TMIM 201610A-2R2MG
TMIM 201610A-2R2MG
    TAI-TECH(台庆)
    IND-2016(METRIC)
    2.2 µH 无屏蔽 模制 电感器 2 A 150 毫欧最大 0806(2016 公制)
TMIM 201610A-2R2MG 数据手册
TAI-TECH P2 SMD Power Inductor TMIM-Series(G) 1. Features 1. Low loss realized with low DCR. 2. High performance realized by metal dust core. Halogen 3. Ultra low buzz noise, due to composite construction. 4. 100% Lead(Pb)-Free and RoHS compliant. Halogen-free 2. Applications Commercial applications 3. Dimensions Series Recommend PC Board Pattern A(mm) B(mm) C(mm) D(mm) L(mm) G(mm) H(mm) 0.5 Ref 1.9 Ref TMIM201610A 2.0±0.3 1.6±0.3 0.8±0.2 0.7±0.3 2.5 Ref TMIM201612A 2.0±0.3 1.6±0.3 1.0±0.2 0.7±0.3 2.5 Ref 0.5 Ref 1.9 Ref TMIM252010A 2.5±0.3 2.0±0.3 0.8±0.2 0.9±0.3 2.9 Ref 0.5 Ref 2.3 Ref TMIM252012A 2.5±0.3 2.0±0.3 1.0±0.2 0.9±0.3 2.9 Ref 0.5 Ref 2.3 Ref TMIM322510A 3.2±0.3 2.5±0.3 0.8±0.2 1.1±0.3 3.7 Ref 0.7 Ref 2.8 Ref TMIM322512A 3.2±0.3 2.5±0.3 1.0±0.2 1.1±0.3 3.7 Ref 0.7 Ref 2.8 Ref TMIM322520A 3.2±0.3 2.5±0.3 1.8±0.2 1.1±0.3 3.7 Ref 0.7 Ref 2.8 Ref 4. Part Numbering TMIM 201610 A A B C A: Series B: Dimension C: Material D: Inductance E: Inductance Tolerance F: Coating - R33 D AxBxC R33=0.33uH M=±20% - M -G E F TAI-TECH P3 5.Specification Part Number Inductance L0 A(uH) ±20% Irms( A ) I sat ( A ) Typ Max Typ Max DCR (mΩ) Typ DCR (mΩ) Max TMIM201610A-R10MG 0.10 8.0 7.0 9.0 8.0 7.5 9.0 TMIM201610A-R22MG 0.22 7.0 6.0 8.0 7.0 10.5 12.6 TMIM201610A-R24MG 0.24 6.5 5.5 7.7 6.7 18.0 20.5 TMIM201610A-R33MG 0.33 5.7 5.2 7.0 6.2 21.0 26.0 TMIM201610A-R47MG 0.47 5.3 4.7 6.0 5.3 28.0 32.0 TMIM201610A-R56MG 0.56 4.6 4.0 5.2 4.6 31.0 37.2 TMIM201610A-R68MG 0.68 4.0 3.4 5.0 4.4 44.0 50.0 TMIM201610A-1R0MG 1.00 3.6 3.2 4.4 3.8 49.0 59.0 TMIM201610A-1R5MG 1.50 2.6 2.3 3.0 2.7 80.0 96.0 TMIM201610A-2R2MG 2.20 2.3 2.0 2.65 2.45 130.0 150.0 TMIM201610A-4R7MG 4.70 1.4 1.2 2.1 1.9 265.0 318.0 Part Number Inductance L0 A(uH) ±20% Irms( A ) I sat ( A ) Typ Max Typ Max DCR (mΩ) Typ DCR (mΩ) Max TMIM201612A-R22MG 0.22 7.0 6.0 8.0 7.0 10.0 13.0 TMIM201612A-R33MG 0.33 5.9 5.3 7.0 6.2 15.0 18.0 TMIM201612A-R47MG 0.47 5.4 4.8 6.0 5.3 20.0 26.0 TMIM201612A-R68MG 0.68 4.2 3.7 5.0 4.4 30.0 36.0 TMIM201612A-1R0MG 1.00 3.7 3.3 4.5 4.0 40.0 48.0 TMIM201612A-1R5MG 1.50 2.9 2.5 3.1 2.8 70.0 84.0 TMIM201612A-2R2MG 2.20 2.5 2.1 2.7 2.5 105.0 126.0 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max DCR (mΩ) Typ DCR (mΩ) Max TMIM252010A-R22MG 0.22 7.2 6.6 7.7 7.0 12 15 TMIM252010A-R33MG 0.33 6.6 6.0 7.2 6.4 16 19 TMIM252010A-R47MG 0.47 5.8 5.1 6.0 5.4 20 24 TMIM252010A-R68MG 0.68 5.1 4.7 5.2 4.8 25 30 TMIM252010A-1R0MG 1.00 4.3 4.0 4.6 3.8 42 50.4 TMIM252010A-1R5MG 1.50 3.3 3.0 3.5 3.2 60 72 TMIM252010A-2R2MG 2.20 2.8 2.5 3.0 2.7 85 102 TMIM252010A-3R3MG 3.30 2.0 1.7 2.1 1.8 130 156 Irms( A ) I sat ( A ) TAI-TECH Part Number P4 Inductance L0 A(uH) ±20% Irms( A ) I sat ( A ) Typ Max Typ Max DCR (mΩ) Typ DCR (mΩ) Max TMIM252012A-R15MG 0.15 9.0 8.0 11.0 10.0 8.0 9.6 TMIM252012A-R24MG 0.24 7.3 6.8 7.8 7.2 11.0 13.2 TMIM252012A-R33MG 0.33 6.8 6.3 7.5 6.8 14.0 17.0 TMIM252012A-R47MG 0.47 6.2 5.6 6.2 5.6 15.0 18.0 TMIM252012A-R56MG 0.56 5.9 5.4 5.9 5.4 20.0 24.0 TMIM252012A-R68MG 0.68 5.3 4.9 5.5 5.0 23.0 27.6 TMIM252012A-1R0MG 1.00 4.5 4.2 5.0 4.2 33.0 39.6 TMIM252012A-1R5MG 1.50 3.7 3.4 4.0 3.5 43.0 51.6 TMIM252012A-2R2MG 2.20 3.1 2.8 3.4 3.1 66.0 79.2 TMIM252012A-3R3MG 3.30 2.4 2.2 3.0 2.7 115 138 TMIM252012A-4R7MG 4.70 2.0 1.8 2.8 2.5 170 204 DCR (mΩ) Typ DCR (mΩ) Max Part Number Inductance L0 A(uH) ±20% Irms( A ) I sat ( A ) Typ Max Typ Max TMIM322510A-R33MG 0.33 7.0 6.0 8.0 7.0 15.0 18.0 TMIM322510A-R47MG 0.47 6.0 5.5 6.5 5.5 18.0 21.6 TMIM322510A-R68MG 0.68 5.5 5.0 6.0 5.2 22.0 26.4 TMIM322510A-1R0MG 1.00 4.8 4.0 4.8 4.0 30.0 36.0 TMIM322510A-1R5MG 1.50 3.8 3.2 4.3 3.8 48.3 58.0 TMIM322510A-2R2MG 2.20 3.1 2.7 3.6 3.3 67.0 80.4 TMIM322510A-3R3MG 3.30 2.5 2.1 3.1 2.8 100.0 120.0 TMIM322510A-4R7MG 4.70 2.0 1.7 2.2 1.9 143.0 172.0 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max DCR (mΩ) Typ DCR (mΩ) Max TMIM322512A-R15MG 0.15 10.1 9.5 11.0 10.0 6.5 7.8 TMIM322512A-R22MG 0.22 9.5 9.0 9.3 8.7 7.4 8.5 TMIM322512A-R33MG 0.33 8.5 8.0 9.1 8.5 10.0 13.0 TMIM322512A-R47MG 0.47 7.0 6.5 8.2 7.4 16.0 19.2 TMIM322512A-R68MG 0.68 6.2 5.7 7.3 6.8 20.0 24.0 TMIM322512A-1R0MG 1.00 5.5 5.0 6.5 5.7 26.0 32.0 TMIM322512A-1R2MG 1.2 4.9 4.4 5.8 5.1 33.0 40.0 TMIM322512A-1R5MG 1.50 4.4 3.9 5.0 4.5 44.0 53.0 TMIM322512A-2R2MG 2.20 4.0 3.6 4.8 4.3 61.0 73.0 TMIM322512A-3R3MG 3.30 3.1 2.8 3.4 3.0 87.0 101.0 TMIM322512A-4R7MG 4.70 2.2 1.9 2.8 2.4 122.0 146.0 Irms( A ) I sat ( A ) TAI-TECH Part Number P5 Inductance L0 A(uH) ±20% Irms( A ) I sat ( A ) Typ Max Typ Max DCR (mΩ) Typ DCR (mΩ) Max TMIM322520A-R33MG 0.33 8.5 8.0 11.0 10.0 8.0 9.6 TMIM322520A-R47MG 0.47 8.0 7.5 9.0 8.0 9.3 11.2 TMIM322520A-R56MG 0.56 7.5 7.0 8.5 7.5 11.4 13.7 TMIM322520A-R68MG 0.68 7.0 6.4 8.0 7.0 13.3 16.0 TMIM322520A-1R0MG 1.00 6.2 5.8 7.5 6.2 18.3 22.0 TMIM322520A-1R5MG 1.50 5.3 4.8 6.0 5.0 25.8 31.0 TMIM322520A-2R2MG 2.20 3.7 3.2 5.0 4.5 38.0 46.0 TMIM322520A-3R3MG 3.30 3.2 2.7 4.2 3.7 56.0 65.0 TMIM322520A-4R7MG 4.70 2.8 2.4 3.4 2.9 90.0 98.0 Note: 1. Test frequency : Ls : 100KHz /1.0V. 2. All test data referenced to 25℃ ambient. 3. Testing Instrument(or equ) : Agilent 4284A,E4991A,4339B,KEYSIGHT E4980A/AL,chroma3302,3250,16502. 4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃ 5. Saturation Current (Isat) will cause L0 to drop approximately 30%. 6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 7. Irms Testing : Temperature rise is highly dependent on many factors including pcb land pattern, trace size, and proximity to other components. Therefore temperature rise should be verified in application conditions. 8. Rated DC current: The lower value of Irms and Isat. 9. Rated voltage 25V DC,The application of voltage depends on many factors,Over voltage may cause components failure、high temperature and burn-out,User needs to verify for appropriate usage. TAI-TECH P6 6. Reliability and Test Condition Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature 1. -10~+40℃,50~60%RH (Product without taping) 2. -40~+125℃(on board) Test Condition Electrical Performance Test Inductance Refer to standard electrical characteristics list. DCR HP4284A,CH11025,CH3302,CH1320,CH1320S LCR Meter. CH16502,Agilent33420A Micro-Ohm Meter. Saturation Current (Isat) Approximately △L30%. Saturation DC Current (Isat) will cause L0 to drop △L(%) Heat Rated Current (Irms) Approximately △T40℃ Heat Rated Current (Irms) will cause the coil temperature rise △T(℃). 1.Applied the allowed DC current 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through IR reflow for 3times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Temperature: 125±2℃(Inductor,ambient + temp rise) Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 3times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Humidity:85±2﹪R.H, Temperature:85℃±2℃ Duration:1000hrs Min. Bead:with 100% rated current, Inductance:with 100% rated current Measured at room temperature after placing for 24±2 hrs. Life Test Load Humidity Appearance:No damage. Moisture Resistance Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Thermal shock Vibration Preconditioning: Run through IR reflow for 3 times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65 ± 2 ℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65 ± 2 ℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25 ℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow for 3 times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Condition for 1 cycle Step1:-40±2℃ 30±5min Step2:125±2℃ ≦0.5min Step3:125±2℃ 30±5minNumber of cycles: 500 Measured at room fempraturc after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 3 times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minutes Equipment: Vibration checker Total Amplitude: 10g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 TAI-TECH Item P7 Performance Bending Appearance:No damage. Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805inch(2012mm):1kg,
TMIM 201610A-2R2MG 价格&库存
很抱歉,暂时无法提供与“TMIM 201610A-2R2MG”相匹配的价格&库存,您可以联系我们找货
TMIM 201610A-2R2MG
  • 2000+1.933412000+0.25005
  • 4000+1.814454000+0.23466
  • 6000+1.748566000+0.22614
  • 10000+1.6692810000+0.21589
  • 14000+1.6191914000+0.20941
  • 20000+1.5679120000+0.20278
库存:3170
TMIM 201610A-2R2MG
  • 1+3.970811+0.51354
  • 10+3.1862510+0.41207
  • 25+2.9166225+0.37720
  • 50+2.7294050+0.35299
  • 100+2.55541100+0.33049
  • 250+2.34483250+0.30325
  • 500+2.19795500+0.28426
  • 1000+2.061051000+0.26655
库存:3170
