Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
TEL: +886 2 2995 0535
http://www.chinsan.com/products/
ALUMINUM ELECTROLYTIC CAPACITORS
CTB
Series
Standard Series at 105℃
Load life 2,000 hours at 105℃
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-40 ~ +105℃
4 ~ 100Vdc
Working Voltage Range
Capacitance Range
0.1 ~ 6,800 μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Rated Voltage (V)
tanδ(Ma×)
4
6.3
10
16
25
35
50
63
100
∅4 ~∅10
0.35
0.30
0.24
0.20
0.16
0.14
0.14
0.12
0.12
∅12.5
0.42
0.38
0.34
0.30
0.26
0.22
0.18
0.14
0.12
The above values should be increased by 0.02 for every additional 1000μF
Leakage Current
(∅4~∅10) I=0.01CV or 3μA whichever is greater impress the rated voltage for 2 minutes.
(∅12.5) I=0.03CV or 4μA whichever is greater impress the rated voltage for 1 minute.
I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V)
Rated voltage (V)
Low Temperature Characteristics
Impedance Ratio(MA×)
∅6.3~∅10
∅12.5
4
6.3
10
16
25
35
50~63
100
Z(-25℃)/Z(+20℃)
7
4
3
2
2
2
2
3
Z(-40℃)/Z(+20℃)
15
8
6
4
4
3
3
4
Z(-25℃)/Z(+20℃)
7
5
4
3
2
2
2
2
Z(-40℃)/Z(+20℃)
17
12
10
8
5
4
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitor are restored to 25°C after subjected to DC voltage
with the rated voltage is applied for 2,000 hours (∅4~6.3×5.8 for 1,000 hours) at 105°C
Endurance
Capacitance change
Dissipation factor(tanδ)
≦ ±20% of the initial value (≦ ±30% of the initial value of 4V or less)
Leakage current
≦ specified value
≦ 200% of the specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after e×posing them for 1,000
hours at 105℃ without voltage applied.
Shelf Life
Capacitance change
Leakage current
Others
DIMENSIONS (mm)
Safety Vent (≧8×10.5)
Conforms to JIS-C-5101-4 (1998), characteristic W
Code
Size
ФD
L
α
A
B
C
W
P
0458
4×5.8
4
5.8
+0.4
-0.1
4.3
4.3
4.8
0.5~0.8
1
5.3
5.3
5.8
0.5~0.8 1.3
0558
5×5.8
5
5.8
+0.4
-0.1
6358
6.3×5.8
6.3
5.8
+0.4
-0.1
6.6
6.6
7.3
0.5~0.8 2.1
6377
6.3×7.7
6.3
7.7
±0.3
6.6
6.6
7.3
0.5~0.8 2.1
0862
8×6.2
8
6.2
+0.4
-0.1
8.3
8.3
8.8
0.5~0.8 2.2
08A5
8×10.5
8
10.5 0.5
8.3
8.3
9.1
0.8~1.2 3.1
10A5
10C5
10×10.5
10×12.5
10
10
10.5 0.5
12.5 0.5
10.3 10.3
10.3 10.3
11
11
0.8~1.2 4.6
0.8~1.2 4.6
12D5
12.5×13.5
1216
12.5×16
12.5 13.5 1.0
12.8 12.8 13.8 0.8~1.2 4.6
12.5
16
1.0
Marking
≦6.3Ф
≧8Ф
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
CTB
NO.:
2022-03-28
PUBLISH DATE
1、Tape & Reel (TR)\ Cut Tape (CT)\ Digi-Reel。
2、Diagram of Dimensions (unit : mm.),and Recommended soldering pad dimensions。
Size Code
ΦD
L
A
B
C
W
P
α
a
b
c
0458
4.0
5.8
4.3
4.3
5.0
0.5~0.8
1.0
0.4/-0.1
1.0
6.2
1.6
0558
5.0
5.8
5.3
5.3
5.9
0.5~0.8
1.5
0.4/-0.1
6358
6.3
5.8
6.6
6.6
7.3
0.5~0.8
2.1
0.4/-0.1
1.4
2.1
7.4
9.1
1.6
1.6
6377
6.3
7.7
6.6
6.6
7.3
0.5~0.8
2.1
0.3
2.1
9.1
1.6
10A5
10.0
10.5
10.3
10.3
11.0
0.8~1.2
4.6
0.5
4.0
12.0
2.5
Safety Vent (≥ 8x10.5)
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
On rated
Working
Capacitance Voltage
(Vdc)
1
CTB0J221MCB6358
220
±20%
6.3
2
CTB1A101MCB0558
100
±20%
10
Surge
Voltage
(Vdc)
Category
Tanδ
Leakage
Temp
@ 25℃
Current
Range
(120Hz)
(uA)
(Max)
(2 min.)
-55°C ~
105°C
-55°C ~
105°C
0.30
13.9
0.24
10
Rated Ripple Rated Ripple
Impedance
Current
Current
(mA rms)
(mA rms)
@ 105℃
@ 105℃
120Hz
100kHz
67mA
@ 120Hz
39mA
@ 120Hz
@20℃
(Ω max/
100kHz)
Dimensions (mm)
Endurance
Appearance
@ 105℃
(Hours)
1000 Hrs
@ 105°C
1000 Hrs
@ 105°C
Drawing
DΦ
L
6.3mm
5.8mm
2.1mm
5.0mm
5.8mm
1.5mm
a
d
P
No
3
CTB1A101MCB6358
100
±20%
10
4
CTB1C100MCB0458
10
±20%
16
5
CTB1C470MCB6358
47
±20%
16
6
CTB1C101MCB6358
100
±20%
16
7
CTB1E470MCB6358
47
±20%
25
8
CTB1E101MCB6377
100
±20%
25
9
CTB1E471MCB10A5
470
±20%
25
10 CTB1V470MCB6358
47
±20%
35
11 CTB1H100MCB0558
10
±20%
50
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
0.24
10
0.20
3
0.20
7.52
0.20
16
0.16
11.75
0.16
25
0.16
117.5
0.14
16.45
0.14
5
53mA
@ 120Hz
18mA
@ 120Hz
48mA
@ 120Hz
60mA
@ 120Hz
48mA
@ 120Hz
91mA
@ 120Hz
280mA
@ 120Hz
50mA
@ 120Hz
21mA
@ 120Hz
1000 Hrs
@ 105°C
1000 Hrs
@ 105°C
1000 Hrs
@ 105°C
1000 Hrs
@ 105°C
1000 Hrs
@ 105°C
2000 Hrs
@ 105°C
2000 Hrs
@ 105°C
1000 Hrs
@ 105°C
1000 Hrs
@ 105°C
6.3mm
5.8mm
2.1mm
4.0mm
5.8mm
1.0mm
6.3mm
5.8mm
2.1mm
6.3mm
5.8mm
2.1mm
6.3mm
5.8mm
2.1mm
6.3mm
7.7mm
2.1mm
10.0mm 10.5mm
4.6mm
6.3mm
5.8mm
2.1mm
5.0mm
5.8mm
1.5mm
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
李科高
张铭仁
聂婷
很抱歉,暂时无法提供与“CTB1V470MCB6358”相匹配的价格&库存,您可以联系我们找货
