MV2S101MNN1630A4ER
MV2S101MNN1630A4ER
    CHINSAN(金山)
    插件
    100 µF 420 V 铝电解电容器 径向,Can 105°C 时为 4000 小时
MV2S101MNN1630A4ER 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 MV     Series High ripple current Low ESR Load life 5,000 hours at 105℃ SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25~ +105℃ Working Voltage Range 160 ~ 450Vdc Capacitance Range 6.8 ~ 470 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated Voltage (V) 160~ 450 tanδ(Max) 0.15 I=0.03CV + 10μA I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes. V : Rated voltage (V) Rated voltage (V) 160~250 400 420 ~ 450 Z(-25℃)/Z(+20℃) 3 5 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 5,000 hours at 105°C. Endurance Shelf Life Capacitance change Dissipation factor(tanδ) ≦ ±20% of the initial value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  ≦ 200% of the specified value Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 10 ФD 12.5 L < 35 16 18 ФD +0.5 Max Фd 0.6 0.6 0.8 0.8 F 5.0 5.0 7.5 7.5 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max a  PART NUMBER SYSTEM( Example : 350V 100µF ) M V 2 V 1 0 1 M N N 1 8 4 5 Special Request Size code(1845 : 18×45) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (100μF) Voltage code(350V) Series code(MV) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES MV NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 MV2C390MNN1212 / 39 µF ±20% 160 V / -25~+105 / / 200 / / / 5000 12.5 12 / / 5 FIG-1 2 MV2G121MNN1830 / 120 µF ±20% 400 V / -25~+105 / / 735 / / / 5000 18 30 / / 7.5 FIG-1 3 MV2S121MNN18N3 / 120 µF ±20% 420 V / -25~+105 / / 775 / / 500 5000 18 31.5 / / 7.5 FIG-1 4 MV2W101MNN1650 / 100 µF ±20% 450 V / -25~+105 / / 750 / / / 5000 16 50 / / 7.5 FIG-1 5 MV2W121MNN1640 / 120 µF ±20% 450 V / -25~+105 / / 700 / / / 5000 16 40 / / 7.5 FIG-1 6 MV2S101MNN1630A4ER / 100 µF ±20% 420 V / -25~+105 / / 900 1400 / 400 4000 16 30 / / 7.5 FIG-1 7 MV2G101MR51830R / 100 µF ±20% 400 V / -25~+105 / / 945 / / / 5000 18 30 / / 7.5 FIG-2 8 MV2G680MNN1625A6 / 68 µF ±20% 400 V / -25~+105 / / 700 / / 600 5000 16 25 / / 7.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES MV NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=3.5±0.3 ΦD0=4.0±0.2 t=0.7±0.2 FIG-1 Original Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated MV2W4R7MP308B5A6 / 4.7 µF Working Capacitance Voltage (%) 1 H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN Φd=0.6 ±0.05 ±20% (Vdc) 450 V Surge Voltage (Vdc) / Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category -25~+105 Tanδ / (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) / 120Hz 100kHz 75 / / 100kHz) 5000 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 6000 8 11.5 / / 3.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
MV2S101MNN1630A4ER 价格&库存
很抱歉,暂时无法提供与“MV2S101MNN1630A4ER”相匹配的价格&库存,您可以联系我们找货
