GM2H681MW43551Y
GM2H681MW43551Y
    CHINSAN(金山)
    Radial, Can - Snap-In
    ALUMINUM ELECTROLYTIC CAPACITORS
GM2H681MW43551Y 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 GM Series  Large size for PCB board mounting hole type.  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -40 ~ +85℃ -25 ~ +85℃ Working Voltage Range 16 ~ 100Vdc 160 ~ 550Vdc Capacitance Range 820 ~ 68,000μF 47 ~ 3,300 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Rated Voltage (V) 16 25 35 50 63 80 ~ 100 160 ~ 250 350 ~ 450 500~550 tanδ(Max) 0.35 0.35 0.25 0.25 0.25 0.20 0.15 0.15 0.20 The above values should be increased by 0.02 for every additional 1000μF I=0.02CV or 3000μA,whichever is smaller I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 5 minutes Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated voltage (V) 16 25 35 50 63 Z(-40℃)/Z(+20℃) 15 10 8 6 6 Z(-25℃)/Z(+20℃) — — — — — 80 100 160 ~ 250 350 400 ~100 — — — 5 5 — — 4 4 420 ~ 550 — 4 8 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 85°C. ≦ ±20% of the initial value Capacitance change Endurance Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 85℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Shelf Life Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  V : Rated voltage (V) Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) Terminal Code : ND : Standard D+1 Max .5 ±0 10 + P C S l e e v e 6 2- 2 L±2 Max 4.0±0.5 b o a r d ° 6 0 B * - Safety vent 0 A * p i n - o u t ° 2 2 . 5 PC board Pin-out M a x Negative mark D + 1 Sleeve Terminal Code :K6 (ø35) C - V e n t L±2 M a x 6 ± . 13 . 0 T e r m i n a l T e r m i n a l  PART NUMBER SYSTEM( Example : 400V 470µF ) G M 2 G 4 7 1 M N D 3 0 5 0 Special Request Size code(3050 : 30×50) Terminal length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code(470μF) Voltage code(400V) Series code (GM) 4 - 2 B = p o s i t i v e A & C = b l a n k Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES GM NO.: FIG-1 FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 85℃ Appearance Drawing (Hours) D Φ L a d F No 1 GM2S152MK44570R / 1500 µF ±20% 420 V / -25~+85 / / 6500 / / / 2000 45 70 / / 22.5 FIG-1 2 GM2W152MK64580 / 1500 µF ±20% 450 V / -25~+85 / / 5600 / / / 2000 45 80 / / 22.5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 GM2G122MKD4570R / 1200 µF Working ±20% (Vdc) 400 V Surge Voltage (Vdc) / GM NO.: Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -25~+85 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ / 2022-03-25 PUBLISH DATE @ 85℃ @ 85℃ 120Hz 100kHz 5500 / 120Hz) 100kHz) / / Dimensions (mm) Endurance @ 85℃ Appearance Drawing (Hours) D Φ L a d F No 2000 45 70 / / 22.5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES GM NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 85℃ (Hours) Appearance D Φ Drawing L a d F No 1 GM2G391MW43045M / 390 µF ±20% 400 V / -25~+85 / / 2100 / / 400 2000 30 45 / / 10 FIG-1 2 GM2E182MW43555 / 1800 µF ±20% 250 V / -25~+85 / / 4200 / / / 2000 35 55 / / 10 FIG-1 3 GM2D102MW43040 / 1000 µF ±20% 200 V / -25~+85 / / 3260 / / / 2000 30 40 / / 10 FIG-1 4 GM2E152MW43551 / 1500 µF ±20% 250 V / -25~+85 / / 3980 / / / 2000 35 51 / / 10 FIG-1 5 GM2H681MW43551Y / 680 µF ±20% 500 V / -25~+85 / / 2800 / / / 2000 35 51 / / 10 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Suffix Y represents assembly without gasket. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES GM NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 50kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 85℃ (Hours) Appearance D Φ Drawing L a d F No 1 GM2W331MND3035R / 330 µF ±20% 450 V / -25~+85 / / 2400 / / / 2000 30 35 / / 10 FIG-1 2 GM2C122MND3041 / 1200 µF ±20% 160 V / -25~+85 / / 3050 / / / 2000 30 41 / / 10 FIG-1 3 GM2D561MND2040 / 560 µF ±20% 200 V / -25~+85 / / 1895 / / / 2000 20 40 / / 10 FIG-1 4 GM2E681MND2245 / 680 µF ±20% 250 V / -25~+85 / / 2260 / / 200 2000 22 45 / / 10 FIG-1 5 GM2G681MND3545 / 680 µF ±20% 400 V / -25~+85 / / 2720 / / / 2000 35 45 / / 10 FIG-1 6 GM2S151MND2235 / 150 µF ±20% 420 V / -25~+85 / / 1320 / / / 2000 22 35 / / 10 FIG-1 7 GM2S391MND2551 / 390 µF ±20% 420 V / -25~+85 / / 1900 / / / 2000 25 51 / / 10 FIG-1 8 GM2W121MND2235 / 120 µF ±20% 450 V / -25~+85 / / 1000 / / / 2000 22 35 / / 10 FIG-1 9 GM2W221MND2245 / 220 µF ±20% 450 V / -25~+85 / / 1450 / / / 2000 22 45 / / 10 FIG-1 10 GM2W391MND3045 / 390 µF ±20% 450 V / -25~+85 / / 2000 / / / 2000 30 45 / / 10 FIG-1 11 GM2W391MND3535 / 390 µF ±20% 450 V / -25~+85 / / 2000 / / / 2000 35 35 / / 10 FIG-1 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 12 GM2W681MND3055 / 680 µF ±20% 450 V / -25~+85 / / 2410 / / / 2000 30 55 / / 10 FIG-1 13 GM2W471MND3040Q / 470 µF ±20% 450 V / -25~+85 / / 2410 / / / 2000 30 40 / / 10 FIG-1 14 GM2D681MND2235P5 / 680 µF ±20% 200 V / -25~+85 / / 2000 / / / 2000 22 35 / / 10 FIG-1 15 GM2S181MND2240 / 180 µF ±20% 420 V / -25~+85 / / 1280 / / / 2000 22 40 / / 10 FIG-1 16 GM2H471MNN3551 / 470 µF ±20% 500 V / -25~+85 / / 2480 / / / 2000 35 51 / / 10 FIG-1 17 GM2W181MND3031P5 / 180 µF ±20% 450 V / -25~+85 / / / 2900 / / 2000 30 31 / / 10 FIG-1 18 GM2G221MND2540 / 220 µF ±20% 400 V / -25~+85 / / 1530 / / / 2000 25 40 / / 10 FIG-1 19 GM2W151VND2235 / 150 µF 10%~20% 450 V / -25~+85 / / 1190 / 950 / 2000 22 35 / / 10 FIG-1 20 GM2A152MNN2531 / 1500 µF ±20% 100 V / -40~+85 / / 2080 / / / 2000 25 31 / / 10 FIG-1 21 GM2G271MND2245 / 270 µF ±20% 400 V / -25~+85 / / 1560 / 740 520 2000 22 45 / / 10 FIG-1 22 GM2D331MND2031 / 330 µF ±20% 200 V / -25~+85 / / 1500 / / / 2000 20 31 / / 10 FIG-1 23 GM2W102MND3565 / 1000 µF ±20% 450 V / -25~+85 / / 3500 / / / 2000 35 65 / / 10 FIG-1 24 GM2W681MND3551 / 680 µF ±20% 450 V / -25~+85 / / 2600 / / / 2000 35 51 / / 10 FIG-1 25 GM2G331MND2545 / 330 µF ±20% 400 V / -25~+85 / / 1730 / / / 2000 25 45 / / 10 FIG-1 26 GM2G471MNN3540R / 470 µF ±20% 400 V / -25~+85 / / 2400 / 480 / 2000 35 40 / / 10 FIG-1 27 GM2S471MND3045Y / 470 µF ±20% 420 V / -25~+85 / / 2154 / / / 2000 30 45 / / 10 FIG-2 28 GM2D222MND3050Y / 2200 µF ±20% 200 V / -25~+85 / / 4100 / / / 2000 30 50 / / 10 FIG-2 29 GM2E821MND2545 / 820 µF ±20% 250 V / -25~+85 / / 2485 / / / 2000 25 45 / / 10 FIG-1 30 GM2G101MNN2231 / 100 µF ±20% 400 V / -25~+85 / / 880 / / / 2000 22 31 / / 10 FIG-1 31 GM2W471MNN3545Q / 470 µF ±20% 450 V / -25~+85 / / 2500 / / / 2000 35 45 / / 10 FIG-1 32 GM2G121MND2225 / 120 µF ±20% 400 V / -25~+85 / / 970 / / 1130 2000 22 25 / / 10 FIG-1 33 GM2W331MND2255R / 330 µF ±20% 450 V / -25~+85 / / 1960 / / / 2000 22 55 / / 10 FIG-1 34 GM2W221MND2245AR / 220 µF ±20% 450 V / -25~+85 / / 1400 / / / 2000 22 45 / / 10 FIG-1 35 GM2W101MND2235RP / 100 µF ±20% 450 V / -25~+85 / / 930 / / / 2000 22 35 / / 10 FIG-1 36 GM2G391MND2545 / 390 µF ±20% 400 V / -25~+85 / / 1769 / / / 2000 25 45 / / 10 FIG-1 37 GM2W391MND3045 / 390 µF ±20% 450 V / -25~+85 / / 2000 / / / 2000 30 45 / / 10 FIG-1 38 GM2E102MND3051RP / 1000 µF ±20% 250 V / -25~+85 / / 3310 / 240 / 2000 30 51 / / 10 FIG-1 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 39 GM2G471MND3045P9 / 470 µF 40 GM2G181VND2240 / 180 µF ±20% http://www.chinsan.com/products/ 400 V / -25~+85 / / 2400 / / / 2000 30 45 / / 10 FIG-1 10%~20% 400 V / -25~+85 / / 1329 / / / 2000 22 40 / / 10 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Dark Blue. Suffix Y represents assembly without gasket. Suffix P5 : indicates Black PET sleeve. Suffix P9 : indicates Black PET sleeve. Suffix Q indicates APP glue. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
GM2H681MW43551Y 价格&库存
很抱歉,暂时无法提供与“GM2H681MW43551Y”相匹配的价格&库存,您可以联系我们找货
