CTB1C101MCB6358
CTB1C101MCB6358
    CHINSAN(金山)
    SMD
    100 µF 16 V 铝电解电容器 径向,Can - SMD 105°C 时为 1000 小时
CTB1C101MCB6358 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ ALUMINUM ELECTROLYTIC CAPACITORS CTB Series  Standard Series at 105℃  Load life 2,000 hours at 105℃  SPECIFICATIONS Item Performance Characteristics Category Temperature Range -40 ~ +105℃ 4 ~ 100Vdc Working Voltage Range Capacitance Range 0.1 ~ 6,800 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Rated Voltage (V) tanδ(Ma×) 4 6.3 10 16 25 35 50 63 100 ∅4 ~∅10 0.35 0.30 0.24 0.20 0.16 0.14 0.14 0.12 0.12 ∅12.5 0.42 0.38 0.34 0.30 0.26 0.22 0.18 0.14 0.12 The above values should be increased by 0.02 for every additional 1000μF Leakage Current (∅4~∅10) I=0.01CV or 3μA whichever is greater impress the rated voltage for 2 minutes. (∅12.5) I=0.03CV or 4μA whichever is greater impress the rated voltage for 1 minute. I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V) Rated voltage (V) Low Temperature Characteristics Impedance Ratio(MA×) ∅6.3~∅10 ∅12.5 4 6.3 10 16 25 35 50~63 100 Z(-25℃)/Z(+20℃) 7 4 3 2 2 2 2 3 Z(-40℃)/Z(+20℃) 15 8 6 4 4 3 3 4 Z(-25℃)/Z(+20℃) 7 5 4 3 2 2 2 2 Z(-40℃)/Z(+20℃) 17 12 10 8 5 4 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitor are restored to 25°C after subjected to DC voltage with the rated voltage is applied for 2,000 hours (∅4~6.3×5.8 for 1,000 hours) at 105°C Endurance Capacitance change Dissipation factor(tanδ) ≦ ±20% of the initial value (≦ ±30% of the initial value of 4V or less) Leakage current ≦ specified value ≦ 200% of the specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after e×posing them for 1,000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±20% of the initial value (≦ ±30% of the initial value of 4V or less) Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  DIMENSIONS (mm) Safety Vent (≧8×10.5) Conforms to JIS-C-5101-4 (1998), characteristic W Code Size ФD L α A B C W P 0458 4×5.8 4 5.8 +0.4 -0.1 4.3 4.3 4.8 0.5~0.8 1 5.3 5.3 5.8 0.5~0.8 1.3 0558 5×5.8 5 5.8 +0.4 -0.1 6358 6.3×5.8 6.3 5.8 +0.4 -0.1 6.6 6.6 7.3 0.5~0.8 2.1 6377 6.3×7.7 6.3 7.7 ±0.3 6.6 6.6 7.3 0.5~0.8 2.1 0862 8×6.2 8 6.2 +0.4 -0.1 8.3 8.3 8.8 0.5~0.8 2.2 08A5 8×10.5 8 10.5 0.5 8.3 8.3 9.1 0.8~1.2 3.1 10A5 10C5 10×10.5 10×12.5 10 10 10.5 0.5 12.5 0.5 10.3 10.3 10.3 10.3 11 11 0.8~1.2 4.6 0.8~1.2 4.6 12D5 12.5×13.5 1216 12.5×16 12.5 13.5 1.0 12.8 12.8 13.8 0.8~1.2 4.6 12.5 12.8 12.8 13.8 0.8~1.2 4.6 16 1.0  Marking ≦6.3Ф ≧8Ф Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES CTB NO.: 2022-03-28 PUBLISH DATE 1、Tape & Reel (TR)\ Cut Tape (CT)\ Digi-Reel。 2、Diagram of Dimensions (unit : mm.),and Recommended soldering pad dimensions。 Size Code ΦD L A B C W P α a b c 0458 4.0 5.8 4.3 4.3 5.0 0.5~0.8 1.0 0.4/-0.1 1.0 6.2 1.6 0558 5.0 5.8 5.3 5.3 5.9 0.5~0.8 1.5 0.4/-0.1 6358 6.3 5.8 6.6 6.6 7.3 0.5~0.8 2.1 0.4/-0.1 1.4 2.1 7.4 9.1 1.6 1.6 6377 6.3 7.7 6.6 6.6 7.3 0.5~0.8 2.1 0.3 2.1 9.1 1.6 10A5 10.0 10.5 10.3 10.3 11.0 0.8~1.2 4.6 0.5 4.0 12.0 2.5 Safety Vent (≥ 8x10.5) Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) 1 CTB0J221MCB6358 220 ±20% 6.3 2 CTB1A101MCB0558 100 ±20% 10 Surge Voltage (Vdc) Category Tanδ Leakage Temp @ 25℃ Current Range (120Hz) (uA) (℃) (Max) (2 min.) -55°C ~ 105°C -55°C ~ 105°C 0.30 13.9 0.24 10 Rated Ripple Rated Ripple Impedance Current Current (mA rms) (mA rms) @ 105℃ @ 105℃ 120Hz 100kHz 67mA @ 120Hz 39mA @ 120Hz / / / / @20℃ (Ω max/ 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ (Hours) 1000 Hrs @ 105°C 1000 Hrs @ 105°C Drawing DΦ L 6.3mm 5.8mm 2.1mm 5.0mm 5.8mm 1.5mm a d P No Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 3 CTB1A101MCB6358 100 ±20% 10 4 CTB1C100MCB0458 10 ±20% 16 5 CTB1C470MCB6358 47 ±20% 16 6 CTB1C101MCB6358 100 ±20% 16 7 CTB1E470MCB6358 47 ±20% 25 8 CTB1E101MCB6377 100 ±20% 25 9 CTB1E471MCB10A5 470 ±20% 25 10 CTB1V470MCB6358 47 ±20% 35 11 CTB1H100MCB0558 10 ±20% 50 -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C -55°C ~ 105°C 0.24 10 0.20 3 0.20 7.52 0.20 16 0.16 11.75 0.16 25 0.16 117.5 0.14 16.45 0.14 5 53mA @ 120Hz 18mA @ 120Hz 48mA @ 120Hz 60mA @ 120Hz 48mA @ 120Hz 91mA @ 120Hz 280mA @ 120Hz 50mA @ 120Hz 21mA @ 120Hz / / / / / / / / / / / / / / / / / / 1000 Hrs @ 105°C 1000 Hrs @ 105°C 1000 Hrs @ 105°C 1000 Hrs @ 105°C 1000 Hrs @ 105°C 2000 Hrs @ 105°C 2000 Hrs @ 105°C 1000 Hrs @ 105°C 1000 Hrs @ 105°C 6.3mm 5.8mm 2.1mm 4.0mm 5.8mm 1.0mm 6.3mm 5.8mm 2.1mm 6.3mm 5.8mm 2.1mm 6.3mm 5.8mm 2.1mm 6.3mm 7.7mm 2.1mm 10.0mm 10.5mm 4.6mm 6.3mm 5.8mm 2.1mm 5.0mm 5.8mm 1.5mm ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 李科高 张铭仁 聂婷
CTB1C101MCB6358 价格&库存
很抱歉,暂时无法提供与“CTB1C101MCB6358”相匹配的价格&库存,您可以联系我们找货
