TMPA 2313SP-4R7MN-D
TMPA 2313SP-4R7MN-D
    TAI-TECH(台庆)
    SMD,23.5x22mm
    4.7 µH 屏蔽 模制 电感器 44 A 2.2 毫欧最大 非标准
TMPA 2313SP-4R7MN-D 数据手册
TAI-TECH P2 SMD Power Inductor TMPA-Series(N) 1. Features 1. Low loss realized with low DCR. 2. High performance realized by metal dust core. Halogen 3. Ultra low buzz noise, due to composite construction. 4. 100% Lead(Pb)-Free and RoHS compliant. Halogen-free 2. Applications Commercial applications 3. Dimensions C L E B 1.5 Recommend PC Board Pattern D H A G Note: 1.PCB layout is referred to standard IPC-7351B 2. The above PCB layout reference only. 3. Recommend solder paste thickness at 0.12mm and above. Series A(mm) B(mm) C(mm) D(mm) E(mm) L(mm) G(mm) H(mm) TMPA0312S 3.2±0.2 3.1±0.2 1.0±0.2 0.8±0.2 0.6±0.2 3.6Ref 1.9Ref 1.0Ref TMPA0315S 3.2±0.2 3.1±0.2 1.3±0.2 0.8±0.2 0.6±0.2 3.6Ref 1.9Ref 1.0Ref TMPA0318S 3.2±0.2 3.1±0.2 1.6±0.2 0.8±0.2 0.6±0.2 3.6Ref 1.9Ref 1.0Ref TMPA0302S 3.5±0.2 3.2±0.2 1.8±0.2 0.7±0.2 1.2±0.2 4.1Ref 1.9Ref 1.45Ref Recommend PC Board Pattern C D L 100 E B H A G Note: 1.PCB layout is referred to standard IPC-7351B 2. The above PCB layout reference only. 3. Recommend solder paste thickness at 0.12mm and above. Series A(mm) B(mm) C(mm) D(mm) E(mm) L(mm) G(mm) H(mm) TMPA0401SP 4.5±0.2 4.1±0.2 1.0Max 0.8±0.25 1.8±0.2 5.2Ref 2.2Ref 2.5Ref TMPA0402SP 4.45±0.25 4.1±0.2 1.8±0.2 0.8±0.25 2.0±0.2 5.2Ref 2.2Ref 2.0Ref A B C L H 100 D E F G T Series A(mm) B(mm) Note: 1. The above PCB layout reference only. 2. Recommend solder paste thickness at 0.12mm and above. C(mm) D(mm) E(mm) F(mm) TMPA404010 4.20±0.20 4.15±0.20 0.83±0.2 0.9±0.20 1.8±0.20 2.4±0.20 T(mm) L(mm) G(mm) H(mm) 0~0.05 4.4 Ref 2.2 Ref 2.0 Ref TAI-TECH P3 Recommend PC Board Pattern H L G Note: 1.PCB layout is referred to standard IPC-7351B 2. The above PCB layout reference only. 3. Recommend solder paste thickness at 0.12mm and above. Series A(mm) A’(mm) B(mm) TMPA606010 6.1±0.3 6.0±0.2 6.1±0.3 C(mm) D(mm) E(mm) 0.8±0.2 1.75±0.3 4.0±0.2 L(mm) G(mm) H(mm) 7.0 2.8 4.5 Recommend PC Board Pattern H L 1R0 2209 Series G Note: 1.PCB layout is referred to standard IPC-7351B 2. The above PCB layout reference only. 3. Recommend solder paste thickness at 0.12mm and above. A(mm) B(mm) C(mm) D(mm) E(mm) L(mm) G(mm) H(mm) TMPA0502SP 5.7±0.3 5.2±0.2 1.8±0.2 1.0±0.3 2.5±0.3 6.0 Ref 2.8 Ref 2.5 Ref TMPA0503S 5.7±0.3 5.2±0.2 2.8±0.2 1.0±0.3 2.0±0.2 6.0 Ref 2.8 Ref 2.5 Ref TMPA053T 4.9±0.3 4.7±0.2 2.8±0.2 1.0±0.3 1.5±0.2 5.5 Ref 2.5 Ref 1.8 Ref TMPA0618S 7.0±0.3 6.6±0.2 1.6±0.2 1.8±0.3 3.0±0.2 8.0Ref 3.7Ref 3.4Ref TMPA0602S 7.1±0.3 6.6±0.2 1.8±0.2 1.6±0.3 3.0±0.2 8.0 Ref 3.7 Ref 3.4 Ref TMPA0624S 7.1±0.3 6.7±0.2 2.2±0.2 1.6±0.3 3.0±0.2 8.0 Ref 3.7 Ref 3.4 Ref TMPA0603S 7.1±0.3 6.6±0.2 2.8±0.2 1.6±0.3 3.0±0.2 8.0 Ref 3.7 Ref 3.4 Ref TMPA0604S 7.1±0.3 6.6±0.2 3.8±0.2 1.6±0.3 2.8±0.3 8.0 Ref 3.7 Ref 3.4 Ref TMPA0605S 7.3±0.3 6.6±0.3 4.8±0.2 1.6±0.3 3.0±0.2 8.0 Ref 3.7 Ref 3.4 Ref TMPA0754S 7.8±0.3 7.1±0.2 5.2±0.2 1.6±0.3 3.0±0.3 9.0 Ref 3.2 Ref 3.5 Ref TMPA0804S 8.8±0.4 8.2±0.3 3.8±0.2 1.4±0.3 5.0±0.3 9.5 Ref 4.0 Ref 5.5 Ref TAI-TECH P4 Recommend PC Board Pattern C B 1R0 2131 Leadframe L D H 2R2 2131 E B A D E C A G Note: 1.PCB layout is referred to standard IPC-7351B 2. The above PCB layout reference only. 3. Recommend solder paste thickness at 0.12mm and above. non-leadframe Series A(mm) B(mm) C(mm) D(mm) TMPA1003S 11.0±0.5 10.0±0.3 2.8±0.2 2.0±0.3 TMPA1004S 11.0±0.3 10.0±0.3 3.8±0.2 2.0±0.3 TMPA1005S 11.0±0.5 10.0±0.3 4.8±0.2 2.0±0.3 TMPA1205SP 13.5±0.5 12.6±0.2 4.7±0.3 2.3±0.3 TMPA1206SP 13.5±0.5 12.6±0.2 5.7±0.3 2.3±0.3 TMPA1265SP 13.5±0.5 12.6±0.2 6.2±0.3 2.3±0.3 E(mm) L(mm) G(mm) H(mm) 13.5Ref 5.4Ref 3.5Ref 12.5Ref 5.4Ref 3.5Ref 12.5Ref 5.4Ref 3.5Ref 14.5Ref 8.0Ref 5.0Ref See Spec table 14.5Ref 8.0Ref 5.0Ref See Spec table 14.5Ref 8.0Ref 5.0Ref See Spec table See Spec table See Spec table See Spec table Recommend PC Board Pattern L C H 820 2209 2131 Series D G E B A A` (TMPA1707) Note: 1.PCB layout is referred to standard IPC-7351B 2. The above PCB layout reference only. 3. Recommend solder paste thickness at 0.17mm and above. (TMPA2313) Note: 1.PCB layout is referred to standard IPC-7351B 2. The above PCB layout reference only. 3. Recommend solder paste thickness at 2.0mm and above. A(mm) A`(mm) B(mm) C(mm) D(mm) E(mm) L(mm) G(mm) H(mm) TMPA1707SP 17.8±0.5 16.9±0.3 16.9±0.3 6.7±0.3 2.3±0.3 11.9±0.3 18.5Ref 12.0Ref 12.5Ref TMPA2313SP 23.5±0.5 22.7±0.3 22.0±0.3 12.6±0.4 5.0±0.4 19.0±0.3 24.0Ref 12.5Ref 19.6Ref TAI-TECH P5 4. Part Numbering TMPA 0302 S A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance 1R5 MN D E BxC Standard.V: Vehicle 1R5=1.50uH. M=±20% Y±30% Marking: Black.1.5 (1.5:1R5). TMPA 0402 SP A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance - 100 MN D E BxC Standard. R10=0.1uh,1R0=1.0uh,100=10uh,101=100uh,102=1000uh. K=±10%,L=±15%,M=±20%,N=±25%,Y=±30% Marking: Black.100 Unidirectional printing. TMPA 0603 S A B C B: Dimension C: Type D: Inductance E: Inductance Tolerance F: Code - - 1R0 MN D E - D F BxC Standard. R10=0.1uh,1R0=1.0uh,100=10uh,101=100uh,102=1000uh. K=±10%,L=±15%,M=±20%,N=±25%,Y=±30% Marking: Black.1R0 and 2209(22YY, 09 WW,follow production date). TAI-TECH P6 5. Specification Part Number Inductance L0 (uH)±20% @0A Typ Max Typ Max Typ Max TMPA0312S-R24MN 0.24 8.3 7.2 9.5 8.0 12.0 14.4 TMPA0312S-R36MN 0.36 7.0 6.4 7.5 6.8 15.5 18.6 TMPA0312S-R47MN 0.47 6.3 5.9 6.6 6.1 20.5 24.6 TMPA0312S-R68MN 0.68 5.1 4.6 5.5 5.0 29.0 34.8 TMPA0312S-1R0MN 1.00 3.8 3.5 4.1 3.6 42.0 50.4 TMPA0312S-1R5MN 1.50 3.3 2.9 3.5 3.0 57.0 68.4 TMPA0312S-2R2MN 2.20 2.8 2.5 3.0 2.6 84 101 TMPA0312S-3R3MN 3.30 2.2 2.0 2.5 2.3 150 180 TMPA0312S-4R7MN 4.70 1.8 1.6 2.2 2.0 225 248 TMPA0312S-6R8MN 6.80 1.5 1.3 1.7 1.5 290 319 TMPA0312S-100MN 10.0 1.2 1.1 1.3 1.2 440 484 Part Number Inductance L0 (uH)±20% @0A Typ Max Typ Max Typ Max TMPA0315S-R22MN 0.22 8.7 8.0 10.0 8.5 10.0 12.0 TMPA0315S-R33MN 0.33 7.4 6.8 8.0 7.0 12.5 15.0 TMPA0315S-R47MN 0.47 6.6 6.1 7.0 6.5 15.5 19.0 TMPA0315S-R56MN 0.56 6.3 6.0 7.0 6.3 20.0 24.0 TMPA0315S-R68MN 0.68 5.6 5.0 6.0 5.5 25.0 30.0 TMPA0315S-1R0MN 1.00 4.7 4.4 5.0 4.5 34.0 41.0 TMPA0315S-1R5MN 1.50 4.0 3.2 4.0 3.2 50.0 60.0 TMPA0315S-2R2MN 2.20 3.2 2.9 3.5 3.1 70.0 84.0 TMPA0315S-3R3MN 3.30 2.6 2.4 2.8 2.5 120 144 TMPA0315S-4R7MN 4.70 2.0 1.8 2.4 2.2 170 204 TMPA0315S-5R6MN 5.60 1.7 1.5 2.0 1.8 200 240 TMPA0315S-6R8MN 6.80 1.6 1.4 1.8 1.6 223 268 TMPA0315S-8R2MN 8.20 1.5 1.3 1.6 1.4 300 360 TMPA0315S-100MN 10.0 1.4 1.2 1.5 1.3 335 402 Part Number Inductance L0 (uH)±20% @0A Typ Max Typ Max Typ Max TMPA0318S-R24MN 0.24 9.0 8.5 11.0 9.5 11.5 13.8 TMPA0318S-R36MN 0.36 7.4 6.9 9.0 8.0 13.0 15.6 TMPA0318S-R47MN 0.47 7.0 6.6 7.7 7.0 15.0 18.0 TMPA0318S-R56MN 0.56 6.6 6.3 7.3 6.5 19.0 22.8 TMPA0318S-R68MN 0.68 6.2 5.9 6.8 6.2 22.0 26.4 TMPA0318S-1R0MN 1.00 5.3 5.0 5.8 5.3 28.0 34.0 TMPA0318S-1R5MN 1.50 4.5 4.0 5.0 4.5 38.0 45.6 TMPA0318S-2R2MN 2.20 3.5 3.2 4.1 3.7 63.0 75.0 TMPA0318S-3R3MN 3.30 2.8 2.5 3.0 2.6 96.0 115.0 TMPA0318S-4R7MN 4.70 2.3 2.0 2.5 2.3 145.0 174.0 TMPA0318S-5R6MN 5.60 2.0 1.8 2.1 1.9 170.0 204.0 TMPA0318S-6R8MN 6.80 1.8 1.5 2.0 1.8 220.0 264.0 TMPA0318S-8R2MN 8.20 1.5 1.3 1.6 1.4 300.0 360.0 TMPA0318S-100MN 10.0 1.6 1.4 1.7 1.5 290.0 348.0 I rms ( A ) I sat ( A ) I rms ( A ) DCR(mΩ) I sat ( A ) I rms ( A ) DCR(mΩ) I sat ( A ) DCR(mΩ) TAI-TECH P7 Irms ( A ) I sat ( A ) DCR (mΩ) Part Number Inductance L0 (uH)±20% Typ Max Typ Max Typ Max TMPA0302S-R15YN 0.15±30% 11.0 10.0 14.0 12.0 8.0 9.6 TMPA0302S-R22MN 0.22 10.0 9.0 12.0 10.5 10.0 12.0 TMPA0302S-R33MN 0.33 9.0 8.0 10.0 9.0 12.0 14.4 TMPA0302S-R47MN 0.47 8.0 7.0 8.5 7.5 14.5 17.4 TMPA0302S-R68MN 0.68 6.8 6.3 7.0 6.5 20 24 TMPA0302S-1R0MN 1.0 5.8 5.3 6.0 5.5 27 33 TMPA0302S-1R5MN 1.5 5.1 4.6 5.5 5.0 35 42 TMPA0302S-2R2MN 2.2 4.0 3.5 4.5 4.0 55 66 TMPA0302S-3R3MN 3.3 3.0 2.6 3.2 2.8 92 111 TMPA0302S-4R7MN 4.7 2.5 2.2 2.8 2.5 122 147 TMPA0302S-6R8MN 6.8 2.0 1.8 2.2 2.0 211 254 TMPA0302S-100MN 10.0 1.5 1.3 1.6 1.4 285 342 Part Number Inductance L0 A(uH) ±20% I rms ( A ) I sat ( A ) DCR(mΩ) Typ Max Typ Max Typ Max 48.3 TMPA0401SP-1R0MN 1.00 3.5 3.0 5.0 4.5 42 TMPA0401SP-1R5MN 1.50 2.8 2.4 4.6 4.3 62 72 TMPA0401SP-2R2MN 2.20 2.6 2.3 3.8 3.3 90 108 TMPA0401SP-3R3MN 3.30 2.1 1.8 3.3 2.8 135 150 TMPA0401SP-4R7MN 4.70 1.9 1.6 2.8 2.4 180 216 TMPA0401SP-6R8MN 6.80 1.7 1.5 2.3 2.0 260 300 TMPA0401SP-8R2MN 8.20 1.5 1.3 2.1 1.8 282 330 TMPA0401SP-100MN 10.0 1.4 1.2 2.0 1.6 316 340 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max Typ Max TMPA0402SP-R10MN 0.10 16 14 26 22 2.9 3.2 TMPA0402SP-R22MN 0.22 14 12.5 15 13 4.8 5.5 TMPA0402SP-R33MN 0.33 12 11 10.5 9.5 7.5 8.3 TMPA0402SP-R47MN 0.47 10 9.0 9.0 8.0 9.5 11 TMPA0402SP-R68MN 0.68 9.0 8.0 7.6 6.6 11.6 13.5 TMPA0402SP-R82MN 0.82 8.0 7.0 6.0 5.5 16.3 18.8 TMPA0402SP-1R0MN 1.00 7.5 6.5 5.5 5.0 19 22 TMPA0402SP-1R5MN 1.50 6.7 5.8 5.2 4.8 27 31 TMPA0402SP-2R2MN 2.20 5.5 5.0 4.5 4.0 41 48 TMPA0402SP-3R3MN 3.30 4.5 3.5 3.1 2.7 65 75 TMPA0402SP-4R7MN 4.70 3.8 3.2 2.8 2.5 84 95 TMPA0402SP-5R6MN 5.60 3.2 2.8 2.6 2.3 97 115 TMPA0402SP-6R8MN 6.80 2.9 2.5 2.4 2.1 131 157 TMPA0402SP-8R2MN 8.20 2.6 2.3 2.2 2.0 140 168 TMPA0402SP-100MN 10.0 2.4 2.2 2.1 1.9 165 215 TMPA0402SP-150MN 15.0 1.5 1.3 1.6 1.4 325 375 I rms ( A ) I sat ( A ) DCR(mΩ) TAI-TECH P8 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max TMPA404010AF-4R7MN 4.70 2.6 2.3 3.0 TMPA404010AF-6R8MN 6.80 2.0 1.8 TMPA404010AF-100MN 10.0 1.6 1.4 Part Number Inductance L0 A(uH) ±20% Irms ( A ) I sat ( A ) DCR (mΩ)Typ DCR (mΩ)Max 2.6 120 144 2.3 2.0 200 240 2.0 1.7 300 320 I rms ( A ) I sat ( A ) DCR(mΩ) Typ Max Typ Max Typ Max 2.3 2.53 TMPA0502SP-R10MN-D 0.10 25 22 29 26 TMPA0502SP-R15YN-D 0.15±30% 22 19 27 24 2.8 3.2 TMPA0502SP-R22MN-D 0.22 16 14 20 17 3.80 4.40 TMPA0502SP-R33MN-D 0.33 14 13 11 9.0 5.20 6.00 TMPA0502SP-R47MN-D 0.47 13 11 9.0 8.0 6.10 7.20 TMPA0502SP-R68MN-D 0.68 12 10 8.0 7.0 8.00 9.20 TMPA0502SP-1R0MN-D 1.00 8.6 7.5 7.5 6.5 14.0 16.2 TMPA0502SP-1R5MN-D 1.50 7.5 6.5 7.0 6.0 22.0 26.4 TMPA0502SP-2R2MN-D 2.20 6.5 6.0 5.8 5.0 29.0 34.0 TMPA0502SP-3R3MN-D 3.30 6.0 5.0 5.0 4.7 50.0 60.0 TMPA0502SP-4R7MN-D 4.70 4.0 3.0 4.7 4.4 84.0 97.0 TMPA0502SP-5R6MN-D 5.60 3.5 2.8 4.4 4.0 91.0 109 TMPA0502SP-6R8MN-D 6.80 3.1 2.6 4.2 3.8 110 127 TMPA0502SP-8R2MN-D 8.20 2.9 2.5 3.9 3.4 123 142 TMPA0502SP-100MN-D 10.0 2.7 2.4 3.5 3.0 150 180 TMPA0502SP-150MN-D 15.0 2.2 1.9 2.6 2.3 224 252 TMPA0502SP-220MN-D 22.0 1.9 1.6 2.2 1.9 290 325 Inductance L0 A(uH) ±20% Typ Max Typ Max TMPA0503S-R10MN-D 0.10 26 23 33 TMPA0503S-R33MN-D 0.33 16 14 TMPA0503S-R47MN-D 0.47 13.5 12 TMPA0503S-R56MN-D 0.56 13.0 TMPA0503S-R68MN-D 0.68 12.5 TMPA0503S-R82MN-D 0.82 TMPA0503S-1R0MN-D 1.00 TMPA0503S-1R5MN-D 1.50 TMPA0503S-2R2MN-D 2.20 TMPA0503S-3R3MN-D TMPA0503S-4R7MN-D I rms ( A ) I sat ( A ) DCR (mΩ)Typ DCR (mΩ)Max 29 2.0 2.2 12 10 4.5 5.4 10 9.0 5.2 6.0 11.5 9.5 8.5 6.1 7.2 11 9.0 8.0 7.4 8.5 10 9.0 8.8 7.7 8.0 9.2 9.0 8.0 8.5 7.5 10.5 12 8.0 7.0 7.5 6.5 13.6 15.7 7.0 6.5 6.5 5.8 21.6 25 3.30 6.3 5.8 6.0 5.3 28 33 4.70 5.5 4.8 5.3 4.6 38 44 TMPA0503S-5R6MN-D 5.60 5.0 4.3 4.6 4.0 50 58 TMPA0503S-6R8MN-D 6.80 4.3 3.7 3.5 3.1 57 66 TMPA0503S-100MN-D 10.0 3.8 3.4 2.5 2.1 88 103 TMPA0503S-150MN-D 15.0 2.9 2.5 2.2 1.7 140 170 TMPA0503S-220MN-D 22.0 2.4 2.0 2.0 1.7 190 228 Part Number TAI-TECH P9 Part Number Inductance L0 A(uH) ±20% Typ Max Typ I rms ( A ) I sat ( A ) Max DCR (mΩ)Typ DCR (mΩ)Max TMPA053T-R10YN-D 0.10±30% 32 28 32 28 1.8 2.1 TMPA053T-R22MN-D 0.22 18 16 17 14.5 2.8 3.2 TMPA053T-R35MN-D 0.35 16.5 15 15 12 4.6 5.1 TMPA053T-R47MN-D 0.47 16 14 11 9.5 5.5 6.4 TMPA053T-R68MN-D 0.68 12 10.5 9.0 8.5 7.0 8.4 TMPA053T-1R0MN-D 1.00 8.5 7.5 8.5 8.0 12.8 13.8 TMPA053T-1R5MN-D 1.50 6.6 6.0 6.3 5.5 16 21 TMPA053T-2R2MN-D 2.20 6.0 5.5 5.7 5.0 23 27.6 TMPA053T-3R3MN-D 3.30 5.5 5.0 5.0 4.3 30 36 TMPA053T-4R7MN-D 4.70 5.0 4.5 4.0 3.7 43 52 Part Number Inductance L0 (uH) ±20% TMPA606010AF-4R7MN-D I rms ( A ) I sat ( A ) DCR (mΩ)Typ DCR (mΩ)Max Typ Max Typ Max 4.70 2.6 2.3 3.5 3.0 140.0 161.0 TMPA606010AF-6R8MN-D 6.80 2.1 1.9 2.5 2.2 164.0 197.0 TMPA606010AF-100MN-D 10.0 1.7 1.5 2.1 1.9 259.0 310.0 Part Number Inductance L0 A(uH) ±20% Typ Max Typ TMPA0618S-R15YN-D 0.15±30% 21 19 30 TMPA0618S-R22MN-D 0.22 19 17 22 TMPA0618S-R33MN-D 0.33 17 15 19.5 TMPA0618S-R47MN-D 0.47 14 12 16 TMPA0618S-R68MN-D 0.68 12 10 14 TMPA0618S-1R0MN-D 1.0 9.5 8.5 11.5 TMPA0618S-1R5MN-D 1.5 8 7 10.5 TMPA0618S-2R2MN-D 2.2 7.0 6.0 TMPA0618S-3R3MN-D 3.3 6.0 TMPA0618S-4R7MN-D 4.7 4.5 TMPA0618S-6R8MN-D 6.8 4 TMPA0618S-100MN-D 10.0 3 Max DCR (mΩ) Typ DCR (mΩ) Max 27 1.9 2.4 20 3 3.6 17.5 4.4 5.3 14 6.3 7.0 12 7 8.4 10 12 14.4 9 18.5 22.2 7.5 6.5 29.5 33.5 5 7 5.7 49 56.4 4 5.8 5 56 67.2 3.2 4 3.5 75 90 2.7 3.3 2.9 109 130 I rms ( A ) I sat ( A ) TAI-TECH P10 Inductance L0 A(uH) ±20% Typ Max Typ Max TMPA0602S-R15MN-D 0.15 28 25 34 TMPA0602S-R22MN-D 0.22 21 18 23 TMPA0602S-R33MN-D 0.33 19 16 TMPA0602S-R47MN-D 0.47 15 13 TMPA0602S-R68MN-D 0.68 13 11 14 12 7.8 8.8 TMPA0602S-1R0MN-D 1.00 11 9.5 12.5 10.5 13.5 15.5 TMPA0602S-1R5MN-D 1.50 9.5 8.0 11.5 9.8 19.5 22.5 TMPA0602S-2R2MN-D 2.20 8.0 7.0 10 9.0 25.6 29.5 TMPA0602S-3R3MN-D 3.30 6.8 5.2 7.5 6.0 41.5 48 TMPA0602S-4R7MN-D 4.70 5.5 4.5 6.0 5.0 48 57 TMPA0602S-5R6MN-D 5.60 5.0 4.0 5.0 4.0 56 66 TMPA0602S-6R8MN-D 6.80 4.5 3.8 4.3 3.6 60 70 TMPA0602S-100MN-D 10.0 3.4 3.0 3.4 3.0 118 140 Part Number I rms ( A ) I sat ( A ) DCR (mΩ)Typ DCR (mΩ)Max 31 2.1 2.4 20 2.7 3.4 20 18 3.7 4.4 18 16 5.6 6.3 Inductance L0 A(uH) ±20% Typ Max Typ Max TMPA0624S-R10YN-D 0.10±30% 30 25 70 Part Number I rms ( A ) I sat ( A ) DCR (mΩ)Typ DCR (mΩ)Max 60 1.2 1.35 TMPA0624S-R15YN-D 0.15±30% 32 30 41 34 1.5 1.80 TMPA0624S-R22MN-D 0.22 26 23 34 28 2.2 2.53 TMPA0624S-R33MN-D 0.33 24 21 27 24 3.2 3.52 TMPA0624S-R47MN-D 0.47 19 16 22 18 4.4 5.06 TMPA0624S-R68MN-D 0.68 17 14 17 15 5.2 6.0 TMPA0624S-R82MN-D 0.82 16 13 16 14 7.3 8.1 TMPA0624S-1R0MN-D 1.00 13 11 15 13 10 11.8 TMPA0624S-1R5MN-D 1.50 11 9.0 14 12 13.5 16 TMPA0624S-2R2MN-D 2.20 9.5 8.0 10 9.0 18.5 23 TMPA0624S-3R3MN-D 3.30 8.0 6.0 8.5 7.0 31 38 TMPA0624S-4R7MN-D 4.70 6.5 5.5 7.0 6.0 38 46 TMPA0624S-5R6MN-D 5.60 6.0 5.0 6.2 5.7 47 56.4 TMPA0624S-6R8MN-D 6.80 4.5 4.0 6.0 5.6 58 67 TMPA0624S-100MN-D 10.0 3.7 3.4 4.6 4.2 81 93 TAI-TECH P11 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max TMPA0603S-R10YN-D 0.10±30% 35 30 45 I rms ( A ) I sat ( A ) DCR (mΩ)Typ DCR (mΩ)Max 40 1.1 1.3 TMPA0603S-R15YN-D 0.15±30% 30 25 40 36 1.7 2.1 TMPA0603S-R22MN-D 0.22 23 21 34 32 2.0 2.5 TMPA0603S-R33MN-D 0.33 21 20 25 22 2.8 3.4 TMPA0603S-R47MN-D 0.47 18 16 20 18 3.4 4.0 TMPA0603S-R56MN-D 0.56 16.5 15 18 16 3.9 4.5 TMPA0603S-R68MN-D 0.68 16 14.5 17 15 4.7 5.3 TMPA0603S-R82MN-D 0.82 14 13 16 14 5.4 6.0 TMPA0603S-1R0MN-D 1.00 12 11 15 13.5 6.7 7.4 TMPA0603S-1R5MN-D 1.50 10 9.0 14 12 10.2 12.1 TMPA0603S-2R2MN-D 2.20 8.0 7.5 10 9.0 13.5 15 TMPA0603S-3R3MN-D 3.30 6.5 6.0 9.5 8.5 19 22 TMPA0603S-4R7MN-D 4.70 5.5 5.0 6.5 5.5 28 33 TMPA0603S-5R6MN-D 5.60 5.5 5.0 6 5.2 39 42 TMPA0603S-6R8MN-D 6.80 4.5 4.2 6 5.0 43 50 TMPA0603S-8R2MN-D 8.20 4.5 4.0 6 4.7 54 60 TMPA0603S-100MN-D 10.0 4.0 3.5 5.5 4.5 62 68 TMPA0603S-150MN-D 15.0 3.0 2.5 4.5 4.0 110 140 TMPA0603S-220MN-D 22.0 2.5 2.0 3.0 2.5 150 190 TMPA0603S-330MN-D 33.0 2.1 1.8 2.5 2.0 215 258 TMPA0603S-470MN-D 47.0 1.9 1.6 1.8 1.6 250 300 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max DCR (mΩ)Typ DCR (mΩ)Max TMPA0604S-R15MN-D 0.15 35 30 45 40 1.4 1.68 TMPA0604S-R33MN-D 0.33 25 23 28 25 2.2 2.5 TMPA0604S-R45MN-D 0.45 20 18 21 18 2.8 3.2 TMPA0604S-R56MN-D 0.56 19 16 20 17 3.4 3.7 TMPA0604S-1R0MN-D 1.00 15 13 15 13.5 5.6 6.2 TMPA0604S-6R8MN-D 6.80 7.6 6.6 6.8 5.8 31 38 TMPA0604S-100MN-D 10.0 5.0 4.5 6.3 5.8 52 60 I rms ( A ) I sat ( A ) TAI-TECH P12 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max TMPA0605S-R15MN-D 0.15 35 32 45 TMPA0605S-R22MN-D 0.22 30 26 40 TMPA0605S-R33MN-D 0.33 26 24 TMPA0605S-R47MN-D 0.47 22 20 TMPA0605S-R56MN-D 0.56 21 TMPA0605S-R68MN-D 0.68 TMPA0605S-R82MN-D 0.82 TMPA0605S-1R0MN-D TMPA0605S-1R5MN-D I rms ( A ) I sat ( A ) DCR (mΩ)Typ DCR (mΩ)Max 40 1.3 1.7 35 1.7 2.2 25 23 1.9 2.4 22 20 2.9 3.3 19 21 18 3.4 3.9 20 18 20 17 3.6 4.1 18 16 18 15 5.3 5.9 1.00 17 15 16 13 5.6 6.2 1.50 15 13 13 10.5 6.6 7.3 TMPA0605S-2R2MN-D 2.20 14 12 10 8.5 10 11.5 TMPA0605S-3R3MN-D 3.30 13 11 9.5 8.0 14 16.2 TMPA0605S-4R7MN-D 4.70 11 9.5 8.8 7.5 20.8 24 TMPA0605S-5R6MN-D 5.60 10 8.5 8.0 7.2 28 33 TMPA0605S-6R8MN-D 6.80 9.0 8.0 7.6 7.0 30 36 TMPA0605S-8R2MN-D 8.20 7.5 6.5 6.5 6.0 38.5 45 TMPA0605S-100MN-D 10.0 7.0 6.0 6.0 5.7 44 53 TMPA0605S-150MN-D 15.0 5.0 4.0 4.0 3.2 73 85 TMPA0605S-220MN-D 22.0 4.2 3.6 3.6 3.1 122 142 TMPA0605S-330MN-D 33.0 3.0 2.5 2.3 1.8 142 170 TMPA0605S-470MN-D 47.0 2.6 2.0 1.8 1.5 275 320 TMPA0605S-101MN-D 100.0 1.8 1.4 1.2 1 432 520 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max Typ Max TMPA0754S-1R5MN-D 1.5 15.5 14.0 16.0 14.0 6.1 7.3 TMPA0754S-3R3MN-D 3.3 11.5 10.5 12.0 11.0 12.0 14.4 TMPA0754S-4R4MN-D 4.4 10.3 9.3 11.5 10.3 15.3 18.4 TMPA0754S-4R7MN-D 4.7 10.0 9.0 11.2 10.0 17.0 20.4 TMPA0754S-6R8MN-D 6.8 8.0 7.0 9.5 8.5 24 28.8 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max Typ Max I rms ( A ) I rms ( A ) I sat ( A ) I sat ( A ) DCR (mΩ) DCR (mΩ) TMPA0804SP-R10YN-D 0.10±30% 35.0 30.0 52.0 47.0 0.42 0.47 TMPA0804SP-R15MN-D 0.15 32.0 28.0 48.0 45.0 1.1 1.25 TMPA0804SP-R33MN-D 0.33 28.0 25.0 36.0 32.0 1.6 1.9 TMPA0804SP-1R0MN-D 1.0 19.0 17.0 18.0 16.0 3.6 4.32 TMPA0804SP-3R3MN-D 3.3 13.0 11.0 13.0 11.0 12.0 14.0 TMPA0804SP-4R7MN-D 4.7 10.0 9.0 11.0 10.0 19.0 21.9 TMPA0804SP-100MN-D 10.0 6.5 5.5 8.5 7.5 45.0 52.0 TMPA0804SP-150MN-D 15.0 5.4 4.9 6.5 6.0 60.0 69.0 TMPA0804SP-220MN-D 22.0 4.5 4.0 4.5 4.0 85.0 98.0 TAI-TECH P13 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max Typ Max TMPA0805SP-1R0MN-D 1.0 20.0 18.0 16.0 14.0 3.4 4.1 TMPA0805SP-3R3MN-D 3.3 15.0 13.0 12.0 10.0 10.8 13.0 TMPA0805SP-4R7MN-D 4.7 11.0 10.0 11.0 10.0 16.0 19.6 TMPA0805SP-100MN-D 10.0 7.2 6.5 8.0 7.0 37 44.5 TMPA0805SP-150MN-D 15.0 5.0 4.0 5.5 4.5 50.0 60.0 TMPA0805SP-220MN-D 22.0 4.6 4 5 4.5 82 90 TMPA0805SP-470MN-D 47.0 3.8 3.2 3.1 2.6 135 150 TMPA0805SP-101MN-D 100.0 2.5 2.2 2.3 1.9 290 319 I rms ( A ) I sat ( A ) Inductance L0 A(uH) ±20% Typ Max Typ Max TMPA1003S-R22MN-D 0.22 33 30 50 TMPA1003S-R36MN-D 0.36 28 25 40 TMPA1003S-R47MN-D 0.47 26 23 TMPA1003S-R82MN-D 0.82 20 18 TMPA1003S-2R2MN-D 2.20 14 TMPA1003S-4R7MN-D 4.70 10 TMPA1003S-8R2MN-D 8.20 7.2 Part Number Inductance L0 A(uH) ±20% Typ 44.0 Part Number TMPA1004S-R15YN-D 0.15±30% TMPA1004S-R15MN-0R4410-D 0.15 I rms ( A ) I sat ( A ) DCR (mΩ) DCR (mΩ) E(mm) Type typ max 45 0.9 1.0 2.7±0.35 non-leadframe 35 1.25 1.4 2.7±0.35 non-leadframe 36 32 1.8 2.2 2.5±0.35 non-leadframe 28 25 3.1 3.7 3.0±0.3 leadframe 12 18 16 7.8 8.8 3.0±0.3 leadframe 9 12 10 18.5 21.3 3.0±0.3 leadframe 6.5 7.2 6.8 32 38 3.0±0.3 leadframe E(mm) ±0.3 Type 3.0 non-leadframe 3.0 non-leadframe 3.0 non-leadframe 3.0 non-leadframe I rms ( A ) I sat ( A ) Max Typ 38.0 82.0 40.0 DCR (mΩ) Max typ max 75.0 0.5 0.6 75.0 0.44±10% TMPA1004S-R22MN-D 0.22 36.0 33.0 70.0 60.0 TMPA1004S-R22MN-R6007-D 0.22 50.0 40.0 72.0 65.0 0.72 0.83 TMPA1004S-R36MN-D 0.36 33.0 29.0 51.0 45.0 1.05 1.18 3.0 non-leadframe TMPA1004S-R47MN-D 0.47 32.0 28.0 46.0 40.0 1.3 1.5 3.0 non-leadframe TMPA1004S-R56MN-D 0.56 25.0 23.0 34.0 29.0 1.6 1.8 2.5 non-leadframe TMPA1004S-R68MN-D 0.68 23.0 20.0 31.0 28.0 1.9 2.2 2.5 non-leadframe TMPA1004S-R82MN-D 0.82 22.0 19.0 30.0 27.0 2.1 2.5 2.5 non-leadframe TMPA1004S-1R0MN-D 1.00 20.0 18.0 29.0 26.0 2.9 3.25 2.5 non-leadframe TMPA1004S-1R5MN-D 1.50 17.5 16.0 26.0 22.0 3.7 4.2 2.5 non-leadframe leadframe 0.6±7% TMPA1004S-2R2MN-D 2.20 15.0 13.0 20.0 16.0 5.8 6.7 3.0 TMPA1004S-3R3MN-D 3.30 11.0 10.0 17.5 14.0 10.5 11.8 3.0 leadframe TMPA1004S-4R7MN-D 4.70 8.8 8.0 15.2 13.0 15.8 19 3.0 leadframe TMPA1004S-5R6MN-D 5.60 8.0 7.2 14.1 11.5 19 22.8 3.0 leadframe TMPA1004S-6R8MN-D 6.80 7.8 6.8 12.2 11.0 22 24.5 3.0 leadframe TMPA1004S-8R2MN-D 8.20 7.6 6.5 9.5 8.5 25 28 3.0 leadframe TMPA1004S-100MN-D 10.0 7.5 6.1 8.6 7.5 27 30 3.0 leadframe TMPA1004S-150MN-D 15.0 6.25 5.0 7.0 6.0 41 45 3.0 leadframe TMPA1004S-220MN-D 22.0 5.0 4.1 6.2 5.5 58 66 3.0 leadframe TMPA1004S-330MN-D 33.0 4.4 3.5 5.5 5.0 84 91 3.0 leadframe TMPA1004S-470MN-D 47.0 3.5 3.0 4.0 3.7 125 143 3.0 leadframe TMPA1004S-680MN-D 68.0 2.6 2.4 3.2 3.0 184 210 3.0 leadframe TMPA1004S-820MN-D 82.0 2.3 2.1 3.0 2.8 240 270 3.0 leadframe 310 3.0 leadframe TMPA1004S-101MN-D 100 2.0 1.8 2.7 2.4 270 TAI-TECH P14 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max Typ Max TMPA1005S-R36MN-D 0.36 34.0 30.0 52.0 46.0 0.82 TMPA1005S-R47MN-D 0.47 33.0 29.0 46.0 40.0 1.15 TMPA1005S-R68MN-D 0.68 28.0 25.0 35.0 32.0 TMPA1005S-1R0MN-D 1.00 25.0 23.0 33.0 30.0 TMPA1005S-1R5MN-D 1.50 23.0 21.0 27.0 TMPA1005S-2R2MN-D 2.20 19.5 17.5 20.0 TMPA1005S-3R3MN-D 3.30 17.0 15.0 TMPA1005S-4R7MN-D 4.70 15.0 TMPA1005S-5R6MN-D 5.60 13.0 TMPA1005S-6R8MN-D 6.80 TMPA1005S-8R2MN-D 8.2 TMPA1005S-100MN-D TMPA1005S-150MN-D I rms ( A ) I sat ( A ) DCR (mΩ) E(mm) ±0.3 Type 0.92 3.0 non-leadframe 1.32 3.0 non-leadframe 1.6 1.9 2.5 non-leadframe 2.6 3.0 2.5 non-leadframe 24.0 3.4 3.8 2.5 non-leadframe 18.0 5.1 5.6 3.0 leadframe 17.5 15.5 8.1 9.1 3.0 leadframe 13.0 16.0 14.0 9.3 10.5 3.0 leadframe 11.0 15.0 12.5 12.8 14.4 3.0 leadframe 12.0 10.0 14.0 12.0 15.0 17.3 3.0 leadframe 10 8.5 13.5 11.5 16.1 18.8 3.0 leadframe 10.0 7.6 7.2 13.0 11.0 18.9 21.8 3.0 leadframe 15.0 6.5 6.0 8.5 7.5 32 39 3.0 leadframe TMPA1005S-220MN-D 22.0 6.0 5.5 6.0 5.5 44.0 54.0 3.0 leadframe TMPA1005S-330MN-D 33.0 5.5 5.0 5.8 5.2 740 86.0 3.0 leadframe TMPA1005S-470MN-D 47.0 4.5 4.0 4.0 3.5 106.0 127.0 3.0 leadframe TMPA1005S-680MN-D 68.0 3.5 3.0 3.5 3.0 148.0 177.0 3.0 leadframe TMPA1005S-101MN-D 100 2.2 2.0 2.8 2.4 242.0 290.0 3.0 leadframe Part Number Inductance L0 A(uH) ±20% Type Typ Max Typ Max Typ Max E(mm) ±0.3 TMPA1205SP-R47MN-D 0.47 38.0 34.0 65.0 58.0 0.77 0.9 4.0 non-leadframe TMPA1205SP-R56MN-D 0.56 36.0 32.5 57.0 50.0 1.1 1.3 4.0 non-leadframe TMPA1205SP-R68MN-D 0.68 34 31 50 42 1.3 1.55 4.0 non-leadframe TMPA1205SP-1R0MN-D 1.00 30 27 40 34 1.6 1.9 4.0 non-leadframe TMPA1205SP-1R5MN-D 1.50 25 22 31 28 3.2 3.8 4.7 leadframe TMPA1205SP-2R2MN-D 2.20 17 15.5 26 23 4.1 4.8 4.7 leadframe TMPA1205SP-3R3MN-D 3.30 15.5 14 23 20.5 6.0 7.0 4.7 leadframe TMPA1205SP-4R7MN-D 4.70 14 12.5 18.5 16 8.8 10.2 4.7 leadframe TMPA1205SP-6R8MN-D 6.80 12 11 16.5 15 13 16 4.7 leadframe TMPA1205SP-100MN-D 10.0 10 9.0 13 10.5 19.2 22 4.7 leadframe TMPA1205SP-150MN-D 15.0 9.4 8.2 11 9.2 30 36 4.7 leadframe TMPA1205SP-220MN-D 22.0 8.0 7.0 8.5 7.5 42 52 4.7 leadframe TMPA1205SP-330MN-D 33.0 6.0 5.2 7.3 6.5 66 80 4.7 leadframe TMPA1205SP-470MN-D 47.0 5.2 4.3 6.0 5.2 78 94 4.7 leadframe TMPA1205SP-680MN-D 68.0 4.3 3.6 5.0 4.4 110 132 4.7 leadframe TMPA1205SP-820MN-D 82.0 3.9 3.4 4.5 4.1 142 171 4.7 leadframe TMPA1205SP-101MN-D 100 3.5 3.0 4.0 3.7 175 210 4.7 leadframe TMPA1205SP-151MN-D 150 2.7 2.3 3.2 2.8 280 336 4.7 leadframe I rms ( A ) I sat ( A ) DCR (mΩ) TAI-TECH Part Number P15 Inductance L0 A(uH) ±20% I rms ( A ) I sat ( A ) DCR (mΩ) Typ Max Typ Max Typ Max E(mm) ±0.3 Type TMPA1206SP-R36MN-D 0.36 60.0 50.0 70.0 60.0 0.65 0.8 4.7 non-leadframe TMPA1206SP-R82MN-D 0.82 35 30 41 36 1.4 1.7 4.0 non-leadframe TMPA1206SP-1R0MN-D 1.00 30.0 26.0 34.0 29.0 1.7 2.0 4.0 leadframe TMPA1206SP-1R5MN-D 1.50 28.0 24.0 32.0 27.0 2.4 3.0 4.0 leadframe TMPA1206SP-2R2MN-D 2.20 25.0 21.0 28.0 24.0 3.7 4.3 4.7 leadframe TMPA1206SP-3R3MN-D 3.30 21.0 18.0 28.0 24.0 5.30 6.50 4.7 leadframe TMPA1206SP-4R7MN-D 4.70 19.0 16.0 23.0 19.5 7.0 8.4 4.7 leadframe TMPA1206SP-5R6MN-D 5.60 16.0 14.0 19.0 17.0 9.0 10.8 4.7 leadframe TMPA1206SP-8R2MN-D 8.20 13.5 12.0 17.0 15.5 13.5 16.0 4.7 leadframe TMPA1206SP-100MN-D 10.0 12.0 10.5 16.0 14.5 15.5 18.6 4.7 leadframe TMPA1206SP-150MN-D 15.0 10.0 8.50 10.0 9.00 24.0 29.0 4.7 leadframe TMPA1206SP-220MN-D 22.0 8.00 7.00 9.00 8.00 31.2 37.5 4.7 leadframe TMPA1206SP-330MN-D 33.0 6.50 5.50 7.80 6.70 56.0 68.0 4.7 leadframe TMPA1206SP-470MN-D 47.0 5.20 4.50 6.70 5.50 76.0 88.0 4.7 leadframe TMPA1206SP-560MN-D 56.0 4.90 4.10 6.30 5.30 90 108 4.7 leadframe TMPA1206SP-680MN-D 68.0 4.50 3.70 5.80 5.00 103 124 4.7 leadframe TMPA1206SP-101MN-D 100 3.20 2.80 5.00 4.00 162 195 4.7 leadframe TMPA1206SP-151MN-D 150 2.60 2.20 4.10 3.20 270 325 4.7 leadframe Part Number Inductance L0 A(uH) ±20% E(mm) ±0.3 Type I rms ( A ) I sat ( A ) Typ Max Typ DCR (mΩ) Max Typ Max TMPA1265SP-R10YN-D 0.10±30% 65 60 120 115 0.2 0.25 4.7 non-leadframe TMPA1265SP-R22MN-D 0.22 53 42 112 105 0.4 0.46 4.7 non-leadframe TMPA1265SP-R33MN-D 0.33 46.0 36.0 75.0 65.0 0.6 0.7 4.7 non-leadframe TMPA1265SP-R47MN-D 0.47 42.0 35.0 68.0 58.0 0.88 1.02 4.7 non-leadframe TMPA1265SP-R56MN-D 0.56 37.0 33.5 57.0 50.0 1.1 1.3 4.0 non-leadframe TMPA1265SP-R68MN-D 0.68 36.5 33 55 46 1.25 1.5 4.0 non-leadframe TMPA1265SP-1R0MN-D 1.00 33 29 45 36 1.5 1.8 4.0 non-leadframe TMPA1265SP-1R5MN-D 1.50 29 25 35 30 2.2 2.53 4.0 non-leadframe TMPA1265SP-2R2MN-D 2.20 25 21 28.5 24 3.7 4.2 4.7 leadframe TMPA1265SP-3R3MN-D 3.30 22 19 27 22.5 5.3 6.2 4.7 leadframe TMPA1265SP-4R7MN-D 4.70 20 17 25 21 6.8 8.0 4.7 leadframe TMPA1265SP-5R6MN-D 5.60 18 15 23 19.5 8.3 9.8 4.7 leadframe TMPA1265SP-6R8MN-D 6.80 16.5 14 21 18 9.8 11.3 4.7 leadframe TMPA1265SP-8R2MN-D 82.0 15 12.5 19 17 12 13.8 4.7 leadframe TMPA1265SP-100MN-D 10.0 13 11 17 15 13 15.8 4.7 leadframe TMPA1265SP-150MN-D 15.0 11 9.5 13.5 12 22 26 4.7 leadframe TMPA1265SP-220MN-D 22.0 10 8 10 9 31 35 4.7 leadframe TMPA1265SP-330MN-D 33.0 9.0 6.5 9.0 8.0 46.0 55.0 4.7 leadframe TMPA1265SP-470MN-D 47.0 8.0 5.7 7.6 6.8 58.0 67.0 4.7 leadframe TMPA1265SP-680MN-D 68.0 5.8 4.8 6.0 5.0 82.0 100.0 4.7 leadframe TMPA1265SP-101MN-D 100 5.0 3.8 5.0 4.0 140.0 161.0 4.7 leadframe TAI-TECH Part Number P16 Inductance L0 A(uH) ±20% I rms ( A ) I sat ( A ) Typ Max Typ Max DCR (mΩ)Typ DCR (mΩ)Max TMPA1707SP-R47MN-D 0.47 60 55 110 100 0.7 0.9 TMPA1707SP-R56MN-D 0.56 56 50 80 70 0.81 0.97 TMPA1707SP-1R0MN-D 1.00 46 42 50 45 1.06 1.3 TMPA1707SP-1R5MN-D 1.50 39 35 46 40 1.5 1.8 TMPA1707SP-2R2MN-D 2.20 32 30 35 32 1.8 2.2 TMPA1707SP-3R3MN-D 3.30 30 28 32 29 2.7 3.3 TMPA1707SP-4R7MN-D 4.70 28 26 29 26 3.7 4.5 TMPA1707SP-5R6MN-D 5.6 26 23 27 23 5.0 6.0 TMPA1707SP-6R8MN-D 6.80 24 22 25 22 6.0 7.2 TMPA1707SP-100MN-D 10.0 21 19 22 19 9.2 10.6 TMPA1707SP-150MN-D 15.0 16 14 16 14 12.8 15.5 TMPA1707SP-220MN-D 22.0 13.5 11.5 13.5 11.5 20.5 24 TMPA1707SP-330MN-D 33.0 12 10 12 10 32 37 TMPA1707SP-470MN-D 47.0 9.5 8.0 9.5 8.0 40 47 TMPA1707SP-560MN-D 56.0 8.8 7.3 9.0 7.6 53 64 TMPA1707SP-680MN-D 68.0 8.0 6.5 8.5 7.2 66 76 TMPA1707SP-820MN-D 82.0 6.5 5.7 8.0 6.5 69 83 TMPA1707SP-101MN-D 100.0 6.0 5.0 6.5 5.5 90 105 TAI-TECH P17 I rms ( A ) I sat ( A ) DCR (mΩ)Typ DCR (mΩ)Max 110 0.44 0.5 90 80 0.6 0.72 60 54 0.8 0.95 57 52 48 1.0 1.15 58 52 48 43 1.05 1.25 49 47 41 37 1.5 1.75 4.70 47 44 38 34 1.9 2.2 5.60 43 40 37 33 2.3 2.7 TMPA2313SP-6R8MN-D 6.80 40 36 36 32 2.7 3.1 TMPA2313SP-100MN-D 10.0 33 30 28 20 3.8 4.15 TMPA2313SP-150MN-D 15.0 26 23 23 18 5.1 6.12 TMPA2313SP-220MN-D 22.0 22 18 15 14 9.2 11 TMPA2313SP-330MN-D 33.0 19 16 12 10.5 13.5 15.4 TMPA2313SP-470MN-D 47.0 17 14 12 10 17.3 20.8 TMPA2313SP-680MN-D 68.0 14 12 12 9.0 26.2 29.5 TMPA2313SP-820MN-D 82.0 12 10 9.0 7.7 31 34.2 TMPA2313SP-101MN-D 100 11 9.5 9.0 7.5 36 40 TMPA2313SP-151MN-D 150 8 7 7 5.5 67 80 TMPA2313SP-251MN-D 250 6.5 5.5 5.0 4.0 110 121 TMPA2313SP-331MN-D 330 5.0 4.5 4.0 3.5 140 160 TMPA2313SP-471MN-D 470 4.5 4.0 3.5 3.0 193 232 Part Number Inductance L0 A(uH) ±20% Typ Max Typ Max TMPA2313SP-R47MN-D 0.47 80 75 140 TMPA2313SP-R68MN-D 0.68 75 70 TMPA2313SP-1R0MN-D 1.00 70 65 TMPA2313SP-1R5MN-D 1.50 62 TMPA2313SP-2R2MN-D 2.20 TMPA2313SP-3R3MN-D 3.30 TMPA2313SP-4R7MN-D TMPA2313SP-5R6MN-D Note: 1. Test frequency : Ls : 100KHz /1.0V. 2. All test data referenced to 25℃ ambient. 3. Testing Instrument(or equ) : Agilent 4284A,E4991A,4339B,KEYSIGHT E4980A/AL,chroma3302,3250,16502. 4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃ 5. Saturation Current (Isat) will cause L0 to drop approximately 30%. 6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 7. Irms Testing : Temperature rise is highly dependent on many factors including pcb land pattern, trace size, and proximity to other components. Therefore temperature rise should be verified in application conditions. 8. Rated DC current: The lower value of Irms and Isat 6. Material List 4 4 3 1 3 1 2 Materials 2 NO Items NO Items 1 Core Alloy Powder . 1 Core Alloy Powder . Wire Polyester Wire or equivalent. 2 Wire Polyester Wire or equivalent. 2 3 Clip 100% Pb free solder(Ni+Sn---Plating) 3 4 Ink Halogen-free ketone 4 Materials Solder 100% Pb free solder Ink Halogen-free ketone TAI-TECH P18 7. Packaging Information (1) Reel Dimension COVER TAPE Type 053T/606010/0618/060 13”x16mm 2/0624/0603/0604/ 0605/0754 0804/0805/1003/1004/ 13”x24mm 1005/1205/1206/1265 C A TMPA 0302/0312/0315/0318/ 0401/0402/0502/0503/ 13”x12mm 401040 B D 2.0∮0.5 EMBOSSED CARRIER A(mm) B(mm) C(mm) D(mm) 12.4+2/-0 100±2 13+0.5/-0.2 330 16.4+2/-0 100±2 13+0.5/-0.2 330 24.4+4/-0 100±2 13.5±0.5 330 1707 13”x32mm 32.4+2/-0 100±2 13+0.5/-0.2 330 2313 13”x44mm 44.4+2/-0 100±2 13+0.5/-0.2 330 (2) Tape Dimension 4.0 Blank portions Chip cavity Blank portions T B0 W F D K0 P 200mm or more 400mm or more Direction of tape A0 Series Size Bo(mm) Ao(mm) Ko(mm) P(mm) W(mm) F(mm) T(mm) D(mm) Packaging Quantity TMPA 0302 3.8±0.1 3.5±0.1 2.3±0.1 8.0±0.1 12±0.3 5.5±0.1 0.35±0.05 1.5±0.1 3000PCS/R TMPA 0312 3.8±0.1 3.5±0.1 1.5±0.1 8.0±0.1 12±0.3 5.5±0.1 0.35±0.05 1.5±0.1 3000PCS/R TMPA 0315 3.8±0.1 3.5±0.1 1.8±0.1 8.0±0.1 12±0.3 5.5±0.1 0.35±0.05 1.5±0.1 4000PCS/R TMPA 0318 4.0±0.1 3.5±0.1 2.0±0.1 8.0±0.1 12±0.3 5.5±0.1 0.35±0.05 1.5±0.1 3000PCS/R TMPA 0401 5.0±0.1 4.4±0.1 1.1±0.1 8.0±0.1 12±0.3 5.5±0.1 0.35±0.05 1.5±0.1 5000PCS/R TMPA 0402 5.0±0.1 4.4±0.1 2.3±0.1 8.0±0.1 12±0.3 5.5±0.1 0.35±0.05 1.5±0.1 3000PCS/R TMPA 404010 5.0±0.1 4.40±0.1 1.1±0.1 8.0±0.1 12±0.3 5.5±0.1 0.35±0.05 1.5±0.1 5000PCS/R TMPA 0502 6.2±0.1 5.6±0.1 2.3±0.1 8.0±0.1 12±0.3 5.5±0.1 0.35±0.05 1.5±0.1 3000PCS/R TMPA 0503 6.2±0.1 5.6±0.1 3.3±0.1 8.0±0.1 12±0.3 5.5±0.1 0.35±0.05 1.5±0.1 2000PCS/R TMPA 053T 5.3±0.1 5.0±0.1 3.3±0.1 12±0.1 16±0.3 5.5±0.1 0.35±0.05 1.5±0.1 1000PCS/R TMPA 606010 6.45±0.1 6.40±0.1 1.1±0.1 12.0±0.1 16±0.3 7.5±0.1 0.35±0.05 1.5±0.1 3000PCS/R TMPA 0618 7.7±0.1 7.0±0.1 2.1±0.1 12.0±0.1 16±0.3 7.5±0.1 0.35±0.05 1.5±0.1 2000PCS/R TMPA 0602 7.7±0.1 7.0±0.1 2.3±0.1 12±0.1 16±0.3 7.5±0.1 0.35±0.05 1.5±0.1 1500PCS/R Chip cavity Blank portions 4.0 Blank portions T B0 W F D K0 P 200mm or more 400mm or more Direction of tape A0 TAI-TECH P19 Series Size Bo(mm) Ao(mm) Ko(mm) P(mm) W(mm) F(mm) T(mm) D(mm) Packaging Quantity TMPA 0624 7.7±0.1 7.0±0.1 2.7±0.1 12±0.1 16±0.3 7.5±0.1 0.35±0.05 1.5±0.1 1500PCS/R TMPA 0603 7.7±0.1 7.0±0.1 3.3±0.1 12±0.1 16±0.3 7.5±0.1 0.35±0.05 1.5±0.1 1000PCS/R TMPA 0604 7.7±0.1 7.0±0.1 4.3±0.1 12±0.1 16±0.3 7.5±0.1 0.35±0.05 1.5±0.1 1000PCS/R TMPA 0605 7.7±0.1 7.0±0.1 5.3±0.1 12±0.1 16±0.3 7.5±0.1 0.35±0.05 1.5±0.1 800PCS/R TMPA 0754 8.6±0.1 7.4±0.1 5.7±0.1 12±0.1 16±0.3 7.5±0.1 0.4±0.05 1.5±0.1 800PCS/R TMPA 0804 10.1±0.1 8.9±0.1 4.5±0.1 16.0±0.1 24±0.3 11.5±0.1 0.35±0.05 1.5±0.1 800PCS/R TMPA 0805 10.1±0.1 8.9±0.1 5.5±0.1 16.0±0.1 24±0.3 11.5±0.1 0.35±0.05 1.5±0.1 500PCS/R TMPA 1003 11.6±0.1 10.4±0.1 3.3±0.1 16.0±0.1 24±0.3 11.5±0.1 0.35±0.05 1.5±0.1 1000PCS/R TMPA 1004 11.6±0.1 10.4±0.1 4.5±0.1 16±0.1 24±0.3 11.5±0.1 0.35±0.05 1.5±0.1 500PCS/R TMPA 1005 11.6±0.1 10.4±0.1 5.3±0.1 16±0.1 24±0.3 11.5±0.1 0.35±0.1 1.5±0.1 500PCS/R TMPA 1205 14.1±0.1 12.9±0.1 5.5±0.1 16±0.1 24±0.3 11.5±0.1 0.35±0.05 1.5±0.1 500PCS/R TMPA 1206 14.1±0.1 12.9±0.1 6.5±0.1 16±0.1 24±0.3 11.5±0.1 0.35±0.05 1.5±0.1 500PCS/R TMPA 1265 14.1±0.1 12.9±0.1 7.0±0.1 16±0.1 24±0.3 11.5±0.1 0.35±0.1 1.5±0.1 500PCS/R Blank portions Blank portions Chip cavity P0 T D B1 B0 D/C Marking D/C W P2 Marking F E D P 200mm or more R0.7 K0 400mm or more Direction of tape 5 0.2±0.05 A1 A0 Series Size Bo(mm) Ao(mm) Ko(mm) P(mm) W(mm) F(mm) T(mm) D(mm) Packaging Quantity TMPA 1707 18.5±0.1 17.5±0.1 7.5±0.1 24±0.1 32±0.3 14.2±0.1 0.5±0.05 1.5±0.1 200PCS/R TMPA 2313 25±0.1 23.0±0.1 13.6±0.1 32±0.1 44±0.3 20.2±0.1 0.5±0.05 1.5±0.1 80 PCS/R (4) Tearing Off Force F Top cover tape The force for tearing off cover tape is 10 to 130 grams in the arrow direction under the following conditions(referenced ANSI/EIA-481-D-2008 of 4.11 standard). 165¢Xto180¢X Base tape Room Temp. (℃) Room Humidity (%) Room atm (hPa) Tearing Speed mm/min 5~35 45~85 860~1060 300 TAI-TECH P20 8. Reliability and Test Condition Item Performance Test Condition Operating temperature -40~+125℃ (Including self - temperature rise) N/A Storage temperature 1. -10~+40℃,50~60%RH (Product with taping) 2. -40~+125℃(on board) N/A Electrical Performance Test Inductance Agilent4284A,E4991A,KEYSIGHTE4980A/AL,chroma3302,3205 Refer to standard electrical characteristics list. DCR Agilent 4339B,chrom16502 Saturation Current (Isat) Approximately △30% Saturation DC Current (Isat) will cause L0 to drop △L(%) Heat Rated Current (Irms) Approximately △T40℃ Heat Rated Current (Irms) will cause the coil temperature rise △ T(℃). 1.Applied the allowed DC current 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through IR reflow for 3 times. times.( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Temperature: 125±2℃(Inductor,ambient + temp rise) Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs. Life Test Preconditioning: Run through IR reflow for 3 times times.( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Humidity:85±2﹪R.H, Temperature:85℃±2℃ Duration:1000hrs Min.(No load current) Measured at room temperature after placing for 24±2 hrs. Load Humidity Moisture Resistance Appearance:No damage. Inductance:within±10% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Thermal shock Vibration Preconditioning: Run through IR reflow for 3 times. times.( IPC/JEDECJ-STD-020E Classification Reflow Profiles) 1. Baked at50 ℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25 ℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow for 3 times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Condition for 1 cycle Step1:-40±2℃ 30±5min Step2:125±2℃ ≦20S Step3:125±2℃ 30±5min Step4:-40±2℃ ≦20S Number of cycles: 500 Measured at room fempraturc after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 3 times. times.( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minutes Equipment: Vibration checker Total Amplitude: 10g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 TAI-TECH Item P21 Performance Bending Appearance:No damage. Inductance:within±10% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Shock Solderability More than 95% of the terminal electrode should be covered with solder。 Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805inch(2012mm):1kg,
TMPA 2313SP-4R7MN-D 价格&库存
很抱歉,暂时无法提供与“TMPA 2313SP-4R7MN-D”相匹配的价格&库存,您可以联系我们找货
TMPA 2313SP-4R7MN-D
  • 1+83.164461+10.73489
  • 10+67.0054810+8.64909
  • 25+61.5524025+7.94520
库存:130
TMPA 2313SP-4R7MN-D
  • 80+55.3244680+7.14130
  • 160+51.94276160+6.70479
  • 240+50.06984240+6.46303
  • 400+47.81465400+6.17193
  • 560+46.39000560+5.98804
  • 800+44.93038800+5.79963
库存:130
