,500~3,000 Pa·s - Brookfield g / cm Ohm-m - ASTM D792 - ASTM D257 °C Tube/Pot - - 3,000 3 13 10 -50~+180 90g/165g/1KG 3.3 13 10 -50~+180 99g/181g/1KG 3 Tolerance Test Method ±0.3 ASTM D5470 T-Global Technology Co., Ltd No. 33, Ln. 50, Daren Rd., Taoyuan Dist., Taoyuan City 330, Taiwan TEL: +886-3-3618899 www.tglobalthermal.com FAX: +886-3-3665666 www.tglobal.com.tw Thermal Interface Materials: Thermal Pad, Thermal Tape, Thermal Grease, Ceramic Heat Spreader Version4 20170701
TG4040-D-30CC 价格&库存
很抱歉,暂时无法提供与“TG4040-D-30CC”相匹配的价格&库存,您可以联系我们找货
