TAI-TECH
P2
SMD Power Inductor
TMIM-Series(G)
1. Features
1. Low loss realized with low DCR.
2. High performance realized by metal dust core.
Halogen
3. Ultra low buzz noise, due to composite construction.
4. 100% Lead(Pb)-Free and RoHS compliant.
Halogen-free
2. Applications
Commercial applications
3. Dimensions
Series
Recommend PC Board Pattern
A(mm)
B(mm)
C(mm)
D(mm)
L(mm)
G(mm)
H(mm)
0.5 Ref
1.9 Ref
TMIM201610A
2.0±0.3
1.6±0.3
0.8±0.2
0.7±0.3
2.5 Ref
TMIM201612A
2.0±0.3
1.6±0.3
1.0±0.2
0.7±0.3
2.5 Ref
0.5 Ref
1.9 Ref
TMIM252010A
2.5±0.3
2.0±0.3
0.8±0.2
0.9±0.3
2.9 Ref
0.5 Ref
2.3 Ref
TMIM252012A
2.5±0.3
2.0±0.3
1.0±0.2
0.9±0.3
2.9 Ref
0.5 Ref
2.3 Ref
TMIM322510A
3.2±0.3
2.5±0.3
0.8±0.2
1.1±0.3
3.7 Ref
0.7 Ref
2.8 Ref
TMIM322512A
3.2±0.3
2.5±0.3
1.0±0.2
1.1±0.3
3.7 Ref
0.7 Ref
2.8 Ref
TMIM322520A
3.2±0.3
2.5±0.3
1.8±0.2
1.1±0.3
3.7 Ref
0.7 Ref
2.8 Ref
4. Part Numbering
TMIM
201610
A
A
B
C
A: Series
B: Dimension
C: Material
D: Inductance
E: Inductance Tolerance
F: Coating
R33
D
AxBxC
R33=0.33uH
M=±20%
M -G
E
F
TAI-TECH
P3
5.Specification
Part Number
Inductance
L0 A(uH)
±20%
Irms( A )
I sat ( A )
Typ
Max
Typ
Max
DCR
(mΩ)
Typ
DCR
(mΩ)
Max
TMIM201610A-R10MG
0.10
8.0
7.0
9.0
8.0
7.5
9.0
TMIM201610A-R22MG
0.22
7.0
6.0
8.0
7.0
10.5
12.6
TMIM201610A-R24MG
0.24
6.5
5.5
7.7
6.7
18.0
20.5
TMIM201610A-R33MG
0.33
5.7
5.2
7.0
6.2
21.0
26.0
TMIM201610A-R47MG
0.47
5.3
4.7
6.0
5.3
28.0
32.0
TMIM201610A-R56MG
0.56
4.6
4.0
5.2
4.6
31.0
37.2
TMIM201610A-R68MG
0.68
4.0
3.4
5.0
4.4
44.0
50.0
TMIM201610A-1R0MG
1.00
3.6
3.2
4.4
3.8
49.0
59.0
TMIM201610A-1R5MG
1.50
2.6
2.3
3.0
2.7
80.0
96.0
TMIM201610A-2R2MG
2.20
2.3
2.0
2.65
2.45
130.0
150.0
TMIM201610A-4R7MG
4.70
1.4
1.2
2.1
1.9
265.0
318.0
Part Number
Inductance
L0 A(uH)
±20%
Irms( A )
I sat ( A )
Typ
Max
Typ
Max
DCR
(mΩ)
Typ
DCR
(mΩ)
Max
TMIM201612A-R22MG
0.22
7.0
6.0
8.0
7.0
10.0
13.0
TMIM201612A-R33MG
0.33
5.9
5.3
7.0
6.2
15.0
18.0
TMIM201612A-R47MG
0.47
5.4
4.8
6.0
5.3
20.0
26.0
TMIM201612A-R68MG
0.68
4.2
3.7
5.0
4.4
30.0
36.0
TMIM201612A-1R0MG
1.00
3.7
3.3
4.5
4.0
40.0
48.0
TMIM201612A-1R5MG
1.50
2.9
2.5
3.1
2.8
70.0
84.0
TMIM201612A-2R2MG
2.20
2.5
2.1
2.7
2.5
105.0
126.0
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
DCR
(mΩ)
Typ
DCR
(mΩ)
Max
TMIM252010A-R22MG
0.22
7.2
6.6
7.7
7.0
12
15
TMIM252010A-R33MG
0.33
6.6
6.0
7.2
6.4
16
19
TMIM252010A-R47MG
0.47
5.8
5.1
6.0
5.4
TMIM252010A-R68MG
0.68
5.1
4.7
5.2
4.8
25
30
TMIM252010A-1R0MG
1.00
4.3
4.0
4.6
3.8
42
50.4
TMIM252010A-1R5MG
1.50
3.3
3.0
3.5
3.2
60
72
TMIM252010A-2R2MG
2.20
2.8
2.5
3.0
2.7
85
102
TMIM252010A-3R3MG
3.30
2.0
1.7
2.1
1.8
130
156
Irms( A )
I sat ( A )
TAI-TECH
Part Number
P4
Inductance
L0 A(uH)
±20%
Irms( A )
I sat ( A )
Typ
Max
Typ
Max
DCR
(mΩ)
Typ
DCR
(mΩ)
Max
TMIM252012A-R15MG
0.15
9.0
8.0
11.0
10.0
8.0
9.6
TMIM252012A-R24MG
0.24
7.3
6.8
7.8
7.2
11.0
13.2
TMIM252012A-R33MG
0.33
6.8
6.3
7.5
6.8
14.0
17.0
TMIM252012A-R47MG
0.47
6.2
5.6
6.2
5.6
15.0
18.0
TMIM252012A-R56MG
0.56
5.9
5.4
5.9
5.4
20.0
24.0
TMIM252012A-R68MG
0.68
5.3
4.9
5.5
5.0
23.0
27.6
TMIM252012A-1R0MG
1.00
4.5
4.2
5.0
4.2
33.0
39.6
TMIM252012A-1R5MG
1.50
3.7
3.4
4.0
3.5
43.0
51.6
TMIM252012A-2R2MG
2.20
3.1
2.8
3.4
3.1
66.0
79.2
TMIM252012A-3R3MG
3.30
2.4
2.2
3.0
2.7
115
138
TMIM252012A-4R7MG
4.70
2.0
1.8
2.8
2.5
170
204
DCR
(mΩ)
Typ
DCR
(mΩ)
Max
Part Number
Inductance
L0 A(uH)
±20%
Irms( A )
I sat ( A )
Typ
Max
Typ
Max
TMIM322510A-R33MG
0.33
7.0
6.0
8.0
7.0
15.0
18.0
TMIM322510A-R47MG
0.47
6.0
5.5
6.5
5.5
18.0
21.6
TMIM322510A-R68MG
0.68
5.5
5.0
6.0
5.2
22.0
26.4
TMIM322510A-1R0MG
1.00
4.8
4.0
4.8
4.0
30.0
36.0
TMIM322510A-1R5MG
1.50
3.8
3.2
4.3
3.8
48.3
58.0
TMIM322510A-2R2MG
2.20
3.1
2.7
3.6
3.3
67.0
80.4
TMIM322510A-3R3MG
3.30
2.5
2.1
3.1
2.8
100.0
120.0
TMIM322510A-4R7MG
4.70
2.0
1.7
2.2
1.9
143.0
172.0
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
DCR
(mΩ)
Typ
DCR
(mΩ)
Max
TMIM322512A-R15MG
0.15
10.1
9.5
11.0
10.0
6.5
7.8
TMIM322512A-R22MG
0.22
9.5
9.0
9.3
8.7
7.4
8.5
TMIM322512A-R33MG
0.33
8.5
8.0
9.1
8.5
10.0
13.0
TMIM322512A-R47MG
0.47
7.0
6.5
8.2
7.4
16.0
19.2
TMIM322512A-R68MG
0.68
6.2
5.7
7.3
6.8
20.0
24.0
TMIM322512A-1R0MG
1.00
5.5
5.0
6.5
5.7
26.0
32.0
TMIM322512A-1R2MG
1.2
4.9
4.4
5.8
5.1
33.0
40.0
TMIM322512A-1R5MG
1.50
4.4
3.9
5.0
4.5
44.0
53.0
TMIM322512A-2R2MG
2.20
4.0
3.6
4.8
4.3
61.0
73.0
TMIM322512A-3R3MG
3.30
3.1
2.8
3.4
3.0
87.0
101.0
TMIM322512A-4R7MG
4.70
2.2
1.9
2.8
2.4
122.0
146.0
Irms( A )
I sat ( A )
TAI-TECH
Part Number
P5
Inductance
L0 A(uH)
±20%
Irms( A )
I sat ( A )
Typ
Max
Typ
Max
DCR
(mΩ)
Typ
DCR
(mΩ)
Max
TMIM322520A-R33MG
0.33
8.5
8.0
11.0
10.0
8.0
9.6
TMIM322520A-R47MG
0.47
8.0
7.5
9.0
8.0
9.3
11.2
TMIM322520A-R56MG
0.56
7.5
7.0
8.5
7.5
11.4
13.7
TMIM322520A-R68MG
0.68
7.0
6.4
8.0
7.0
13.3
16.0
TMIM322520A-1R0MG
1.00
6.2
5.8
7.5
6.2
18.3
22.0
TMIM322520A-1R5MG
1.50
5.3
4.8
6.0
5.0
25.8
31.0
TMIM322520A-2R2MG
2.20
3.7
3.2
5.0
4.5
38.0
46.0
TMIM322520A-3R3MG
3.30
3.2
2.7
4.2
3.7
56.0
65.0
TMIM322520A-4R7MG
4.70
2.8
2.4
3.4
2.9
90.0
98.0
Note:
1. Test frequency : Ls : 100KHz /1.0V.
2. All test data referenced to 25℃ ambient.
3. Testing Instrument(or equ) : Agilent 4284A,E4991A,4339B,KEYSIGHT E4980A/AL,chroma3302,3250,16502.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃
5. Saturation Current (Isat) will cause L0 to drop approximately 30%.
6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Irms Testing : Temperature rise is highly dependent on many factors including pcb land pattern, trace size, and proximity to other components.
Therefore temperature rise should be verified in application conditions.
8. Rated DC current: The lower value of Irms and Isat.
9. Rated voltage 25V DC,The application of voltage depends on many factors,Over voltage may cause components failure、high temperature
and burn-out,User needs to verify for appropriate usage.
TAI-TECH
P6
6. Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃ (Including self - temperature rise)
Storage temperature
1. -10~+40℃,50~60%RH (Product without taping)
2. -40~+125℃(on board)
Test Condition
Electrical Performance Test
Inductance
Refer to standard electrical characteristics list.
DCR
HP4284A,CH11025,CH3302,CH1320,CH1320S
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
Approximately △L30%.
Saturation DC Current (Isat) will cause L0
to drop △L(%)
Approximately △T40℃
△T(℃).
1.Applied the allowed DC current
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through IR reflow for 3times.
( IPC/JEDECJ-STD-020E Classification Reflow Profiles)
Temperature: 125±2℃(Inductor,ambient + temp rise)
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs.
Humidity:85±2﹪R.H,
Temperature:85℃±2℃
Duration:1000hrs Min. Bead:with 100% rated current,
Inductance:with 100% rated current
Life Test
Load Humidity
Appearance:No damage.
Moisture Resistance
Inductance:within±10% of initial value
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not
Thermal shock
Vibration
Preconditioning: Run through IR reflow for 3 times.
1. Baked at50℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65 ± 2 ℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65 ± 2 ℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25 ℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Step2:125±2℃ ≦0.5min
Step3:125±2℃ 30±5minNumber of cycles: 500
Measured at room fempraturc after placing for 24±2 hrs.
Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minutes
Equipment: Vibration checker
Total Amplitude: 10g
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
TAI-TECH
Item
P7
Performance
Bending
Test Condition
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805inch(2012mm):1kg,
很抱歉,暂时无法提供与“TMIM 252010A-2R2MG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+2.065362000+0.26721
- 4000+1.938354000+0.25078
- 6000+1.868056000+0.24169
- 10000+1.7833910000+0.23073
- 14000+1.7299314000+0.22382
- 20000+1.6751620000+0.21673
- 国内价格 香港价格
- 1+4.237291+0.54821
- 10+3.3983710+0.43967
- 25+3.1140325+0.40289
- 50+2.9144450+0.37706
- 100+2.73001100+0.35320
- 250+2.50425250+0.32399
- 500+2.34767500+0.30374
- 1000+2.201601000+0.28484
