ED1V101MP26311U
ED1V101MP26311U
    CHINSAN(金山)
    插件
    100 µF 35 V 铝电解电容器 径向,Can 1.59 欧姆 @ 120Hz 105°C 时为 2000 小时
ED1V101MP26311U 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 ED Series  Suitable for use in high ripple current capability  Miniaturized, Low E.S.R and low impedance  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -40 ~ +105℃ Working Voltage Range 6.3 ~ 100Vdc Capacitance Range 10 ~10,000 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated Voltage (V) 6.3 10 16 25 35 50 63 100 tanδ(Max) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.08 The above values should be increased by 0.02 for every additional 1000μF I=0.01CV or 3μA whichever is greater I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for2 minutes V : Rated voltage (V) Rated voltage (V) 6.3 10 16 25 35 50 63 100 Z(-40℃)/Z(+20℃) 8 6 6 5 4 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000~5,000 hours at 105°C Endurance Shelf Life Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 5 6.3 8 10 ФD D 12.5 16 18 ФD + 0.5 Max Фd 0.5 0.5 0.6 0.6 0.6 0.8 0.8 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 a  E Life time (hours) 2,000 3,000 5,000 The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 500 hours at 105℃ without voltage applied. Capacitance change ≦ ±25% of the initial value Others  Size D×L ~ 8×12 8×16 ~ 10Ф 12.5Ф ~ 18Ф L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max PART NUMBER SYSTEM( Example : 25V 4700µF ) 1 E 4 7 2 M N N 1 6 4 0 Special Request Size code(1640 : 16×40) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (4700μF) Voltage code (25V) Series code (ED) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit(mm): Original P=12.7±1.0 P0=12.7±0.2 W =18.0±0.5 W0=12.5MIN P1=3.85±0.5 ΦD0=4.0±0.2 P2=6.35±1.0 F=2.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 ED1V220MPZ0511EU / 22 µF ±20% 35 V / -40~+105 / / 160 / 750 2000 5 11 / / 2.0 FIG-1 2 ED1H100MNN0511EU / 10 µF ±20% 50 V / -40~+105 / / 105 / 1450 2000 5 11 / / 2.0 Original ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1. Sleeve Color: Brown. 2. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8 /-0.2 ΦD0=4.0±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 450 1860 / 1590 1590 / / 200 200 220 120 220 220 650 300 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 2000 2000 2000 2000 2000 2000 2000 2000 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 11 11 11 11 11 11 11 11 / / / / / / / / / / / / / / / / 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 Original Original 100kHz 1 ED1A471MP26311EU 2 ED1C221MP26311U 3 ED1E101MP26311U 4 ED1E221MP26311U 5 ED1V101MP26311U 6 ED1V101MP26311UH 7 ED1H470MNN6311U 8 ED1H560MNN6311ERU / / / / / / / / 470 µF 220 µF 100 µF 220 µF 100 µF 100 µF 47 µF 56 µF ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% 10 V 16 V 25 V 25 V 35 V 35 V 50 V 50 V / / / / / / / / -40~+105 -40~+105 -40~+105 -40~+105 -40~+105 -40~+105 -40~+105 -40~+105 / / / / / / / / / / / / / / / / 674 410 370 500 385 385 220 385 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: 1. Sleeve Color: Brown. 2. Suffix U indicates convex rubber cover. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8 /-0.2 ΦD0=4.0±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 400 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 2000 6.3 15 / / 2.5 FIG-1 100kHz 1 ED1H101MP26315E / 100 µF ±20% 50 V / -40~+105 / / 560 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit (mm): Original P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 W1=9.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 220 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 2000 6.3 11 / / 5.0 FIG-1 100kHz 1 ED1A221MP56311EU / 220 µF ±20% 10 V / -40~+105 / / 340 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1. Sleeve Color: Brown. 2. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 W =18.0±0.5 F=3.5+0.8/-0.2 ΦD0=4.0±0.2 Original Tolerance No. Part No. Customer Capacitance Part No. (uF) t=0.7±0.2 FIG-1 Rated CHINSAN W0=12.5MIN On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 ED1C102MNN0820 / 1000 µF ±20% 16 V / -40~+105 / / 1300 / 50 3000 8 20 / / 3.5 Original 2 ED1C681MNN0820 / 680 µF ±20% 16 V / -40~+105 / / 1050 / 69 2000 8 20 / / 3.5 Original 3 ED1E221MNN0812 / 220 µF ±20% 25 V / -40~+105 / / 640 / 150 2000 8 12 / / 3.5 FIG-1 4 ED1C471MP308B5E / 470 µF ±20% 16 V / -40~+105 / / 1140 / 36 3000 8 11.5 / / 3.5 FIG-1 5 ED1A102MP30816 / 1000 µF ±20% 10 V / -40~+105 / / 920 / 85 3000 8 16 / / 3.5 FIG-1 6 ED1E331MP30816 / 330 µF ±20% 25 V / -40~+105 / / 840 / 86 3000 8 16 / / 3.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Brown. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 100kHz 1 ED1V221MP50812E / 220 µF ±20% 35 V / -40~+105 / / 750 / 87 2000 8 12 / / 5 FIG-1 2 ED1E471MP50816E / 470 µF ±20% 25 V / -40~+105 / / 1000 / 69 3000 8 16 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Brown. APPROVED BY CHECKED BY PREPARED BY Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 520 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 4000 8 11.5 / / 5 FIG-1 100kHz 1 ED2A330MP508B5F4RU / 33 µF ±20% 100 V / -40~+105 / / 724 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. 3.Suffix F4 indicates the life of the capacitor is 4000 hrs. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F1=5.0+0.8/-0.2 H=17.5±0.75 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H0=16.0±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 F=3.5±0.5 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 56 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 3000 8 16 / / 5 FIG-1 100kHz 1 ED1E471MPS0816 / 470 µF ±20% 25 V / -40~+105 / / 1600 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: FIG-1 FIG-2 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple Impedance Temp @ 25℃ Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ @ 105℃ 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 ED1A102MCD1012 / 1000 µF ±20% 10 V / -40~+105 / / 1100 40 3000 10 12 / / 5.0 FIG-1 2 ED1A222MNN1025 / 2200 µF ±20% 10 V / -40~+105 / / 1725 30 3000 10 25 / / 5.0 FIG-2 3 ED1C222MNN1025 / 2200 µF ±20% 16 V / -40~+105 / / 2200 52 3000 10 25 / / 5.0 FIG-2 4 ED1V471MNN1020 / 470 µF ±20% 35 V / -40~+105 / / 1400 40 3000 10 20 / / 5.0 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit (mm) P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0+0.2 F=5.0+0.8/-0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 ED1C222MP51025P9 / 2200 µF ±20% 16 V 2 ED1C332MP51030 / 3300 µF ±20% 3 ED1J221MP51016 / 220 µF 4 ED1J470MP51013E / 5 ED1K181MP51020 6 7 / -40~+105 / / 2200 / 30 3000 10 25 / / 5.0 FIG-1 16 V -40~+105 / / 2595 45 20 3000 10 30 / / 5.0 FIG-1 ±20% 63 V -40~+105 / / 390 / 200 3000 10 16 / / 5.0 FIG-1 47 µF ±20% 63 V -40~+105 / / 650 / 280 3000 10 13 / / 5.0 FIG-1 / 180 µF ±20% 80 V / -40~+105 / / 450 / 200 3000 10 20 / / 5.0 FIG-1 ED1V471MP51016 / 470 µF ±20% 35 V / -40~+105 / / 1350 / 50 3000 10 16 / / 5.0 FIG-1 ED1V471MP51020E / 470 µF ±20% 35 V / -40~+105 / / 1400 / 39 3000 10 20 / / 5.0 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: 1. Sleeve Color: Brown. 2.Suffix P9 : indicates Black PET sleeve. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0+0.2 F=5.0+0.8/-0.2 t=0.7±0.2 H1=9.5±1.0 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple Impedance Temp @ 25℃ Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ @ 105℃ 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 3000 10 20 / / 5.0 FIG-1 100kHz 1 ED1A222MP51020U / 2200 µF ±20% 10 V / -40~+105 / / 1300 45 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1. Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple Impedance Temp @ 25℃ Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ @ 105℃ 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 ED1C152MPN1020EP5 / 1500 µF ±20% 16 V / -40~+105 / / 2000 250 3000 10 20 / / 5.0 FIG-1 2 ED1E471MPN1012R / 470 µF ±20% 25 V / -40~+105 / / 1210 250 3000 10 12 / / 5.0 FIG-1 3 ED2A470MPN1013ER / 47 µF ±20% 100 V / -40~+105 / / 560 250 3000 10 13 / / 5.0 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1. Sleeve Color: Brown. 2. Suffix P5 : indicates Black PET sleeve. Aluminum Electrolytic Capacitor Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 Customer Digi-Key SERIES http://www.chinsan.com/products/ ED NO.: 2022-03-25 PUBLISH DATE Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) (uA) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 ED1V122MNN1620 / 1200 µF ±20% 35 V / -40~+105 / / 1647 130 65 5000 16 20 / / 7.5 --- 2 ED1J102MNN1632 / 1000 µF ±20% 63 V / -40~+105 / / 2320 / 33 5000 16 32 / / 7.5 --- 3 ED2A221MNN1620 / 220 µF ±20% 100 V / -40~+105 / / 850 / 150 5000 16 20 / / 7.5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Aluminum Electrolytic Capacitor Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Customer Digi-Key SERIES ED NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8/-0.2 ΦD0=4.0±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 ED1C101MP20511EP5U / 100 µF ±20% 16 V / -40~+105 / / 285 / 800 2000 5 11 / / 2.5 FIG-1 2 ED1E100MP20511U / 10 µF ±20% 25 V / -40~+105 / / 100 / 1200 2000 5 11 / / 2.5 FIG-1 3 ED1H010MP20511U / 1 µF ±20% 50 V / -40~+105 / / 40 / 3000 2000 5 11 / / 2.5 FIG-1 4 ED1H100MP20511ERU / 10 µF ±20% 50 V / -40~+105 / / 142 / 1280 2000 5 11 / / 2.5 FIG-1 5 ED1H100MP20511U / 10 µF ±20% 50 V / -40~+105 / / 105 13270 1400 2000 5 11 / / 2.5 FIG-1 6 ED1H220MP20511EP9U / 22 µF ±20% 50 V / -40~+105 / / 180 6030 750 2000 5 11 / / 2.5 FIG-1 7 ED1H2R2MP20511U / 2.2 µF ±20% 50 V / -40~+105 / / 45 10000 1300 2000 5 11 / / 2.5 FIG-1 8 ED1H4R7MP20511RU / 4.7 µF ±20% 50 V / -40~+105 / / 135 / 1020 2000 5 11 / / 2.5 FIG-1 9 ED1V100MP20511U / 10 µF ±20% 35 V / -40~+105 / / 100 / 1500 2000 5 11 / / 2.5 FIG-1 10 ED2A4R7MP20511U / 4.7 µF ±20% 100 V / -40~+105 / / 40 / 2100 2000 5 11 / / 2.5 FIG-1 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. 1. 2. 3. 4. REMARKS: Sleeve Color: Brown. Suffix P5 : indicates Black PET sleeve. Suffix P9 : indicates Black PET sleeve. Suffix U indicates convex rubber cover. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
ED1V101MP26311U
1. 物料型号:文档列出了多种不同型号的电容器,包括它们的容量、额定工作电压、工作温度范围等。
2. 器件简介:ED系列电容器适用于高纹波电流能力的应用场景,具有小型化、低等效串联电阻(ESR)和低阻抗的特点。
3. 引脚分配:文档中未明确提供引脚分配图,但通常铝电解电容器有正负两个引脚。
4. 参数特性: - 工作电压范围:6.3V至100V - 电容范围:10μF至10,000μF - 电容公差:+20%(25°C和120Hz时) - 损耗角正切(tanδ):根据额定电压不同,25°C和120Hz时的最大值从0.08至0.22不等 - 漏电流:根据电容器的额定容量和电压确定
5. 功能详解:电容器设计用于在高温下保持稳定的性能,具有较长的寿命和耐久性。
6. 应用信息:适用于需要高纹波电流能力的场合,如电源滤波等。
7. 封装信息:提供了详细的尺寸信息,包括电容器的直径(D)、长度(L)、引脚长度(a)等。
ED1V101MP26311U 价格&库存
很抱歉,暂时无法提供与“ED1V101MP26311U”相匹配的价格&库存,您可以联系我们找货
