TMPC 0603H-R22MG-D
TMPC 0603H-R22MG-D
    TAI-TECH(台庆)
    SMD,7.3x6.6mm
    220 nH 无屏蔽 模制 电感器 23 A 2.8 毫欧最大 非标准
TMPC 0603H-R22MG-D 数据手册
TAI-TECH P2 SMD Power Choke Coil TMPC-Series(G) 1. Features 1. Low loss realized with low DCR. 2. High performance realized by metal dust core. Halogen 3. Ultra low buzz noise, due to composite construction. 4. 100% Lead(Pb)-Free and RoHS compliant. Halogen-free 2. Applications Commercial applications 3. Dimensions Recommend PC Board Pattern C  1.0 D L Note: 1.PCB layout is referred to standard IPC-7351B 2. The above PCB layout reference only. 3. Recommend solder paste thickness at 0.12mm and above. H E B A G leadframe Series A(mm) B(mm) C(mm) D(mm) E(mm) L(mm) G(mm) H(mm) TMPC0312H 3.5±0.2 3.2±0.2 1.0±0.2 0.7±0.2 1.2±0.2 4.1 1.9 1.45 TMPC0315H 3.5±0.3 3.2±0.2 1.3±0.2 0.7±0.2 1.2±0.2 4.1 1.9 1.45 TMPC0318H 3.5±0.3 3.2±0.2 1.6±0.2 0.7±0.2 1.2±0.2 4.1 1.9 1.45 1.2±0.2 4.1 1.9 1.45 TMPC0302H 3.5±0.2 C 0.7±0.2 D L E 2R2   1R0 1.8±0.2 Note: 1.PCB layout is referred to standard IPC-7351B 2. The above PCB layout reference only. 3. Recommend solder paste thickness at 0.12mm and above. H A B 3.2±0.2 G A(mm) C(mm) D(mm) E(mm) L(mm) G(mm) H(mm) TMPC0412HP 4.45±0.25 4.06±0.25 1.0±0.2 0.76±0.30 2.0±0.20 5.2 2.2 2.4 TMPC0415HP 4.45±0.25 4.06±0.25 1.3±0.2 0.76±0.30 2.0±0.20 5.2 2.2 2.4 TMPC0418HP 4.45±0.25 4.06±0.25 1.6±0.2 0.76±0.30 2.0±0.20 5.2 2.2 2.3 TMPC0402HP 4.45±0.25 4.06±0.25 1.8±0.2 0.76±0.30 2.0±0.20 5.2 2.2 2.4 C A B B(mm) 2R2 1R0 1205 2134 D' E D L E' Note: 1.PCB layout is referred to standard IPC-7351B 2. The above PCB layout reference only. 3. Recommend solder paste thickness at 0.12mm and above. H Series G Series A(mm) B(mm) C(mm) D(mm) D’(mm) E(mm) E’(mm) TMPC053T 4.9±0.3 4.7±0.2 2.8±0.2 1.0±0.3 1.5±0.1 1.5±0.3 2.0±0.2 L(mm) G(mm) H(mm) 7.0 3.0 2.5 TAI-TECH C   1R0 2134 L D H E B A P3 Note2 (TMPC06XX) 1. The above PCB layout reference only. 2. Recommend solder paste thickness at 0.15mm and above. G Series Note1 (TMPC05XX) 1. The above PCB layout reference only. 2. Recommend solder paste thickness at 0.12mm and above. A(mm) B(mm) C(mm) D(mm) E(mm) L(mm) G(mm) H(mm) TMPC0512HP 5.7±0.3 5.2±0.2 1.0±0.2 1.1±0.3 2.5±0.3 6.2 2.2 2.8 TMPC0515HP 5.7±0.3 5.2±0.2 1.3±0.2 1.1±0.3 2.5±0.3 6.2 2.2 2.8 2.2 2.8 TMPC0518HP 5.7±0.3 5.2±0.2 1.6±0.2 1.1±0.3 2.5±0.3 6.2 TMPC0502HP 5.7±0.3 5.2±0.2 1.8±0.2 1.1±0.3 2.5±0.3 6.2 2.2 2.8 TMPC0503H 5.7±0.3 5.2±0.2 2.8±0.2 1.1±0.3 1.5±0.2 6.2 2.5 1.8 TMPC0503HP 5.7±0.3 5.2±0.2 2.8±0.2 1.1±0.3 2.5±0.3 6.5 2.5 2.8 TMPC0612H 7.0±0.3 6.6±0.3 1.0±0.2 1.8±0.3 2.5±0.3 7.7 2.5 3.0 TMPC0615H 7.0±0.3 6.6±0.3 1.3±0.2 1.8±0.3 3.0±0.3 7.7 2.5 3.5 TMPC0618H 7.0±0.3 6.6±0.3 1.6±0.2 1.8±0.3 3.0±0.3 7.7 2.5 3.5 TMPC0602H 7.0±0.3 6.6±0.3 1.8±0.2 1.8±0.3 3.0±0.3 7.7 2.5 3.5 TMPC0624H 7.3±0.3 6.6±0.3 2.2±0.2 1.8±0.3 3.0±0.3 7.7 2.5 3.5 TMPC0603H 7.3±0.3 6.6±0.3 2.8±0.2 1.8±0.3 3.0±0.3 8.4 2.5 3.5 TMPC0604H 7.3±0.3 6.6±0.3 3.8±0.2 1.8±0.30 3.0±0.3 8.4 2.5 3.5 TMPC0605H 7.3±0.3 6.6±0.3 4.8±0.2 1.8±0.3 3.0±0.3 8.4 2.5 3.5 TAI-TECH P4 4. Part Numbering TMPC 0302 H A B C - A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance . 1R0 MG D E BxC Carbonyl Powder. 1R0=1.00uH M=±20%,Y=±30%, TMPC 0412 HP A B C - 2R2 D A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: Control S/N One-way Black marking MG - Z02 E F BxC H: Carbonyl powder;P: PAD broaden 2R2=2.20uH M=±20%;Y=±30% One-way Black marking TMPC 053 T A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: Control S/N - 1R0 MG D E - V01 F BxC Carbonyl Powder. 1R0=1.00uH M= ±20% Marking: Black.1R0 and 2134(21 YY, 34WW,follow production date). TMPC 0512 HP A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: D/C 2R2 MG - D E D F BxC H: Carbonyl powder, P: PAD broaden 2R2=2.2uH M=±20%;Y=±30% Marking: Black.2R2 and 2134(21 YY,34WW,follow production date). TMPC 0624 H A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: Control S/N G: Date - - 1R0 MG D E - Z02 F - D G BxC Carbonyl Powder. 1R0=1.00uH M= ±20% Marking: Black.1R0 and 2134(21 YY, 34WW,follow production date). TAI-TECH P5 5. Specification Part Number Inductance L0 (uH) ±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0312H-R15YG 0.15±30% 10 14 9.6 11 TMPC0312H-R22MG 0.22 6.5 10 14 17 TMPC0312H-R33MG 0.33 6.2 9.2 16 20 TMPC0312H-R47MG 0.47 5.0 7.2 25 30 TMPC0312H-R56MG 0.56 4.5 6.6 31 36 TMPC0312H-R68MG 0.68 4.0 6.1 34 40 TMPC0312H-R82MG 0.82 3.5 5.8 41 48 TMPC0312H-1R0MG 1.00 3.3 5.5 50 60 TMPC0312H-1R5MG 1.50 3.0 4.0 71 85 TMPC0312H-2R2MG 2.20 2.7 3.4 98 115 TMPC0312H-3R3MG 3.30 2.0 3.1 191 210 TMPC0312H-4R7MG 4.70 1.6 2.8 266 293 TMPC0312H-5R6MG 5.6 1.5 2.2 310 360 TMPC0312H-6R8MG 6.80 1.4 2.0 360 400 TMPC0312H-8R2MG 8.20 1.2 1.7 420 463 TMPC0312H-100MG 10.0 1.0 1.4 498 550 DCR(mΩ) Typ DCR(mΩ) Max Part Number Inductance L0 (uH)±20% I rms ( A ) I sat ( A ) TMPC0315H-R22MG 0.22 7.0 10.8 14 17 TMPC0315H-R47MG 0.47 5.5 8.0 23.3 28 TMPC0315H-R56MG 0.56 5.0 7.2 28 33 TMPC0315H-R68MG 0.68 4.5 6.5 34 42 TMPC0315H-1R0MG 1.00 3.6 5.8 41 50 TMPC0315H-1R5MG 1.50 3.4 4.0 64 77 TMPC0315H-2R2MG 2.20 3.2 3.8 82 98 TMPC0315H-3R3MG 3.30 2.5 3.2 170 205 TMPC0315H-4R7MG 4.70 1.9 2.8 220 264 TMPC0315H-5R6MG 5.60 1.7 2.3 265 318 TMPC0315H-6R8MG 6.80 1.5 2.0 290 348 TMPC0315H-8R2MG 8.20 1.3 1.8 390 468 TMPC0315H-100MG 10.0 1.2 1.6 435 522 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0318H-R47MG 0.47 6 8.5 21.5 25 TMPC0318H-R56MG 0.56 5 8 21 26 TMPC0318H-R68MG 0.68 5 6.5 29 33.5 TMPC0318H-1R0MG 1.00 3.8 5 38 44 TMPC0318H-1R5MG 1.50 3.5 4 56 65 TMPC0318H-2R2MG 2.20 3.3 3.7 73 85 TMPC0318H-3R3MG 3.30 2.7 3.3 136 158 TMPC0318H-4R7MG 4.70 2.3 2.9 180 208 TMPC0318H-5R6MG 5.60 1.9 2.3 238 275 TMPC0318H-6R8MG 6.80 1.5 2.1 275 320 TMPC0318H-8R2MG 8.20 1.4 1.9 350 405 TMPC0318H-100MG 10.0 1.3 1.6 375 450 TMPC0318H-150MG 15.0 1.2 1.5 520 600 TAI-TECH P6 Part Number Inductance L0 (uH) ±20% I rms ( A ) Typ TMPC0302H-R10YG 0.10±30% TMPC0302H-R22YG 0.22±30% TMPC0302H-R33MG I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max 10.5 14 6.6 9.0 9.0 11.2 11 14 0.33 8.0 10 17 21 TMPC0302H-R47MG 0.47 7.0 9.0 19.7 23 TMPC0302H-R68MG 0.68 5.5 7.0 25.5 29 TMPC0302H-1R0MG 1.00 4.0 5.0 32 38 TMPC0302H-1R5MG 1.50 3.8 4.0 42 50 TMPC0302H-2R2MG 2.20 3.5 3.7 65 75 TMPC0302H-3R3MG 3.30 3.0 3.5 125 145 TMPC0302H-4R7MG 4.70 2.6 3.0 172 200 TMPC0302H-5R6MG 5.60 2.2 2.6 205 238 TMPC0302H-6R8MG 6.80 1.9 2.2 260 300 TMPC0302H-8R2MG 8.20 1.6 1.9 340 390 TMPC0302H-100MG 10.0 1.4 1.6 366 422 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0412HP-R10YG-Z02 0.10±30% 11.5 25 4.3 5.5 TMPC0412HP-R15YG-Z02 0.15±30% 10 21.5 5.5 6.8 TMPC0412HP-R22MG-Z02 0.22 8.5 20 6.6 8.0 TMPC0412HP-R33MG-Z02 0.33 7.0 11 13.6 16 TMPC0412HP-R47MG-Z02 0.47 6.0 6.5 18 20 TMPC0412HP-R68MG-Z02 0.68 5.0 6.0 32 37 TMPC0412HP-1R0MG-Z02 1.00 4.0 6.0 41 47 TMPC0412HP-1R5MG-Z02 1.50 3.0 4.0 55 63.3 TMPC0412HP-2R2MG-Z02 2.20 2.8 3.5 69.2 80 TMPC0412HP-3R3MG-Z02 3.30 2.3 3.0 84 97 TMPC0412HP-4R7MG-Z02 4.70 2.0 2.5 128 145 TMPC0412HP-5R6MG-Z02 5.60 1.7 2.3 180 208 TMPC0412HP-6R8MG-Z02 6.80 1.5 1.7 300 360 TMPC0412HP-8R2MG-Z02 8.20 1.4 1.6 313 376 TMPC0412HP-100MG-Z02 10.0 1.3 1.4 410 463 TMPC0412HP-220MG-Z02 22.0 0.8 1.0 950 1050 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0415HP-47NMG-Z02 0.047 20.5 48 2.1 2.5 TMPC0415HP-R10YG-Z02 0.10±30% 16 32 3.2 4.0 TMPC0415HP-R22MG-Z02 0.22 10 20 6.5 7.8 TMPC0415HP-R47MG-Z02 0.47 8.0 11 15 19 TMPC0415HP-R56MG-Z02 0.56 7.2 10 17 20.5 TMPC0415HP-R68MG-Z02 0.68 6.5 8.5 19 21.5 TMPC0415HP-1R0MG-Z02 1.00 5.0 7.0 34 40 TMPC0415HP-2R2MG-Z02 2.20 3.2 4.0 63 72 TMPC0415HP-4R7MG-Z02 4.70 2.2 2.8 120 140 TMPC0415HP-6R8MG-Z02 6.80 1.7 2.3 230 276 TMPC0415HP-100MG-Z02 10.0 1.5 1.9 345 400 TAI-TECH P7 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0418HP-R22MG-Z02 0.22 12.0 21.0 6.6 7.3 TMPC0418HP-R33MG-Z02 0.33 9.0 16.0 8.5 9.5 TMPC0418HP-R56MG-Z02 0.56 6.0 9.0 16 20 TMPC0418HP-R68MG-Z02 0.68 5.8 8.5 18.5 22 TMPC0418HP-1R0MG-Z02 1.00 4.8 6.9 24.5 30 TMPC0418HP-1R5MG-Z02 1.50 4.1 5.6 33 38 TMPC0418HP-2R2MG-Z02 2.20 3.5 4.2 39 45 TMPC0418HP-3R3MG-Z02 3.30 3.0 3.6 82 100 TMPC0418HP-4R7MG-Z02 4.70 2.3 3.0 106 130 TMPC0418HP-5R6MG-Z02 5.60 2.1 2.8 125 150 TMPC0418HP-6R8MG-Z02 6.80 1.95 2.6 150 180 TMPC0418HP-8R2MG-Z02 8.20 1.80 2.4 198 235 TMPC0418HP-100MG-Z02 10.0 1.65 2.1 220 265 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0402HP-R10YG-Z02 0.10±30% 14.0 35.0 3.2 4.0 TMPC0402HP-R22YG-Z02 0.22±30% 13.0 24.0 6.6 7.3 TMPC0402HP-R33MG-Z02 0.33 10.0 18.0 7.8 8.6 TMPC0402HP-R47MG-Z02 0.47 8.00 12.0 11.2 14 TMPC0402HP-R56MG-Z02 0.56 7.30 10.0 13.5 16 TMPC0402HP-R68MG-Z02 0.68 7.00 10.0 16 19 TMPC0402HP-1R0MG-Z02 1.00 5.00 8.50 22 27 TMPC0402HP-1R5MG-Z02 1.50 4.50 7.00 34.8 42 TMPC0402HP-2R2MG-Z02 2.20 4.00 6.00 51 61 TMPC0402HP-3R3MG-Z02 3.30 3.50 4.00 69 76 TMPC0402HP-4R7MG-Z02 4.70 2.60 3.50 95 105 TMPC0402HP-5R6MG-Z02 5.60 2.20 3.00 112 125 TMPC0402HP-6R8MG-Z02 6.80 2.10 2.80 150 172 TMPC0402HP-8R2MG-Z02 8.20 2.00 2.50 158 180 TMPC0402HP-100MG-Z02 10.0 1.80 2.30 215 243 TMPC0402HP-150MG-Z02 15.0 1.50 1.90 325 374 TMPC0402HP-220MG-Z02 22.0 1.20 1.40 470 500 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC053T-R10MG-V01 0.10 20.0 34.0 2.0 2.5 TMPC053T-R22MG-V01 0.22 14.0 20.0 3.5 3.9 TMPC053T-R33MG-V01 0.33 13.0 19.0 4.7 5.4 TMPC053T-R47MG-V01 0.47 10.0 16.0 7.1 8.1 TMPC053T-R56MG-V01 0.56 9.5 15.0 7.3 8.4 TMPC053T-R68MG-V01 0.68 8.5 14.0 8.1 9.0 TMPC053T-1R0MG-V01 1.00 7.0 11.0 12.5 14.0 TMPC053T-1R5MG-V01 1.50 6.0 10.0 17.0 22.0 TMPC053T-2R2MG-V01 2.20 5.5 9.0 24.0 27.0 TMPC053T-3R3MG-V01 3.30 5.0 7.0 32.0 38.0 TMPC053T-4R7MG-V01 4.70 4.5 5.0 50.0 60.0 TMPC053T-100MG-V01 10.0 3.3 3.7 104.0 125.0 TAI-TECH P8 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR (mΩ) Typ DCR (mΩ) Max TMPC0512HP-R10YG-D 0.10±30% 14 14.5 4.3 5.2 TMPC0512HP-R15YG-D 0.15±30% 12 14.2 4.5 6.0 TMPC0512HP-R22MG-D 0.22 10.7 14.0 5.5 6.7 TMPC0512HP-R33MG-D 0.33 8.5 13.5 7.8 9.4 TMPC0512HP-R47MG-D 0.47 7.0 11 13.6 15.8 TMPC0512HP-R68MG-D 0.68 6.0 9.0 21.5 24.5 TMPC0512HP-1R0MG-D 1.00 5.0 6.0 26 30 TMPC0512HP-1R5MG-D 1.50 4.0 5.0 38 44 TMPC0512HP-2R2MG-D 2.20 3.5 4.0 65 75 TMPC0512HP-3R3MG-D 3.30 3.0 3.8 75 86 TMPC0512HP-4R7MG-D 4.70 2.5 3.2 100 115 TMPC0512HP-5R6MG-D 5.60 2.4 3.2 175 201 TMPC0512HP-6R8MG-D 6.80 2.0 3.0 193 222 TMPC0512HP-8R2MG-D 8.20 1.7 2.8 327 378 TMPC0512HP-100MG-D 10.0 1.5 1.8 335 385 TMPC0512HP-150MG-D 15.0 1.3 1.6 410 470 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0515HP-R10YG-D 0.10±30% 16.0 35.0 2.75 3.10 TMPC0515HP-R15YG-D 0.15±30% 16.0 25.0 3.6 4.1 TMPC0515HP-R22YG-D 0.22±30% 12.0 20.0 5.0 6.5 TMPC0515HP-R33MG-D 0.33 9.0 16.0 8.5 9.8 TMPC0515HP-R47MG-D 0.47 8.0 15.0 12.0 13.8 TMPC0515HP-R68MG-D 0.68 7.0 13.0 14 16.2 TMPC0515HP-1R0MG-D 1.00 6.0 9.0 22 25.3 TMPC0515HP-1R5MG-D 1.50 4.5 7.0 39 45 TMPC0515HP-2R2MG-D 2.20 4.0 6.0 45 52 TMPC0515HP-3R3MG-D 3.30 3.2 4.5 78 90 TMPC0515HP-4R7MG-D 4.70 2.7 4.0 103 118 TMPC0515HP-5R6MG-D 5.60 2.4 3.2 126 152 TMPC0515HP-6R8MG-D 6.80 2.3 3.0 142 171 TMPC0515HP-8R2MG-D 8.20 2.1 2.6 175 210 TMPC0515HP-100MG-D 10.0 2.0 2.3 210 235 TMPC0515HP-150MG-D 15.0 1.6 2.0 310 380 TMPC0515HP-220MG-D 22.0 1.2 1.7 405 466 TAI-TECH P9 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR (mΩ) Typ DCR (mΩ) Max TMPC0518HP-R10YG-D 0.10±30% 17.0 40.0 2.5 2.8 TMPC0518HP-R15YG-D 0.15±30% 15.5 27.0 3.5 3.9 TMPC0518HP-R22MG-D 0.22 13 22 4.2 5.0 TMPC0518HP-R33MG-D 0.33 11 15 7.5 8.6 TMPC0518HP-R47MG-D 0.47 10 14 9.8 11.3 TMPC0518HP-R56MG-D 0.56 9.5 13.5 11 13 TMPC0518HP-R68MG-D 0.68 9 13 12.4 14.3 TMPC0518HP-1R0MG-D 1.0 6.8 10 18.2 21 TMPC0518HP-1R5MG-D 1.5 6.0 9.0 26 30 TMPC0518HP-2R2MG-D 2.2 4.5 7.5 42 48.3 TMPC0518HP-3R3MG-D 3.3 3.5 5.0 60 69 TMPC0518HP-4R7MG-D 4.7 3.0 4.5 85 98 TMPC0518HP-5R6MG-D 5.6 2.5 4.0 110 127 TMPC0518HP-6R8MG-D 6.8 2.4 3.5 118 137 TMPC0518HP-8R2MG-D 8.2 2.3 3.0 143 165 TMPC0518HP-100MG-D 10 2.3 2.8 165 190 TMPC0518HP-150MG-D 15.0 1.7 2.3 275 318 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR (mΩ) Typ DCR (mΩ) Max TMPC0502HP-R10YG-D 0.10±30% 18 45 3.6 4.0 TMPC0502HP-R15YG-D 0.15±30% 16 27 3.8 4.6 TMPC0502HP-R22MG-D 0.22 15 25 4.0 5.5 TMPC0502HP-R33MG-D 0.33 12 21.3 6.3 7.3 TMPC0502HP-R47MG-D 0.47 11.5 18 7.3 8.6 TMPC0502HP-R68MG-D 0.68 10 12.8 11 12.4 TMPC0502HP-1R0MG-D 1.00 7.0 13.7 17.5 20 TMPC0502HP-1R5MG-D 1.50 5.5 9.8 26.5 30.5 TMPC0502HP-2R2MG-D 2.20 4.2 9.0 42.0 50.0 TMPC0502HP-3R3MG-D 3.30 3.3 7.3 66.0 76 TMPC0502HP-4R7MG-D 4.70 2.8 5.0 103 116 TMPC0502HP-5R6MG-D 5.60 2.5 4.0 112 122 TMPC0502HP-6R8MG-D 6.80 2.4 3.8 130 150 TMPC0502HP-8R2MG-D 8.20 2.3 3.5 148 171 TMPC0502HP-100MG-D 10.0 2.3 3.4 180 199 TMPC0502HP-150MG-D 15.0 1.9 2.8 240 270 TMPC0502HP-220MG-D 22.0 1.5 1.8 350 390 TAI-TECH P10 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR (mΩ) Typ DCR (mΩ) Max TMPC0503H-R10YG-D 0.10±30% 23 27 2.5 3.0 TMPC0503H-R22MG-D 0.22 15.5 21 3.7 4.4 TMPC0503H-R33MG-D 0.33 14 18 4.3 5.0 TMPC0503H-R47MG-D 0.47 12 16 6.4 7.4 TMPC0503H-R56MG-D 0.56 10 15 8.0 10 TMPC0503H-R68MG-D 0.68 8.5 14 10 12 TMPC0503H-1R0MG-D 1.00 7.0 11 13 14 TMPC0503H-1R5MG-D 1.50 6.0 10 16 25 TMPC0503H-2R2MG-D 2.20 5.5 9.0 25 35 TMPC0503H-3R3MG-D 3.30 5.0 8.0 32 38 TMPC0503H-4R7MG-D 4.70 4.6 6.0 50 53 TMPC0503H-5R6MG-D 5.60 4.25 4.50 55 63 TMPC0503H-6R8MG-D 6.80 4.0 4.3 68 76.2 TMPC0503H-100MG-D 10.0 2.75 3.50 110 128 TMPC0503H-150MG-D 15.0 2.1 2.6 165 190 TMPC0503H-220MG-D 22.0 1.9 1.7 220 250 TMPC0503H-330MG-D 33.0 1.6 1.6 380 440 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0503HP-R10YG-D02 0.10±30% 24.0 40.0 2.20 2.60 TMPC0503HP-R15YG-D02 0.15±30% 22.0 37.0 2.50 3.00 TMPC0503HP-R22MG-D02 0.22 19.0 32.0 3.20 3.80 TMPC0503HP-R33MG-D02 0.33 15.0 20.0 4.30 5.00 TMPC0503HP-R47MG-D02 0.47 13.0 18.0 6.30 7.10 TMPC0503HP-R56MG-D02 0.56 12.0 17.0 7.80 8.60 TMPC0503HP-R68MG-D02 0.68 11.0 15.5 8.0 9.0 TMPC0503HP-1R0MG-D02 1.00 9.0 13.0 11.0 12.7 TMPC0503HP-1R5MG-D02 1.50 8.0 11.5 14.4 16.6 TMPC0503HP-2R2MG-D02 2.20 7.0 11.0 26.0 29.2 TMPC0503HP-3R3MG-D02 3.30 6.0 9.0 33.0 38.0 TMPC0503HP-4R7MG-D02 4.70 5.5 8.0 48.0 53.0 TMPC0503HP-5R6MG-D02 5.60 4.7 7.3 54.0 62.0 TMPC0503HP-6R8MG-D02 6.80 4.2 6.0 68.0 76.2 TMPC0503HP-8R2MG-D02 8.20 3.8 5.0 85.0 97.0 TMPC0503HP-100MG-D02 10.0 3.5 4.0 104.0 120.0 TMPC0503HP-150MG-D02 15.0 2.7 3.2 165.0 190.0 TMPC0503HP-220MG-D02 22.0 2.2 2.7 217.0 250.0 TAI-TECH P11 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR (mΩ) Typ DCR (mΩ) Max TMPC0612H-R10YG-D 0.10±30% 16 30 3.3 4.0 TMPC0612H-R15YG-D 0.15±30% 14 24 4.9 5.7 TMPC0612H-R22YG-D 0.22±30% 11 19 6.5 7.5 TMPC0612H-R33MG-D 0.33 9.5 16 9.0 10 TMPC0612H-R47MG-D 0.47 8.5 12 13 17 TMPC0612H-R68MG-D 0.68 7 9 17 19 TMPC0612H-1R0MG-D 1.00 6 7 27 30 TMPC0612H-1R5MG-D 1.50 4.5 6.5 35 40 TMPC0612H-2R2MG-D 2.20 4.0 5.0 53 61 TMPC0612H-3R3MG-D 3.30 3.2 4.0 90 103 TMPC0612H-4R7MG-D 4.70 2.5 3.8 130 150 TMPC0612H-6R8MG-D 6.80 2.1 3.0 172 198 TMPC0612H-100MG-D 10.0 1.8 2.5 280 290 TMPC0612H-180MG-D 18.0 1.35 2.0 490 540 TMPC0612H-220MG-D 22.0 1.2 1.7 540 600 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR (mΩ) Typ DCR (mΩ) Max TMPC0615H-R10YG-D 0.10±30% 17.5 35.0 2.5 3.1 TMPC0615H-R15YG-D 0.15±30% 16 25 3.7 4.5 TMPC0615H-R22YG-D 0.22±30% 14 22 4.3 5.2 TMPC0615H-R33MG-D 0.33 11 18 6.6 7.6 TMPC0615H-R47MG-D 0.47 9.5 16 9.0 10.3 TMPC0615H-R56MG-D 0.56 9 15.5 12.5 14 TMPC0615H-R68MG-D 0.68 7.5 15 13.8 15.2 TMPC0615H-R82MG-D 0.82 7 14 20 24 TMPC0615H-1R0MG-D 1.00 6.5 12 23 25.8 TMPC0615H-1R5MG-D 1.50 5.0 9.5 37 42.5 TMPC0615H-2R2MG-D 2.20 4.5 6.5 48 55 TMPC0615H-3R3MG-D 3.30 4.2 6.0 62 74 TMPC0615H-4R7MG-D 4.70 3.8 5.0 96 111 TMPC0615H-5R6MG-D 5.60 3.0 4.5 115 138 TMPC0615H-6R8MG-D 6.80 2.6 3.5 128 148 TMPC0615H-8R2MG-D 8.20 2.4 3.2 153 184 TMPC0615H-100MG-D 10.0 2.3 2.8 180 216 TMPC0615H-220MG-D 22.0 1.5 2.5 420 504 TAI-TECH P12 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR (mΩ) Typ DCR (mΩ) Max TMPC0618H-R10YG-D 0.10±30% 18 45 2.1 2.5 TMPC0618H-R15MG-D 0.15 18 34 2.2 2.6 TMPC0618H-R22MG-D 0.22 16 26 2.5 3 TMPC0618H-R33MG-D 0.33 14 22 4.8 5.8 TMPC0618H-R47MG-D 0.47 12 18 6.4 7.4 TMPC0618H-R56MG-D 0.56 11 17.5 8.5 10 TMPC0618H-R68MG-D 0.68 10 17 9.5 11.0 TMPC0618H-R82MG-D 0.82 8.5 15.5 11.5 14.0 TMPC0618H-1R0MG-D 1.00 7.0 14 14.5 17.0 TMPC0618H-1R5MG-D 1.50 6.0 13 21 25.2 TMPC0618H-2R2MG-D 2.20 6.0 11 31 35 TMPC0618H-3R3MG-D 3.30 5.0 9.0 40 46 TMPC0618H-4R7MG-D 4.70 4.0 7.0 68 76 TMPC0618H-5R6MG-D 5.60 3.5 6.0 78 86 TMPC0618H-6R8MG-D 6.80 3.0 5.5 93 104 TMPC0618H-8R2MG-D 8.20 2.6 4.5 123 140 TMPC0618H-100MG-D 10.0 2.3 3.5 143 160 TMPC0618H-150MG-D 15.0 2.0 3.0 240 280 TMPC0618H-220MG-D 22.0 1.8 2.5 300 360 TMPC0618H-330MG-D 33.0 1.3 2.1 550 650 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR (mΩ) Typ DCR (mΩ) Max TMPC0602H-R10YG-D 0.10±30% 21 40 2.0 2.4 TMPC0602H-R15YG-D 0.15±30% 18 39 2.3 2.7 TMPC0602H-R22YG-D 0.22±30% 15 32 3.5 4.0 TMPC0602H-R33MG-D 0.33 14 25 4.5 5.0 TMPC0602H-R47MG-D 0.47 11.7 20 7.1 8.3 TMPC0602H-R56MG-D 0.56 11.0 18 7.9 9.3 TMPC0602H-R68MG-D 0.68 10.5 16 8.3 10 TMPC0602H-1R0MG-D 1.00 8.0 14 16.5 18 TMPC0602H-1R5MG-D 1.50 7 12 23 27 TMPC0602H-2R2MG-D 2.20 6.0 10 32 37 TMPC0602H-3R3MG-D 3.30 5.0 8.0 43 48 TMPC0602H-4R7MG-D 4.70 4.5 7.0 53 60 TMPC0602H-5R6MG-D 5.60 4.0 6.0 59 68 TMPC0602H-6R8MG-D 6.80 4.0 5.5 63 73 TMPC0602H-8R2MG-D 8.20 3.2 5.0 101 116 TMPC0602H-100MG-D 10.0 2.8 4.0 134 154 TMPC0602H-150MG-D 15.0 2.1 3.3 190 210 TMPC0602H-220MG-D 22.0 1.5 2.5 236 280 TAI-TECH P13 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0624H-R10YG-D 0.10±30% 30 70 1.4 1.7 TMPC0624H-R15YG-D 0.15±30% 30 45 1.8 2.3 TMPC0624H-R22MG-D 0.22 21 34 2.0 3.2 TMPC0624H-R33MG-D 0.33 18 30 3.6 4.4 TMPC0624H-R47MG-D 0.47 15 26 4.8 5.1 TMPC0624H-R56MG-D 0.56 13 24 5.5 6.5 TMPC0624H-R68MG-D 0.68 13 21 6.4 7.2 TMPC0624H-R82MG-D 0.82 11 17 8.0 9.5 TMPC0624H-1R0MG-D 1.00 11 16 10.5 13.5 TMPC0624H-1R5MG-D 1.50 9 15 17 20 TMPC0624H-2R2MG-D 2.20 7 14 23 28 TMPC0624H-3R3MG-D 3.30 6 10 34 39 TMPC0624H-4R7MG-D 4.70 5.5 9 41 50 TMPC0624H-5R6MG-D 5.60 5 8 56 62 TMPC0624H-6R8MG-D 6.80 4 7 65 72 TMPC0624H-8R2MG-D 8.20 3.6 6.0 81 95 TMPC0624H-100MG-D 10.0 3.2 5.0 92 101 TMPC0624H-150MG-D 15.0 2.5 3.5 150 180 TMPC0624H-220MG-D 22.0 1.8 3.0 185 215 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0603H-R10YG-D 0.10±30% 32.5 60.0 1.2 1.7 1.5 TMPC0603H-R15YG-D 0.15±30% 27 45 TMPC0603H-R15MG-0R907-D 0.15±20% 37.0 46.0 TMPC0603H-R22YG-D 0.22±30% 23.0 40.0 2.1 2.8 TMPC0603H-R33MG-D 0.33 20.0 32.0 3.5 3.9 TMPC0603H-R47MG-D 0.47 17.5 26.0 4.0 4.2 TMPC0603H-R56MG-D 0.56 16.5 25.5 4.7 5.0 TMPC0603H-R68MG-D 0.68 15.5 25.0 4.8 5.5 TMPC0603H-R82MG-D 0.82 13.0 24.0 6.7 8.0 TMPC0603H-1R0MG-D 1.00 11.0 22.0 8.3 10 TMPC0603H-1R5MG-D 1.50 9.0 18.0 13 15 TMPC0603H-2R2MG-D 2.20 8.0 14.0 18 20 TMPC0603H-3R3MG-D 3.30 6.0 13.5 28 30 TMPC0603H-4R7MG-D 4.70 5.5 10.0 37 40 TMPC0603H-5R6MG-D 5.60 5.0 9.0 43 48 TMPC0603H-6R8MG-D 6.80 4.5 8.0 54 60 TMPC0603H-8R2MG-D 8.20 4.0 7.5 64 68 TMPC0603H-100MG-D 10.0 3.5 6.0 75 85 TMPC0603H-150MG-D 15.0 3.00 4.00 107 123 TMPC0603H-220MG-D 22.0 2.0 3.5 165 190 TMPC0603H-330MG-D 33.0 2.0 2.5 200 240 TMPC0603H-470MG-D 47.0 1.75 2.0 302 363 0.90±7% 1.9 (打扁式) TAI-TECH P14 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ 0.9 TMPC0604H-R15YG-D 0.15±30% 30 55 TMPC0604H-R15MG-R6705-D 0.15 40.0 60.0 0.67±5% 1.2 (打扁式) TMPC0604H-R22MG-D 0.22 25 34 TMPC0604H-R22MG-M98-D 0.22 32 50 0.98±7% TMPC0604H-R33MG-D 0.33 25 34 2.0 2.6 TMPC0604H-R47MG-D 0.47 23 28 3.0 3.4 TMPC0604H-R56MG-D 0.56 20 26 3.8 4.3 TMPC0604H-R68MG-D 0.68 16 24 4.1 4.5 TMPC0604H-1R0MG-D 1.00 14 22 6.8 8.0 TMPC0604H-1R5MG-D 1.50 12 20 10 12 TMPC0604H-2R2MG-D 2.20 9.0 14 11.5 14 TMPC0604H-3R3MG-D 3.30 8.0 12 24 27 TMPC0604H-4R7MG-D 4.70 6.0 11 28 32.5 TMPC0604H-5R6MG-D 5.60 5.0 9.0 33 38 TMPC0604H-6R8MG-D 6.80 4.5 8.5 44 50 TMPC0604H-8R2MG-D 8.20 4.5 8.0 55 64 TMPC0604H-100MG-D 10.0 4.0 7.0 64 72 TMPC0604H-150MG-D 15.0 3.0 3.5 80 90 TMPC0604H-220MG-D 22.0 2.5 3.5 120 145 TMPC0604H-330MG-D 33.0 1.8 3.2 180 210 TMPC0604H-470MG-D 47.0 1.8 2.5 295 350 Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat ( A ) Typ DCR(mΩ) Typ DCR(mΩ) Max TMPC0605H-R10YG-D 0.10±30% 32 65 0.65 0.78 TMPC0605H-R15YG-D 0.15±30% 30 50 1.3 1.7 0.22 25 35 1.6 1.9 TMPC0605H-R33MG-D 0.33 25 32 2.5 3.0 TMPC0605H-R47MG-D 0.47 22 30 3.5 3.9 TMPC0605H-R56MG-D 0.56 20 27 3.6 4.2 TMPC0605H-R68MG-D 0.68 18 24 4.0 4.5 TMPC0605H-1R0MG-D 1.00 15 20 6.1 6.5 TMPC0605H-1R5MG-D 1.50 12 16.5 8.6 9.0 TMPC0605H-2R2MG-D 2.20 10 14 11.2 12.0 TMPC0605H-3R3MG-D 3.30 8 12 19 20.9 TMPC0605H-4R7MG-D 4.70 6.5 10 28 30.8 TMPC0605H-5R6MG-D 5.60 6.0 9.0 43.5 49 TMPC0605H-6R8MG-D 6.80 5.5 8.5 46 51.5 TMPC0605H-8R2MG-D 8.20 5.0 8.0 56 63 TMPC0605H-100MG-D 10.0 4.0 7.5 60 69 TMPC0605H-150MG-D 15.0 3.5 6.0 81 92 TMPC0605H-220MG-D 22.0 2.5 5.5 140 170 TMPC0605H-330MG-D 33.0 2.0 3.5 173 200 TMPC0605H-470MG-D 47.0 1.9 2.7 290 330 TMPC0605H-560MG-D 56.0 1.6 2.1 342 396 TMPC0605H-680MG-D 68.0 1.2 2.0 386 445 TMPC0605H-820MG-D 82.0 1.1 1.8 430 500 TMPC0605H-101MG-D 100.0 1.0 1.6 460 552 TMPC0605H-R22MG-D 1.85 DCR(mΩ) Max 2.1 (打扁式) TAI-TECH P15 6. Material List 4 5 3 1 NO Items 1 Core Carbonyl Powder. Materials 2 Wire Polyester Wire or equivalent. 3 Clip 100% Pb free solder(Ni+Sn) 4 Ink Halogen-free ketone 5 paint Epoxy resin 2 7. Reliability and Test Condition Item Performance Operating temperature Storage temperature Electrical Performance Test Test Condition -40~+125℃ (Including self - temperature rise) 1. -10~+40℃,50~60%RH (Product with taping) 2. -40~+125℃(on board) Inductance Refer to standard electrical characteristics list. DCR HP4284A,CH11025,CH3302,CH1320,CH1320S LCR Meter. CH16502,Agilent33420A Micro-Ohm Meter. Saturation Current (Isat) Approximately △L30%. Saturation DC Current (Isat) will cause L0 to drop △L(%) Heat Rated Current (Irms) Approximately △T40℃ Heat Rated Current (Irms) will cause the coil temperature rise △T(℃). 1.Applied the allowed DC current 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through IR reflow for 3times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Temperature: 125±2℃(Inductor,ambient + temp rise) Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 3times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Humidity:85±2﹪R.H, Temperature:85℃±2℃ Duration:1000hrs Min. Bead:with 100% rated current, Inductance:with 100% rated current Measured at room temperature after placing for 24±2 hrs. Life Test Load Humidity Moisture Resistance Thermal shock Vibration Appearance:No damage. Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 3 times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65 ± 2 ℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65 ± 2 ℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25 ℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow for 3 times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Condition for 1 cycle Step1:-40±2℃ 30±5min Step2:125±2℃ ≦0.5min Step3:125±2℃ 30±5minNumber of cycles: 500 Measured at room fempraturc after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 3 times. ( IPC/JEDECJ-STD-020E Classification Reflow Profiles) Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minutes Equipment: Vibration checker Total Amplitude: 10g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 TAI-TECH Item P16 Performance Bending Appearance:No damage. Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Shock Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805inch(2012mm):1kg,
TMPC 0603H-R22MG-D
物料型号: - 型号命名规则包括系列、尺寸、类型、电感值和公差等信息。
器件简介: - 该器件为SMD功率电感,特点包括低损耗、高性能、超低噪音,并符合无铅和RoHS标准。
引脚分配: - 文档提供了详细的引脚分配图和尺寸,以及推荐的PCB布局,参照IPC-7351B标准。
参数特性: - 包括电感值、额定电流、直流电阻等参数,不同型号有不同规格。
功能详解: - 描述了功率电感的功能和应用场景,主要用于商业应用。
应用信息: - 功率电感的商业应用领域。
封装信息: - 提供了不同系列的封装尺寸和推荐PCB布局。
TMPC 0603H-R22MG-D 价格&库存
很抱歉,暂时无法提供与“TMPC 0603H-R22MG-D”相匹配的价格&库存,您可以联系我们找货
TMPC 0603H-R22MG-D
  • 1000+4.366291000+0.56361
  • 2000+4.098262000+0.52901
  • 3000+3.949813000+0.50985
  • 5000+3.771125000+0.48678
  • 7000+3.658267000+0.47221
  • 10000+3.5426710000+0.45729
库存:1990
TMPC 0603H-R22MG-D
  • 1+8.433151+1.08856
  • 10+6.7164810+0.86697
  • 25+6.1577125+0.79484
  • 50+5.7673850+0.74446
  • 100+5.40441100+0.69761
  • 250+4.96200250+0.64050
  • 500+4.65360500+0.60069
库存:1990
