KJ2W100MP51016
KJ2W100MP51016
    CHINSAN(金山)
    插件
    10 µF 450 V 铝电解电容器 径向,Can 105°C 时为 10000 小时
KJ2W100MP51016 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 KJ     Series Downsize and high ripple current Load life: 10,000 to 12,000 hours at 105℃ For electronic ballast circuits and other long life applications SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25~ +105℃ Working Voltage Range 160 ~ 450Vdc Capacitance Range 6.8 ~ 560 μF Capacitance Tolerance Dissipation Factor (tanδ) (at 25℃, 120Hz) ±20% (at 25℃ and 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Endurance Shelf Life Rated Voltage (V) 160 ~ 250 350 ~ 450 tanδ(Max) 0.20 0.24 I=0.03CV + 10uA I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes Rated voltage (V) 160~250 350 400 450 Z(-25℃)/Z(+20℃) 4 4 4 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 12,000 ( 10,000 hours for Ф 10 ) hours at 105°C. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 500% of the specified value Others  V : Rated voltage (V) Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 10 12.5 ФD J 18 0.6 0.8 0.8 7.5 7.5 Фd 0.6 F 5.0 5.0 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max a  K 16 ФD + 0.5 Max PART NUMBER SYSTEM( Example : 200V 82µF ) 2 D 8 2 0 M N N 1 2 3 0 Special Request Size code(1230 : 12.5×30) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (82μF) Voltage code (200V) Series code (KJ) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES KJ NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 KJ2W100MP51016 / 10 µF ±20% 450 V / -25~+105 / / / 330 / / 10000 10 16 / / 5 FIG-1 2 KJ2G100MNN1016 / 10 µF ±20% 400 V / -25~+105 / / 125 / / / 10000 10 16 / / 5 Original 3 KJ2G101MNN18N3 / 100 µF ±20% 400 V / -25~+105 / / 770 / / / 12000 18 31.5 / / 7.5 Original 4 KJ2W150MNN1020R / 15 µF ±20% 450 V / -40~+105 / / 190 475 / / 10000 10 20 / / 5 Original 5 KJ2D220MP51020 / 22 µF ±20% 200 V / -25~+105 / / / 470 / / 10000 10 20 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES KJ NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 KJ2G6R8MP50815D / 6.8 µF Working ±20% (Vdc) 400 V Surge Voltage (Vdc) / Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category -25~+105 Tanδ / (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) / 120Hz 100kHz 90 / 860 100kHz) / Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 8000 8 15 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
KJ2W100MP51016 价格&库存
很抱歉,暂时无法提供与“KJ2W100MP51016”相匹配的价格&库存,您可以联系我们找货
