CED1E101MCB6358
CED1E101MCB6358
    CHINSAN(金山)
    SMD
    100 µF 25 V 铝电解电容器 径向,Can - SMD 105°C 时为 2000 小时
CED1E101MCB6358 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ ALUMINUM ELECTROLYTIC CAPACITORS CED Series  Extra Low Impedance  Load life 2,000 to 3,000 hours at 105℃  SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 6.3 ~ 50Vdc Capacitance Range 10 ~ 3,300 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Rated Voltage (V) Dissipation Factor (tanδ) (at 25℃, 120Hz) tanδ(Max) 6.3 10 16 25 35 50 ∅6.3~∅10 0.22 0.20 0.16 0.14 0.12 0.12 ∅12.5 0.26 0.22 0.18 0.16 0.14 0.12 The above values should be increased by 0.02 for every additional 1000μF Leakage Current (∅6.3~∅10) I=0.01CV or 3μA whichever is greater impress the rated voltage for 2 minutes. (∅12.5) I=0.03CV or 4μA whichever is greater impress the rated voltage for 1 minute. I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V) Rated voltage (V) Low Temperature Characteristics Impedance Ratio(MAX) ∅6.3~∅10 ∅12.5 6.3 10 16 25 35 50 Z(-25℃)/Z(+20℃) 2 2 2 2 2 2 Z(-55℃)/Z(+20℃) 5 4 4 3 3 3 Z(-25℃)/Z(+20℃) 3 3 2 2 2 2 Z(-55℃)/Z(+20℃) 10 8 6 4 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated voltage is applied for 3,000 hours (∅6.3x5.8 for 2,000 hours) at 105°C Endurance Capacitance change ≦ ±30% of the initial value Dissipation factor(tanδ) ≦ 300% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±30% of the initial value Dissipation factor(tanδ) ≦ 300% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W  DIMENSIONS (mm) Code Size ФD L 𝜶 A B C W P 6358 6.3×5.8 6.3 5.8 +0.4 -0.1 6.6 6.6 7.3 0.5~0.8 2.1 6377 6.3×7.7 6.3 7.7 ±0.3 6.6 6.6 7.3 0.5~0.8 2.1 8.3 8.3 8.8 0.5~0.8 2.2 8.3 8.3 9.1 0.8~1.2 3.1 Safety Vent (≧8×10.5) 0862 8×6.2 8 6.2 +0.4 -0.1 08A5 8×10.5 8 10.5 0.5 10A5 10×10.5 10 10.5 0.5 10.3 10.3 11.0 0.8~1.2 4.6 10C5 10×12.5 10 12.5 0.5 10.3 10.3 11.0 0.8~1.2 4.6 12D5 12.5×13.5 12.5 13.5 1.0 12.8 12.8 13.8 0.8~1.2 4.6 1216 12.5×16 12.5 16 1.0 12.8 12.8 13.8 0.8~1.2 4.6 Marking ≦6.3Ф ≧8Ф Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES CED NO.: 1、Tape & Reel (TR)\ Cut Tape (CT)\ Digi-Reel。 2、Diagram of Dimensions (unit : mm.),and Recommended soldering pad dimensions。 Size Code ΦD L A B C W P α a b PUBLISH DATE 2022-03-28 c 0558 5.0 5.8 5.3 5.3 5.9 0.5~0.8 1.5 0.4/-0.1 1.4 7.4 1.6 6358 6.3 5.8 6.6 6.6 7.3 0.5~0.8 2.1 0.4/-0.1 2.1 9.1 1.6 6377 6.3 7.7 6.6 6.6 7.3 0.5~0.8 2.1 0.3 2.1 9.1 1.6 08A5 8.0 10.5 8.3 8.3 9.1 0.8~1.2 3.1 0.5 3.0 11.0 2.5 10A5 10.0 10.5 10.3 10.3 11.0 0.8~1.2 4.6 0.5 4.0 12.0 2.5 Safety Vent (≥ 8x10.5) Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance (%) 1 CED0J221MCB6358 220 ±20% Working Surge Voltage Voltage (Vdc) (Vdc) 6.3 Category Tanδ Temp.Ran @ 25℃ Leakage Current ge (120Hz) (uA) (℃) (Max) (2 min.) -55°C ~ 105°C 0.22 13.86 Rated Ripple Rated Ripple Current Current (mA rms) (mA rms) @ 105℃ @ 105℃ 120Hz 100kHz 230mA @ 100 kHz Impedance @20℃ (Ω max/ 100kHz) 0.44Ω Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L 2000 Hrs @ 105°C 6.3mm 5.8mm a d P 2.1mm No Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 2 CED0J102MCB08A5F2 1000 ±20% 6.3 3 CED1A102MCB10A5 1000 ±20% 10 4 CED1A151MCB6358 150 ±20% 10 5 CED1A221MCB6377 220 ±20% 10 6 CED1C101MCB6358 100 ±20% 16 7 CED1C101MCB6377 100 ±20% 16 8 CED1C221MCB6377 220 ±20% 16 9 CED1C221MCB6377F2 220 ±20% 16 10 CED1C470MCB0558 47 ±20% 16 11 CED1C470MCB6358 47 ±20% 16 12 CED1C471MCB08A5F2 470 ±20% 16 13 CED1E470MCB6358 47 ±20% 25 14 CED1E101MCB6358 100 ±20% 25 15 CED1E101MCB6377F2 100 ±20% 25 16 CED1E331MCB08A5F2 330 ±20% 25 17 CED1V470MCB6358 47 ±20% 35 18 CED1V101MCB6377F2 100 ±20% 35 19 CED1V221MCB08A5 220 ±20% 35 20 CED1H470MCB6377F2 47 ±20% 50 -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C 0.22 63 0.2 100 0.2 15 0.2 22 0.16 16 0.16 16 0.16 35.2 0.16 35.2 0.16 7.52 0.16 7.52 0.16 75.2 0.14 11.75 0.14 25 0.14 25 0.14 82.5 0.12 16.45 0.12 35 0.12 77 0.12 23.5 450mA @ 100 kHz 670mA @ 100 kHz 230mA @ 100 kHz 280mA @ 100 kHz 230mA @ 100 kHz 280mA @ 100 kHz 280mA @ 100 kHz 280mA @ 100 kHz 150mA @ 100 kHz 230mA @ 100 kHz 450mA @ 100 kHz 230mA @ 100 kHz 230mA @ 100 kHz 280mA @ 100 kHz 450mA @ 100 kHz 230mA @ 100 kHz 280mA @ 100 kHz 450mA @ 100 kHz 185mA @ 100 kHz 0.17Ω 0.09Ω 0.44Ω 0.34Ω 0.44Ω 0.34Ω 0.34Ω 0.34Ω 0.8Ω 0.44Ω 0.17Ω 0.44Ω 0.44Ω 0.34Ω 0.17Ω 0.44Ω 0.34Ω 0.17Ω 0.68Ω 2000 Hrs 8.0mm 10.5mm @ 105°C 3000 Hrs 10.0mm 10.5mm @ 105°C 2000 Hrs 6.3mm 5.8mm @ 105°C 3000 Hrs 6.3mm 7.7mm @ 105°C 2000 Hrs 6.3mm 5.8mm @ 105°C 3000 Hrs 6.3mm 7.7mm @ 105°C 3000 Hrs 6.3mm 7.7mm @ 105°C 2000 Hrs 6.3mm 7.7mm @ 105°C 2000 Hrs 5.0mm 5.8mm @ 105°C 2000 Hrs 6.3mm 5.8mm @ 105°C 2000 Hrs 8.0mm 10.5mm @ 105°C 2000 Hrs 6.3mm 5.8mm @ 105°C 2000 Hrs 6.3mm 5.8mm @ 105°C 2000 Hrs 6.3mm 7.7mm @ 105°C 2000 Hrs 8.0mm 10.5mm @ 105°C 2000 Hrs 6.3mm 5.8mm @ 105°C 2000 Hrs 6.3mm 7.7mm @ 105°C 3000 Hrs 8.0mm 10.5mm @ 105°C 2000 Hrs 6.3mm 7.7mm @ 105°C 3.1mm 4.6mm 2.1mm 2.1mm 2.1mm 2.1mm 2.1mm 2.1mm 1.5mm 2.1mm 3.1mm 2.1mm 2.1mm 2.1mm 3.1mm 2.1mm 2.1mm 3.1mm 2.1mm ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 李科高 张铭仁 聂婷
CED1E101MCB6358 价格&库存
很抱歉,暂时无法提供与“CED1E101MCB6358”相匹配的价格&库存,您可以联系我们找货
