TXF 353229NF-181
TXF 353229NF-181
    TAI-TECH(台庆)
    120µH LAN 脉冲变压器 1:1 表面贴装型
TXF 353229NF-181 数据手册
TAI-TECH P2 SMD LAN Inductor TXF353229NF-SERIES 1. Features 1. SMD type pulse transformers. Halogen 2. TXF353229NF is small size and low profile 3.50X3.20X2.9 mm. 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen-free 4. Operating temperature -40~ +85℃ (Including self - temperature rise) 5. For 10/100/1G Base-T 2. Dimension / Part Dimension Series A(mm) B(mm) C(mm) 353229NF 3.50±0.20 3.20±0.20 E’(mm) F’(mm) G’(mm) H’(mm) 2.90 max 0.40±0.06 0.43±0.06 0.61±0.06 1.50±0.10 I’(mm) Recommended PC Board Pattern D(mm) E(mm) 353229NF 4.00 0.42 F(mm) G(mm) H(mm) I(mm) 0.37 0.63 1.50 0.29 J(mm) K(mm) L(mm) 0.85 0.85 Units: mm www.tai-tech.com.tw K’(mm) L’(mm) M’(mm) 0.26±0.06 0.72±0.06 0.72±0.06 0.57±0.06 2.06±0.10 Units: mm Series J’(mm) 0.70 TAI-TECH P3 3. Part Numbering TXF 353229 N A B C F - 181 D E A: Series B: Dimension AxBxC C: Material Ferrite Core D: RoHs F=Lead Free E: Inductance 181=180 uH 4. Specification TAI-TECH Part Number Inductance (uH) DC BIAS 0mA Test Frequency 1 to○ 2 ○ (Hz/V) or 4 to⑤ ○ Insertion loss (Max) Cp Capacitance (pF) ③to⑥ Turns ratio 1 to○ 2 ○ : 4 to⑤ ○ HI-POT 1 ○ ○ 2 ⑥to ④⑤③ TXF353229NF-121 120uH (Min ) 100K/0.1 1M-100MHz -1.0dB Max 35pF MAX 1:1 AC 1.5KV 60SEC TXF353229NF-181 180uH (Min ) 100K/0.1 1M-100MHz -1.0dB Max 35pF MAX 1:1 AC 1.5KV 60SEC www.tai-tech.com.tw TAI-TECH P4 SMD LAN Inductor TXF353229NF-SERIES-P0 1. Features Halogen 1. SMD type pulse transformers. 2. TXF353229NF is small size and low profile 3.50X3.20X2.9 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~ +85℃ (Including self - temperature rise) 5. TXF353229NF-SERIES-P0-for 10/100/1G Base-T, POE=350mA 5. TXF353229NF-121-P1-for 10/100/1G Base-T, POE+ 600mA 2. Dimension / Part Dimension Series A(mm) B(mm) C(mm) 353229NF 3.50±0.20 3.20±0.20 E’(mm) F’(mm) G’(mm) H’(mm) 2.90 max 0.40±0.06 0.43±0.06 0.61±0.06 1.50±0.10 I’(mm) Recommended PC Board Pattern D(mm) E(mm) 353229NF 4.00 0.42 F(mm) G(mm) H(mm) I(mm) 0.37 0.63 1.50 0.29 J(mm) K(mm) L(mm) 0.85 0.85 Units: mm www.tai-tech.com.tw K’(mm) L’(mm) M’(mm) 0.26±0.06 0.72±0.06 0.72±0.06 0.57±0.06 2.06±0.10 Units: mm Series J’(mm) 0.70 TAI-TECH P5 3. Part Numbering TXF 353229 N A B F C - 121 D - E P0 F A: Series B: Dimension AxBxC C: Material Ferrite Core D: RoHs F=Lead Free E: Inductance 121=120 uH F: Control S/N 4. Specification TAI-TECH Part Number Inductance (uH) DC BIAS 0mA Test 1 to○ 2 ○ Frequency or (Hz/V) 4 to⑤ ○ Insertion loss (Max) Cp Capacitance (pF) ③to⑥ Rated Current (mA) Max. Turns ratio 1 to○ 2 ○ : 4 to⑤ ○ HI-POT 1 ○ ○ 2 ⑥to ④⑤③ TXF353229NF-121-P0 120uH (Min ) 100K/0.1 1-100MHz -1.0dB Max 35pF MAX 350 1:1 AC 1.5KV 60SEC TXF353229NF-181-P0 180uH (Min ) 100K/0.1 1-100MHz -1.0dB Max 35pF MAX 350 1:1 AC 1.5KV 60SEC TXF353229NF-121-P1 120uH (Min ) 100K/0.1 1-100MHz -1.0dB Max 35pF MAX 600 1:1 AC 1.5KV 60SEC www.tai-tech.com.tw TAI-TECH P6 SMD LAN Inductor TXF353229NF-SERIES-G 1. Features Halogen 1. SMD type pulse transformers. 2. TXF353229NF is small size and low profile 3.50X3.20X2.9 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~ +85℃ (Including self - temperature rise) 5. For 2.5G/5G BASE-T. 2. Dimension / Part Dimension Series A(mm) B(mm) C(mm) 353229NF 3.50±0.20 3.20±0.20 E’(mm) F’(mm) G’(mm) H’(mm) 2.90 max 0.40±0.06 0.43±0.06 0.61±0.06 1.50±0.10 I’(mm) Recommended PC Board Pattern D(mm) E(mm) 353229NF 4.00 0.42 F(mm) G(mm) H(mm) I(mm) 0.37 0.63 1.50 0.29 J(mm) K(mm) L(mm) 0.85 0.85 Units: mm www.tai-tech.com.tw K’(mm) L’(mm) M’(mm) 0.26±0.06 0.72±0.06 0.72±0.06 0.57±0.06 2.06±0.10 Units: mm Series J’(mm) 0.70 TAI-TECH P7 3. Part Numbering TXF 353229 N A B F C - 121 D - E G F A: Series B: Dimension AxBxC C: Material Ferrite Core D: RoHs F=Lead Free E: Inductance 121=120 uH F: Control S/N 4. Specification TAI-TECH Part Number Inductance (uH) DC BIAS 0mA 1 to○ 2 ○ or 4 to⑤ ○ Test Frequency (Hz/V) TXF353229NF-121-G 120uH (Min ) 100K/0.1 TXF353229NF-181-G 180uH (Min ) 100K/0.1 Cp Capacitance (pF) ③to⑥ Turns ratio 1 to○ 2 ○ : 4 to⑤ ○ 1-125MHz -1.5dB Max 35pF MAX 1:1 AC 1.5KV 60SEC 1-125MHz -1.5dB Max 35pF MAX 1:1 AC 1.5KV 60SEC Insertion loss (Max) www.tai-tech.com.tw HI-POT 1 ○ ○ 2 ⑥to ④⑤③ TAI-TECH P8 SMD LAN Inductor TXF353229NF-SERIES-GP0 1. Features 1. SMD type pulse transformers. Halogen 2. TXF353229NF is small size and low profile 3.50X3.20X2.9 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~ +85℃ (Including self - temperature rise) 5. TXF353229NF-SERIES-GP0-for 1G, 2.5/5G Base-T, POE 350mA 6. TXF353229NF-121-GP1-for 1G, 2.5/5G Base-T, POE+ 600mA 2. Dimension / Part Dimension Series A(mm) B(mm) C(mm) 353229NF 3.50±0.20 3.20±0.20 E’(mm) F’(mm) G’(mm) H’(mm) 2.90 max 0.40±0.06 0.43±0.06 0.61±0.06 1.50±0.10 I’(mm) Recommended PC Board Pattern D(mm) E(mm) 353229NF 4.00 0.42 F(mm) G(mm) H(mm) I(mm) 0.37 0.63 1.50 0.29 J(mm) K(mm) L(mm) 0.85 0.85 Units: mm www.tai-tech.com.tw K’(mm) L’(mm) M’(mm) 0.26±0.06 0.72±0.06 0.72±0.06 0.57±0.06 2.06±0.10 Units: mm Series J’(mm) 0.70 TAI-TECH P9 3. Part Numbering TXF 353229 N A B F C - 121 D - GP0 E F A: Series B: Dimension AxBxC C: Material Ferrite Core D: RoHs F=Lead Free E: Inductance 121=120 uH F: Control S/N 4. Specification TAI-TECH Part Number Inductance (uH) DC BIAS 0mA 1 to○ 2 ○ or 4 to⑤ ○ Test Frequency (Hz/V) TXF353229NF-121-GP0 120uH (Min ) 100K/0.1 TXF353229NF-181-GP0 180uH (Min ) TXF353229NF-121-GP1 120uH (Min ) Cp Capacitance (pF) ③to⑥ Rated Current (mA) Max. Turns ratio 1 to○ 2 ○ : 4 to⑤ ○ 1-125MHz -1.5dB Max 35pF MAX 350 1:1 AC 1.5KV 60SEC 100K/0.1 1-125MHz -1.5dB Max 35pF MAX 350 1:1 AC 1.5KV 60SEC 100K/0.1 1-125MHz -1.5dB Max 35pF MAX 600 1:1 AC 1.5KV 60SEC Insertion loss (Max) www.tai-tech.com.tw HI-POT 1 ○ ○ 2 ⑥to ④⑤③ TAI-TECH P10 SMD LAN Inductor TXF353229NF-121-H 1. Features Halogen 1. SMD type pulse transformers. 2. TXF353229NF is small size and low profile 3.50X3.20X2.9 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~ +85℃ (Including self - temperature rise) 5. For 1G, 2.5/5G, 10G Base-T 2. Dimension / Part Dimension Series A(mm) B(mm) C(mm) 353229NF 3.50±0.20 3.20±0.20 E’(mm) F’(mm) G’(mm) H’(mm) 2.90 max 0.40±0.06 0.43±0.06 0.61±0.06 1.50±0.10 I’(mm) Recommended PC Board Pattern D(mm) E(mm) 353229NF 4.00 0.42 F(mm) G(mm) H(mm) I(mm) 0.37 0.63 1.50 0.29 J(mm) K(mm) L(mm) 0.85 0.85 Units: mm www.tai-tech.com.tw K’(mm) L’(mm) M’(mm) 0.26±0.06 0.72±0.06 0.72±0.06 0.57±0.06 2.06±0.10 Units: mm Series J’(mm) 0.70 TAI-TECH P11 3. Part Numbering TXF 353229 N A B C F - 121 D - E H F A: Series B: Dimension AxBxC C: Material Ferrite Core D: RoHs F=Lead Free E: Inductance 121=120 uH F: Control S/N 4. Specification TAI-TECH Part Number Inductance (uH) DC BIAS 0mA 1 to○ 2 ○ or 4 to⑤ ○ Test Frequency (Hz/V) TXF353229NF-121-H 120uH (Min ) 100K/0.1 Insertion loss 1-500MHz -3.5dB Max www.tai-tech.com.tw Cp Capacitance (pF) ③to⑥ Turns ratio 1 to○ 2 ○ : 4 to⑤ ○ 35pF MAX 1:1 HI-POT 1 ○ ○ 2 ⑥to ④⑤③ AC 1.5KV 60SEC TAI-TECH P12 SMD LAN Inductor TXF353229NF-121-HP0 1. Features 1. SMD type pulse transformers. Halogen 2. TXF353229NF is small size and low profile 3.50X3.20X2.9 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~ +85℃ (Including self - temperature rise) 5. TXF353229NF-121-HP0-for 1G, 2.5/5G, 10G Base-T, POE 350mA 6. TXF353229NF-121-HP1- for 1G, 2.5/5G, 10G Base-T, POE+ 600mA 2. Dimension / Part Dimension Series A(mm) B(mm) C(mm) 353229NF 3.50±0.20 3.20±0.20 E’(mm) F’(mm) G’(mm) H’(mm) 2.90 max 0.40±0.06 0.43±0.06 0.61±0.06 1.50±0.10 I’(mm) Recommended PC Board Pattern D(mm) E(mm) 353229NF 4.00 0.42 F(mm) G(mm) H(mm) I(mm) 0.37 0.63 1.50 0.29 J(mm) K(mm) L(mm) 0.85 0.85 Units: mm www.tai-tech.com.tw K’(mm) L’(mm) M’(mm) 0.26±0.06 0.72±0.06 0.72±0.06 0.57±0.06 2.06±0.10 Units: mm Series J’(mm) 0.70 TAI-TECH P13 3. Part Numbering TXF 353229 N A B F C - 121 D - HP0 E F A: Series B: Dimension AxBxC C: Material Ferrite Core D: RoHs F=Lead Free E: Inductance 121=120 uH F: Control S/N 4. Specification TAI-TECH Part Number Inductance (uH) DC BIAS 0mA 1 to○ 2 ○ or 4 to⑤ ○ Test Frequency (Hz/V) TXF353229NF-121-HP0 120uH (Min ) 100K/0.1 TXF353229NF-121-HP1 120uH (Min ) 100K/0.1 Cp Capacitance (pF) ③to⑥ Rated Current (mA) Max. Turns ratio 1 to○ 2 ○ : 4 to⑤ ○ 1-500MHz -3.5dB Max 35pF MAX 350 1:1 AC 1.5KV 60SEC 1-500MHz -3.5dB Max 35pF MAX 600 1:1 AC 1.5KV 60SEC Insertion loss (Max) www.tai-tech.com.tw HI-POT 1 ○ ○ 2 ⑥to ④⑤③ TAI-TECH P14 SMD LAN Inductor TXF453229NF-SERIES 1. Features 1. SMD type pulse transformers. Halogen 2. TXF453229NF is small size and low profile 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen-free 4. Operating temperature-40~ +85℃ (Including self - temperature rise) 5. For 10/100/1G Base-T 2. Dimension / Part Dimension Series A(mm) B(mm) C(mm) E’(mm) F’(mm) G’(mm) H’(mm) 453229NF 4.60±0.20 3.25±0.20 2.90 Max 0.45±0.06 0.47±0.06 0.60±0.06 1.43±0.10 I’(mm) Recommended PC Board Pattern 453229NF D(mm) E(mm) F(mm) G(mm) H(mm) I(mm) 4.90 0.50 0.45 0.65 1.45 0.25 J(mm) K(mm) K1(mm) 1.10 0.90 1.10 Units: mm www.tai-tech.com.tw K’(mm) L’(mm) M’(mm) 0.25±0.10 1.00±0.10 1.00±0.10 0.80±0.06 2.70±0.10 Units: mm Series J’(mm) TAI-TECH P15 3. Part Numbering TXF 453229 N A B F C - D 181 E A: Series B: Dimension AxBxC C: Material Ferrite Core D: RoHs F=Lead Free E: Inductance 181=180 uH 4. Specification Inductance (uH) 1 to○ 2 ○ or 4 to⑤ ○ Test Frequency (Hz/V) TXF453229NF-121 120 uH(min) 100K/0.1 TXF453229NF-181 180 uH(min.) 100K/0.1 TAI-TECH Part Number TAI-TECH Part Number TXF453229NF-381 Inductance (uH) (DC bias 0mA) 1 to○ 2 ○ or 4 to⑤ ○ 380 uH(min) Cp Capacitance (pF) ③to⑥ Turns ratio 1 to○ 2 ○ or 4 to⑤ ○ 1-100MHZ -1.5dB Max 35pF(typ) 1:1 AC 1.5KV 60SEC 1-100MHZ -1.5dB Max 35pF(typ) 1:1 AC 1.5KV 60SEC Insertion loss Inductance(uH) (DC bias 8mA) Test Frequency 1 to○ 2 ○ (Hz/V) or 4 to⑤ ○ 350 uH(min) 100K/0.1 Insertion loss 1-100MHZ -1.5dB Max www.tai-tech.com.tw Cp Capacitance (pF) ③to⑥ Turns ratio 1 to○ 2 ○ : 4 to⑤ ○ 35pF(typ) 1:1 HI-POT 1 ○ ○ 2 ⑥to ④⑤③ HI-POT 1 ○ ○ 2 ⑥to ④⑤③ AC 1.5KV 60SEC TAI-TECH P16 SMD LAN Inductor TXF453229NF-SERIES-P0 1. Features 1. SMD type pulse transformers. 2. TXF453229NF is small size and low profile Halogen 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~ +85℃ (Including self - temperature rise) Halogen-free 5. TXF453229NF-SERIES-P0-for 10/100/1G Base-T, POE=350mA 6. TXF453229NF-121-P1-for 10/100/1G Base-T, POE+ 600mA 7. TXF453229NF-181-P1-for 10/100/1G Base-T, POE+ 720mA 8. TXF453229NF-121-P2-for 10/100/1G Base-T, POE++ 1000mA 2. Dimension / Part Dimension Series A(mm) B(mm) C(mm) E’(mm) F’(mm) G’(mm) H’(mm) 453229NF 4.60±0.20 3.25±0.20 2.90 Max 0.45±0.06 0.47±0.06 0.60±0.06 1.43±0.10 I’(mm) Recommended PC Board Pattern 453229NF D(mm) E(mm) F(mm) G(mm) H(mm) I(mm) 4.90 0.50 0.45 0.65 1.45 0.25 J(mm) K(mm) K1(mm) 1.10 0.90 1.10 Units: mm www.tai-tech.com.tw K’(mm) L’(mm) M’(mm) 0.25±0.10 1.00±0.10 1.00±0.10 0.80±0.06 2.70±0.10 Units: mm Series J’(mm) TAI-TECH P17 3. Part Numbering TXF 453229 N A B F C - 181 D - E P0 F A: Series B: Dimension AxBxC C: Material Ferrite Core D: RoHs F=Lead Free E: Inductance 181=180 uH F: Control S/N 4. Specification Inductance (uH) 1 to○ 2 Test Frequency ○ (Hz/V) or 4 to⑤ ○ TAI-TECH Part Number Insertion loss Cp Capacitance (pF) ③to⑥ Rated Current (mA) Max. Turns ratio 1 to○ 2 ○ or 4 to⑤ ○ HI-POT 1 ○ ○ 2 ⑥to ④⑤③ TXF453229NF-121-P0 120 uH(min) 100K/0.1 1-100MHZ -1.5dB Max 35pF(typ) 350 1:1 AC 1.5KV 60SEC TXF453229NF-181-P0 180 uH(min.) 100K/0.1 1-100MHZ -1.5dB Max 35pF(typ) 350 1:1 AC 1.5KV 60SEC TXF453229NF-121-P1 120 uH(min) 100K/0.1 1-100MHZ -1.5dB Max 35pF(typ) 600 1:1 AC 1.5KV 60SEC TXF453229NF-181-P1 180 uH(min.) 100K/0.1 1-100MHZ -1.5dB Max 35pF(typ) 720 1:1 AC 1.5KV 60SEC TXF453229NF-121-P2 120 uH(min) 100K/0.1 1-100MHZ -1.5dB Max 35pF(typ) 1000 1:1 AC 1.5KV 60SEC TAI-TECH Part Number TXF453229NF-381-P0 Inductance (uH) Inductance(uH) (DC bias 0mA) (DC bias 8mA) Test Frequency 1 to○ 2 1 to○ 2 ○ ○ (Hz/V) or or 4 to⑤ 4 to⑤ ○ ○ 380 uH(min) 350 uH(min) 100K/0.1 Cp Turns ratio Capacitance 1 to○ 2 Rated Current ○ Insertion loss (pF) (mA) Max. : 4 to⑤ ○ ③to⑥ 1-100MHZ -1.5dB Max www.tai-tech.com.tw 35pF(typ) 350 1:1 HI-POT 1 ○ ○ 2 ⑥to ④⑤③ AC 1.5KV 60SEC TAI-TECH P18 SMD LAN Inductor TXF453229NF-SERIES-G C 1. Features 1. SMD type pulse transformers. Halogen 2. TXF453229NF is small size and low profile 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen-free 4. Operating temperature -40~ +85℃ (Including self - temperature rise) 5. For 1G, 2.5/5G Base-T 2. Dimension / Part Dimension Series A(mm) B(mm) C(mm) E’(mm) F’(mm) G’(mm) H’(mm) 453229NF 4.60±0.20 3.25±0.20 2.90 Max 0.45±0.06 0.47±0.06 0.60±0.06 1.43±0.10 I’(mm) Recommended PC Board Pattern 453229NF D(mm) E(mm) F(mm) G(mm) H(mm) I(mm) 4.90 0.50 0.45 0.65 1.45 0.25 J(mm) K(mm) K1(mm) 1.10 0.90 1.10 Units: mm www.tai-tech.com.tw K’(mm) L’(mm) M’(mm) 0.25±0.10 1.00±0.10 1.00±0.10 0.80±0.06 2.70±0.10 Units: mm Series J’(mm) TAI-TECH P19 3. Part Numbering TXF 453229 N A B C F - D 121 - E G F A: Series B: Dimension AxBxC C: Material Ferrite Core D: RoHs F=Lead Free E: Inductance 121=120 uH F: Control S/N 4. Specification Inductance (uH) 1 to○ 2 ○ or 4 to⑤ ○ Test Frequency (Hz/V) TXF453229NF-121-G 120 uH(min) 100K/0.1 TXF453229NF-181-G 180 uH(min.) 100K/0.1 TAI-TECH Part Number Cp Capacitance (pF) ③to⑥ Turns ratio 1 to○ 2 ○ or 4 to⑤ ○ HI-POT 1○ ○ 2 ⑥to ④⑤③ 1-125MHZ -1.5dB Max 35pF(typ) 1:1 AC 1.5KV 60SEC 1-125MHZ -1.5dB Max 35pF(typ) 1:1 AC 1.5KV 60SEC Insertion loss www.tai-tech.com.tw TAI-TECH P20 SMD LAN Inductor TXF453229NF-SERIES-GP0 1. Features 1. SMD type pulse transformers. 2. TXF453229NF is small size and low profile Halogen 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~ +85℃ (Including self - temperature rise) Halogen-free 5. TXF453229NF-SERIES-GP0-for 1G, 2.5/5G Base-T, POE=350mA 6. TXF453229NF-121-GP1-for 1G, 2.5/5G Base-T, POE+ 600mA 7. TXF453229NF-181-GP1-for 1G, 2.5/5G Base-T, POE+ 720mA 8. TXF453229NF-121-GP2-for 1G, 2.5/5G Base-T, POE++ 1000mA 2. Dimension / Part Dimension Series A(mm) B(mm) C(mm) E’(mm) F’(mm) G’(mm) H’(mm) 453229NF 4.60±0.20 3.25±0.20 2.90 Max 0.45±0.06 0.47±0.06 0.60±0.06 1.43±0.10 I’(mm) Recommended PC Board Pattern 453229NF D(mm) E(mm) F(mm) G(mm) H(mm) I(mm) 4.90 0.50 0.45 0.65 1.45 0.25 J(mm) K(mm) K1(mm) 1.10 0.90 1.10 Units: mm www.tai-tech.com.tw K’(mm) L’(mm) M’(mm) 0.25±0.10 1.00±0.10 1.00±0.10 0.80±0.06 2.70±0.10 Units: mm Series J’(mm) TAI-TECH P21 3. Part Numbering TXF 453229 N A B C F - 181 D - E GP0 F A: Series B: Dimension AxBxC C: Material Ferrite Core D: RoHs F=Lead Free E: Inductance 181=180 uH F: Control S/N 4. Specification TAI-TECH Part Number Inductance (uH) Test 1 to○ 2 ○ Frequency or (Hz/V) 4 to⑤ ○ Insertion loss Cp Capacitance (pF) ③to⑥ Rated Current (mA) Max. Turns ratio 1 to○ 2 ○ or 4 to⑤ ○ HI-POT 1 ○ ○ 2 ⑥to ④⑤③ TXF453229NF-121-GP0 120 uH(min) 100K/0.1 1-125MHZ -1.5dB Max 35pF(typ) 350 1:1 AC 1.5KV 60SEC TXF453229NF-181-GP0 180 uH(min.) 100K/0.1 1-125MHZ -1.5dB Max 35pF(typ) 350 1:1 AC 1.5KV 60SEC TXF453229NF-121-GP1 120 uH(min) 100K/0.1 1-125MHZ -1.5dB Max 35pF(typ) 600 1:1 AC 1.5KV 60SEC TXF453229NF-181-GP1 180 uH(min.) 100K/0.1 1-125MHZ -1.5dB Max 35pF(typ) 720 1:1 AC 1.5KV 60SEC TXF453229NF-121-GP2 120 uH(min) 100K/0.1 1-125MHZ -1.5dB Max 35pF(typ) 1000 1:1 AC 1.5KV 60SEC www.tai-tech.com.tw TAI-TECH P22 7. Reliability and Test Condition (TXF353229, 453229) Item Performance Operating temperature -40~ +85℃ (Including self - temperature rise) Storage temperature -40~ +85℃ (on board) Test Condition Electrical Performance Test Ls Cp Keysight –E4980AL+ Keysight t -16334A Refer to standard electrical characteristics list. Insertion Loss Keysight –E4980AL+ Keysight t -16334A Agilent E5071C Reliability Test Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Temperature:85±2℃ Life Test Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24 hrs. Load Humidity Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Humidity:85±3% R.H, Temperature:85℃±2℃ Duration : 1000hrs Min. Bead : with 100% rated current , Inductance: with 10% rated current Measured at room temperature after placing for 24 hrs. Moisture Resistance Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Appearance:No damage. Inductance:within±10% of initial value Cp: within ±15% of initial value and shall not Insertion Loss:within Specification Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min Thermal shock Step2:85±2℃ ≦0.5min Step3:85±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24 hrs. Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minute Equipment: Vibration checker Total Amplitude:10g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Vibration www.tai-tech.com.tw TAI-TECH P23 Item Performance Bending Appearance:No damage. Inductance:within±10% of initial value Cp: within ±15% of initial value and shall not Insertion Loss:within Specification Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg , =0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg , =0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg , =0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg ,
TXF 353229NF-181 价格&库存
很抱歉,暂时无法提供与“TXF 353229NF-181”相匹配的价格&库存,您可以联系我们找货
TXF 353229NF-181
  • 1+4.220771+0.54674
  • 10+3.7805710+0.48972
  • 25+3.6153625+0.46832
  • 50+3.4979150+0.45310
  • 100+3.38226100+0.43812
  • 250+3.23473250+0.41901
  • 500+3.12665500+0.40501
  • 1000+3.021941000+0.39145
库存:2084
TXF 353229NF-181
  • 2000+2.920372000+0.37829
  • 4000+2.821944000+0.36554
  • 6000+2.765756000+0.35827
  • 10000+2.6964410000+0.34929
  • 14000+2.6516814000+0.34349
  • 20000+2.6049820000+0.33744
库存:2084
