EY1V222HCG1625E
EY1V222HCG1625E
    CHINSAN(金山)
    插件
    2200 µF 35 V 铝电解电容器 径向,Can 105°C 时为 10000 小时
EY1V222HCG1625E 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 EY http://www.chinsan.com/products/ Series  Miniaturized, Low E.S.R and Low impedance  Suitable for use in high ripple current capability  Load life 4,000~10,000 hours at 105℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -55~ +105℃ Working Voltage Range 6.3 ~ 100Vdc Capacitance Range 6.8 ~18,000μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Endurance Rated Voltage (V) 6.3 10 16 25 35 50 63 100 tanδ(Max) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.08 The above values should be increased by 0.02 for every additional 1000μF I=0.01CV or 3μA whichever is greater \The above values should be increased by 0.02 for every additional 1000μF I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V) Impress the rated voltage for 2 minutes Rated voltage (V) 6.3 10 16 25 35 50 63 100 Z(-55℃)/Z(+20℃) 4 3 3 3 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 4,000~10,000 hours at 105°C Life time (hours) ≦ ±25% of the initial value Capacitance change Size (6.3~10WV) (16~100WV) Dissipation factor(tanδ) ≦200% of the specified value ≦ 6.3 Ф 4,000 5,000 8 ~ 10 Ф 6,000 7,000 Leakage current ≦ specified value ≧12.5Ф 8,000 10,000 The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 5 6.3 8 ФD Y 12.5 16 18 ФD + 0.5 Max Фd 0.5 0.5 0.6 0.6 0.6 0.8 0.8 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 a  E 10 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max PART NUMBER SYSTEM( Example : 10V 5600µF ) 1 A 5 6 2 M N N 1 8 2 0 Special Request Size code(1820 : 18×20) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (5600μF) Voltage code (10V) Series code (EY) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: FIG-1 FIG-2 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EY2A391MNN1240 / 390 µF ±20% 100 V / -55~+105 / / 2340 / 65 10000 12.5 40 / / 5 FIG-1 2 EY2A471MNN16P1 / 470 µF ±20% 100 V / -55~+105 / / 2400 / 45 10000 16 35.5 / / 7.5 FIG-1 3 EY3A102MNN1850M / 1000 µF ±20% 120 V / -40~+105 / / 2400 / 70 10000 18 50 / / 7.5 FIG-1 4 EY1C152MNN1016 / 1500 µF ±20% 16 V / -55~+105 / / 1500 / 80 7000 10 16 / / 5 FIG-1 5 EY1C152MNN1220 / 1500 µF ±20% 16 V / -55~+105 / / 1910 / 65 10000 12.5 20 / / 5 FIG-1 6 EY1C681MNN0820 / 680 µF ±20% 16 V / -55~+105 / / 1330 / 140 7000 8 20 / / 3.5 FIG-1 7 EY1E102MNN1020 / 1000 µF ±20% 25 V / -55~+105 / / 1710 / 78 7000 10 20 / / 5 FIG-1 8 EY1E102MNN1616E / 1000 µF ±20% 25 V / -55~+105 / / 1940 / 42 10000 16 16 / / 7.5 FIG-1 9 EY1E222MNN1225 / 2200 µF ±20% 25 V / -55~+105 / / 2700 / 57 10000 12.5 25 / / 5 FIG-1 10 EY1E562MNN1635 / 5600 µF ±20% 25 V / -55~+105 / / 4000 / 26 10000 16 35 / / 7.5 FIG-1 11 EY1E222MNN1620E / 2200 µF ±20% 25 V / -40~+105 / / 3450 / 15 10000 16 20 / / 7.5 FIG-1 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 12 EY1V102MNN1818E / 1000 µF ±20% 35 V / -55~+105 / / 2150 / 43 10000 18 18 / / 7.5 FIG-1 13 EY1V470MNN0816 / 47 µF ±20% 35 V / -55~+105 / / 310 / 45 7000 8 16 / / 3.5 FIG-1 14 EY1V681MNN1220F7 / 680 µF ±20% 35 V / -55~+105 / / 1910 / 72 7000 12.5 20 / / 5 FIG-1 15 EY1V332MNN1836 / 3300 µF ±20% 35 V / -55~+105 / / 4220 70 25 10000 18 36 / / 7.5 FIG-1 16 EY1V222MNN1625 / 2200 µF ±20% 35 V / -55~+105 / / 1900 / 42 10000 16 25 / / 7.5 FIG-1 17 EY1V392MNN1840F8 / 3900 µF ±20% 35 V / -55~+105 / / 4000 120 8000 18 40 / / 7.5 FIG-1 18 EY1V101MNN6311EP5U / 100 µF ±20% 35 V / -55~+105 / / 450 / 550 5000 6.3 11 / / 2.5 FIG-2 19 EY1H102MNN1820 / 1000 µF ±20% 50 V / -55~+105 / / 2600 / 36 10000 18 20 / / 7.5 FIG-1 20 EY1H222MNN18P1E / 2200 µF ±20% 50 V / -55~+105 / / 3800 / 20 10000 18 35.5 / / 7.5 FIG-1 21 EY1H332MNN1840E / 3300 µF ±20% 50 V / -55~+105 / / 4850 / 20 10000 18 40 / / 7.5 FIG-1 22 EY1J221MNN1016F6 / 220 µF ±20% 63 V / -55~+105 / / 998 / 110 6000 10 16 / / 5 FIG-1 23 EY1J122MNN1825ER / 1200 µF ±20% 63 V / -40~+105 / / 2930 / 30 10000 18 25 / / 7.5 FIG-1 24 EY1J332MNN1840EF8R / 3300 µF ±20% 63 V / -55~+105 / / 4300 / 20 8000 18 40 / / 7.5 FIG-1 25 EY1K152MNN18P1EM / 1500 µF ±20% 80 V / -40~+105 / / 3510 / 28 10000 18 35.5 / / 7.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Brown. Suffix F6 indicates the life of the capacitor is 6000 hrs. Suffix F7 indicates the life of the capacitor is 7000 hrs. Suffix F8 indicates the life of the capacitor is 8000 hrs. Suffix P5 : indicates Black PET sleeve. Suffix U indicates convex rubber cover. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: FIG-2 FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EY1C102MCC0820EP9 / 1000 µF ±20% 16 V / -40~+105 / / 1500 / 29 7000 8 20 / / 3.5 FIG-1 2 EY1V222HCG1625E / 2200 µF -5~+20% 35 V / -55~+105 / / 3350 / 35 10000 16 25 / / 7.5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix P9 : indicates Black PET sleeve. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: FIG-2 FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EY2A680MCH0815S / 68 µF ±20% 100 V / -55~+105 / / 350 / 430 7000 8 15 / / 3.5 FIG-1 2 EY1V102MLT1225ER / 1000 µF ±20% 35 V / -55~+105 / / 2300 / 60 10000 12.5 25 / / 5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: FIG-2 FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EY1C392MS21228E / 3900 µF ±20% 16 V / -40~+105 / / 2860 / 21 10000 12.5 28 / / 5 FIG-1 2 EY1K680HTM0816E / 68 µF 5%~20% 80 V / -55~+105 / / 250 / 800 7000 8 16 / / 3.5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H0=16.0±0.5 H=17.5±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 t=0.7±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 780 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 7000 8 11 / / 5 FIG-1 100kHz 1 EY2A330MQS0811ERS / 33 µF ±20% 100 V / -55~+105 / / 462 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8/-0.2 ΦD0=4.0±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EY2A4R7MP20511F6U / 4.7 µF ±20% 100 V / -55~+105 / / 80 / 2100 6000 5 11 / / 2.5 FIG-1 2 EY2A100MP20511U / 10 µF ±20% 100 V / -55~+105 / / 120 / 1500 5000 5 11 / / 2.5 FIG-1 3 EY1C680HP20511EU / 68 µF 5%~20% 16 V / -40~+105 / / 260 / 500 5000 5 11 / / 2.5 FIG-1 4 EY1E470MP20511U / 47 µF ±20% 25 V / -55~+105 / / 205 3950 570 5000 5 11 / / 2.5 FIG-1 5 EY1E680MP20511RU / 68 µF ±20% 25 V / -55~+105 / / 330 / 900 5000 5 11 / / 2.5 FIG-1 6 EY1V330MP20511EP5U / 33 µF ±20% 35 V / -55~+105 / / 220 / 1200 5000 5 11 / / 2.5 FIG-1 7 EY1V470MP20511EP5U / 47 µF ±20% 35 V / -55~+105 / / 250 / 2300 5000 5 11 / / 2.5 FIG-1 8 EY1V470MP20511EU / 47 µF ±20% 35 V / -55~+105 / / 250 3390 410 5000 5 11 / / 2.5 FIG-1 9 EY1V470RP20511EU / 47 µF 0%~20% 35 V / -55~+105 / / 260 / 500 5000 5 11 / / 2.5 FIG-1 10 EY1H100MP20511U / 10 µF ±20% 50 V / -55~+105 / / 135 13300 1300 5000 5 11 / / 2.5 FIG-1 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 11 EY1H6R8MP20511RU / 6.8 µF ±20% 50 V / -55~+105 / / 250 10000 820 5000 5 11 / / 2.5 FIG-1 12 EY1H4R7MP20511EU / 4.7 µF ±20% 50 V / -55~+105 / / 120 / 1500 5000 5 11 / / 2.5 FIG-1 13 EY1H220MP20511ERU / 22 µF ±20% 50 V / -55~+105 / / 250 / 800 5000 5 11 / / 2.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Brown. Suffix U indicates convex rubber cover. Suffix P5 : indicates Black PET sleeve. Suffix F6 indicates the life of the capacitor is 6000 hrs. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8 /-0.2 ΦD0=4.0±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) ±20% ±20% ±20% ±20% 5%~20% ±20% ±20% ±20% ±20% ±20% ±20% 10 V 16 V 16 V 25 V 25 V 25 V 35 V 35 V 50 V 50 V 63 V Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -40~+105 -55~+105 -55~+105 -55~+105 -40~+105 -55~+105 -55~+105 -40~+105 -55~+105 -55~+105 -55~+105 / / / / / / / / / / / / / / / / / / / / / / (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / / / 1500 / 840 / / 1950 / / 220 150 1000 210 130 450 700 100 600 300 1200 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 4000 4000 5000 5000 5000 5000 5000 5000 4000 5000 5000 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 11 11 11 11 11 11 11 11 11 15 11 / / / / / / / / / / / / / / / / / / / / / / 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 100kHz 1 EY1A221MP26311EU 2 EY1C221MP26311ERU 3 EY1C101MP26311U 4 EY1E101MP26311U 5 EY1E101HP26311RU 6 EY1E221MP26311U 7 EY1V101MP26311P5RU 8 EY1V101MP26311EU 9 EY1H470MP26311RU 10 EY1H101MP26315 11 EY1J220MP26311U / / / / / / / / / / / 220 µF 220 µF 100 µF 100 µF 100 µF 220 µF 100 µF 100 µF 47 µF 100 µF 22 µF / / / / / / / / / / / 340 580 310 340 455 500 500 550 300 560 120 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Brown. Suffix U indicates convex rubber cover. Suffix P5 : indicates Black PET sleeve. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit (mm): Original P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 W =18.0±0.5 F=3.5+0.8/-0.2 F1=5.0+0.5/-0.2 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 H0=5.5±0.5 FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 1760 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 5000 5 11 / / 3.5 FIG-1 100kHz 1 EY1H3R3MP30511EU / 3.3 µF ±20% 50 V / -55~+105 / / 58 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit (mm): Original P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 W =18.0±0.5 F=3.5+0.8/-0.2 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EY1C471MP308B5E / 470 µF ±20% 16 V / -40~+105 / / 1030 / 1300 7000 8 11.5 / / 3.5 FIG-1 2 EY1V221MP30812 / 220 µF ±20% 35 V / -55~+105 / / 1000 / 72 7000 8 12 / / 3.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F1=5.0+0.8/-0.2 H=18.5±0.5 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H0=16.0±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 100kHz 1 EY2A100MP50511U / 10 µF ±20% 100 V / -55~+105 / / 120 / 1500 5000 5 11 / / 5 FIG-1 2 EY1V470MP50511EU / 47 µF ±20% 35 V / -55~+105 / / 250 3390 410 5000 5 11 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 t=0.7±0.2 H=18.5±0.5 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 100kHz 1 EY2A150MP56311EU / 15 µF ±20% 100 V / -55~+105 / / 267 / 960 5000 6.3 11 / / 5 FIG-1 2 EY1H470MP56311EU / 47 µF ±20% 50 V / -55~+105 / / 400 / 380 5000 6.3 11 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 100kHz 1 EY1E471MP50816E / 470 µF ±20% 25 V / -55~+105 / / 1280 / 110 7000 8 16 / / 5 FIG-1 2 EY1E331MP50816 / 330 µF ±20% 25 V / -55~+105 / / 850 / 220 7000 8 16 / / 5 FIG-1 3 EY1V221MP50815E / 220 µF ±20% 35 V / -40~+105 / / 850 / 86 7000 8 15 / / 5 FIG-1 4 EY1V101MP508B5E / 100 µF ±20% 35 V / -55~+105 / / 510 / 170 7000 8 11.5 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0+0.2 F=5.0+0.8/-0.2 t=0.7±0.2 H1=9.5±1.0 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EY1C102MP51016EU / 1000 µF ±20% 16 V / -40~+105 / / 1815 / 30 7000 10 16 / / 5 FIG-1 2 EY1V331MP510C5U / 330 µF ±20% 35 V / -55~+105 / / 1020 / / 7000 10 12.5 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 2 3 EY1C222MP51023F6 EY1C681MP51015E EY1C102MP51020E / / / 2200 µF 680 µF 1000 µF ±20% ±20% ±20% 16 V 16 V 16 V / / / -55~+105 -55~+105 -55~+105 / / / / / / 2400 1210 2200 / / / 30 64 46 6000 7000 7000 10 10 10 23 15 20 / / / / / / 5 5 5 FIG-1 FIG-1 FIG-1 4 EY1C152MP51020E / 1500 µF ±20% 16 V / -40~+105 / / 2500 / 19 7000 10 20 / / 5 FIG-1 5 EY1E102MP51020 / 1000 µF ±20% 25 V / -55~+105 / / 1700 / 78 7000 10 20 / / 5 FIG-1 6 EY1V681MP51020E / 680 µF ±20% 35 V / -40~+105 / / 1960 / 20 2000 10 20 / / 5 FIG-1 7 EY1V221MP51012 / 220 µF ±20% 35 V / -40~+105 / / 890 / 120 7000 10 12 / / 5 FIG-1 8 EY1H221MP51012E / 220 µF ±20% 50 V / -40~+105 / / 1330 / 83 7000 10 12 / / 5 FIG-1 9 EY1J820MP510C5ER / 82 µF ±20% 63 V / -55~+105 / / 680 / 350 7000 10 12.5 / / 5 FIG-1 10 EY1J470MP51007E / 47 µF ±20% 63 V / -55~+105 / / 850 / 250 7000 10 7 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Brown. Suffix F6 indicates the life of the capacitor is 6000 hrs. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=15.0±1.0 H=18.5±0.5 P0=15.0±0.2 W =18.0±0.5 P1=5.0±0.5 W0=12.5MIN P2=7.5±1.0 ΦD0=4.0±0.2 F=5.0+0.8/-0.2 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EY1C152MP51216E / 1500 µF ±20% 16 V / -40~+105 / / 2200 140 85 10000 12.5 16 / / 5 FIG-1 2 EY1J681MP51225E / 680 µF ±20% 63 V / -55~+105 / / 2200 / 43 10000 12.5 25 / / 5 FIG-1 3 EY1J471MP51220 / 470 µF ±20% 63 V / -55~+105 / / 1600 300 85 10000 12.5 20 / / 5 FIG-1 4 EY1K331MP51225ER / 330 µF ±20% 80 V / -55~+105 / / 1620 / 60 10000 12.5 25 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 t=0.7±0.2 H=18.5±0.5 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 1500 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 5000 6.3 11 / / 5 FIG-1 100kHz 1 EY1H330MPN6311U / 33 µF ±20% 50 V / -55~+105 / / 205 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EY NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 H1=9.5±1.0 Original FIG-1 Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0+0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) / 80 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 7000 10 20 / / 5 FIG-1 100kHz 1 EY1V471MPN1020U / 470 µF ±20% 35 V / -55~+105 / / 1410 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown.
EY1V222HCG1625E
1. 物料型号:文档列出了多种电容器的型号,包括它们的额定容量、容差、工作电压、电压范围、尺寸等。
2. 器件简介:EY系列电容器是小型化、低等效串联电阻(ESR)和低阻抗的产品,适用于高纹波电流能力的场合,设计寿命在105℃下为4,000至10,000小时。
3. 引脚分配:文档提供了电容器的尺寸图,包括引脚长度和形成类型代码。
4. 参数特性:详细列出了电容器在不同工作电压和温度范围内的电容范围、容差、耗散因子(tano)、漏电流、低温特性、阻抗比、耐久性等参数。
5. 功能详解:文档解释了电容器的各个性能参数,如在-55℃至+105℃的温度范围内的工作电压范围、电容公差、在25℃和120Hz下的耗散因子最大值等。
6. 应用信息:虽然文档没有直接说明应用信息,但从电容器的特性可以推断,它们适用于需要高可靠性和长寿命的应用场合。
7. 封装信息:提供了电容器的物理尺寸和引脚规格,包括外径、长度、引脚直径等。
EY1V222HCG1625E 价格&库存
很抱歉,暂时无法提供与“EY1V222HCG1625E”相匹配的价格&库存,您可以联系我们找货
