EJ1E221MLT0812UR
EJ1E221MLT0812UR
    CHINSAN(金山)
    插件
    ALUMINUM ELECTROLYTIC CAPACITORS
EJ1E221MLT0812UR 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 EJ Series  Low impedance and High ripple current  Load life 3,000 to 5,000 hours at 105℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -55~ +105℃ Working Voltage Range 6.3 ~ 63Vdc Capacitance Range 10 ~10,000μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Endurance Rated Voltage (V) 6.3 10 16 25 35 50 63 tanδ(Max) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 The above values should be increased by 0.02 for every additional 1000μF I=0.01CV or 3μA whichever is greater I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 6.3 10 16 25 35 50 63 Z(-55℃)/Z(+20℃) 4 3 3 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 3,000~5,000 hours at 105°C Size Life time (hours) ≦ ±25% of the initial value Capacitance change ≦ 6.3Ф 3,000 Dissipation factor(tanδ) ≦ 200% of the specified value =8Ф 4,000 Leakage current ≦ specified value ≧10 Ф 5,000 The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current Others  ≦ 200% of the specified value Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 5 6.3 8 10 ФD Фd 0.5 F a  E 12.5 16 18 0.6 0.8 0.8 5.0 7.5 7.5 ФD + 0.5 Max 2.0 0.5 0.6 0.6 2.5 3.5 5.0 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max PART NUMBER SYSTEM( Example : 6.3V 10000µF ) J 0 J 1 0 3 M N N 1 6 P 1 Special Request Size code(16P1 : 16×35.5) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (10000μF) Voltage code (6.3V) Series code (EJ) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EJ NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8/-0.2 ΦD0=4.0±0.2 Original FIG-1 Tolerance No. CHINSAN Customer Capacitance Part No. Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple Impedance Temp @ 25℃ Current Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ @ 105℃ @ 105℃ 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 EJ1E470MP20511EF2U / 47 µF ±20% 25 V / -55~+105 / / / 210 1000 2000 5 11 / / 2.5 FIG-1 2 EJ1C470MP20511EU / 47 µF ±20% 16 V / -55~+105 / / / 155 900 3000 5 11 / / 2.5 FIG-1 3 EJ1H100MP20511U / 10 µF ±20% 50 V / -55~+105 / / / 140 1800 3000 5 11 / / 2.5 FIG-1 4 EJ1C470MP20511U / 47 µF ±20% 16 V / -55~+105 / / / 155 800 3000 5 11 / / 2.5 FIG-1 5 EJ1V330MNN0511U / 33 µF ±20% 35 V / -55~+105 / / / 210 1200 3000 5 11 / / 2 Original ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. 3. Suffix F2 indicates the life of the capacitor is 2000 hrs. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EJ NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8 /-0.2 ΦD0=4.0±0.2 Original FIG-1 Tolerance No. CHINSAN Customer Capacitance Part No. Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple Impedance Temp @ 25℃ Current Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ @ 105℃ @ 105℃ 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 120Hz 100kHz 1 EJ1E101MP26311U / 100 µF ±20% 25 V / -55~+105 / / 170 340 850 3000 6.3 11 / / 2.5 FIG-1 2 EJ1C101MP26311RU / 100 µF ±20% 16 V / -55~+105 / / / 265 / 3000 6.3 11 / / 2.5 FIG-1 3 EJ1V101MP26311P9U / 100 µF ±20% 35 V / -55~+105 / / / 300 550 3000 6.3 11 / / 2.5 FIG-1 4 EJ1V151MP26311U / 150 µF ±20% 35 V / -55~+105 / / / 450 350 3000 6.3 11 / / 2.5 FIG-1 5 EJ1E101MNN6311U / 100 µF ±20% 25 V / -55~+105 / / / 340 850 3000 6.3 11 / / 2.5 Original ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: 1.Sleeve Color: Brown. 2.Suffix P9 : indicates Black PET sleeve. 3.Suffix U indicates convex rubber cover. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EJ NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 W =18.0±0.5 F=3.5+0.8/-0.2 W0=12.5MIN ΦD0=4.0±0.2 Φd=0.6 ±0.05 t=0.7±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple Impedance Temp @ 25℃ Current Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ @ 105℃ @ 105℃ 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 EJ1H101MP30812 / 100 µF ±20% 50 V / -55~+105 / / / 555 250 4000 8 12 / / 3.5 FIG-1 2 EJ1V101MNN0812ER / 100 µF ±20% 35 V / -55~+105 / / / 445 170 4000 8 12 / / 3.5 Original ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 EJ1E221MLT0812UR / 220 µF Working ±20% (Vdc) 25 V Surge Voltage (Vdc) / EJ NO.: Rated Rated Category Tanδ Leakage Ripple Ripple Impedance Temp @ 25℃ Current Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -55~+105 / (mA rms) (mA rms) (mΩ max/ @ 105℃ @ 105℃ / 2022-03-25 PUBLISH DATE 120Hz 100kHz / 730 100kHz) 1300 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 4000 8 12 / / 3.5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EJ NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0+0.2 F=5.0+0.8/-0.2 t=0.7±0.2 H1=9.5±1.0 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple Impedance Temp @ 25℃ Current Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ @ 105℃ @ 105℃ 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 EJ1V331MP51016F4U / 330 µF ±20% 35 V / -55~+105 / / / 1210 60 4000 10 16 / / 5 FIG-1 2 EJ1C681MP51016U / 680 µF ±20% 16 V / -55~+105 / / / 1200 68 5000 10 16 / / 5 FIG-1 3 EJ1H221MP51013RU / 220 µF ±20% 50 V / -55~+105 / / / 950 130 5000 10 13 / / 5 FIG-1 4 EJ1H470MP51009U / 47 µF ±20% 50 V / -55~+105 / / / 520 500 5000 10 9 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EJ NO.: 2022-03-25 PUBLISH DATE Unit (mm) P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated EJ1V102MPH1025 / 1000 µF Working Capacitance Voltage (%) 1 H=20.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0+0.2 t=0.7±0.2 ±20% (Vdc) 35 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple Impedance Temp @ 25℃ Current Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -55~+105 / (mA rms) (mA rms) (mΩ max/ @ 105℃ @ 105℃ / 120Hz 100kHz / 2400 100kHz) 38 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 5000 10 25 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EJ NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 H1=9.5±1.0 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated EJ1J101MPN1012RU / 100 µF Working Capacitance Voltage (%) 1 H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0+0.2 t=0.7±0.2 ±20% (Vdc) 63 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple Impedance Temp @ 25℃ Current Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -55~+105 / (mA rms) (mA rms) (mΩ max/ @ 105℃ @ 105℃ / 120Hz 100kHz / 800 100kHz) 430 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 5000 10 12 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EJ NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) 1 EJ1C102MPN1016RF6P / 1000 µF H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 ±20% (Vdc) 16 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple Impedance Temp @ 25℃ Current Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -55~+105 / (mA rms) (mA rms) (mΩ max/ @ 105℃ @ 105℃ / 120Hz 100kHz / 1750 100kHz) 65 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 6000 10 16 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1.Sleeve Color: Brown. 2.Suffix P : indicates PET sleeve. 3.Suffix F6 indicates the life of the capacitor is 6000 hrs. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EJ NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple Impedance Temp @ 25℃ Current Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ @ 105℃ @ 105℃ 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 EJ1J471MNN1230ERU / 470 µF ±20% 63 V / -55~+105 / / / 2250 39 5000 12.5 30 / / 5 FIG-2 2 EJ1C332MNN1235 / 3300 µF ±20% 16 V / -55~+105 / / / 2880 35 5000 12.5 35 / / 5 FIG-1 3 EJ1J681MNN1240 / 680 µF ±20% 63 V / -55~+105 / / / 1180 70 5000 12.5 40 / / 5 FIG-1 4 EJ1H102MNN1640E / 1000 µF ±20% 50 V / -55~+105 / / / 1780 27 5000 16 40 / / 7.5 FIG-1 5 EJ1V102MNN1620 / 1000 µF ±20% 35 V / -55~+105 / / / 2230 27 5000 16 20 / / 7.5 FIG-1 6 EJ1H821MNN1820 / 820 µF ±20% 50 V / -55~+105 / / / 2150 36 5000 18 20 / / 7.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EJ NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Customer Capacitance Part No. Part No. (uF) On rated EJ1C102MP51016ER EJ1C222MP51025E EJ1C471MP51012 EJ1E471MP51016 EJ1V152MNN1040 EJ1V471MNN1020 EJ1V221MP51012 EJ1H101MP51016 EJ2A271MNN1040 / / / / / / / / / 1000 µF 2200 µF 470 µF 470 µF 1500 µF 470 µF 220 µF 100 µF 270 µF Working Capacitance Voltage (%) 1 2 3 4 5 6 7 8 9 H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% (Vdc) 16 V 16 V 16 V 25 V 35 V 35 V 35 V 50 V 100 V Surge Voltage (Vdc) / / / / / / / / / Rated Rated Category Tanδ Leakage Ripple Ripple Impedance Temp @ 25℃ Current Current Current @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -40~+105 -55~+105 -55~+105 -55~+105 -55~+105 -55~+105 -55~+105 -55~+105 -55~+105 / / / / / / / / / (mA rms) (mA rms) (mΩ max/ @ 105℃ @ 105℃ / / / / / / / / / 120Hz 100kHz / / / / / / / / / 1300 2100 840 1210 2880 1400 1060 707 2000 100kHz) 30 27 / 60 60 150 250 900 200 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 5000 5000 5000 5000 5000 5000 5000 5000 5000 10 10 10 10 10 10 10 10 10 16 25 12 16 40 20 12 16 40 / / / / / / / / / / / / / / / / / / 5 5 5 5 5 5 5 5 5 FIG-1 FIG-1 FIG-1 FIG-1 Original Original FIG-1 FIG-1 Original ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Brown. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
EJ1E221MLT0812UR 价格&库存
很抱歉,暂时无法提供与“EJ1E221MLT0812UR”相匹配的价格&库存,您可以联系我们找货
