Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
http://www.chinsan.com/products/
TEL: +886 2 2995 0535
EP
Series
Miniaturized, Low ESR and Low impedance
Suitable for use in high ripple current capability
Load life 4,000 hours at 105℃
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
-40 ~ +105℃
Working Voltage Range
10 ~ 100Vdc
Capacitance Range
68 ~1,800 μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Rated Voltage (V)
10
16
25
35
100
tanδ(Max)
0.19
0.16
0.14
0.12
0.08
The above values should be increased by 0.02 for every additional 1000μF
I=0.01CV or 3μA whichever is greater
I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V)
Impress the rated voltage for2 minutes
Rated voltage (V)
10
16
25
35
100
Z(-40℃)/Z(+20℃)
6
6
5
4
3
(at 120Hz)
The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for
4,000 hours at 105℃.
Endurance
Capacitance change
≦ ±25% of the initial value
Dissipation factor(tanδ)
≦ 200% of the specified value
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 500
hours at 105℃ without voltage applied.
Shelf Life
Capacitance change
Dissipation factor(tanδ )
Leakage current
Others
DIMENSIONS (mm)
E
Conforms to JIS-C-5101-4 (1998), characteristic W
ФD
12.5×12
ФD
ФD + 0.5 Max
Фd
0.6
F
5.0
a
L + 1.0 Max
PART NUMBER SYSTEM( Example : 35V 470µF )
P
1 V 4 7 1 M N N 1 2
1 2
Special Request
Size code(1212 : 12.5×12)
Lead length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (470μF)
Voltage code (35V)
Series code (EP)
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
EP
NO.:
Rated
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
2022-03-25
PUBLISH DATE
Category
Tanδ
Leakage
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
(2 min.)
(mA rms) (mΩ max/ (mΩ max/
@ 105℃
120Hz)
100kHz)
Dimensions (mm)
Endurance
Appearance
@ 105℃
Drawing
(Hours)
DΦ
L
a
d
F
No
100kHz
1
EP1C102MNN1212
1000 µF
±20%
16 V
-40~+105
1300
150
4000
12.5
12
5
2
EP1E102MNN1216
1000 µF
±20%
25 V
-40~+105
1450
110
4000
12.5
16
5
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Sleeve Color: Brown.
很抱歉,暂时无法提供与“EP1C102MNN1212”相匹配的价格&库存,您可以联系我们找货
