MJ2G470MNN1620A6
MJ2G470MNN1620A6
    CHINSAN(金山)
    插件
    47 µF 400 V 铝电解电容器 径向,Can 105°C 时为 10000 小时
MJ2G470MNN1620A6 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 MJ      Series For electronic ballast circuits and long life Low ESR High ripple current Load life: 8,000 to 10,000 hours at 105℃ SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25~ +105℃ Working Voltage Range 160 ~ 450Vdc Capacitance Range 10 ~ 560 μF Capacitance Tolerance Dissipation Factor (tanδ) (at 25℃, 120Hz) ±20% (at 25℃ and 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Endurance Shelf Life Rated Voltage (V) 160 ~ 450 tanδ(Max) 0.15 I=0.03CV + 10μA I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes Rated voltage (V) 160~250 400 420 ~ 450 Z(-25℃)/Z(+20℃) 3 5 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 10,000 ( 8,000 hours for Ф 10 ) hours at 105°C. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) Leakage current Others  V : Rated voltage (V) ≦ 200% of the specified value ≦ 200% of the specified value Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 10 12.5 ФD J 18 ФD + 0.5 Max Фd 0.6 0.6 0.8 0.8 F 5.0 5.0 7.5 7.5 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max a  M 16 PART NUMBER SYSTEM( Example : 250V 220µF ) 2 E 2 2 1 M N N 1 8 N 3 Special Request Size code(18N3 : 18×31.5) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (220μF) Voltage code(250V) Series code(MJ) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) MJ NO.: Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) 2022-03-25 PUBLISH DATE (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 MJ2G270MNN1220 / 27 µF ±20% 400 V / -25~+105 / / 360 / / / 10000 12.5 20 / / 5 --- 2 MJ2G470MNN1620A6 / 47 µF ±20% 400 V / -25~+105 / / 550 / / 1250 10000 16 20 / / 7.5 --- 3 MJ2W121MNN1835A4EJ / 120 µF ±20% 450 V / -25~+105 / / 820 / / 400 10000 18 35 / / 7.5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
MJ2G470MNN1620A6 价格&库存
很抱歉,暂时无法提供与“MJ2G470MNN1620A6”相匹配的价格&库存,您可以联系我们找货
