CES1V221MCB08A5
CES1V221MCB08A5
    CHINSAN(金山)
    SMD
    220 µF 35 V 铝电解电容器 径向,Can - SMD 105°C 时为 2000 小时
CES1V221MCB08A5 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ ALUMINUM ELECTROLYTIC CAPACITORS CES Series  Low impedance  Load life 1,000 to 2,000 hours at 105℃  SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 6.3 ~ 50Vdc Capacitance Range 1 ~ 3,300 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Rated Voltage (V) Dissipation Factor (tanδ) (at 25℃, 120Hz) tanδ(Max) 6.3 10 16 25 35 50 ∅4~∅10 0.22 0.20 0.16 0.14 0.12 0.12 ∅12.5 0.26 0.22 0.18 0.16 0.14 0.12 The above values should be increased by 0.02 for every additional 1000μF Leakage Current (∅4~∅10) I=0.01CV or 3μA whichever is greater impress the rated voltage for 2 minutes. (∅12.5) I=0.03CV or 4μA whichever is greater impress the rated voltage for 1 minutes. I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V) Rated voltage (V) Low Temperature Characteristics Impedance Ratio(MAX) ∅4~∅10 ∅12.5 6.3 10 16 25 35 50 Z(-25℃)/Z(+20℃) 2 2 2 2 2 2 Z(-55℃)/Z(+20℃) 5 4 4 3 3 3 Z(-25℃)/Z(+20℃) 3 3 2 2 2 2 Z(-55℃)/Z(+20℃) 10 8 6 4 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated voltage is applied for 2,000 hours (∅4~6.3x5.8 for 1,000 hours) at 105°C Endurance Capacitance change ≦ ±20% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±20% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  DIMENSIONS (mm)  Safety Vent (≧8×10.5) Conforms to JIS-C-5101-4 (1998), characteristic W Code Size ФD L α A B C W P 4.3 4.3 4.8 0.5~0.8 1  Marking 0458 4×5.8 4 5.8 +0.4 -0.1 0558 5×5.8 5 5.8 +0.4 -0.1 5.3 5.3 5.8 0.5~0.8 1.3 ≦6.3Ф +0.4 -0.1 6.6 6.6 7.3 0.5~0.8 2.1 ≦6.3Ф 6358 6.3×5.8 6.3 5.8 6377 6.3×7.7 6.3 7.7 ±0.3 6.6 6.6 7.3 0.5~0.8 2.1 8.3 8.3 8.8 0.5~0.8 2.2 8.3 8.3 9.1 0.8~1.2 3.1 0862 8×6.2 8 6.2 +0.4 -0.1 08A5 8×10.5 8 10.5 0.5 10A5 10C5 12D5 10×10.5 10×12.5 12.5×13.5 10 10.5 10 12.5 12.5 13.5 0.5 1.0 10.3 10.3 11 0.8~1.2 4.6 10.3 10.3 11 0.8~1.2 4.6 12.8 12.8 13.8 0.8~1.2 4.6 1216 12.5×16 12.5 1.0 12.8 12.8 13.8 0.8~1.2 4.6 16 0.5 ≦6.3Ф ≧8Ф Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES CES NO.: PUBLISH DATE 2022-03-28 1、Tape & Reel (TR)\ Cut Tape (CT)\ Digi-Reel。 2、Diagram of Dimensions (unit : mm.),and Recommended soldering pad dimensions。 Size Code ΦD L A B C W P α a b c 6358 6.3 5.8 6.6 6.6 7.3 0.5~0.8 2.1 0.4/-0.1 2.1 9.1 1.6 08A5 8 10.5 8.3 8.3 9.1 0.8~1.2 3.1 0.5 3.0 11.0 2.5 Safety Vent (≥ 8x10.5) Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) 1 CES1C101MCB6358 100 ±20% 16 2 CES1V221MCB08A5 220 ±20% 35 Surge Voltage (Vdc) Category Tanδ Leakage Temp @ 25℃ Current Range (120Hz) (uA) (℃) (Max) (2 min.) 0.16 16 0.12 77 -55°C ~ 105°C -55°C ~ 105°C Rated Ripple Rated Ripple Current Current (mA rms) (mA rms) @ 105℃ @ 105℃ 120Hz 100kHz 140mA @ 100 kHz 450mA @ 100 kHz Impedance @20℃ (Ω max/ 100kHz) 1.0Ω 0.3Ω Dimensions (mm) Endurance Appearance @ 105℃ Drawing DΦ L 6.3mm P No 5.8mm 2.1mm --- 8.0mm 10.5mm 3.1mm (Hours) 1000 Hrs @ 105°C 2000 Hrs @ 125°C a d ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 李科高 张铭仁 聂婷
CES1V221MCB08A5 价格&库存
很抱歉,暂时无法提供与“CES1V221MCB08A5”相匹配的价格&库存,您可以联系我们找货
