CEE1C471MCB08A5
CEE1C471MCB08A5
    CHINSAN(金山)
    SMD
    470 µF 16 V 铝电解电容器 径向,Can - SMD 105°C 时为 5000 小时
CEE1C471MCB08A5 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ ALUMINUM ELECTROLYTIC CAPACITORS CEE Series  Extra Low impedance  Load life 2,000~5,000 hours at 105℃  SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 50 ~ 100Vdc Capacitance Range 3.3 ~ 470 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated Voltage (V) tanδ(Max) 50 63 80 100 ∅4~∅10 0.10 0.08 0.08 0.07 ∅12.5 0.10 0.08 0.08 0.07 (∅6.3~∅10) I=0.01CV or 3μA whichever is greater impress the rated voltage for 2 minutes. (∅12.5) I=0.03CV or 4μA whichever is greater impress the rated voltage for 1 minutes. I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V) Rated voltage (V) 50 63 80 100 Z(-25℃)/Z(+20℃) 2 2 2 2 Z(-55℃)/Z(+20℃) 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated voltage is applied for 5,000 hours (∅4~6.3x5.8, ∅6.3x7.7, ∅8x6.2 for 2,000 hours) at 105°C Endurance Capacitance change ≦ ±30% of the initial value Dissipation factor(tanδ) ≦ 300% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±30% of the initial value Dissipation factor(tanδ) ≦ 300% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W  DIMENSIONS (mm) Safety Vent (≧8×10.5) Code Size ФD L α A B C W P 0458 4×5.8 4 5.8 +0.4 -0.1 4.3 4.3 4.8 0.5~0.8 1 0558 5×5.8 5 5.8 +0.4 -0.1 5.3 5.3 5.8 0.5~0.8 1.3 6358 6.3×5.8 6.3 5.8 +0.4 -0.1 6.6 6.6 7.3 0.5~0.8 2.1 6377 6.3×7.7 6.3 7.7 ±0.3 6.6 6.6 7.3 0.5~0.8 2.1 0862 8×6.2 8 6.2 +0.4 -0.1 8.3 8.3 8.8 0.5~0.8 2.2 8 10.5 0.5 8.3 8.3 9.1 0.8~1.2 3.1 08A5 8×10.5 10A5 10C5 12D5 10×10.5 10×12.5 12.5×13.5 1216 12.5×16 10 10.5 0.5 10 12.5 0.5 12.5 13.5 1.0 10.3 10.3 11 0.8~1.2 4.6 10.3 10.3 11 0.8~1.2 4.6 12.8 12.8 13.8 0.8~1.2 4.6 12.5 12.8 12.8 13.8 0.8~1.2 4.6 16 1.0 ≦6.3Ф ≧8Ф Marking Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES CEE NO.: 1、Tape & Reel (TR)\ Cut Tape (CT)\ Digi-Reel。 2、Diagram of Dimensions (unit : mm.),and Recommended soldering pad dimensions。 Size Code ΦD L A B C W P α a b 0862 8 6.2 8.3 8.3 8.8 0.5~0.8 2.2 0.4/-0.1 08A5 8 10.5 8.3 8.3 9.1 0.8~1.2 3.1 1010 10 10.0 10.3 10.3 11.0 0.8~1.2 10A5 10 10.5 10.3 10.3 11.0 12D5 12.5 13.5 12.8 12.8 13.8 PUBLISH DATE 2022-03-28 c 0.5 2.1 3.0 10.1 11.0 1.6 2.5 4.6 0.5 4.0 12.0 2.5 0.8~1.2 4.6 0.5 4.0 12.0 2.5 0.8~1.2 4.6 1.0 4.0 15.4 3.0 Safety Vent (≥ 8x10.5) Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 CEE1A102MCB10A5 1000 Working ±20% (Vdc) 10 Surge Voltage (Vdc) Category Tanδ Leakage Temp @ 25℃ Current Range (120Hz) (uA) (℃) (Max) (2 min.) -55°C ~ 105°C 0.19 100 Rated Ripple Rated Ripple Current Current (mA rms) (mA rms) @ 105℃ @ 105℃ 120Hz 100kHz 850mA @ 100 kHz Impedance @20℃ (Ω max/ 100kHz) 0.09Ω Dimensions (mm) Endurance Appearance @ 105℃ (Hours) 5000 Hrs @ 105°C Drawing DΦ L 10.0mm 10.5mm a d P 4.6mm No Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 2 CEE1C471MCB08A5 470 ±20% 16 3 CEE1C681MCB1010F2M9 680 ±20% 16 4 CEE1E221MCB08A5F2 220 ±20% 25 5 CEE1E471MCB10A5 470 ±20% 25 6 CEE1E471MCB10A5F2 470 ±20% 25 7 CEE1H221MCB10A5 220 ±20% 50 8 CEE1J220MCB0862 22 ±20% 63 9 CEE1J221MCB12D5 220 ±20% 63 10 CEE1V331MCB10A5 330 ±20% 35 -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C 0.16 75.2 0.16 108.8 0.14 55 0.14 117.5 0.14 117.5 0.10 110 0.08 13.86 0.08 415.8 0.12 115.5 600mA @ 100 kHz 850mA @ 100 kHz 600mA @ 100 kHz 850mA @ 100 kHz 850mA @ 100 kHz 670mA @ 100 kHz 120mA @ 100 kHz 800mA @ 100 kHz 850mA @ 100 kHz 0.17Ω 0.09Ω 0.17Ω 0.09Ω 0.09Ω 0.18Ω 1.2Ω 0.16Ω 0.16Ω 5000 Hrs @ 105°C 2000 Hrs @ 105°C 2000 Hrs @ 105°C 5000 Hrs @ 105°C 2000 Hrs @ 105°C 5000 Hrs @ 105°C 2000 Hrs @ 105°C 5000 Hrs @ 105°C 5000 Hrs @ 105°C 8.0mm 10.5mm 3.1mm 10.0mm 10.0mm 4.6mm 8.0mm 10.5mm 3.1mm 10.0mm 10.5mm 4.6mm 10.0mm 10.5mm 4.6mm 10.0mm 10.5mm 4.6mm 8.0mm 6.2mm 2.2mm 12.5mm 13.5mm 4.6mm 10.0mm 10.5mm 4.6mm ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 李科高 张铭仁 聂婷
CEE1C471MCB08A5 价格&库存
很抱歉,暂时无法提供与“CEE1C471MCB08A5”相匹配的价格&库存,您可以联系我们找货
