MW2E220MNN1016R
MW2E220MNN1016R
    CHINSAN(金山)
    插件
    22 µF 250 V 铝电解电容器 径向,Can 105°C 时为 2000 小时
MW2E220MNN1016R 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 MW   Series Low ESR Load life 2,000 hours at 105℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +105℃ Working Voltage Range 160 ~ 450Vdc Capacitance Range 33 ~ 560 μF Capacitance Tolerance Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Endurance ±20% (at 25℃ and 120Hz) Rated Voltage (V) tanδ(Max) 160 ~ 450 0.15 I=0.03CV + 10μA I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes Rated voltage (V) 160~250 400 420 ~450 Z(-25℃)/Z(+20℃) 3 5 6 ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current Shelf Life V : Rated voltage (V) Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 16 ФD M W 0.8 0.8 F 7.5 7.5 PART NUMBER SYSTEM( Example : 450V 150µF ) 2 W 1 5 1 M N N 1 8 ФD + 0.5 Max Фd a  18 5 0 Special Request Size code(1850 : 18×50) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (150μF) Voltage code(450V) Series code(MW) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES MW NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=30.0±1.0 P0=15.0±0.2 P1=3.75±0.5 P2=7.5±1.0 F=7.5+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 MW2E220MNN1016R / 22 µF ±20% 250 V / -25~+105 / / / 300 / / 2000 10 16 / / 5 Original 2 MW2G121MNN1830A6EF3 / 120 µF ±20% 400 V / -25~+105 / / / 900 / 400 3000 18 30 / / 7.5 Original 3 MW2G100MNN0816 / 10 µF ±20% 400 V / -25~+105 / / 100 / / / 2000 8 16 / / 3.5 Original 4 MW2G121MNN1635 / 120 µF ±20% 400 V / -25~+105 / / 800 / / / 2000 16 35 / / 7.5 Original 5 MW2G121MNN1825 / 120 µF ±20% 400 V / -25~+105 / / 650 / / / 2000 18 25 / / 7.5 Original 6 MW2G151MNN1835 / 150 µF ±20% 400 V / -25~+105 / / 750 / / / 2000 18 35 / / 7.5 Original 7 MW2G470MNN1225 / 47 µF ±20% 400 V / -25~+105 / / 510 / / / 2000 12.5 25 / / 5 Original 8 MW2G680MNN1623 / 68 µF ±20% 400 V / -25~+105 / / 430 / / / 2000 16 23 / / 7.5 Original 9 MW2G820MNN1625 / 82 µF ±20% 400 V / -25~+105 / / 500 / / / 2000 16 25 / / 7.5 Original 10 MW2G680MNN1625A4E / 68 µF ±20% 400 V / -25~+105 / / 550 / / 400 2000 16 25 / / 7.5 Original 11 MW2S680MNN1625A4ER / 68 µF ±20% 420 V / -25~+105 / / 700 / / 400 2000 16 25 / / 7.5 Original Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 12 MW2S101MNN1630A4E / 100 µF ±20% 420 V / -25~+105 / / 800 / / 400 2000 16 30 / / 7.5 Original 13 MW2S100MNN1015 / 10 µF ±20% 420 V / -25~+105 / / 100 / / / 2000 10 15 / / 5 Original 14 MW2S151MNN1835 / 150 µF ±20% 420 V / -25~+105 / / 1250 / / / 2000 18 35 / / 7.5 Original 15 MW2S820MNN1825A4EF3 / 82 µF ±20% 420 V / -25~+105 / / 620 / / 400 3000 18 25 / / 7.5 Original 16 MW2S121MNN1830A4ES / 120 µF ±20% 420 V / -25~+105 / / 85 / 700 400 2000 18 30 / / 7.5 Original 17 MW2W101MNN1630A4EJ / 100 µF ±20% 450 V / -25~+105 / / 850 1120 780 300 2000 16.5 30 / / 7.5 Original 18 MW2W820MNN1825A4EF3 / 82 µF ±20% 450 V / -25~+105 / / 750 / / 400 3000 18 25 / / 7.5 Original 19 MW2W101MNN1830A4E / 100 µF ±20% 450 V / -25~+105 / / 900 1120 / 400 2000 18 30 / / 7.5 Original 20 MW2W181MNN1840A4EF3 / 180 µF ±20% 450 V / -40~+105 / / 1100 1640 / 400 3000 18 40 / / 7.5 Original 21 MW2W820MNN1625A4E / 82 µF ±20% 450 V / -25~+105 / / 700 1100 850 430 2000 16 25 / / 7.5 Original 22 MW2W151MNN1840 / 150 µF ±20% 450 V / -25~+105 / / 750 / / / 2000 18 40 / / 7.5 Original 23 MW2W470MNN1230 / 47 µF ±20% 450 V / -25~+105 / / 350 / / / 2000 12.5 30 / / 5 Original 24 MW2W221DNN1850A6E / 220 µF 25%~20% 450 V / -25~+105 / / 1450 / / 300 2000 18 50 / / 7.5 Original 25 MW2W121MNN16P1E / 120 µF ±20% 450 V / -25~+105 / / 1000 / / 400 2000 16 35.5 / / 7.5 Original 26 MW2W220MPI1620R / 22 µF ±20% 450 V / -40~+105 / / 550 / 6850 / 2000 16 20 / / 7.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. Suffix F3 indicates the life of the capacitor is 3000 hrs. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
MW2E220MNN1016R 价格&库存
很抱歉,暂时无法提供与“MW2E220MNN1016R”相匹配的价格&库存,您可以联系我们找货
