EM1H100MP26307F2P9U
EM1H100MP26307F2P9U
    CHINSAN(金山)
    插件
    10 µF 50 V 铝电解电容器 径向,Can 105°C 时为 2000 小时
EM1H100MP26307F2P9U 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 EM Series  Low impedance, high ripple current and miniature size with 7 to 9 mm height  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -40 ~ +105℃ Working Voltage Range 6.3 ~ 35Vdc Capacitance Range 33 ~ 470 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated Voltage (V) 6.3 10 16 25 30 35 tanδ(Max) 0.24 0.20 0.16 0.14 0.14 0.14 I=0.01CV or 3 μA, whichever is greater I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 6.3 10 16 25 30 35 Z(-40℃)/Z(+20℃) 8 6 6 5 4 4 (at 120Hz) The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000~2,000 hours at 105℃. Endurance Size Life time (hours) Dissipation factor(tanδ) ≦ ±25% of the initial value (6.3V、10V:≦±30%) ≦ 200% of the specified value ≦6.3Ф 1,000 Leakage current ≦ specified value ≧8Ф 2,000 Capacitance change The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 500 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±25% of the initial value (6.3V、10V:≦±30%) Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current Others  ≦ 200% of the specified value Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD ФD Фd  E M 8 ×7 8 ×9 ФD + 0.5 Max 0.45 0.50 F 3.5 a L + 1.0 Max PART NUMBER SYSTEM( Example : 25V 220µF ) 1 E 2 2 1 M N N 0 8 0 9 Special Request Size code(0809 : 8×9) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (220μF) Voltage code (25V) Series code (EM) Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EM NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8 /-0.2 ΦD0=4.0±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EM1H100MP26307F2P9U / 10 µF ±20% 50 V / -40~+105 / / 105 / 3500 2000 6.3 7 / / 2.5 FIG-1 2 EM1H220MP26307F2P9U / 22 µF ±20% 50 V / -40~+105 / / 150 / 2000 2000 6.3 7 / / 2.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: 1.Suffix P9 : indicates Black PET sleeve. 2.Suffix F2 indicates the life of the capacitor is 2000 hrs. 3. Suffix U indicates convex rubber cover. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EM NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 W=18.0±0.5 F=3.5+0.8/-0.2 W0=12.5MIN ΦD0=4.0±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 120 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 2000 8 9 / / 3.5 FIG-1 100kHz 1 EM1C331MP30809 / 330 µF ±20% 16 V / -40~+105 / / 550 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EM NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0+0.2 F=5.0+0.8/-0.2 t=0.7±0.2 H1=9.5±1.0 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 300 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 2000 10 9 / / 5 FIG-1 100kHz 1 EM1V101MP51009U / 100 µF ±20% 35 V / -40~+105 / / 350 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 1.Sleeve Color: Brown. 2.Suffix U indicates convex rubber cover.
EM1H100MP26307F2P9U 价格&库存
很抱歉,暂时无法提供与“EM1H100MP26307F2P9U”相匹配的价格&库存,您可以联系我们找货
