PJ2W100MP51020R
PJ2W100MP51020R
    CHINSAN(金山)
    径向,Can
    10 µF 450 V 铝电解电容器 径向,Can 105°C 时为 8000 小时
PJ2W100MP51020R 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 PJ      Series For electronic ballast circuits and long life required applications High ripple current Load life: 8,000 to 10,000 hours at 105℃ SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25~ +105℃ Working Voltage Range 160 ~ 500Vdc Capacitance Range 10~560 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated Voltage (V) 160 200 250 400 450 500 tanδ(Max) 0.20 0.20 0.24 0.24 0.24 0.24 I=0.03CV + 10μA I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 160 ~250 400 420 ~ 450 500 Z(-25℃)/Z(+20℃) 3 5 6 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 10,000 ( 8,000 hours for Ф 10 ) hours at 105°C Endurance Shelf Life Capacitance change Dissipation factor(tanδ) ≦ ±20% of the initial value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 500% of the specified value Others  ≦ 200% of the specified value Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 10 12.5 ФD 18 0.6 0.8 0.8 7.5 7.5 Фd 0.6 F 5.0 5.0 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max a  P 16 ФD + 0.5 Max PART NUMBER SYSTEM( Example : 350V 150µF ) J 2 V 1 5 1 M N N 1 8 4 0 Special Request Size code(1840 : 18×40) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (150μF) Voltage code (350V) Series code (PJ) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PJ NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F No 1 PJ2W100MP51020R / 10 µF ±20% 450 V / -25~+105 / / 150 / / / 8000 10 20 / / 5 FIG-1 2 PJ2W101MNN1840 / 100 µF ±20% 450 V / -25~+105 / / 800 / 3620 / 10000 18 40 / / 7.5 Original ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PJ NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F No 1 PJ2W220MBD1620 / 22 µF ±20% 450 V / -25~+105 / / 290 / / / 10000 16 20 / / 7.5 FIG-1 2 PJ2W151MRT1845 / 150 µF ±20% 450 V / -25~+105 / / 1000 / / / 10000 18 45 / / 7.5 FIG-2 3 PJ2W121MRT1836 / 120 µF ±20% 450 V / -25~+105 / / 900 / / / 10000 18 36 / / 7.5 FIG-2 4 PJ2W121MRT1640AF8 / 120 µF ±20% 450 V / -25~+105 / / 800 / / / 8000 16 40 / / 7.5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. Suffix F8 indicates the life of the capacitor is 8000 hrs. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
PJ2W100MP51020R 价格&库存
很抱歉,暂时无法提供与“PJ2W100MP51020R”相匹配的价格&库存,您可以联系我们找货
