CHJ1J221MCB12D5F2
CHJ1J221MCB12D5F2
    CHINSAN(金山)
    径向,Can-SMD
    220 µF 63 V 铝电解电容器 径向,Can - SMD 250 毫欧 @ 120Hz 125°C 时为 2000 小时
CHJ1J221MCB12D5F2 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ ALUMINUM ELECTROLYTIC CAPACITORS CHJ Series  High temperature at 125℃  Load life 1,000 to 5,000 hours  SPECIFICATIONS Item Performance Characteristics Category Temperature Range -40 ~ +125℃ Working Voltage Range 10 ~ 450Vdc Capacitance Range 3.3 ~1,000 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Rated Voltage (V) Dissipation Factor (tanδ) (at 25℃, 120Hz) tanδ(Max) 10 16 25 35 50 63 100 ∅6.3~∅10 0.24 0.20 0.16 0.14 0.14 0.18 0.18 160~250 400~450 - - ∅12.5 0.22 0.18 0.16 0.14 0.12 0.14 0.10 0.20 0.20 The above values should be increased by 0.02 for every additional 1000μF Leakage Current (10V~100V) I=0.03CV or 4μA whichever is greater impress the rated voltage for 2 minutes. (160V~450V) I=0.04CV+100μA whichever is greater impress the rated voltage for 2 minutes. I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V) Rated voltage (V) ∅6.3~∅10 Low Temperature Characteristics Impedance Ratio(MAX) ∅12.5 10 16 25 Z(-25℃)/Z(+20℃) 4 3 2 35~100 160~250 400~450 2 Z(-40℃)/Z(+20℃) 10 8 6 4 - - Z(-25℃)/Z(+20℃) 4 3 2 2 3 6 Z(-40℃)/Z(+20℃) 8 6 4 3 6 10 - - (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated voltage is applied for 5,000 hours ( ∅8x10.5~ ∅10 for 2,000 hours), ( ∅6.3 for 1,000 hours) at 125°C. Rated voltage is applied for 2,000hours (160~450V ,∅12.5) at 125°C. Endurance Capacitance change ≦ ±30% of the initial value Dissipation factor(tanδ) ≦ 300% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Shelf Life Capacitance change ≦ ±30% of the initial value Dissipation factor(tanδ) ≦ 300% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) Safety Vent (≧8×10.5) Code Size ФD L 𝜶 A B C 6358 6.3x5.8 6.3 5.8 +0.4 -0.1 6.6 6.6 7.3 0.5~0.8 2.1 6377 6.3x7.7 6.3 7.7 0.3 6.6 6.6 7.3 0.5~0.8 2.1 08A5 8x10.5 8 10.5 0.5 8.3 8.3 9.1 0.8~1.2 3.1 10A5 10x10.5 10 10.5 0.5 10.3 10.3 11.0 0.8~1.2 4.6 10C5 10x12.5 10 12.5 0.5 10.3 10.3 11.0 0.8~1.2 4.6 12D5 12.5x13.5 12.5 13.5 1.0 12.8 12.8 13.8 0.8~1.2 4.6 1216 12.5x16 12.5 12.8 12.8 13.8 0.8~1.2 4.6 16 1.0 W P  Marking ≦6.3Ф ≧8Ф Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES CHJ NO.: 2022-03-28 PUBLISH DATE 1、Tape & Reel (TR)/ Cut Tape (CT)/ Digi-Reel。 2、Diagram of Dimensions (unit : mm.),and Recommended soldering pad dimensions。 Size Code ΦD L A B C W P α a b c 12D5 12.5 13.5 12.8 12.8 13.8 0.8~1.2 4.6 1.0 4.0 15.4 3.0 Safety Vent (≥ 8x10.5) Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 CHJ1J221MCB12D5F2 220 Working ±20% (Vdc) 63 Surge Voltage (Vdc) Category Tanδ Leakage Temp @ 25℃ Current Range (120Hz) (uA) (℃) (Max) (2 min.) -40°C ~ 125°C 0.14 415.8 Rated Ripple Rated Ripple Current Current (mA rms) (mA rms) @ 125℃ @ 125℃ 120Hz 100kHz / 500 mA @ 100 kHz ESR @20℃ (Ω max/ 100kHz) 0.25Ω Dimensions (mm) Endurance Appearance @ 125℃ (Hours) 2000 Hrs @ 125°C Drawing DΦ L 12.5mm 13.5mm a d P No 4.6mm ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 李科高 张铭仁 聂婷
CHJ1J221MCB12D5F2 价格&库存
很抱歉,暂时无法提供与“CHJ1J221MCB12D5F2”相匹配的价格&库存,您可以联系我们找货
