Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
TEL: +886 2 2995 0535
PA
http://www.chinsan.com/products/
Series
● 105℃ Long Life (5,000 hours), Ultra Miniature size
Body diameter of Ф10mm to Ф14.5mm with high ripple current capability
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
-25 ~ +105℃
Working Voltage Range
400 ~ 450Vdc
Capacitance Range
27 ~ 120 μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Rated Voltage (V)
400
420
450
tanδ(Max)
0.20
0.20
0.20
I=0.03CV + 10μA
I : Leakage current (μA) C : Rated capacitance (μF)
Impress the rated voltage for 2 minutes
Rated voltage (V)
400
420 ~ 450
Z(-25℃)/Z(+20℃)
5
6
V : Rated voltage (V)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 5,000 hours at 105°C.
Endurance
Shelf Life
Capacitance change
Dissipation factor(tanδ)
≦ ±20% of the initial value
Leakage current
≦specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied
for 1,000 hours at 105℃ without voltage applied.
Capacitance change
≦ 200% of the specified value
Leakage current
Others
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
ФD
10
ФD
P
0.6
0.6
0.8
F
5.0
5.0
7.5
L + 1.5 Max
≤ 35 L+1.5Max
≥ 40 L+2.0 Max
L + 2.0 Max
PART NUMBER SYSTEM( Example : 450V 39µF )
A
2 W 3 9 0 M N N 1 0
14.5
Фd
a
12.5
ФD + 0.5 Max
5 5
Special Request
Size code(1055 : 10×55)
Lead length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (39μF)
Voltage code (450V)
Series code (PA)
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
PA
NO.:
FIG-1
FIG-2
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
2022-03-25
PUBLISH DATE
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Rated
Rated
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃ Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(Max)
Category
Tanδ
(uA)
(mA rms) (mA rms) (mΩ max/ (mΩ max/
(2 min.) @ 105℃ @ 105℃ 120Hz)
120Hz
100kHz
100kHz)
Dimensions (mm)
Endurance
Appearance
@ 105℃
Drawing
(Hours)
DΦ
L
a
d
F
No
1
PA2W680MNN1250
68 µF
±20%
450 V
-25~+105
550
5000
12.5
50
5
FIG-1
2
PA2W560MSD1052
56 µF
±20%
450 V
-25~+105
450
5000
10
52
5
FIG-2
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Sleeve Color: Black.
很抱歉,暂时无法提供与“PA2W560MSD1052”相匹配的价格&库存,您可以联系我们找货
