BPH323023W5-390T
BPH323023W5-390T
    TAI-TECH(台庆)
    SMD,3.08x2.9x2.2mm
    39 Ohms @ 100 MHz 1 电源线 铁氧体磁珠和芯片 非标准 21A 0.6 毫欧
BPH323023W5-390T 数据手册
TAI-TECH P2 High Current Ferrite Bead BPH322521W5-350T 1. Features 1. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 2. Operating temperature -40~+125℃ (Including self - temperature rise) Halogen 2. Dimension Halogen-free CORE SIZE A(mm) B(mm) C(mm) D(mm) 3.10±0.15 2.50±0.15 2.10±0.15 0.90±0.15 PRODUCT SIZE A(mm) B(mm) C(mm) D(mm) E(mm) F(mm) G(mm) 3.10±0.15 2.50±0.15 2.15±0.15 0.85±0.20 1.20±0.20 0.00~0.10 0.70±0.10   3. Part Numbering BPH 322521 W5 A B - C 350 T D E A: Series B: Dimension C: Material Ferrite Core D: Impedance 350=35Ω E: Packaging T=Taping and Reel 4. Specification TAI-TECH Part Number BPH322521W5-350T ELECTRICAL REQUIREMENTS 1 ELECTRICAL REQUIREMENTS 2 Test Impedance Tolerance Frequency (Ω) (%) (MHz) Test Impedance Tolerance Frequency (Ω) (%) (MHz) 25 25 ±25 35 Note: Rated Current: (1) : Chroma high current test fixture. www.tai-tech.com.tw ±25 100 DCR (mΩ) Max. Rated Current(A) △T=40℃ TYP. 0.60 21.0 TAI-TECH P3 Typical Impedance v.s. Frequency Curve IMPEDANCE(Ohm) 100 10 1 1 10 100 1000 FREQUENCY(MHz) 5. Material List No. Description Specification a. Core Ferrite Core b. Wire Electroplated nickel-tin flat copper wire 6. Recommended PC Board Pattern www.tai-tech.com.tw 10000 TAI-TECH P4 High Current Ferrite Bead BPH323023W5-400T 1. Features Halogen 1. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 2. Operating temperature-40~+125℃ (Including self - temperature rise) Halogen-free 2. Dimension PRODUCT SIZE A(mm) B(mm) C(mm) D(mm) E(mm) F(mm) G(mm) 2.90±0.10 2.20±0.10 0.80±0.20 1.20 Min. 0.00~0.11 0.85±0.10 3.08 +0.10/-0.15 3. Part Numbering BPH 323023 W5 A B - 400 T D E C A: Series B: Dimension C: Material Ferrite Core D: Impedance E: Packaging 400=40Ω T=Taping and Reel 4. Specification ELECTRICAL REQUIREMENTS 1 TAI-TECH Part Number BPH323023W5-400T ELECTRICAL REQUIREMENTS 2 Rated Current(A) Test Test Impedance Tolerance Impedance Tolerance Frequency Frequency (Ω) (%) (Ω) (%) (MHz) (MHz) 23 ±25 25 40 ±25 Note: Rated Current : (1) : Chroma high current test fixture. (2) :PCB test fixture ( 30x45mm copper pattern , 50um copper thickness). www.tai-tech.com.tw 100 DCR (mΩ) Max. △T=40℃ △T=60℃ TYP. TYP. 0.60 21.0(1) 15.0(2) 26.0(1) 18.0(2) TAI-TECH P5 Typical Impedance v.s. Frequency Curve IMPEDANCE(Ohm) 100 10 1 1 10 100 1000 10000 FREQUENCY(MHz) 5. Material List No. a. Description Core Specification Ferrite Core a Electroplated nickel-tin flat copper wire b. Wire (0.8W X 0.25T)mm b 6. Recommended PC Board Pattern L(mm) G(mm) H(mm) 3.70 1.10 1.10 www.tai-tech.com.tw TAI-TECH P6 High Current Ferrite Bead BPH403022R5-400T-G 1. Features 1. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen 2. Operating temperature -40~+125℃ (Including self - temperature rise) Halogen-free 2. Dimension PRODUCT SIZE A(mm) B(mm) C(mm) D(mm) E(mm) 3.90~4.50 3.00±0.15 2.20 Max 1.00±0.20 1.25±0.15   3. Part Numbering BPH 403022 R5 A B - 400 T D E C - G F A: Series B: Dimension C: Material Ferrite Core D: Impedance 400=40Ω E: Packaging T=Taping and Reel F: Control S/N 4. Specification TAI-TECH Part Number BPH403022R5-400T-G ELECTRICAL REQUIREMENTS 1 ELECTRICAL REQUIREMENTS 2 Test Impedance Tolerance Frequency (Ω) (%) (Hz) Test Impedance Tolerance Frequency (Ω) (%) (Hz) 24 25M ±25 40 ±25 Note: Rated Current : (1) : Chroma high current test fixture. (2) : DCR is measured on a micro-ohmmeter at points indicat in the diagram. www.tai-tech.com.tw 100M DCR (mΩ) Max. 0.7 Rated Current(A) △T=40℃ TYP. △T=60℃ TYP. 20.0 28.0 TAI-TECH P7 Typical Impedance v.s. Frequency Curve IMPEDANCE(Ohm) 100 10 1 1 10 100 1000 10000 FREQUENCY(MHz) 5. Material List No. Description a. Core b. Wire Specification a Ferrite Core Electroplated nickel-tin flat copper wire (1.25W X 0.21T)m/m b 6. Recommended PC Board Pattern L(mm) G(mm) H(mm) 4.8 2.0 1.5 www.tai-tech.com.tw TAI-TECH P8 High Current Ferrite Bead BPH403025R5-530T 1. Features 1. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen 2. Operating temperature-40~+125℃ (Including self - temperature rise) 2. Dimension Halogen-free CORE SIZE A(mm) B(mm) C(mm) D(mm) 4.00±0.25 3.10±0.15 2.50±0.15 1.50±0.15 PRODUCT SIZE A(mm) B(mm) C(mm) D(mm) E(mm) 4.30~5.10 3.10±0.15 2.70~3.1 1.35±0.20 1.35±0.15 3. Part Numbering BPH 403025 R5 A B - 530 T D E C A: Series B: Dimension C: Material Ferrite Core D: Impedance 530=53Ω E: Packaging T=Taping and Reel 4. Specification TAI-TECH Part Number BPH403025R5-530T ELECTRICAL REQUIREMENTS 1 ELECTRICAL REQUIREMENTS 2 Test Test Impedance Tolerance Impedance Tolerance Frequency Frequency (Ω) (%) (Ω) (%) (MHz) (MHz) 35 ±25 25 53 ±25 100 Note: Rated Current : (1) : Chroma high current test fixture. (2) :PCB test fixture ( 30x45mm copper pattern , 50um copper thickness). www.tai-tech.com.tw DCR (mΩ) Max. 0.60 Rated Current(A) △T=40℃ TYP. △T=60℃ TYP. 35.0(1) 15.0(2) 45.0(1) 18.0(2) TAI-TECH P9 Typical Impedance v.s. Frequency Curve IMPEDANCE(Ohm) 100 10 1 1 10 100 1000 10000 FREQUENCY(MHz) 5. Material List No. Description a. Core b. Wire Specification a Ferrite Core Electroplated nickel-tin flat copper wire (1.25W X 0.21T)m/m b 6. Recommended PC Board Pattern L(mm) G(mm) H(mm) 4.8 1.4 1.5 www.tai-tech.com.tw TAI-TECH P10 High Current Ferrite Bead BPH403025MN5-470TP 1. Features 1. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen 2. Operating temperature -40~+125℃ (Including self - temperature rise) 2. Dimension Halogen-free CORE SIZE A(mm) B(mm) C(mm) D(mm) 4.00±0.25 3.10±0.15 2.50±0.15 1.50±0.15 PRODUCT SIZE A(mm) B(mm) 4.30~5.10 3.10±0.15 C(mm) D(mm) 2.70~3.10 1.35±0.20 E(mm) 1.35±0.15 3. Part Numbering BPH 403025 MN5 - A B 470 T P D E F C A: Series B: Dimension C: Material MnZn Core D: Impedance 470=47Ω E: Packaging T=Taping and Reel F: Surface coating Parylene coating 4. Specification TAI-TECH Part Number ELECTRICAL REQUIREMENTS 1 ELECTRICAL REQUIREMENTS 2 Test Impedance Tolerance Frequency (Ω) (%) (MHz) Test Impedance Tolerance Frequency (Ω) (%) (MHz) BPH403025MN5-470TP 20 ±25 1 47 ±25 Note: Rated Current : (1) : Chroma high current test fixture. (2) :PCB test fixture ( 30x45mm copper pattern , 50um copper thickness). www.tai-tech.com.tw Rated Current(A) 10 DCR (mΩ) Max. 0.75 △T=40℃ TYP. △T=60℃ TYP. 24.0(1) 10.0(2) 28.0(1) 13.0(2) TAI-TECH P11 Typical Impedance v.s. Frequency Curve BPH403025MN5-470TP 60 IMPEDANCE (Ω) 50 40 0amp 30 1amp 2amp 3amp 20 4amp 5amp 10 0 1 10 100 1000 FREQUENCY(MHz) BPH403025MN5-470TP 60 IMPEDANCE (Ω) 50 40 30 20 10 0 1 10 100 1000 10000 FREQUENCY(MHz) R X Z c 5. Material List No. Description a. Core b. Wire Specification a MnZn Ferrite Core Electroplated nickel-tin flat copper wire (1.25W X 0.21T)m/m c b Surface coating Parylene coating 6. Recommended PC Board Pattern L(mm) G(mm) H(mm) 4.8 1.4 1.5 www.tai-tech.com.tw TAI-TECH P12 High Current Ferrite Bead BPH853025R5-101T 1. Features 1. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen 2. Operating temperature -40~+125℃ (Including self - temperature rise) Halogen-free 2. Dimension CORE SIZE A(mm) B(mm) C(mm) D(mm) 8.50±0.25 3.00±0.15 2.50±0.15 1.50±0.15 PRODUCT SIZE A(mm) B(mm) C(mm) D(mm) E(mm) 9.00±0.40 3.00±0.15 2.80±0.25 1.50±0.50 1.25±0.20 3. Part Numbering BPH A 853025 R5 B - C 101 T D E A: Series B: Dimension C: Material Ferrite Core D: Impedance E: Packaging 101=100Ω T=Taping and Reel 4. Specification TAI-TECH Part Number BPH853025R5-101T ELECTRICAL REQUIREMENTS 1 ELECTRICAL REQUIREMENTS 2 Test Impedance Tolerance Frequency (Ω) (%) (MHz) Test Impedance Tolerance Frequency (Ω) (%) (MHz) 65 25 ±25 100 ±25 Note: Rated Current : (1) : Chroma high current test fixture. (2) :PCB test fixture ( 30x45mm copper pattern , 50um copper thickness). www.tai-tech.com.tw 100 DCR (mΩ) Max. 1.00 Rated Current(A) △T=40℃ TYP. △T=60℃ TYP. 30(1) 13(2) 40(1) 18(2) TAI-TECH P13 Typical Impedance v.s. Frequency Curve IMPEDANCE(Ohm) 1000 100 10 1 1 10 100 1000 10000 FREQUENCY(MHz) 5. Material List No. Description a. Core b. Wire Specification a Ferrite Core Electroplated nickel-tin flat copper wire (1.25W X 0.21T)m/m b 6. Recommended PC Board Pattern L(mm) G(mm) H(mm) 10.7 4.5 1.5 www.tai-tech.com.tw TAI-TECH P14 Reliability and Test Condition Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature -40~+125℃ (on board) Test Condition Electrical Performance Test Z( Impedance) Agilent E4991A + Keysight 16092A Refer to standard electrical characteristics list. DCR Agilent-34420A Heat Rated Current (Irms) will cause the coil temperature rise △ Heat Rated Current (Irms) T(℃) without core loss. Approximately △T≦40℃ 1.Applied the allowed DC current(keep 1 min.). 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Temperature: 125±2℃(Inductor) Life Test Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24 hrs. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Humidity:85±3% R.H, Load Humidity Temperature:85℃±2℃ Duration : 1000hrs Min. Bead : with 100% rated current , Inductance: with 10% rated current Measured at room temperature after placing for 24 hrs. Moisture Resistance Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25 ℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min Thermal shock Step2:125±2℃ ≦0.5min Step3:125±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24 hrs Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minute Equipment: Vibration checker Total Amplitude:10g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Vibration www.tai-tech.com.tw TAI-TECH Item P15 Performance Bending Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Shock Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg ,
BPH323023W5-390T 价格&库存
很抱歉,暂时无法提供与“BPH323023W5-390T”相匹配的价格&库存,您可以联系我们找货
