TMPA606010AF-100MN-D 数据手册
TAI-TECH
P2
SMD Power Inductor
TMPA-Series(N)
1. Features
1. Low loss realized with low DCR.
2. High performance realized by metal dust core.
Halogen
3. Ultra low buzz noise, due to composite construction.
4. 100% Lead(Pb)-Free and RoHS compliant.
Halogen-free
2. Applications
Commercial applications
3. Dimensions
C
L
E
B
1.5
Recommend PC Board Pattern
D
H
A
G
Note: 1.PCB layout is referred to standard IPC-7351B
2. The above PCB layout reference only.
3. Recommend solder paste thickness at
0.12mm and above.
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
L(mm)
G(mm)
H(mm)
TMPA0312S
3.2±0.2
3.1±0.2
1.0±0.2
0.8±0.2
0.6±0.2
3.6Ref
1.9Ref
1.0Ref
TMPA0315S
3.2±0.2
3.1±0.2
1.3±0.2
0.8±0.2
0.6±0.2
3.6Ref
1.9Ref
1.0Ref
TMPA0318S
3.2±0.2
3.1±0.2
1.6±0.2
0.8±0.2
0.6±0.2
3.6Ref
1.9Ref
1.0Ref
TMPA0302S
3.5±0.2
3.2±0.2
1.8±0.2
0.7±0.2
1.2±0.2
4.1Ref
1.9Ref
1.45Ref
C
D
L
100
E
B
H
A
G
0.12mm and above.
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
L(mm)
G(mm)
H(mm)
TMPA0401SP
4.5±0.2
4.1±0.2
1.0Max
0.8±0.25
1.8±0.2
5.2Ref
2.2Ref
2.5Ref
TMPA0402SP
4.45±0.25
4.1±0.2
1.8±0.2
0.8±0.25
2.0±0.2
5.2Ref
2.2Ref
2.0Ref
A
B
C
L
H
100
D
E
F
G
T
Series
A(mm)
B(mm)
Note: 1. The above PCB layout reference only.
2. Recommend solder paste thickness at
0.12mm and above.
C(mm)
D(mm)
E(mm)
F(mm)
TMPA404010 4.20±0.20 4.15±0.20 0.83±0.2 0.9±0.20 1.8±0.20 2.4±0.20
T(mm)
L(mm)
G(mm)
H(mm)
0~0.05
4.4 Ref
2.2 Ref
2.0 Ref
TAI-TECH
P3
H
L
G
0.12mm and above.
Series
A(mm)
A’(mm)
B(mm)
TMPA606010
6.1±0.3
6.0±0.2
6.1±0.3
C(mm)
D(mm)
E(mm)
0.8±0.2 1.75±0.3 4.0±0.2
L(mm)
G(mm)
H(mm)
7.0
2.8
4.5
H
L
1R0
2209
Series
G
0.12mm and above.
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
L(mm)
G(mm)
H(mm)
TMPA0502SP
5.7±0.3
5.2±0.2
1.8±0.2
1.0±0.3
2.5±0.3
6.0 Ref
2.8 Ref
2.5 Ref
TMPA0503S
5.7±0.3
5.2±0.2
2.8±0.2
1.0±0.3
2.0±0.2
6.0 Ref
2.8 Ref
2.5 Ref
TMPA053T
4.9±0.3
4.7±0.2
2.8±0.2
1.0±0.3
1.5±0.2
5.5 Ref
2.5 Ref
1.8 Ref
TMPA0618S
7.0±0.3
6.6±0.2
1.6±0.2
1.8±0.3
3.0±0.2
8.0Ref
3.7Ref
3.4Ref
TMPA0602S
7.1±0.3
6.6±0.2
1.8±0.2
1.6±0.3
3.0±0.2
8.0 Ref
3.7 Ref
3.4 Ref
TMPA0624S
7.1±0.3
6.7±0.2
2.2±0.2
1.6±0.3
3.0±0.2
8.0 Ref
3.7 Ref
3.4 Ref
TMPA0603S
7.1±0.3
6.6±0.2
2.8±0.2
1.6±0.3
3.0±0.2
8.0 Ref
3.7 Ref
3.4 Ref
TMPA0604S
7.1±0.3
6.6±0.2
3.8±0.2
1.6±0.3
2.8±0.3
8.0 Ref
3.7 Ref
3.4 Ref
TMPA0605S
7.3±0.3
6.6±0.3
4.8±0.2
1.6±0.3
3.0±0.2
8.0 Ref
3.7 Ref
3.4 Ref
TMPA0754S
7.8±0.3
7.1±0.2
5.2±0.2
1.6±0.3
3.0±0.3
9.0 Ref
3.2 Ref
3.5 Ref
TMPA0804S
8.8±0.4
8.2±0.3
3.8±0.2
1.4±0.3
5.0±0.3
9.5 Ref
4.0 Ref
5.5 Ref
TAI-TECH
P4
C
B
1R0
2131
Leadframe
L
D
H
2R2
2131
E
B
A
D
E
C
A
G
0.12mm and above.
non-leadframe
Series
A(mm)
B(mm)
C(mm)
D(mm)
TMPA1003S
11.0±0.5
10.0±0.3
2.8±0.2
2.0±0.3
TMPA1004S
11.0±0.3
10.0±0.3
3.8±0.2
2.0±0.3
TMPA1005S
11.0±0.5
10.0±0.3
4.8±0.2
2.0±0.3
TMPA1205SP
13.5±0.5
12.6±0.2
4.7±0.3
2.3±0.3
TMPA1206SP
13.5±0.5
12.6±0.2
5.7±0.3
2.3±0.3
TMPA1265SP
13.5±0.5
12.6±0.2
6.2±0.3
2.3±0.3
E(mm)
L(mm)
G(mm)
H(mm)
13.5Ref
5.4Ref
3.5Ref
12.5Ref
5.4Ref
3.5Ref
12.5Ref
5.4Ref
3.5Ref
14.5Ref
8.0Ref
5.0Ref
See Spec
table
14.5Ref
8.0Ref
5.0Ref
See Spec
table
14.5Ref
8.0Ref
5.0Ref
See Spec
table
See Spec
table
See Spec
table
See Spec
table
L
C
H
820
2209
2131
Series
D
G
E
B
A
A`
(TMPA1707)
0.17mm and above.
(TMPA2313)
2.0mm and above.
A(mm)
A`(mm)
B(mm)
C(mm)
D(mm)
E(mm)
L(mm)
G(mm)
H(mm)
TMPA1707SP
17.8±0.5
16.9±0.3
16.9±0.3
6.7±0.3
2.3±0.3
11.9±0.3
18.5Ref
12.0Ref
12.5Ref
TMPA2313SP
23.5±0.5
22.7±0.3
22.0±0.3
12.6±0.4
5.0±0.4
19.0±0.3
24.0Ref
12.5Ref
19.6Ref
TAI-TECH
P5
4. Part Numbering
TMPA
0302
S
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
1R5
MN
D
E
BxC
Standard.V: Vehicle
1R5=1.50uH.
M=±20% Y±30%
Marking: Black.1.5 (1.5:1R5).
TMPA
0402
SP
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
100
MN
D
E
BxC
Standard.
R10=0.1uh,1R0=1.0uh,100=10uh,101=100uh,102=1000uh.
K=±10%,L=±15%,M=±20%,N=±25%,Y=±30%
Marking: Black.100 Unidirectional printing.
TMPA
0603
S
A
B
C
B: Dimension
C: Type
D: Inductance
F: Code
1R0
MN
D
E
D
F
BxC
Standard.
Marking: Black.1R0 and 2209(22YY, 09 WW,follow production date).
TAI-TECH
P6
5. Specification
Part Number
Inductance
L0 (uH)±20%
@0A
Typ
Max
Typ
Max
Typ
Max
TMPA0312S-R24MN
0.24
8.3
7.2
9.5
8.0
12.0
14.4
TMPA0312S-R36MN
0.36
7.0
6.4
7.5
6.8
15.5
18.6
TMPA0312S-R47MN
0.47
6.3
5.9
6.6
6.1
20.5
24.6
TMPA0312S-R68MN
0.68
5.1
4.6
5.5
5.0
29.0
34.8
TMPA0312S-1R0MN
1.00
3.8
3.5
4.1
3.6
42.0
50.4
TMPA0312S-1R5MN
1.50
3.3
2.9
3.5
3.0
57.0
68.4
TMPA0312S-2R2MN
2.20
2.8
2.5
3.0
2.6
84
101
TMPA0312S-3R3MN
3.30
2.2
2.0
2.5
2.3
150
180
TMPA0312S-4R7MN
4.70
1.8
1.6
2.2
2.0
225
248
TMPA0312S-6R8MN
6.80
1.5
1.3
1.7
1.5
290
319
TMPA0312S-100MN
10.0
1.2
1.1
1.3
1.2
440
484
Part Number
Inductance
L0 (uH)±20%
@0A
Typ
Max
Typ
Max
Typ
Max
TMPA0315S-R22MN
0.22
8.7
8.0
10.0
8.5
10.0
12.0
TMPA0315S-R33MN
0.33
7.4
6.8
8.0
7.0
12.5
15.0
TMPA0315S-R47MN
0.47
6.6
6.1
7.0
6.5
15.5
19.0
TMPA0315S-R56MN
0.56
6.3
6.0
7.0
6.3
20.0
24.0
TMPA0315S-R68MN
0.68
5.6
5.0
6.0
5.5
25.0
30.0
TMPA0315S-1R0MN
1.00
4.7
4.4
5.0
4.5
34.0
41.0
TMPA0315S-1R5MN
1.50
4.0
3.2
4.0
3.2
50.0
60.0
TMPA0315S-2R2MN
2.20
3.2
2.9
3.5
3.1
70.0
84.0
TMPA0315S-3R3MN
3.30
2.6
2.4
2.8
2.5
120
144
TMPA0315S-4R7MN
4.70
2.0
1.8
2.4
2.2
170
204
TMPA0315S-5R6MN
5.60
1.7
1.5
2.0
1.8
200
240
TMPA0315S-6R8MN
6.80
1.6
1.4
1.8
1.6
223
268
TMPA0315S-8R2MN
8.20
1.5
1.3
1.6
1.4
300
360
TMPA0315S-100MN
10.0
1.4
1.2
1.5
1.3
335
402
Part Number
Inductance
L0 (uH)±20%
@0A
Typ
Max
Typ
Max
Typ
Max
TMPA0318S-R24MN
0.24
9.0
8.5
11.0
9.5
11.5
13.8
TMPA0318S-R36MN
0.36
7.4
6.9
9.0
8.0
13.0
15.6
TMPA0318S-R47MN
0.47
7.0
6.6
7.7
7.0
15.0
18.0
TMPA0318S-R56MN
0.56
6.6
6.3
7.3
6.5
19.0
22.8
TMPA0318S-R68MN
0.68
6.2
5.9
6.8
6.2
22.0
26.4
TMPA0318S-1R0MN
1.00
5.3
5.0
5.8
5.3
28.0
34.0
TMPA0318S-1R5MN
1.50
4.5
4.0
5.0
4.5
38.0
45.6
TMPA0318S-2R2MN
2.20
3.5
3.2
4.1
3.7
63.0
75.0
TMPA0318S-3R3MN
3.30
2.8
2.5
3.0
2.6
96.0
115.0
TMPA0318S-4R7MN
4.70
2.3
2.0
2.5
2.3
145.0
174.0
TMPA0318S-5R6MN
5.60
2.0
1.8
2.1
1.9
170.0
204.0
TMPA0318S-6R8MN
6.80
1.8
1.5
2.0
1.8
220.0
264.0
TMPA0318S-8R2MN
8.20
1.5
1.3
1.6
1.4
300.0
360.0
TMPA0318S-100MN
10.0
1.6
1.4
1.7
1.5
290.0
348.0
I rms ( A )
I sat ( A )
I rms ( A )
DCR(mΩ)
I sat ( A )
I rms ( A )
DCR(mΩ)
I sat ( A )
DCR(mΩ)
TAI-TECH
P7
Irms ( A )
I sat ( A )
DCR (mΩ)
Part Number
Inductance
L0 (uH)±20%
Typ
Max
Typ
Max
Typ
Max
TMPA0302S-R15YN
0.15±30%
11.0
10.0
14.0
12.0
8.0
9.6
TMPA0302S-R22MN
0.22
10.0
9.0
12.0
10.5
10.0
12.0
TMPA0302S-R33MN
0.33
9.0
8.0
10.0
9.0
12.0
14.4
TMPA0302S-R47MN
0.47
8.0
7.0
8.5
7.5
14.5
17.4
TMPA0302S-R68MN
0.68
6.8
6.3
7.0
6.5
TMPA0302S-1R0MN
1.0
5.8
5.3
6.0
5.5
27
33
TMPA0302S-1R5MN
1.5
5.1
4.6
5.5
5.0
35
42
TMPA0302S-2R2MN
2.2
4.0
3.5
4.5
4.0
55
66
TMPA0302S-3R3MN
3.3
3.0
2.6
3.2
2.8
92
111
TMPA0302S-4R7MN
4.7
2.5
2.2
2.8
2.5
122
147
TMPA0302S-6R8MN
6.8
2.0
1.8
2.2
2.0
211
254
TMPA0302S-100MN
10.0
1.5
1.3
1.6
1.4
285
342
Part Number
Inductance
L0 A(uH)
±20%
I rms ( A )
I sat ( A )
DCR(mΩ)
Typ
Max
Typ
Max
Typ
Max
48.3
TMPA0401SP-1R0MN
1.00
3.5
3.0
5.0
4.5
42
TMPA0401SP-1R5MN
1.50
2.8
2.4
4.6
4.3
62
72
TMPA0401SP-2R2MN
2.20
2.6
2.3
3.8
3.3
90
108
TMPA0401SP-3R3MN
3.30
2.1
1.8
3.3
2.8
135
150
TMPA0401SP-4R7MN
4.70
1.9
1.6
2.8
2.4
180
216
TMPA0401SP-6R8MN
6.80
1.7
1.5
2.3
2.0
260
300
TMPA0401SP-8R2MN
8.20
1.5
1.3
2.1
1.8
282
330
TMPA0401SP-100MN
10.0
1.4
1.2
2.0
1.6
316
340
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
Typ
Max
TMPA0402SP-R10MN
0.10
16
14
26
22
2.9
3.2
TMPA0402SP-R22MN
0.22
14
12.5
15
13
4.8
5.5
TMPA0402SP-R33MN
0.33
12
11
10.5
9.5
7.5
8.3
TMPA0402SP-R47MN
0.47
10
9.0
9.0
8.0
9.5
11
TMPA0402SP-R68MN
0.68
9.0
8.0
7.6
6.6
11.6
13.5
TMPA0402SP-R82MN
0.82
8.0
7.0
6.0
5.5
16.3
18.8
TMPA0402SP-1R0MN
1.00
7.5
6.5
5.5
5.0
19
22
TMPA0402SP-1R5MN
1.50
6.7
5.8
5.2
4.8
27
31
TMPA0402SP-2R2MN
2.20
5.5
5.0
4.5
4.0
41
48
TMPA0402SP-3R3MN
3.30
4.5
3.5
3.1
2.7
65
75
TMPA0402SP-4R7MN
4.70
3.8
3.2
2.8
2.5
84
95
TMPA0402SP-5R6MN
5.60
3.2
2.8
2.6
2.3
97
115
TMPA0402SP-6R8MN
6.80
2.9
2.5
2.4
2.1
131
157
TMPA0402SP-8R2MN
8.20
2.6
2.3
2.2
2.0
140
168
TMPA0402SP-100MN
10.0
2.4
2.2
2.1
1.9
165
215
TMPA0402SP-150MN
15.0
1.5
1.3
1.6
1.4
325
375
I rms ( A )
I sat ( A )
DCR(mΩ)
TAI-TECH
P8
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
TMPA404010AF-4R7MN
4.70
2.6
2.3
3.0
TMPA404010AF-6R8MN
6.80
2.0
1.8
TMPA404010AF-100MN
10.0
1.6
1.4
Part Number
Inductance
L0 A(uH)
±20%
Irms ( A )
I sat ( A )
DCR
(mΩ)Typ
DCR
(mΩ)Max
2.6
120
144
2.3
2.0
200
240
2.0
1.7
300
320
I rms ( A )
I sat ( A )
DCR(mΩ)
Typ
Max
Typ
Max
Typ
Max
2.3
2.53
TMPA0502SP-R10MN-D
0.10
25
22
29
26
TMPA0502SP-R15YN-D
0.15±30%
22
19
27
24
2.8
3.2
TMPA0502SP-R22MN-D
0.22
16
14
3.80
4.40
TMPA0502SP-R33MN-D
0.33
14
13
11
9.0
5.20
6.00
TMPA0502SP-R47MN-D
0.47
13
11
9.0
8.0
6.10
7.20
TMPA0502SP-R68MN-D
0.68
12
10
8.0
7.0
8.00
9.20
TMPA0502SP-1R0MN-D
1.00
8.6
7.5
7.5
6.5
14.0
16.2
TMPA0502SP-1R5MN-D
1.50
7.5
6.5
7.0
6.0
22.0
26.4
TMPA0502SP-2R2MN-D
2.20
6.5
6.0
5.8
5.0
29.0
34.0
TMPA0502SP-3R3MN-D
3.30
6.0
5.0
5.0
4.7
50.0
60.0
TMPA0502SP-4R7MN-D
4.70
4.0
3.0
4.7
4.4
84.0
97.0
TMPA0502SP-5R6MN-D
5.60
3.5
2.8
4.4
4.0
91.0
109
TMPA0502SP-6R8MN-D
6.80
3.1
2.6
4.2
3.8
110
127
TMPA0502SP-8R2MN-D
8.20
2.9
2.5
3.9
3.4
123
142
TMPA0502SP-100MN-D
10.0
2.7
2.4
3.5
3.0
150
180
TMPA0502SP-150MN-D
15.0
2.2
1.9
2.6
2.3
224
252
TMPA0502SP-220MN-D
22.0
1.9
1.6
2.2
1.9
290
325
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
TMPA0503S-R10MN-D
0.10
26
23
33
TMPA0503S-R33MN-D
0.33
16
14
TMPA0503S-R47MN-D
0.47
13.5
12
TMPA0503S-R56MN-D
0.56
13.0
TMPA0503S-R68MN-D
0.68
12.5
TMPA0503S-R82MN-D
0.82
TMPA0503S-1R0MN-D
1.00
TMPA0503S-1R5MN-D
1.50
TMPA0503S-2R2MN-D
2.20
TMPA0503S-3R3MN-D
TMPA0503S-4R7MN-D
I rms ( A )
I sat ( A )
DCR
(mΩ)Typ
DCR
(mΩ)Max
29
2.0
2.2
12
10
4.5
5.4
10
9.0
5.2
6.0
11.5
9.5
8.5
6.1
7.2
11
9.0
8.0
7.4
8.5
10
9.0
8.8
7.7
8.0
9.2
9.0
8.0
8.5
7.5
10.5
12
8.0
7.0
7.5
6.5
13.6
15.7
7.0
6.5
6.5
5.8
21.6
25
3.30
6.3
5.8
6.0
5.3
28
33
4.70
5.5
4.8
5.3
4.6
38
44
TMPA0503S-5R6MN-D
5.60
5.0
4.3
4.6
4.0
50
58
TMPA0503S-6R8MN-D
6.80
4.3
3.7
3.5
3.1
57
66
TMPA0503S-100MN-D
10.0
3.8
3.4
2.5
2.1
88
103
TMPA0503S-150MN-D
15.0
2.9
2.5
2.2
1.7
140
170
TMPA0503S-220MN-D
22.0
2.4
2.0
2.0
1.7
190
228
Part Number
TAI-TECH
P9
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
I rms ( A )
I sat ( A )
Max
DCR
(mΩ)Typ
DCR
(mΩ)Max
TMPA053T-R10YN-D
0.10±30%
32
28
32
28
1.8
2.1
TMPA053T-R22MN-D
0.22
18
16
17
14.5
2.8
3.2
TMPA053T-R35MN-D
0.35
16.5
15
15
12
4.6
5.1
TMPA053T-R47MN-D
0.47
16
14
11
9.5
5.5
6.4
TMPA053T-R68MN-D
0.68
12
10.5
9.0
8.5
7.0
8.4
TMPA053T-1R0MN-D
1.00
8.5
7.5
8.5
8.0
12.8
13.8
TMPA053T-1R5MN-D
1.50
6.6
6.0
6.3
5.5
16
21
TMPA053T-2R2MN-D
2.20
6.0
5.5
5.7
5.0
23
27.6
TMPA053T-3R3MN-D
3.30
5.5
5.0
5.0
4.3
30
36
TMPA053T-4R7MN-D
4.70
5.0
4.5
4.0
3.7
43
52
Part Number
Inductance
L0 (uH) ±20%
TMPA606010AF-4R7MN-D
I rms ( A )
I sat ( A )
DCR
(mΩ)Typ
DCR
(mΩ)Max
Typ
Max
Typ
Max
4.70
2.6
2.3
3.5
3.0
140.0
161.0
TMPA606010AF-6R8MN-D
6.80
2.1
1.9
2.5
2.2
164.0
197.0
10.0
1.7
1.5
2.1
1.9
259.0
310.0
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
TMPA0618S-R15YN-D
0.15±30%
21
19
30
TMPA0618S-R22MN-D
0.22
19
17
22
TMPA0618S-R33MN-D
0.33
17
15
19.5
TMPA0618S-R47MN-D
0.47
14
12
16
TMPA0618S-R68MN-D
0.68
12
10
14
TMPA0618S-1R0MN-D
1.0
9.5
8.5
11.5
TMPA0618S-1R5MN-D
1.5
8
7
10.5
TMPA0618S-2R2MN-D
2.2
7.0
6.0
TMPA0618S-3R3MN-D
3.3
6.0
TMPA0618S-4R7MN-D
4.7
4.5
TMPA0618S-6R8MN-D
6.8
4
TMPA0618S-100MN-D
10.0
3
Max
DCR
(mΩ)
Typ
DCR
(mΩ)
Max
27
1.9
2.4
3.6
17.5
4.4
5.3
14
6.3
7.0
12
7
8.4
10
12
14.4
9
18.5
22.2
7.5
6.5
29.5
33.5
5
7
5.7
49
56.4
4
5.8
5
56
67.2
3.2
4
3.5
75
90
2.7
3.3
2.9
109
130
I rms ( A )
I sat ( A )
TAI-TECH
P10
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
TMPA0602S-R15MN-D
0.15
28
25
34
TMPA0602S-R22MN-D
0.22
21
18
23
TMPA0602S-R33MN-D
0.33
19
16
TMPA0602S-R47MN-D
0.47
15
13
TMPA0602S-R68MN-D
0.68
13
11
14
12
7.8
8.8
TMPA0602S-1R0MN-D
1.00
11
9.5
12.5
10.5
13.5
15.5
TMPA0602S-1R5MN-D
1.50
9.5
8.0
11.5
9.8
19.5
22.5
TMPA0602S-2R2MN-D
2.20
8.0
7.0
10
9.0
25.6
29.5
TMPA0602S-3R3MN-D
3.30
6.8
5.2
7.5
6.0
41.5
48
TMPA0602S-4R7MN-D
4.70
5.5
4.5
6.0
5.0
48
57
TMPA0602S-5R6MN-D
5.60
5.0
4.0
5.0
4.0
56
66
TMPA0602S-6R8MN-D
6.80
4.5
3.8
4.3
3.6
60
70
TMPA0602S-100MN-D
10.0
3.4
3.0
3.4
3.0
118
140
Part Number
I rms ( A )
I sat ( A )
DCR
(mΩ)Typ
DCR
(mΩ)Max
31
2.1
2.4
3.4
3.7
4.4
18
16
5.6
6.3
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
TMPA0624S-R10YN-D
0.10±30%
30
25
70
Part Number
I rms ( A )
I sat ( A )
DCR
(mΩ)Typ
DCR
(mΩ)Max
60
1.2
1.35
TMPA0624S-R15YN-D
0.15±30%
32
30
41
34
1.5
1.80
TMPA0624S-R22MN-D
0.22
26
23
34
28
2.2
2.53
TMPA0624S-R33MN-D
0.33
24
21
27
24
3.2
3.52
TMPA0624S-R47MN-D
0.47
19
16
22
18
4.4
5.06
TMPA0624S-R68MN-D
0.68
17
14
17
15
5.2
6.0
TMPA0624S-R82MN-D
0.82
16
13
16
14
7.3
8.1
TMPA0624S-1R0MN-D
1.00
13
11
15
13
10
11.8
TMPA0624S-1R5MN-D
1.50
11
9.0
14
12
13.5
16
TMPA0624S-2R2MN-D
2.20
9.5
8.0
10
9.0
18.5
23
TMPA0624S-3R3MN-D
3.30
8.0
6.0
8.5
7.0
31
38
TMPA0624S-4R7MN-D
4.70
6.5
5.5
7.0
6.0
38
46
TMPA0624S-5R6MN-D
5.60
6.0
5.0
6.2
5.7
47
56.4
TMPA0624S-6R8MN-D
6.80
4.5
4.0
6.0
5.6
58
67
TMPA0624S-100MN-D
10.0
3.7
3.4
4.6
4.2
81
93
TAI-TECH
P11
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
TMPA0603S-R10YN-D
0.10±30%
35
30
45
I rms ( A )
I sat ( A )
DCR
(mΩ)Typ
DCR
(mΩ)Max
40
1.1
1.3
TMPA0603S-R15YN-D
0.15±30%
30
25
40
36
1.7
2.1
TMPA0603S-R22MN-D
0.22
23
21
34
32
2.0
2.5
TMPA0603S-R33MN-D
0.33
21
22
2.8
3.4
TMPA0603S-R47MN-D
0.47
18
16
3.4
4.0
TMPA0603S-R56MN-D
0.56
16.5
15
18
16
3.9
4.5
TMPA0603S-R68MN-D
0.68
16
14.5
17
15
4.7
5.3
TMPA0603S-R82MN-D
0.82
14
13
16
14
5.4
6.0
TMPA0603S-1R0MN-D
1.00
12
11
15
13.5
6.7
7.4
TMPA0603S-1R5MN-D
1.50
10
9.0
14
12
10.2
12.1
TMPA0603S-2R2MN-D
2.20
8.0
7.5
10
9.0
13.5
15
TMPA0603S-3R3MN-D
3.30
6.5
6.0
9.5
8.5
19
22
TMPA0603S-4R7MN-D
4.70
5.5
5.0
6.5
5.5
28
33
TMPA0603S-5R6MN-D
5.60
5.5
5.0
6
5.2
39
42
TMPA0603S-6R8MN-D
6.80
4.5
4.2
6
5.0
43
50
TMPA0603S-8R2MN-D
8.20
4.5
4.0
6
4.7
54
60
TMPA0603S-100MN-D
10.0
4.0
3.5
5.5
4.5
62
68
TMPA0603S-150MN-D
15.0
3.0
2.5
4.5
4.0
110
140
TMPA0603S-220MN-D
22.0
2.5
2.0
3.0
2.5
150
190
TMPA0603S-330MN-D
33.0
2.1
1.8
2.5
2.0
215
258
TMPA0603S-470MN-D
47.0
1.9
1.6
1.8
1.6
250
300
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
DCR
(mΩ)Typ
DCR
(mΩ)Max
TMPA0604S-R15MN-D
0.15
35
30
45
40
1.4
1.68
TMPA0604S-R33MN-D
0.33
25
23
28
25
2.2
2.5
TMPA0604S-R45MN-D
0.45
21
18
2.8
3.2
TMPA0604S-R56MN-D
0.56
19
16
3.4
3.7
TMPA0604S-1R0MN-D
1.00
15
13
15
13.5
5.6
6.2
TMPA0604S-6R8MN-D
6.80
7.6
6.6
6.8
5.8
31
38
TMPA0604S-100MN-D
10.0
5.0
4.5
6.3
5.8
52
60
I rms ( A )
I sat ( A )
TAI-TECH
P12
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
TMPA0605S-R15MN-D
0.15
35
32
45
TMPA0605S-R22MN-D
0.22
30
26
40
TMPA0605S-R33MN-D
0.33
26
24
TMPA0605S-R47MN-D
0.47
22
TMPA0605S-R56MN-D
0.56
21
TMPA0605S-R68MN-D
0.68
TMPA0605S-R82MN-D
0.82
TMPA0605S-1R0MN-D
TMPA0605S-1R5MN-D
I rms ( A )
I sat ( A )
DCR
(mΩ)Typ
DCR
(mΩ)Max
40
1.3
1.7
35
1.7
2.2
25
23
1.9
2.4
22
3.3
19
21
18
3.4
3.9
3.6
4.1
18
16
18
15
5.3
5.9
1.00
17
15
16
13
5.6
6.2
1.50
15
13
13
10.5
6.6
7.3
TMPA0605S-2R2MN-D
2.20
14
12
10
8.5
10
11.5
TMPA0605S-3R3MN-D
3.30
13
11
9.5
8.0
14
16.2
TMPA0605S-4R7MN-D
4.70
11
9.5
8.8
7.5
20.8
24
TMPA0605S-5R6MN-D
5.60
10
8.5
8.0
7.2
28
33
TMPA0605S-6R8MN-D
6.80
9.0
8.0
7.6
7.0
30
36
TMPA0605S-8R2MN-D
8.20
7.5
6.5
6.5
6.0
38.5
45
TMPA0605S-100MN-D
10.0
7.0
6.0
6.0
5.7
44
53
TMPA0605S-150MN-D
15.0
5.0
4.0
4.0
3.2
73
85
TMPA0605S-220MN-D
22.0
4.2
3.6
3.6
3.1
122
142
TMPA0605S-330MN-D
33.0
3.0
2.5
2.3
1.8
142
170
TMPA0605S-470MN-D
47.0
2.6
2.0
1.8
1.5
275
320
TMPA0605S-101MN-D
100.0
1.8
1.4
1.2
1
432
520
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
Typ
Max
TMPA0754S-1R5MN-D
1.5
15.5
14.0
16.0
14.0
6.1
7.3
TMPA0754S-3R3MN-D
3.3
11.5
10.5
12.0
11.0
12.0
14.4
TMPA0754S-4R4MN-D
4.4
10.3
9.3
11.5
10.3
15.3
18.4
TMPA0754S-4R7MN-D
4.7
10.0
9.0
11.2
10.0
17.0
20.4
TMPA0754S-6R8MN-D
6.8
8.0
7.0
9.5
8.5
24
28.8
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
Typ
Max
I rms ( A )
I rms ( A )
I sat ( A )
I sat ( A )
DCR (mΩ)
DCR (mΩ)
TMPA0804SP-R10YN-D
0.10±30%
35.0
30.0
52.0
47.0
0.42
0.47
TMPA0804SP-R15MN-D
0.15
32.0
28.0
48.0
45.0
1.1
1.25
TMPA0804SP-R33MN-D
0.33
28.0
25.0
36.0
32.0
1.6
1.9
TMPA0804SP-1R0MN-D
1.0
19.0
17.0
18.0
16.0
3.6
4.32
TMPA0804SP-3R3MN-D
3.3
13.0
11.0
13.0
11.0
12.0
14.0
TMPA0804SP-4R7MN-D
4.7
10.0
9.0
11.0
10.0
19.0
21.9
TMPA0804SP-100MN-D
10.0
6.5
5.5
8.5
7.5
45.0
52.0
TMPA0804SP-150MN-D
15.0
5.4
4.9
6.5
6.0
60.0
69.0
TMPA0804SP-220MN-D
22.0
4.5
4.0
4.5
4.0
85.0
98.0
TAI-TECH
P13
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
Typ
Max
TMPA0805SP-1R0MN-D
1.0
20.0
18.0
16.0
14.0
3.4
4.1
TMPA0805SP-3R3MN-D
3.3
15.0
13.0
12.0
10.0
10.8
13.0
TMPA0805SP-4R7MN-D
4.7
11.0
10.0
11.0
10.0
16.0
19.6
TMPA0805SP-100MN-D
10.0
7.2
6.5
8.0
7.0
37
44.5
TMPA0805SP-150MN-D
15.0
5.0
4.0
5.5
4.5
50.0
60.0
TMPA0805SP-220MN-D
22.0
4.6
4
5
4.5
82
90
TMPA0805SP-470MN-D
47.0
3.8
3.2
3.1
2.6
135
150
TMPA0805SP-101MN-D
100.0
2.5
2.2
2.3
1.9
290
319
I rms ( A )
I sat ( A )
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
TMPA1003S-R22MN-D
0.22
33
30
50
TMPA1003S-R36MN-D
0.36
28
25
40
TMPA1003S-R47MN-D
0.47
26
23
TMPA1003S-R82MN-D
0.82
TMPA1003S-2R2MN-D
2.20
14
TMPA1003S-4R7MN-D
4.70
10
TMPA1003S-8R2MN-D
8.20
7.2
Part Number
Inductance
L0 A(uH)
±20%
Typ
44.0
Part Number
TMPA1004S-R15YN-D
0.15±30%
TMPA1004S-R15MN-0R4410-D
0.15
I rms ( A )
I sat ( A )
DCR (mΩ)
DCR (mΩ)
E(mm)
Type
typ
max
45
0.9
1.0
2.7±0.35
non-leadframe
35
1.25
1.4
2.7±0.35
non-leadframe
36
32
1.8
2.2
2.5±0.35
non-leadframe
28
25
3.1
3.7
3.0±0.3
leadframe
12
18
16
7.8
8.8
3.0±0.3
leadframe
9
12
10
18.5
21.3
3.0±0.3
leadframe
6.5
7.2
6.8
32
38
3.0±0.3
leadframe
E(mm)
±0.3
Type
3.0
non-leadframe
3.0
non-leadframe
3.0
non-leadframe
3.0
non-leadframe
I rms ( A )
I sat ( A )
Max
Typ
38.0
82.0
40.0
DCR (mΩ)
Max
typ
max
75.0
0.5
0.6
75.0
0.44±10%
TMPA1004S-R22MN-D
0.22
36.0
33.0
70.0
60.0
TMPA1004S-R22MN-R6007-D
0.22
50.0
40.0
72.0
65.0
0.72
0.83
TMPA1004S-R36MN-D
0.36
33.0
29.0
51.0
45.0
1.05
1.18
3.0
non-leadframe
TMPA1004S-R47MN-D
0.47
32.0
28.0
46.0
40.0
1.3
1.5
3.0
non-leadframe
TMPA1004S-R56MN-D
0.56
25.0
23.0
34.0
29.0
1.6
1.8
2.5
non-leadframe
TMPA1004S-R68MN-D
0.68
23.0
20.0
31.0
28.0
1.9
2.2
2.5
non-leadframe
TMPA1004S-R82MN-D
0.82
22.0
19.0
30.0
27.0
2.1
2.5
2.5
non-leadframe
TMPA1004S-1R0MN-D
1.00
20.0
18.0
29.0
26.0
2.9
3.25
2.5
non-leadframe
TMPA1004S-1R5MN-D
1.50
17.5
16.0
26.0
22.0
3.7
4.2
2.5
non-leadframe
leadframe
0.6±7%
TMPA1004S-2R2MN-D
2.20
15.0
13.0
20.0
16.0
5.8
6.7
3.0
TMPA1004S-3R3MN-D
3.30
11.0
10.0
17.5
14.0
10.5
11.8
3.0
leadframe
TMPA1004S-4R7MN-D
4.70
8.8
8.0
15.2
13.0
15.8
19
3.0
leadframe
TMPA1004S-5R6MN-D
5.60
8.0
7.2
14.1
11.5
19
22.8
3.0
leadframe
TMPA1004S-6R8MN-D
6.80
7.8
6.8
12.2
11.0
22
24.5
3.0
leadframe
TMPA1004S-8R2MN-D
8.20
7.6
6.5
9.5
8.5
25
28
3.0
leadframe
TMPA1004S-100MN-D
10.0
7.5
6.1
8.6
7.5
27
30
3.0
leadframe
TMPA1004S-150MN-D
15.0
6.25
5.0
7.0
6.0
41
45
3.0
leadframe
TMPA1004S-220MN-D
22.0
5.0
4.1
6.2
5.5
58
66
3.0
leadframe
TMPA1004S-330MN-D
33.0
4.4
3.5
5.5
5.0
84
91
3.0
leadframe
TMPA1004S-470MN-D
47.0
3.5
3.0
4.0
3.7
125
143
3.0
leadframe
TMPA1004S-680MN-D
68.0
2.6
2.4
3.2
3.0
184
210
3.0
leadframe
TMPA1004S-820MN-D
82.0
2.3
2.1
3.0
2.8
240
270
3.0
leadframe
310
3.0
leadframe
TMPA1004S-101MN-D
100
2.0
1.8
2.7
2.4
270
TAI-TECH
P14
Part Number
Inductance
L0 A(uH)
±20%
Typ
Max
Typ
Max
Typ
Max
TMPA1005S-R36MN-D
0.36
34.0
30.0
52.0
46.0
0.82
TMPA1005S-R47MN-D
0.47
33.0
29.0
46.0
40.0
1.15
TMPA1005S-R68MN-D
0.68
28.0
25.0
35.0
32.0
TMPA1005S-1R0MN-D
1.00
25.0
23.0
33.0
30.0
TMPA1005S-1R5MN-D
1.50
23.0
21.0
27.0
TMPA1005S-2R2MN-D
2.20
19.5
17.5
20.0
TMPA1005S-3R3MN-D
3.30
17.0
15.0
TMPA1005S-4R7MN-D
4.70
15.0
TMPA1005S-5R6MN-D
5.60
13.0
TMPA1005S-6R8MN-D
6.80
TMPA1005S-8R2MN-D
8.2
TMPA1005S-100MN-D
TMPA1005S-150MN-D
I rms ( A )
I sat ( A )
DCR (mΩ)
E(mm)
±0.3
Type
0.92
3.0
non-leadframe
1.32
3.0
non-leadframe
1.6
1.9
2.5
non-leadframe
2.6
3.0
2.5
non-leadframe
24.0
3.4
3.8
2.5
non-leadframe
18.0
5.1
5.6
3.0
leadframe
17.5
15.5
8.1
9.1
3.0
leadframe
13.0
16.0
14.0
9.3
10.5
3.0
leadframe
11.0
15.0
12.5
12.8
14.4
3.0
leadframe
12.0
10.0
14.0
12.0
15.0
17.3
3.0
leadframe
10
8.5
13.5
11.5
16.1
18.8
3.0
leadframe
10.0
7.6
7.2
13.0
11.0
18.9
21.8
3.0
leadframe
15.0
6.5
6.0
8.5
7.5
32
39
3.0
leadframe
TMPA1005S-220MN-D
22.0
6.0
5.5
6.0
5.5
44.0
54.0
3.0
leadframe
TMPA1005S-330MN-D
33.0
5.5
5.0
5.8
5.2
740
86.0
3.0
leadframe
TMPA1005S-470MN-D
47.0
4.5
4.0
4.0
3.5
106.0
127.0
3.0
leadframe
TMPA1005S-680MN-D
68.0
3.5
3.0
3.5
3.0
148.0
177.0
3.0
leadframe
TMPA1005S-101MN-D
100
2.2
2.0
2.8
2.4
242.0
290.0
3.0
leadframe
Part Number
Inductance
L0 A(uH)
±20%
Type
Typ
Max
Typ
Max
Typ
Max
E(mm)
±0.3
TMPA1205SP-R47MN-D
0.47
38.0
34.0
65.0
58.0
0.77
0.9
4.0
non-leadframe
TMPA1205SP-R56MN-D
0.56
36.0
32.5
57.0
50.0
1.1
1.3
4.0
non-leadframe
TMPA1205SP-R68MN-D
0.68
34
31
50
42
1.3
1.55
4.0
non-leadframe
TMPA1205SP-1R0MN-D
1.00
30
27
40
34
1.6
1.9
4.0
non-leadframe
TMPA1205SP-1R5MN-D
1.50
25
22
31
28
3.2
3.8
4.7
leadframe
TMPA1205SP-2R2MN-D
2.20
17
15.5
26
23
4.1
4.8
4.7
leadframe
TMPA1205SP-3R3MN-D
3.30
15.5
14
23
20.5
6.0
7.0
4.7
leadframe
TMPA1205SP-4R7MN-D
4.70
14
12.5
18.5
16
8.8
10.2
4.7
leadframe
TMPA1205SP-6R8MN-D
6.80
12
11
16.5
15
13
16
4.7
leadframe
TMPA1205SP-100MN-D
10.0
10
9.0
13
10.5
19.2
22
4.7
leadframe
TMPA1205SP-150MN-D
15.0
9.4
8.2
11
9.2
30
36
4.7
leadframe
TMPA1205SP-220MN-D
22.0
8.0
7.0
8.5
7.5
42
52
4.7
leadframe
TMPA1205SP-330MN-D
33.0
6.0
5.2
7.3
6.5
66
80
4.7
leadframe
TMPA1205SP-470MN-D
47.0
5.2
4.3
6.0
5.2
78
94
4.7
leadframe
TMPA1205SP-680MN-D
68.0
4.3
3.6
5.0
4.4
110
132
4.7
leadframe
TMPA1205SP-820MN-D
82.0
3.9
3.4
4.5
4.1
142
171
4.7
leadframe
TMPA1205SP-101MN-D
100
3.5
3.0
4.0
3.7
175
210
4.7
leadframe
TMPA1205SP-151MN-D
150
2.7
2.3
3.2
2.8
280
336
4.7
leadframe
I rms ( A )
I sat ( A )
DCR (mΩ)
TAI-TECH
Part Number
P15
Inductance
L0 A(uH)
±20%
I rms ( A )
I sat ( A )
DCR (mΩ)
Typ
Max
Typ
Max
Typ
Max
E(mm)
±0.3
Type
TMPA1206SP-R36MN-D
0.36
60.0
50.0
70.0
60.0
0.65
0.8
4.7
non-leadframe
TMPA1206SP-R82MN-D
0.82
35
30
41
36
1.4
1.7
4.0
non-leadframe
TMPA1206SP-1R0MN-D
1.00
30.0
26.0
34.0
29.0
1.7
2.0
4.0
leadframe
TMPA1206SP-1R5MN-D
1.50
28.0
24.0
32.0
27.0
2.4
3.0
4.0
leadframe
TMPA1206SP-2R2MN-D
2.20
25.0
21.0
28.0
24.0
3.7
4.3
4.7
leadframe
TMPA1206SP-3R3MN-D
3.30
21.0
18.0
28.0
24.0
5.30
6.50
4.7
leadframe
TMPA1206SP-4R7MN-D
4.70
19.0
16.0
23.0
19.5
7.0
8.4
4.7
leadframe
TMPA1206SP-5R6MN-D
5.60
16.0
14.0
19.0
17.0
9.0
10.8
4.7
leadframe
TMPA1206SP-8R2MN-D
8.20
13.5
12.0
17.0
15.5
13.5
16.0
4.7
leadframe
TMPA1206SP-100MN-D
10.0
12.0
10.5
16.0
14.5
15.5
18.6
4.7
leadframe
TMPA1206SP-150MN-D
15.0
10.0
8.50
10.0
9.00
24.0
29.0
4.7
leadframe
TMPA1206SP-220MN-D
22.0
8.00
7.00
9.00
8.00
31.2
37.5
4.7
leadframe
TMPA1206SP-330MN-D
33.0
6.50
5.50
7.80
6.70
56.0
68.0
4.7
leadframe
TMPA1206SP-470MN-D
47.0
5.20
4.50
6.70
5.50
76.0
88.0
4.7
leadframe
TMPA1206SP-560MN-D
56.0
4.90
4.10
6.30
5.30
90
108
4.7
leadframe
TMPA1206SP-680MN-D
68.0
4.50
3.70
5.80
5.00
103
124
4.7
leadframe
TMPA1206SP-101MN-D
100
3.20
2.80
5.00
4.00
162
195
4.7
leadframe
TMPA1206SP-151MN-D
150
2.60
2.20
4.10
3.20
270
325
4.7
leadframe
Part Number
Inductance
L0 A(uH)
±20%
E(mm)
±0.3
Type
I rms ( A )
I sat ( A )
Typ
Max
Typ
DCR (mΩ)
Max
Typ
Max
TMPA1265SP-R10YN-D
0.10±30%
65
60
120
115
0.2
0.25
4.7
non-leadframe
TMPA1265SP-R22MN-D
0.22
53
42
112
105
0.4
0.46
4.7
non-leadframe
TMPA1265SP-R33MN-D
0.33
46.0
36.0
75.0
65.0
0.6
0.7
4.7
non-leadframe
TMPA1265SP-R47MN-D
0.47
42.0
35.0
68.0
58.0
0.88
1.02
4.7
non-leadframe
TMPA1265SP-R56MN-D
0.56
37.0
33.5
57.0
50.0
1.1
1.3
4.0
non-leadframe
TMPA1265SP-R68MN-D
0.68
36.5
33
55
46
1.25
1.5
4.0
non-leadframe
TMPA1265SP-1R0MN-D
1.00
33
29
45
36
1.5
1.8
4.0
non-leadframe
TMPA1265SP-1R5MN-D
1.50
29
25
35
30
2.2
2.53
4.0
non-leadframe
TMPA1265SP-2R2MN-D
2.20
25
21
28.5
24
3.7
4.2
4.7
leadframe
TMPA1265SP-3R3MN-D
3.30
22
19
27
22.5
5.3
6.2
4.7
leadframe
TMPA1265SP-4R7MN-D
4.70
25
21
6.8
8.0
4.7
leadframe
TMPA1265SP-5R6MN-D
5.60
18
15
23
19.5
8.3
9.8
4.7
leadframe
TMPA1265SP-6R8MN-D
6.80
16.5
14
21
18
9.8
11.3
4.7
leadframe
TMPA1265SP-8R2MN-D
82.0
15
12.5
19
17
12
13.8
4.7
leadframe
TMPA1265SP-100MN-D
10.0
13
11
17
15
13
15.8
4.7
leadframe
TMPA1265SP-150MN-D
15.0
11
9.5
13.5
12
22
26
4.7
leadframe
TMPA1265SP-220MN-D
22.0
10
8
10
9
31
35
4.7
leadframe
TMPA1265SP-330MN-D
33.0
9.0
6.5
9.0
8.0
46.0
55.0
4.7
leadframe
TMPA1265SP-470MN-D
47.0
8.0
5.7
7.6
6.8
58.0
67.0
4.7
leadframe
TMPA1265SP-680MN-D
68.0
5.8
4.8
6.0
5.0
82.0
100.0
4.7
leadframe
TMPA1265SP-101MN-D
100
5.0
3.8
5.0
4.0
140.0
161.0
4.7
leadframe
TAI-TECH
Part Number
P16
Inductance
L0 A(uH)
±20%
I rms ( A )
I sat ( A )
Typ
Max
Typ
Max
DCR
(mΩ)Typ
DCR
(mΩ)Max
TMPA1707SP-R47MN-D
0.47
60
55
110
100
0.7
0.9
TMPA1707SP-R56MN-D
0.56
56
50
80
70
0.81
0.97
TMPA1707SP-1R0MN-D
1.00
46
42
50
45
1.06
1.3
TMPA1707SP-1R5MN-D
1.50
39
35
46
40
1.5
1.8
TMPA1707SP-2R2MN-D
2.20
32
30
35
32
1.8
2.2
TMPA1707SP-3R3MN-D
3.30
30
28
32
29
2.7
3.3
TMPA1707SP-4R7MN-D
4.70
28
26
29
26
3.7
4.5
TMPA1707SP-5R6MN-D
5.6
26
23
27
23
5.0
6.0
TMPA1707SP-6R8MN-D
6.80
24
22
25
22
6.0
7.2
TMPA1707SP-100MN-D
10.0
21
19
22
19
9.2
10.6
TMPA1707SP-150MN-D
15.0
16
14
16
14
12.8
15.5
TMPA1707SP-220MN-D
22.0
13.5
11.5
13.5
11.5
20.5
24
TMPA1707SP-330MN-D
33.0
12
10
12
10
32
37
TMPA1707SP-470MN-D
47.0
9.5
8.0
9.5
8.0
40
47
TMPA1707SP-560MN-D
56.0
8.8
7.3
9.0
7.6
53
64
TMPA1707SP-680MN-D
68.0
8.0
6.5
8.5
7.2
66
76
TMPA1707SP-820MN-D
82.0
6.5
5.7
8.0
6.5
69
83
TMPA1707SP-101MN-D
100.0
6.0
5.0
6.5
5.5
90
105
TAI-TECH
P17
I rms ( A )
I sat ( A )
DCR
(mΩ)Typ
DCR
(mΩ)Max
110
0.44
0.5
90
80
0.6
0.72
60
54
0.8
0.95
57
52
48
1.0
1.15
58
52
48
43
1.05
1.25
49
47
41
37
1.5
1.75
4.70
47
44
38
34
1.9
2.2
5.60
43
40
37
33
2.3
2.7
TMPA2313SP-6R8MN-D
6.80
40
36
36
32
2.7
3.1
TMPA2313SP-100MN-D
10.0
33
30
28
4.15
TMPA2313SP-150MN-D
15.0
26
23
23
18
5.1
6.12
TMPA2313SP-220MN-D
22.0
22
18
15
14
9.2
11
TMPA2313SP-330MN-D
33.0
19
16
12
10.5
13.5
15.4
TMPA2313SP-470MN-D
47.0
17
14
12
10
17.3
20.8
TMPA2313SP-680MN-D
68.0
14
12
12
9.0
26.2
29.5
TMPA2313SP-820MN-D
82.0
12
10
9.0
7.7
31
34.2
TMPA2313SP-101MN-D
100
11
9.5
9.0
7.5
36
40
TMPA2313SP-151MN-D
150
8
7
7
5.5
67
80
TMPA2313SP-251MN-D
250
6.5
5.5
5.0
4.0
110
121
TMPA2313SP-331MN-D
330
5.0
4.5
4.0
3.5
140
160
TMPA2313SP-471MN-D
470
4.5
4.0
3.5
3.0
193
232
Part Number
Inductance
L0 A(uH) ±20%
Typ
Max
Typ
Max
TMPA2313SP-R47MN-D
0.47
80
75
140
TMPA2313SP-R68MN-D
0.68
75
70
TMPA2313SP-1R0MN-D
1.00
70
65
TMPA2313SP-1R5MN-D
1.50
62
TMPA2313SP-2R2MN-D
2.20
TMPA2313SP-3R3MN-D
3.30
TMPA2313SP-4R7MN-D
TMPA2313SP-5R6MN-D
Note:
1. Test frequency : Ls : 100KHz /1.0V.
2. All test data referenced to 25℃ ambient.
3. Testing Instrument(or equ) : Agilent 4284A,E4991A,4339B,KEYSIGHT E4980A/AL,chroma3302,3250,16502.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃
5. Saturation Current (Isat) will cause L0 to drop approximately 30%.
6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Irms Testing : Temperature rise is highly dependent on many factors including pcb land pattern, trace size, and proximity to other components.
Therefore temperature rise should be verified in application conditions.
8. Rated DC current: The lower value of Irms and Isat
6. Material List
4
4
3
1
3
1
2
Materials
2
NO
Items
NO
Items
1
Core
Alloy Powder .
1
Core
Alloy Powder .
Wire
Polyester Wire or equivalent.
2
Wire
2
3
Clip
100% Pb free solder(Ni+Sn---Plating)
3
4
Ink
Halogen-free ketone
4
Materials
Solder 100% Pb free solder
Ink
Halogen-free ketone
TAI-TECH
P18
7. Packaging Information
(1) Reel Dimension
COVER TAPE
Type
053T/606010/0618/060
13”x16mm
2/0624/0603/0604/
0605/0754
0804/0805/1003/1004/
13”x24mm
1005/1205/1206/1265
C
A
TMPA
0302/0312/0315/0318/
0401/0402/0502/0503/ 13”x12mm
401040
B
D
2.0∮0.5
EMBOSSED CARRIER
A(mm)
B(mm)
C(mm)
D(mm)
12.4+2/-0
100±2
13+0.5/-0.2
330
16.4+2/-0
100±2
13+0.5/-0.2
330
24.4+4/-0
100±2
13.5±0.5
330
1707
13”x32mm
32.4+2/-0
100±2
13+0.5/-0.2
330
2313
13”x44mm
44.4+2/-0
100±2
13+0.5/-0.2
330
(2) Tape Dimension
4.0
Blank portions
Chip cavity
Blank portions
T
B0
W
F
D
K0
P
200mm or more
400mm or more
Direction of tape
A0
Series
Size
Bo(mm)
Ao(mm)
Ko(mm)
P(mm)
W(mm)
F(mm)
T(mm)
D(mm)
Packaging
Quantity
TMPA
0302
3.8±0.1
3.5±0.1
2.3±0.1
8.0±0.1
12±0.3
5.5±0.1
0.35±0.05
1.5±0.1
3000PCS/R
TMPA
0312
3.8±0.1
3.5±0.1
1.5±0.1
8.0±0.1
12±0.3
5.5±0.1
0.35±0.05
1.5±0.1
3000PCS/R
TMPA
0315
3.8±0.1
3.5±0.1
1.8±0.1
8.0±0.1
12±0.3
5.5±0.1
0.35±0.05
1.5±0.1
4000PCS/R
TMPA
0318
4.0±0.1
3.5±0.1
2.0±0.1
8.0±0.1
12±0.3
5.5±0.1
0.35±0.05
1.5±0.1
3000PCS/R
TMPA
0401
5.0±0.1
4.4±0.1
1.1±0.1
8.0±0.1
12±0.3
5.5±0.1
0.35±0.05
1.5±0.1
5000PCS/R
TMPA
0402
5.0±0.1
4.4±0.1
2.3±0.1
8.0±0.1
12±0.3
5.5±0.1
0.35±0.05
1.5±0.1
3000PCS/R
TMPA
404010
5.0±0.1
4.40±0.1
1.1±0.1
8.0±0.1
12±0.3
5.5±0.1
0.35±0.05
1.5±0.1
5000PCS/R
TMPA
0502
6.2±0.1
5.6±0.1
2.3±0.1
8.0±0.1
12±0.3
5.5±0.1
0.35±0.05
1.5±0.1
3000PCS/R
TMPA
0503
6.2±0.1
5.6±0.1
3.3±0.1
8.0±0.1
12±0.3
5.5±0.1
0.35±0.05
1.5±0.1
2000PCS/R
TMPA
053T
5.3±0.1
5.0±0.1
3.3±0.1
12±0.1
16±0.3
5.5±0.1
0.35±0.05
1.5±0.1
1000PCS/R
TMPA
606010
6.45±0.1
6.40±0.1
1.1±0.1
12.0±0.1
16±0.3
7.5±0.1
0.35±0.05
1.5±0.1
3000PCS/R
TMPA
0618
7.7±0.1
7.0±0.1
2.1±0.1
12.0±0.1
16±0.3
7.5±0.1
0.35±0.05
1.5±0.1
2000PCS/R
TMPA
0602
7.7±0.1
7.0±0.1
2.3±0.1
12±0.1
16±0.3
7.5±0.1
0.35±0.05
1.5±0.1
1500PCS/R
Chip cavity
Blank portions
4.0
Blank portions
T
B0
W
F
D
K0
P
200mm or more
400mm or more
Direction of tape
A0
TAI-TECH
P19
Series
Size
Bo(mm)
Ao(mm)
Ko(mm)
P(mm)
W(mm)
F(mm)
T(mm)
D(mm)
Packaging
Quantity
TMPA
0624
7.7±0.1
7.0±0.1
2.7±0.1
12±0.1
16±0.3
7.5±0.1
0.35±0.05
1.5±0.1
1500PCS/R
TMPA
0603
7.7±0.1
7.0±0.1
3.3±0.1
12±0.1
16±0.3
7.5±0.1
0.35±0.05
1.5±0.1
1000PCS/R
TMPA
0604
7.7±0.1
7.0±0.1
4.3±0.1
12±0.1
16±0.3
7.5±0.1
0.35±0.05
1.5±0.1
1000PCS/R
TMPA
0605
7.7±0.1
7.0±0.1
5.3±0.1
12±0.1
16±0.3
7.5±0.1
0.35±0.05
1.5±0.1
800PCS/R
TMPA
0754
8.6±0.1
7.4±0.1
5.7±0.1
12±0.1
16±0.3
7.5±0.1
0.4±0.05
1.5±0.1
800PCS/R
TMPA
0804
10.1±0.1
8.9±0.1
4.5±0.1
16.0±0.1
24±0.3
11.5±0.1
0.35±0.05
1.5±0.1
800PCS/R
TMPA
0805
10.1±0.1
8.9±0.1
5.5±0.1
16.0±0.1
24±0.3
11.5±0.1
0.35±0.05
1.5±0.1
500PCS/R
TMPA
1003
11.6±0.1
10.4±0.1
3.3±0.1
16.0±0.1
24±0.3
11.5±0.1
0.35±0.05
1.5±0.1
1000PCS/R
TMPA
1004
11.6±0.1
10.4±0.1
4.5±0.1
16±0.1
24±0.3
11.5±0.1
0.35±0.05
1.5±0.1
500PCS/R
TMPA
1005
11.6±0.1
10.4±0.1
5.3±0.1
16±0.1
24±0.3
11.5±0.1
0.35±0.1
1.5±0.1
500PCS/R
TMPA
1205
14.1±0.1
12.9±0.1
5.5±0.1
16±0.1
24±0.3
11.5±0.1
0.35±0.05
1.5±0.1
500PCS/R
TMPA
1206
14.1±0.1
12.9±0.1
6.5±0.1
16±0.1
24±0.3
11.5±0.1
0.35±0.05
1.5±0.1
500PCS/R
TMPA
1265
14.1±0.1
12.9±0.1
7.0±0.1
16±0.1
24±0.3
11.5±0.1
0.35±0.1
1.5±0.1
500PCS/R
Blank portions
Blank portions
Chip cavity
P0
T
D
B1
B0
D/C
Marking
D/C
W
P2
Marking
F
E
D
P
200mm or more
R0.7
K0
400mm or more
Direction of tape
5
0.2±0.05
A1
A0
Series
Size
Bo(mm)
Ao(mm)
Ko(mm)
P(mm)
W(mm)
F(mm)
T(mm)
D(mm)
Packaging
Quantity
TMPA
1707
18.5±0.1
17.5±0.1
7.5±0.1
24±0.1
32±0.3
14.2±0.1
0.5±0.05
1.5±0.1
200PCS/R
TMPA
2313
25±0.1
23.0±0.1
13.6±0.1
32±0.1
44±0.3
20.2±0.1
0.5±0.05
1.5±0.1
80 PCS/R
(4) Tearing Off Force
F
Top cover tape
The force for tearing off cover tape is 10 to 130 grams in the arrow
direction under the following conditions(referenced
ANSI/EIA-481-D-2008 of 4.11 standard).
165¢Xto180¢X
Base tape
Room Temp.
Room Humidity
Room atm
(hPa)
Tearing Speed
mm/min
5~35
45~85
860~1060
300
TAI-TECH
P20
8. Reliability and Test Condition
Item
Performance
Test Condition
Operating temperature
-40~+125℃ (Including self - temperature rise)
N/A
Storage temperature
1. -10~+40℃,50~60%RH (Product with taping)
2. -40~+125℃(on board)
N/A
Electrical Performance Test
Inductance
Agilent4284A,E4991A,KEYSIGHTE4980A/AL,chroma3302,3205
Refer to standard electrical characteristics list.
DCR
Agilent 4339B,chrom16502
Approximately △30%
Saturation DC Current (Isat) will cause L0
to drop △L(%)
Approximately △T40℃
Heat Rated Current (Irms) will cause the coil temperature rise △
T(℃).
1.Applied the allowed DC current
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through IR reflow for 3 times.
times.( IPC/JEDECJ-STD-020E Classification Reflow Profiles)
Temperature: 125±2℃(Inductor,ambient + temp rise)
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs.
Life Test
Humidity:85±2﹪R.H,
Temperature:85℃±2℃
Duration:1000hrs Min.(No load current)
Load Humidity
Moisture Resistance
Appearance:No damage.
Inductance:within±10% of initial value
RDC:within ±15% of initial value and shall not
exceed the specification value
Thermal shock
Vibration
1. Baked at50 ℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep
3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25 ℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Step2:125±2℃ ≦20S
Step3:125±2℃ 30±5min
Step4:-40±2℃ ≦20S
Number of cycles: 500
Measured at room fempraturc after placing for 24±2 hrs.
Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minutes
Equipment: Vibration checker
Total Amplitude: 10g
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
TAI-TECH
Item
P21
Performance
Bending
Shock
Solderability
More than 95% of the terminal electrode should
be covered with solder。
Test Condition
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805inch(2012mm):1kg,
TMPA606010AF-100MN-D 价格&库存
很抱歉,暂时无法提供与“TMPA606010AF-100MN-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.382241+1.08992
- 10+6.6759310+0.86806
- 25+6.1205325+0.79584
- 50+5.7323450+0.74537
- 100+5.37167100+0.69847
- 250+4.93191250+0.64129
- 500+4.62537500+0.60143
- 1000+4.339811000+0.56430
- 国内价格 香港价格
- 3000+3.925853000+0.51047
- 6000+3.687006000+0.47942
- 9000+3.554709000+0.46221
- 15000+3.3953515000+0.44149
- 21000+3.3071121000+0.43002
