Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
TEL: +886 2 2995 0535
http://www.chinsan.com/products/
ALUMINUM ELECTROLYTIC CAPACITORS
CED
Series
Extra Low Impedance
Load life 2,000 to 3,000 hours at 105℃
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-55 ~ +105℃
Working Voltage Range
6.3 ~ 50Vdc
Capacitance Range
10 ~ 3,300 μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Rated Voltage (V)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
tanδ(Max)
6.3
10
16
25
35
50
∅6.3~∅10
0.22
0.20
0.16
0.14
0.12
0.12
∅12.5
0.26
0.22
0.18
0.16
0.14
0.12
The above values should be increased by 0.02 for every additional 1000μF
Leakage Current
(∅6.3~∅10) I=0.01CV or 3μA whichever is greater impress the rated voltage for 2 minutes.
(∅12.5) I=0.03CV or 4μA whichever is greater impress the rated voltage for 1 minute.
I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V)
Rated voltage (V)
Low Temperature Characteristics
Impedance Ratio(MAX)
∅6.3~∅10
∅12.5
6.3
10
16
25
35
50
Z(-25℃)/Z(+20℃)
2
2
2
2
2
2
Z(-55℃)/Z(+20℃)
5
4
4
3
3
3
Z(-25℃)/Z(+20℃)
3
3
2
2
2
2
Z(-55℃)/Z(+20℃)
10
8
6
4
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC
voltage with the rated voltage is applied for 3,000 hours (∅6.3x5.8 for 2,000 hours) at 105°C
Endurance
Capacitance change
≦ ±30% of the initial value
Dissipation factor(tanδ)
≦ 300% of the specified value
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 105℃ without voltage applied.
Shelf Life
Capacitance change
Leakage current
≦ 200% of the specified value
Others
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
Code
Size
ФD
L
𝜶
A
B
C
W
P
6358
6.3×5.8
6.3
5.8
+0.4
-0.1
6.6
6.6
7.3
0.5~0.8
2.1
6377
6.3×7.7
6.3
7.7
±0.3
6.6
6.6
7.3
0.5~0.8
2.1
8.3
8.3
8.8
0.5~0.8
2.2
8.3
8.3
9.1
0.8~1.2
3.1
Safety Vent (≧8×10.5)
0862
8×6.2
8
6.2
+0.4
-0.1
08A5
8×10.5
8
10.5
0.5
10A5
10×10.5
10
10.5
0.5
10.3 10.3
11.0
0.8~1.2
4.6
10C5
10×12.5
10
12.5
0.5
10.3 10.3
11.0
0.8~1.2
4.6
12D5
12.5×13.5
12.5
13.5
1.0
12.8 12.8
13.8
0.8~1.2
4.6
1216
12.5×16
12.5
16
1.0
12.8 12.8
13.8
0.8~1.2
4.6
Marking
≦6.3Ф
≧8Ф
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES CED
NO.:
1、Tape & Reel (TR)\ Cut Tape (CT)\ Digi-Reel。
2、Diagram of Dimensions (unit : mm.),and Recommended soldering pad dimensions。
Size Code ΦD
L
A
B
C
W
P
α
a
b
PUBLISH DATE
2022-03-28
c
0558
5.0
5.8
5.3
5.3
5.9
0.5~0.8
1.5
0.4/-0.1
1.4
7.4
1.6
6358
6.3
5.8
6.6
6.6
7.3
0.5~0.8
2.1
0.4/-0.1
2.1
9.1
1.6
6377
6.3
7.7
6.6
6.6
7.3
0.5~0.8
2.1
0.3
2.1
9.1
1.6
08A5
8.0
10.5
8.3
8.3
9.1
0.8~1.2
3.1
0.5
3.0
11.0
2.5
10A5
10.0
10.5
10.3
10.3
11.0
0.8~1.2
4.6
0.5
4.0
12.0
2.5
Safety Vent (≥ 8x10.5)
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
On rated
Capacitance
1
CED0J221MCB6358
220
±20%
Working
Surge
Voltage
Voltage
(Vdc)
(Vdc)
6.3
Category
Tanδ
Temp.Ran @ 25℃
Leakage
Current
ge
(120Hz)
(uA)
(Max)
(2 min.)
-55°C ~
105°C
0.22
13.86
Rated Ripple Rated Ripple
Current
Current
(mA rms)
(mA rms)
@ 105℃
@ 105℃
120Hz
100kHz
230mA
@ 100 kHz
Impedance
@20℃
(Ω max/
100kHz)
0.44Ω
Dimensions (mm)
Endurance
Appearance
@ 105℃
Drawing
(Hours)
DΦ
L
2000 Hrs
@ 105°C
6.3mm
5.8mm
a
d
P
2.1mm
No
2
CED0J102MCB08A5F2
1000
±20%
6.3
3
CED1A102MCB10A5
1000
±20%
10
4
CED1A151MCB6358
150
±20%
10
5
CED1A221MCB6377
220
±20%
10
6
CED1C101MCB6358
100
±20%
16
7
CED1C101MCB6377
100
±20%
16
8
CED1C221MCB6377
220
±20%
16
9
CED1C221MCB6377F2
220
±20%
16
10 CED1C470MCB0558
47
±20%
16
11 CED1C470MCB6358
47
±20%
16
12 CED1C471MCB08A5F2
470
±20%
16
13 CED1E470MCB6358
47
±20%
25
14 CED1E101MCB6358
100
±20%
25
15 CED1E101MCB6377F2
100
±20%
25
16 CED1E331MCB08A5F2
330
±20%
25
17 CED1V470MCB6358
47
±20%
35
18 CED1V101MCB6377F2
100
±20%
35
19 CED1V221MCB08A5
220
±20%
35
20 CED1H470MCB6377F2
47
±20%
50
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
0.22
63
0.2
100
0.2
15
0.2
22
0.16
16
0.16
16
0.16
35.2
0.16
35.2
0.16
7.52
0.16
7.52
0.16
75.2
0.14
11.75
0.14
25
0.14
25
0.14
82.5
0.12
16.45
0.12
35
0.12
77
0.12
23.5
450mA
@ 100 kHz
670mA
@ 100 kHz
230mA
@ 100 kHz
280mA
@ 100 kHz
230mA
@ 100 kHz
280mA
@ 100 kHz
280mA
@ 100 kHz
280mA
@ 100 kHz
150mA
@ 100 kHz
230mA
@ 100 kHz
450mA
@ 100 kHz
230mA
@ 100 kHz
230mA
@ 100 kHz
280mA
@ 100 kHz
450mA
@ 100 kHz
230mA
@ 100 kHz
280mA
@ 100 kHz
450mA
@ 100 kHz
185mA
@ 100 kHz
0.17Ω
0.09Ω
0.44Ω
0.34Ω
0.44Ω
0.34Ω
0.34Ω
0.34Ω
0.8Ω
0.44Ω
0.17Ω
0.44Ω
0.44Ω
0.34Ω
0.17Ω
0.44Ω
0.34Ω
0.17Ω
0.68Ω
2000 Hrs
8.0mm 10.5mm
@ 105°C
3000 Hrs
10.0mm 10.5mm
@ 105°C
2000 Hrs
6.3mm 5.8mm
@ 105°C
3000 Hrs
6.3mm 7.7mm
@ 105°C
2000 Hrs
6.3mm 5.8mm
@ 105°C
3000 Hrs
6.3mm 7.7mm
@ 105°C
3000 Hrs
6.3mm 7.7mm
@ 105°C
2000 Hrs
6.3mm 7.7mm
@ 105°C
2000 Hrs
5.0mm 5.8mm
@ 105°C
2000 Hrs
6.3mm 5.8mm
@ 105°C
2000 Hrs
8.0mm 10.5mm
@ 105°C
2000 Hrs
6.3mm 5.8mm
@ 105°C
2000 Hrs
6.3mm 5.8mm
@ 105°C
2000 Hrs
6.3mm 7.7mm
@ 105°C
2000 Hrs
8.0mm 10.5mm
@ 105°C
2000 Hrs
6.3mm 5.8mm
@ 105°C
2000 Hrs
6.3mm 7.7mm
@ 105°C
3000 Hrs
8.0mm 10.5mm
@ 105°C
2000 Hrs
6.3mm 7.7mm
@ 105°C
3.1mm
4.6mm
2.1mm
2.1mm
2.1mm
2.1mm
2.1mm
2.1mm
1.5mm
2.1mm
3.1mm
2.1mm
2.1mm
2.1mm
3.1mm
2.1mm
2.1mm
3.1mm
2.1mm
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
李科高
张铭仁
聂婷
很抱歉,暂时无法提供与“CED0J102MCB08A5F2”相匹配的价格&库存,您可以联系我们找货
