EG1V560MNN6311U
EG1V560MNN6311U
    CHINSAN(金山)
    Radial, Can
    ALUMINUM ELECTROLYTIC CAPACITORS
EG1V560MNN6311U 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 EG Series  Low impedance and High ripple current  Load life 3,000 to 6,000 hours at 105℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -55~ +105℃ Working Voltage Range 6.3 ~ 63Vdc Capacitance Range 10 ~10,000μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Endurance Rated Voltage (V) 6.3 10 16 25 35 50 63 tanδ(Max) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 The above values should be increased by 0.02 for every additional 1000μF I=0.01CV or 3μA whichever is greater I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 6.3 10 16 25 35 50 63 Z(-55℃)/Z(+20℃) 4 3 3 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 3,000~6,000 hours at 105°C Size Life time (hours) ≦ ±25% of the initial value Capacitance change ≦ 6.3Ф 3,000 =8Ф 4,000 Dissipation factor(tanδ) ≦ 200% of the specified value = 10Ф 5,000 Leakage current ≦ specified value ≧12.5Ф 6,000 The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 5 6.3 8 10 ФD Фd 0.5 F a  E 12.5 16 18 ФD + 0.5 Max 2.0 0.5 0.6 0.6 0.6 0.8 0.8 2.5 3.5 5.0 5.0 7.5 7.5 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max PART NUMBER SYSTEM( Example : 35V 3900µF ) G 1 V 3 9 2 M N N 1 8 4 0 Special Request Size code(1840 : 18×40) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (3900μF) Voltage code (35V) Series code (EG) L +1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EG NO.: FIG-2 FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EG1C100MNN0511U / 10 µF ±20% 16 V / -55~+105 / / 50 / 2500 3000 5 11 / / 2.0 FIG-2 2 EG1E4R7MNN0511U / 4.7 µF ±20% 25 V / -55~+105 / / 120 / 1200 3000 5 11 / / 2.0 FIG-2 3 EG1E101MNN6311U / 100 µF ±20% 25 V / -55~+105 / / 340 / 250 3000 6.3 11 / / 2.5 FIG-2 4 EG1V560MNN6311U / 56 µF ±20% 35 V / -55~+105 / / 230 / 770 3000 6.3 11 / / 2.5 FIG-2 5 EG1H470MNN6311U / 47 µF ±20% 50 V / -55~+105 / / 220 / 400 3000 6.3 11 / / 2.5 FIG-2 6 EG1V221MNN0816 / 220 µF ±20% 35 V / -55~+105 / / 840 / 130 4000 8 16 / / 3.5 FIG-1 7 EG1J471MNN1225EF7 / 470 µF ±20% 63 V / -55~+105 / / 1720 / 70 7000 12.5 25 / / 5 FIG-1 8 EG1E222MNN1625EF8 / 2200 µF ±20% 25 V / -55~+105 / / 2555 / 22 8000 16 25 / / 7.5 FIG-1 9 EG1V182MNN1625EF8 / 1800 µF ±20% 35 V / -55~+105 / / 3080 / 22 8000 16 25 / / 7.5 FIG-1 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 10 EG1H102MNN1625EF8 / 1000 µF ±20% 50 V / -55~+105 / / 2555 / 34 8000 16 25 / / 7.5 FIG-1 11 EG1H222MNN18P1EF8 / 2200 µF ±20% 50 V / -55~+105 / / 3100 / 23 8000 18 35.5 / / 7.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. 3.Suffix F7 indicates the life of the capacitor is 7000 hrs. 4.Suffix F8 indicates the life of the capacitor is 8000 hrs. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EG NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 W1=9.0±0.5 W0=12.5MIN Φd=0.5±0.05 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 F=2.5+0.8/-0.2 ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EG1C470MP20511U / 47 µF ±20% 16 V / -55~+105 / / 120 / 900 3000 5 11 / / 2.5 FIG-1 2 EG1H100MP20511EU / 10 µF ±20% 50 V / -55~+105 / / 105 / 1500 3000 5 11 / / 2.5 FIG-1 3 EG1H4R7MP20511EU / 4.7 µF ±20% 50 V / -55~+105 / / 70 / 1500 3000 5 11 / / 2.5 FIG-1 4 EG1H220MP20511U / 22 µF ±20% 50 V / -55~+105 / / 180 / 1200 3000 5 11 / / 2.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EG NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F1=5.0+0.8/-0.2 t=0.7±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H0=16.0±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 H=18.5±0.5 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 680 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 4000 8 12 / / 5 FIG-1 100kHz 1 EG2A330MP50812ERSU / 33 µF ±20% 100 V / -55~+105 / / 724 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EG NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / / Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 5000 8 16 / / 5 FIG-1 100kHz 1 EG1H121MP50816F5 / 120 µF ±20% 50 V / -55~+105 / / 690 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. 3.Suffix F5 indicates the life of the capacitor is 5000 hrs. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EG NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 t=0.7±0.2 H=18.5±0.5 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 1450 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 3000 5 11 / / 5 FIG-1 100kHz 1 EG1H100MPN0511U / 10 µF ±20% 50 V / -55~+105 / / 115 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EG NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 70 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 5000 10 20 / / 5 FIG-1 100kHz 1 EG1E681MPN1020E / 680 µF ±20% 25 V / -55~+105 / / 1400 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown.
EG1V560MNN6311U
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器,适用于多种嵌入式应用。
2. 器件简介:该器件具备高性能、低成本、低功耗等特点,适用于需要复杂控制和处理的应用场景,如工业控制、消费电子和物联网等。
3. 引脚分配:该器件共有48个引脚,包括电源引脚、地引脚、I/O引脚、复位引脚等,具体分配需参考数据手册。
4. 参数特性:工作电压范围为2.0V至3.6V,工作频率可达72MHz,具备多种外设接口如USB、CAN、I2C等。
5. 功能详解:详细介绍了各外设模块的功能和使用方法,如GPIO、ADC、定时器、通信接口等。
6. 应用信息:适用于需要高性能处理和复杂控制的嵌入式系统,如工业自动化、智能家电、医疗设备等。
EG1V560MNN6311U 价格&库存
很抱歉,暂时无法提供与“EG1V560MNN6311U”相匹配的价格&库存,您可以联系我们找货
