MZ2W490MNN1050A4E
MZ2W490MNN1050A4E
    CHINSAN(金山)
    插件
    49 µF 450 V 铝电解电容器 径向,Can 105°C 时为 2000 小时
MZ2W490MNN1050A4E 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 MZ     Series Low ESR Load life 2,000 hours at 105℃ Ideal for low profile power supply applications SPECIFICATIONS Performance Characteristics Item Category Temperature Range -40 ~ +105℃ -25 ~ +105℃ Working Voltage Range 200 ~ 400Vdc 420 ~ 450Vdc Capacitance Range 27 ~ 270 μF 18 ~ 270 μF Capacitance Tolerance Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) ±20% (at 25℃ and 120Hz) Rated Voltage (V) 200 ~ 450 tanδ(Max) 0.15 I=0.03CV + 10μA I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 200 400 420 ~ 450 Z(-40℃)/Z(+20℃) 6 6 — Z(-25℃)/Z(+20℃) 3 5 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C. Endurance Shelf Life Capacitance change Dissipation factor(tanδ) ≦ ±20% of the initial value ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 8 10 ФD Фd 0.6 0.6 F 3.5 a  M 12.5 L+ 1.5 Max 0.6 0.8 5.0 5.0 7.5 L+ 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max L+ 2.0 Max PART NUMBER SYSTEM( Example : 400V 100µF ) Z 2 G 1 0 1 M N N 1 4 14.5 ФD + 0.5 Max 4 5 Special Request Size code(1445 : 14.5×45) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (100μF) Voltage code (400V) Series code (MZ) Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 MZ2W490MNN1050A4E / 49 µF Working ±20% (Vdc) 450 V Surge Voltage (Vdc) / MZ NO.: Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category -25~+105 Tanδ / (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) / 2022-03-25 PUBLISH DATE 120Hz 100kHz 350 / / 100kHz) 800 Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 2000 10 50 / / 5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
MZ2W490MNN1050A4E 价格&库存
很抱歉,暂时无法提供与“MZ2W490MNN1050A4E”相匹配的价格&库存,您可以联系我们找货
